View Full Version : Evo Engine / Turbo / Drivetrain
- Buschar customers with GT-35R.
- Which 264in cam has highest "lift" - stock valve springs compliant
- drop in filter
- T-bolt clamp-#705-1531
- blew my water pump freeze plug out.
- Gains over 264s!!!
- What mods next?
- RMR intercooler piping.
- Transmission Oil
- WR or AEM ems for stock turbo
- Symptom of a bad clutch?
- Car going to dealership.
- Just got new plugs: BPR7EIX
- Clanking Noise when shifting???
- Car blows out of 2nd gear
- Stock 05 evo noise
- Trasfercase
- Better SIDEPIPE photos now up!
- Sound Clips of APEXi N1 Cat-Back Exhaust?
- Rmr Clutch Disc?
- White rabbit sucks, BLACK DOG TURBO!
- Attention All MR Owners- HELP with grinding noise from tranny!!!!!
- APS contact information?
- CV joint ? Differential?
- Boost curve
- just did cam install
- JIC DP installed 05 GSR..pics
- 10.5 hotside
- Samco rad hose heat tolerance?
- Walbro fp question?
- JDM MR BOV- Higest Boost obtained?
- Buschur 21G Status?
- Too Hot
- Would u get a GT35r with a 0.63ar?
- plastic shield under car
- install cams yourself or let a shop handle it?
- How Does A TApping Noise Sound Like?
- Which cams should i get?
- Which manifold?
- Installed GSC cams and ARP studs...got a couple questions
- Defi EGT PROBE INSTALL HELP
- Fake Boost Leak Sound
- Overheated and now won't turn!!!
- Exhaust vendors
- Can anyone answer this question?
- boost taper BAD
- serpentine tensioner pulley
- Warning to those with Walbro 255's
- 3071 newB questions gallore!!
- Changing only (1) cam - pro's/con's???
- Those who track their Evos.
- fuel pump failure will cause engine damage?
- CEL, again.
- burning oil
- blown engine will it run the same
- Need to replace radiator fan!
- Clatter noise
- Which I/C pipe clears stock air-box?
- Jun racing 280 cams
- lifters tap x100
- look at whats new , Brand new UR piping kits
- New Exedy Clutch...Break in or not?
- Anybody tried Nology Spark Plug Cables?
- Should I get Evo 8 with Utec?????
- 5th Gear Clunk
- Boost Hiccup?
- ARP Headbolts needs to be Re Torque, yes or no
- Catback Without a Reflash
- Just installed new turbosmart dual port bov!!!
- low boost question
- 05 GSR--HKS downpipe ISSUES
- Really Odd Boost Problem
- Pulling the old misfire code
- Cams, injectors, reflash, help!!!
- Fuel pump question...
- Hks BOV and cams
- for those who have fidanza cam gears...
- Tilton clutches
- Where to buy a exhaust manifold flange?
- Problem with my car!! HELP PLZ
- Transmission question
- Spark Plug Wires???
- Valve stem seal & height info needed
- Does anyone know a thing or two about radiators & fans?
- TRE final drive gears.
- Locked out of EVERY gear!?!?
- Flutter and Stall?
- Is my fuel pump going bad???
- First Look at the New DTEC-FC Fuel Controller
- 4" exhausts
- Boost with 110 oct?
- Timing Tensioner Belt Tool
- Evo8 Cylinder Head Torque
- Flywheels - ProStreet/Fidanza/Stock
- what do i need when installing cam gears?
- AMS fuel rail/injector compatability ?
- Gear oil for the MR tranny
- GT3040 turbo
- evo runs really bad...
- Drivetrain noise....twin disk related?
- New Gsc Cams???
- mini battery ?
- ? how to wire DSM Power Transistor
- Just got my AMS exhaust put on
- Props to works! also with following mods how much power would i be making?
- Cam Gears?????
- ACD Conversion
- New CEL fix solution??
- OEM replacement studs for 10.5 upgrade
- MIXing cam Companies? BAD IDEA?
- Can you run 264 cams w/o fuel pump???
- better performance throtel
- Question about a turbo knowledge
- what kind of intake should i buy?
- clutch disc replacement
- Help me with my idle problem
- Greddy Type- S Boost Controller.
- How to run NITROUS
- when does fuel cut come into play
- Injen IC Pipe Kit
- engine noise?
- camshafts and daily driving
- Electronic boost controller detailed explanation
- Clutch and Engine Questions
- Vacuum hose? (on maf pipe)
- What lower intercooler pipes is everyone using?
- helix intercooler install?
- Small Intake Hose Purpose?
- Megan's Cat-Back exhaust?
- Advantages of a flash and fuel management
- Any way to test uninstalled knock sensor?
- What kind of mods will run 11.90
- Going to track, troubles with S-AFC
- Can detonation
- whats the highest temps?
- Mounting FPR
- High oil consumption due to running too rich?
- 28psi On 1st Gear
- what are my options for a bolt on turbo?
- Blitz NUR Spec Exhaust
- Blown Transmission?
- Anybody try the new BR coil on plug
- Evo3 turbo on an EVO
- Engine damper??????
- Buddy Club Cams vs. HKS Cams
- Ralliart Spark Plug Wires
- Pruven fuel rail adapter question
- Mivec?
- Quaife Probelm, Do Not Install
- fact or fiction?
- Can I use flywheel from HKS twin disc with another clutch
- Installed HKS Hi power and test pipe
- Stupid Launch Question for GT35R
- cam break in?
- APS Twin Vent BOV review
- Don't like that sound
- Need to remove valve cover! What do I need?
- R-1 titanium
- MR Trans Swap?
- Havent posted in a while...some questions~
- HKS TT Harness = Blitz TT Harness???
- rower stroker kit vs. RnR 2.4l stroker motor
- Does venting to atmosphere slightly aid in turbo lag???
- Megan Racing Headers and O2?
- where to buy diaqueen besides the dealer?
- 469AWHP on STOCK TURBO!
- Ses Po138
- Service Engine Soon light? Help Please!
- Simple question on catch cans
- Newest in turbo design and innovation!!
- if you have HKS 264/272 and cam gears....
- I Need An Ebc Solenoid!!!!
- My car rattles when....
- Exedy Clutches...Which One?
- So I hit a pothole last night
- need a help
- Guys with TRE Race Gears???
- Crower stroker kit installation question
- 1G BOV vs Forge BOV?? Opinions Needed
- Plugs / AFR / Weather
- Helix downpipe rattling!!!
- Clutchmasters Stage IV only lasted 17,000 miles?
- Dealer fixed synchros, now my stick dances
- New Bolt in turbo... FP White Rabbit.
- HKS T04R turbo
- Center differential gear box
- Boosting?
- At what point are Larger Injectors Indicated??
- 2 NGK broken electrodes fall into cylinders!
- point me in the right direction
- Question on MBC Low boost 1st,2nd,3rd gear
- which intake best for my setup?
- transfercase
- Vibrating at Idle
- Do my old plugs look ok?
- New APS BOV Adjustment?
- Is 1300°F coating good enough for o2 Housing?
- Are these Injectors worth buy?
- Fujitsubo RM01A
- GT35 Highest boost level?
- Spun Rod Bearings???
- AMS Stage 1 kit...
- How does the WRC 05 develop so much torque?
- Br 21g....
- Lovefab Manifold :P
- AMS Parts Deliver!
- APS BOV & Shifting?
- Ngk BPR7EIX question
- Stroker +GT35R compression ratio.
- Dyno'ing your EVO in 2wd...t-cases available.
- Most HP with a stock cat?
- push clutch pedal = nasty noise and vibration thru pedal
- question on Transfer Case
- boost control problems
- Recirc or VTA? Noticing something weird
- Exhaust Manifold Comparison, RNR Vs. AMS....
- Turbosmart Eboost 2
- scratched valve cover
- broken turbo
- Evo 8 tubular manifold
- GM MAF and MAFT?
- Weight of Exedy Twin Disk Flywheel
- Can a 2.75" exhaust hook up to a 3" Testpipe
- Ultimate Racing Turbo Kit
- Thumping sound when i press the clutch.
- Best power package??
- NEW TOYS this weekand
- compression test
- clutch problem?
- Official HKS EVC V settings thread
- 280i/272e anyone?
- TRE Rebuild...Questions/Opinions wanted.
- Jun 272 or Tomei 280
- Downpipe Rattle Dangerous?
- only 16 psi?
- HKS 280 cams + stock turbo={thumbup}
- Next mod, LOL i know its been asked a ton of times...
- lost all boost..help!!
- Bang inbetween shifts
- RNR GT30R result! (w/ pics)
- Installed gsc 272/264, tbe, and fp. i hope the flash makes a bigger diff
- rattle when car starts
- Trans wont come out...........
- car dumps boost at 4k in 5th
- Buschur turbo kit
- drivetrain gone bad?
- Exhaust Silencer ?
- 05 Transfer case fluid capacity
- Anyone with T68 or T76
