PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Big Turbo Intake + Lower Radiator Hose = Clutch Fork Interference
  2. Evo 8 D2 STM Drag spec coilvers alignment
  3. Tdo6Hr GTX3076R turbolabs
  4. What motor should I go with?
  5. Clutch slippage or wheel spin??
  6. Metal on timing belt
  7. Did this shop do my leak-down/compression test correctly?
  8. Hfc to test pipe - retune needed?
  9. Evo 9 leak/compression bad
  10. Speedometer issue?
  11. Stock EVO 9 skips a beat/slight misfire
  12. Trying to rebuild tcase - pinion gear is rubbing on the case
  13. Dipstick tube stuck
  14. Clutch adjustment, rod?!?!?!?!
  15. Upper Clutch Switch (NLTS) - Evo 9
  16. Lobing Idle help
  17. Evo 9 mr transmission upgrade routes?
  18. Leak near oil filter
  19. need help
  20. Stumbling/Idling Funky, Wideband Reading Super Rich
  21. Lean Idle - search performed, but somewhat unique
  22. rear diff case spreader
  23. Walbro fuel pump noise and dropping fuel pressure
  24. Evo VI GSR Throttle body/IAC leak
  25. Side motor mount putting back in
  26. Rewired my walbro 450 fuel pressure above 50psi
  27. Exhaust Fitment Questions
  28. Curt brown engine built?
  29. Throttle hesitation in EVO 8.
  30. Recamendations for a good evo shop in NY area
  31. EVO 9 short block into EVO 7 help plz oil pressure switch positions
  32. Boost drama?
  33. VRSF Muse Evo 8/9 Cat back Install/Review Pics!!
  34. Transmission input shaft bearing noise help
  35. Garret Gt3076R -- Anyone have one?
  36. Manual 5 speed shims
  37. Evo 8 oil filter housing relief valve nut size?
  38. Ordered 71hta... received 71htz...
  39. MHI FP Red on stock block/head/cams?
  40. oil pressure dropping at high rpm
  41. 4g63 shortblock build 1000hp capable
  42. What turbo next?
  43. Timing Marks On Lower Timing Cover
  44. Evo IX engine broke up
  45. Fitting evo 7 cams and turbo to 7.5gta
  46. Trying to figure out a problem. Please help !
  47. P0090 Fuel Pressure solenoid circuit 1
  48. Modify Evo 9 Turbo or Evo 6 Turbo with Garett components
  49. Evo 9 Up Pipe Plug Ideas
  50. Need a brand new E9 Turbo
  51. 4g69 Sleeved 2.0 ??
  52. FP red BB MHI on EBAY
  53. Garrett G-series Evo 4-9 bolt-on
  54. Shall i change valve keepers ?
  55. Breaking up at 5k+, scratching my head.
  56. Need help finding a fitting size!!!!
  57. Issues with Mishimoto FMIC?
  58. Yet another tranny knock (Yes i read the other forums)
  59. Gfs car low boost
  60. 24 pounds of boost.
  61. Welding a bung for wideband
  62. Anyone have experience with STM intake manifold catch can?
  63. Cop pack failure
  64. Turbo does not inflate
  65. Faulty Grimmspeed boost solenoid ?
  66. Walbro 525lph Gas/E85 in tank pump
  67. Intake popped off???
  68. SS fp green
  69. Question for Center Diff
  70. Differential issues during hill climb
  71. td05hr-16gb-10.5t. vs. td05hr-06-16gb-10.5t
  72. losing power, give me a list of things to do to find my issue
  73. FP 71HTA questions for Evo 9
  74. Modified 9 Thermostat to work in 8
  75. Advice needed pulling head
  76. Precision 6266 Turbo Opinions
  77. Car in gear isnt moving
  78. Turbo upgrade, confused about bolts/ studs needed
  79. Base fuel pressure.
  80. Run a ported stock manifold or FP race?
  81. Cam Install Evo VIII GSR
  82. 700whp pump gas only? How hard/far have you pushed pump gas?
  83. My evo 4 snapped timing belt
  84. Buschur Racing block with je pistons 10.0:1
  85. Anyone know if the ACT streetlite flywheel will work on a stage 2 comp clutch
  86. Spark plug gap
  87. Biss/Sas adjustment
  88. Exedy twin clutch uneven wear issue.
  89. Need help finding a fitting!!!
  90. Evo IX Stalling out Randomly
  91. Evo 9 lean idle help.
  92. FP green/red etc what is it?
  93. Forged pistons on stock rods...WHY? and what to do...?
  94. A question about meth
  95. Looking for Evo 8 Turbo Rebuild
  96. JDM 03 Evo 8 GSR Rear Diff Mount
  97. FP is offering the MHI housing
  98. Intermittent starting issues (driving me crazy)
  99. Misfire off idle at light throttle
  100. Best stock frame turbo choice for my setup!!
  101. Rough idle help.
  102. dumb question about IX oil pressure/switch
  103. 6266 vs 6466 tune map
  104. 2.1L Stroker 4G63 Evo 8
  105. Weird SD Stalling issue, help!!
  106. Question about J pipe for install on FP red.
  107. Evo 9 engine wiring question
  108. Which wastegate fits on a FP green turbo?
  109. Losing cylinder(s) while driving
  110. Injector seals leak
  111. Breakup at ~40psi - options?
  112. Walbro 450 fuel system question?
  113. Help with oil burning problem please!
  114. Evo 9 vs evo 7 OEM retainers!
  115. Wierd Idle problem
  116. Car won't turn over
  117. Why do people like the 4.11 FD
  118. E85 Review kit
  119. Aftermarket intercooler help!
  120. Fuel Pump Getting No Power
  121. Blaast Turbo Factory in Canada
  122. New Chinese $165 500Hp turbo for real?
  123. Looking for recommendations on gauges?
  124. Injector leak at intake to injector seal question
  125. Evo 8 Missing/Stuttering while Cruising (Log attached)
  126. WGA too close to the radiator
  127. Weird Issue
  128. Full Blown Motorsports 70mm Throttle Body reviews?
  129. Evo 8 FP Red Install Question
  130. Boost gauge at idle not showing correct Vaccum
  131. Clutch kit question
  132. Mivec intake cam timing help!
  133. Evo 8 sputtering
  134. Spun out hit a gutter. Smoke and leak
  135. Transfer case specs for Evo 6RS ( CP9A )
  136. Evo 8 Rust on tops of pistons
  137. Evo dying
  138. Brian Crower Cams "Hate"
  139. Gsc s1 vs tomei poncam 270
  140. Evo 9 low compression?
  141. Charge-Air Cooler Replacement?
  142. What wire is this
  143. Evo 9 turbo on Evo 8 Question
  144. Stock engine internals maximum rpm!
  145. Evolution IX camshafts advice!
  146. Oil Light flickering
  147. 2nd gear grind + lockout + weird noise at high rpm after clutch change
  148. Evo 8 cams
  149. HELP: Weird donut gasket/adapter in downpipe?
  150. Oil pressure regulator for Ball bearing turbochargers
  151. Intake Manifold Egr Top Port
  152. Forward Facing Turbo A/C Kit solutions
  153. Gtx or gt turbos
  154. AMS Turbo test car
  155. Comp Clutch stage 2 clutch kit vs rigid clutch kit
  156. Wich Dual Clutch are recommended?
  157. In need of an oil catch can. What do yall use?
  158. Current build power output estimate
  159. High idle after Parts Install
  160. GTX3071R or FP Red JB
  161. Camshafts (Yes I know, I'm sorry)
  162. p0011 on 4G64 block with evo 9
  163. Clutch Master 725 Dual disk problem!!!!
  164. Intake Manifold torque order?
  165. Clogged internal fuel hanger issues
  166. Stumped on rear diff install 8/9
  167. Evo 4 Transmission oil issue.
  168. Suggestions on how to remove the OEM Trans mount?
  169. Which twin clutch for my evo 5 daily?
  170. Anyone kows why I keep breaking V-Band bolts!
  171. Change crankshaft seal with timing belt
  172. Evo 9 Mr ticking/knocking sound
  173. Rear diff driver and pinion
  174. Intake manifold brass plug boost leak
  175. Stock Evo 8 coil pack
  176. fp green
  177. what gains should I see by adding cams to an Evo IX with FP black
  178. Weir 12-plate for Evo VIII/IX review & info.
  179. Evo 9 low RPM problem, please help
  180. 122 mph @ 11.6 whats my whp no dyno near by...questions about my set up
  181. Lifter Upgrade?
  182. Speed Sensor Failure
  183. Muse/VRSF 3" V-Band Stainless Steel Catback Exhaust! We need your help!
  184. Evo 9 - 2006 OEM O2 housing price and part #
  185. Car turns all 4 wheels in Neutral in Air
  186. Hiccup at idle?
  187. Another “why is my Evo smoking” thread
  188. Sheepey Built manifold/ Speed Factory Ti Bolts access
  189. Serpentine belt replacement
  190. Maperformance Setrab AN Fittings Leaking
  191. Mishimoto universal R line FMIC
  192. EVO 8 inconsistent boost drop
  193. Tial QR Bov Evo 8/9 Pictures?
  194. 71hta or fp red htz mhi
  195. Evo 8 boost stuttering
  196. 2003 EVO 8 service light flashing
  197. Evo 8 5spd odd clutch fork shaft
  198. Gates Timing Belt noisy af
  199. Act clutch with hrb
  200. STM Standard Oil Cooler Kit
  201. Need help evo 8
  202. Bought a car without ABS or ACD
  203. Miss fire at idle + battery/ brake lights come on
  204. Transfer case to transmission threads stripped (2)
  205. Will CP Piston rings fit evo stock pistons?
  206. Rear Differential / quick question
  207. Intake Manifold Torque Specs
  208. Questions about rocker arms
  209. Mixing Diaqueen Tranny Fluid
  210. Clutch fork postion...
  211. Anti-surge block off, on a kinugawa 3" compressor cover
  212. CEL P0122 and sometimes P0107.. car dies, sometimes runs fine
  213. Evo 8 starter motor fit Evo 7?
  214. Evo 9 studdered then died, crank no start, starts cold
  215. Suspect head gasket compromised? Evo8
  216. Engine to transmission bolts... dumb question
  217. EVO VII won't start
  218. Need Help: Cooling Issues
  219. QM flywheel hitting oil pan
  220. EVO 9 - CEL P0171 , P0420 and P0133 - need help and opinion
  221. evo 8 engine pull
  222. BISS randomly not helping???
  223. EVO 9 - CEL P0420 then P0133 need help to fix :(
  224. Evo 9 6-speed output shaft bearing
  225. p0243 turbocharger wastegate Cel
  226. Jerks and quirks
  227. Evo stalls and sometimes randomly starts..Omni MAP sensor?
  228. Evo 9 piston damage
  229. oil leak at knock sensor?
  230. Welding ports onto 4" SD intake
  231. Carrillo pro-SA
  232. Info on 63TNE pistons? (Outlander/Airtrek 2.0T) Pictures
  233. Is torquing the valve cover crucial?
  234. Opinion on Mazworx Stage 3 Short Block - 4G63
  235. Evo 8 crank won't make full rotation
  236. Beginning of the evil transfer case whine?
  237. Top Brands for Intercooler
  238. Built EVO - shifting into neutral engine stall
  239. Do I need to port my head and run cdi ignition for 900hp
  240. Evo 8 battery relocation confirmation questions
  241. Grinding noise when rolling in neutral and in gear, car won't move.
  242. No power to coils
  243. Balance shaft delete and head port question
  244. Need Help with odd sensor on 03 Evo throttle body
  245. Crankshaft Stresses 101
  246. 4.08 final drive
  247. internals for evo8 stock turbo
  248. Transmission question/issue
  249. MAP oil feed line failure be aware
  250. Can I remove this ABS metal cover
