PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Need HELP!!!!
  2. HP Limit on Catalytic Converters?
  3. broken T case
  4. How much tension in Timing belt and Balance Shaft belt
  5. Bad head or new block?
  6. question about my evo 9 turbo
  7. Noob axle evo 8/9 ??
  8. Break In Oil Questions
  9. Oil Pressure HELP
  10. Whats wrong with my tranny?
  11. fp black or bbk?
  12. Ticking sound from comming the head
  13. New power new problem
  14. 4G64 with evo head timing belt
  15. What retainers to run w/ GSC beehive springs?
  16. wiring IAT for SD....
  17. Tranny Noise
  18. Boost spike to 20psi boost leak?
  19. ECU install
  20. Could a p0401 Code cause a p0300 code?
  21. Turbo power vs. reliability debate
  22. What goes on the bottom of the stat housing?
  23. evo 8 stalls when cold
  24. Having problems with my powerband. Cams?
  25. 600whp, best clutch and longevity?
  26. 6765 or 6262
  27. WGA - Need to replace, ideas?
  28. Twinscroll Vacuum Line Routing??
  29. Suspected blown head gasket
  30. wastegate actuator
  31. Engine works only with Okada coils
  32. weird oil temp problem
  33. Car won't start. 12.5+ volts. Pump kicks on. Starter?
  34. Bar Map???
  35. My 2010 build thread
  36. starting car with cams.
  37. Upgrading Parts, What Gaskets to Replace?
  38. Need help with upgrading turbo
  39. Throttle Body Water Hose Split in Two
  40. Big problems with Evo 9 engine - Please help me!
  41. Reproducible rich condition
  42. 2.0 or 2.3 on the fence?
  43. PTE 6262 BB vs FP Black
  44. Crank sensor noises
  45. Boost leak test help!!
  46. Too much crank case psi! Any ideas?
  47. grounding and Sliping
  48. My Shop Evo IX MR SE build
  49. cosworth headgasket ????
  50. go fast bits stealth..thumbs down
  51. Fuel pump install
  52. Damn you pendulum mount!!
  53. Nitrous + E85
  54. Boost wavering problem
  55. Serpentine Belt- front pump wheel shaking, need advice please!
  56. Question about my Hallman MBC
  57. Cant get into gear while car is running
  58. major shifting and disengagement problems, after trany pull
  59. Exedy twin install need help!!!
  60. mivec gsc s1 vs hks 272
  61. WTF!!!! Evo Is Going Crazy... I Need HELP!
  62. Balance Shaft Timing
  63. max power on 1000cc's and single walboro
  64. Insane Jerking, bucking WOT only on cold-ish motor??
  65. Oil leaking from my exhaust
  66. skunk 2 cams
  67. need helpwih timing
  68. GReddy 720cc power limits??
  69. Need advice on a fuel system for FPGreen
  70. 1600cc, Single Walbro?
  71. gasket kit??
  72. 04 Evo8 and 06 Evo 9 oil return line.
  73. Grinding Noise Upon Acceleration (not decel) - New ACT Intstalled
  74. shifter cables...
  75. E85 Too Old?
  76. Need Help - Exhaust Back firing after replacing Spark Plugs
  77. Converting from hydraulic-push style back to pull clutch
  78. What kind of cams are these?
  79. 10.5 hotside question
  80. Help me read my spark plugs please...
  81. problem with turbo actuator
  82. are there any aftermarket snorkel replacements for evo 8 & 9
  83. cam sensor
  84. Posible Diff issue...Vid inside
  85. Is two of my cylinder running rich or two running lean?
  86. Weird wheelspin problem
  87. new a/c question for a/c gurus
  88. Anyone running a forward facing stock style turbo?
  89. Oil Pressure light on
  90. more efficient upgrade
  91. Tren with buschur heads and oil leaks??
  92. help RS intake
  93. Evo viii intake. Whats the best?
  94. Exedy Heavy duty cermatellic twin clutch
  95. Boost at high elevation
  96. Amsoil VS Royal Purple
  97. What piece is this?
  98. Can a T3 6262 BB turbo kit be put together for $3000
  99. Cosworth M3s
  100. evo 9 cosworth M2 vs FP4 Cams
  101. evo8 turbo to evo9 turbo
  102. Help!!!
  103. 06 MR 2nd gear grind
  104. Ask a question about the pt68
  105. Evo ix trouble - rotating noise
  106. megan racing downpipe rattle
  107. Help me find my needle in the haystack.
  108. Advice Needed: Engine Removal
  109. Intake question for SD setup
  110. do stock evo 8 ignition coils have ignitors built in?
  111. Transfer Case after Trackday
  112. reducing spool up time with FP black
  113. Fp black vs HKS GT2835
  114. idle issue
  115. Timing is 180 degrees off ??? Pic and Video
  116. Needed: ACAD exhaust manifold flanges drawings
  117. Intake mounting bracket help
  118. ITM, JAM, OEM lifters
  119. installed maperrformance o2 dump tube....
  120. competition clutch stage 3
  121. Clutch pedal height issue
  122. Help Needed. Somethings wrong with my car.
  123. Tomei Evo 9 Turbo Upgrade with Pics!!
  124. Titanium-Magnesium turbo
  125. do i need a new clutch or just a clutch cable?!?!
  126. Evo 10's Transfer case on an Evo 9??
  127. Intermittent engine problems while cruising
  128. misfiring need help
  129. New TiAL QR BOV flutter
  130. Cleaned throttle body and still idle problems.
  131. Throttle body in turbo intake to increase response/spool
  132. Looking at act clutches, couple of questions.
  133. Am i missing anything...?
  134. BOV flutter? or surge?
  135. pertaining to aftermarket clutches..
  136. Very good info on evo clutches and why the flywheel is crap.
  137. Where to find evo 8 transmission to engine bolt size and pitch?
  138. Throw out bearing won't lock into retainer clip...
  139. What clutch for my use, and what shop in the U.P.?
  140. Can anyone diagnose this problem? (mp3)
  141. evo 9 turbo upgrade
  142. Trans Install. Want to light myself on fire.
  143. DriveTrain Upgrade
  144. Sticky Gearshift (tranny?)
  145. Cv Joints or axles
  146. Noise from front left under acceleration
  147. Clutch might be slipping...
  148. Car stalls on left turns?
  149. Best 600-800WHP Turbo Kit for under $5000
  150. 4g63 head issue
  151. Trick to oil pump screw?
  152. Samco Intake Hose Fitment
  153. Evo 9 Valve adjustment??
  154. Engine Teardown *PICS*
  155. 5 speed vs 6 speed clutch
  156. Idle surge on Startup only
  157. highest amount of power made on stock intercooler?
  158. Apexi Isamu Turbo Kit, How many have this kit?
  159. Evo 8 noise after 100k service.. water pump bearing due to tight tensioner?
  160. New Engine for $100!!!
  161. How to identify clutch??
  162. Sudden Idle Issues
  163. Exhaust Cutout vs. Turboback Exhaust
  164. Clutch for 600-800awhp
  165. BR TBE vs Greddy TI
  166. Help Clutch!
  167. Best Transmission Fluid for EVO 8
  168. need help, threw codes p335 &340
  169. Need help with fuel trim malfunction
  170. Did you resurface your flywheel on your Exedy Twin?
  171. Lancer 1996 to evo 6
  172. Yet another transfer case whine thread...
  173. Huge problem on the dyno yesterday(need some good evo tech support)
  174. big spike with Blitz I color
  175. Bellhousing Bolts
  176. ID these Bolts???
  177. throttle body mishap
  178. Clutch Issues: HORRIBLE Grinding/Rattle under load, clutch smell + Can't shift fast
  179. How to Tune Cams
  180. what to do to get 400whp
  181. cam angle sensor help
  182. My Built 2.0L Setup
  183. There is two sides to every spring....
  184. bigger intercooler???
  185. car misfire and dont idle
  186. cams
  187. Best Evo IX MR 6spd, TC, Diff Fluid???
  188. 237 MPH Fastest EVO Video!!!
  189. Evo 8 02 Sensor
  190. Possible bad pump?
  191. Dual Fuel Pump Setups!?
  192. Aps bov?
  193. HELP: EVO noise concern under my vehicle when turn right
  194. should an new 2.3 sound like this
  195. Difference between Internal Wastegate n External Wasteagte
  196. 3 tanks of E85 and look at my ID2000's! unreal!
  197. Oil Pressure gauge instead of boost gauge?
  198. Buschur Street FMIC crash beam removal?
  199. Tial V-band turbine housing testing.
  200. Duel fuel rail setup
  201. Predefined Compression Ratio Calculator
  202. Cam Gear on a Evo IX with mild cams
  203. Rocker arm fell out
  204. Best oil for tranny..
  205. drops revs
  206. Boost cut/fuel cut in 4th and 5th g w/the cut disabled on my tune. Please help!
  207. HELP: EVO wierd noise under vehicle after my clutch maintenance
  208. Your Dream Evo Build
  209. tomei arms or FP?
  210. Idle vid of Mivec GSC S2's?
  211. Is Head porting worth the time and labor?
  212. Does the Water pump have to be replaced during a motor swap?
  213. Phantom Knock
  214. 600+whp goal? What would it take?
  215. oil return
  216. evo vs lancer water pump?
  217. Help with a/c please.
  218. HKS bov needs help plz!!!
  219. Evans Coolant Has anyone used it?
  220. Transmission Issue - HELP!
  221. Clutch help
  222. Education on PTE Turbo's
  223. ACD oil going low!?
  224. Strange whine at 60-65 and 71-73 mph...
  225. FP Red only hitting 28 PSI
  226. Anyone running E-85 w/ a 93 alternative map?
  227. Bubbling in the coolant reservior
  228. Problem with Cable Shifter Bushings
  229. BR Older Style Cast 35R Kit ?'s
  230. Apexi Isamu Turbo Kit exhaust manifold fix
  231. how does your water pump feel?
  232. Diff pins broke!!!
  233. Slight "knock" after installing built shortblock
  234. cam seal swap out
  235. Weird numbers?
  236. BBK with stock head/block opinions
  237. going to get car tuned
  238. Going to pull the head. Advice?
  239. Cams - should I?
  240. Stealth turbo upgrades
  241. fuel pump issues? ignition?
  242. light knock (certain times?)
  243. NEED HELP!! with my mr
  244. Boost Off...Was 26.5 - Now 21.5
  245. Clutch shaking problem
  246. Reverse light switch on Tranny
  247. power steering pressure sensor (p0554)
  248. Turbo going from a E85 to 93 oct
  249. BOV/DV Flutter issue made better
  250. NEED HELP: theres oil in the radiator
