PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Evo 9 4g63 evap purge check valve
  2. Clutch Recommendations
  3. confirm if flywheel should have step machined
  4. Dumb to Port Cylinder Head on 400 CHP?
  5. Headgasket to use for high boost applicaton
  6. 6 speed Bell Housing
  7. Evo 5 Cylinder Head Replacement...
  8. Evo IX Oil pressure questions
  9. Rebuild List 4g63
  10. NEED sh7055.bin and sh7058.bin files
  11. Best intercooler for overbuilt Evo 8 on Evo 9 turbo
  12. Cusco LSD Into Evo V AYC Housing
  13. Strange noise
  14. Ongoing starter issues. Help.
  15. Noise coming from front end
  16. Oil coming out of breeder at Transfercase
  17. Do i have the correct camshafts?
  18. Need help with planning a swap
  19. Crud in Clutch Master Cylinder
  20. 3"high flow cat cuestion...
  21. Car stalls at idle when cold -- IAC?
  22. Weird coolant issue (Evo 8)
  23. APS Twin Vent BOV cleaning
  24. RS front diff install in '04 that came with an open difff.
  25. 800hp engine build question
  26. Torque value on evo ix headstud
  27. Transfer case breather questions.
  28. 4G63 in a 1968 Volvo… need engine advice
  29. Blown head gasket twice on cylinder 3 – starting to lose my mind
  30. 6 speed transmission search
  31. Rebuilt my 4g63 to competition specs and took it to tuner
  32. Oil pressure issues
  33. Fuel Pump Hanger Question
  34. Unsure where to go from here
  35. Clutch For 700-750 whp. Need help.
  36. Stretched timing belt? Not many miles on belt
  37. Will This Turbo Be Direct Swap?
  38. Metal in oil but pan looks fine, thoughts?
  39. EVO 4 Keep SAS?
  40. Question about aitrek gearboxs
  41. Extremely Stiff/Heavy Clutch
  42. Probably in over my head - shop recommendations?
  43. New block weird number
  44. Cylinder Head Work - 05 Evo 8
  45. Evo 9 Drive/Long Shaft Leaks
  46. Turbo Housing Rust
  47. FIC 1650's at increased base pressure on gasoline
  48. Evo 8 radiator size
  49. Quarter Master HRB - Violent downshift clunk/shock - Anyone else?
  50. Rebuild kit transmission
  51. Fuel cut or bad ignition coils coming onto boost? - Stock Evo 8
  52. FP Race J Pipe to LICP Q?
  53. Megan 02 Housing fitment issue
  54. ETS standard placement turbo kit for evo 9mr..
  55. finally got he FP manifold on after 3 hours
  56. Evo clutch disengagement issues - Losing my mind and sanity
  57. Coolant crossover pipe to water pump gasket
  58. Fp black bb leaking
  59. Turbo Protector/Heat Shield Removal
  60. 1997 evo 4 gsr Engine rebuild kit ?
  61. Evo 8 hla regulator bolt size?
  62. Is this normal behavior for a 3-port boost control solenoid?
  63. Head evo 7 on shortblock evo 9
  64. Weird sound from the engine
  65. Rev Limit of 4G63?
  66. Advise on turbo selection
  67. Coolant loss
  68. Evo 5/6 Engine Mounts
  69. Noise coming from MIVEC gear, does anyone recognise this sound?
  70. Evo 8 Pressure test
  71. Looking for best turbo for street use occasional high way drags
  72. Evo 9 5 speed transmission/clutch
  73. Level Car for AYC Bleed
  74. Evo 8 no spark, crank no start
  75. Issues with ACD/Transfer case
  76. What 4g63 motor is this ?
  77. Looking for FP stock location UHF MHi results
  78. Alternator belt Evo 4 Gsr
  79. engine ticking under 1krpm
  80. Exedy Hyper Evo Clutch MH01SDX
  81. Shifter upgrade question
  82. Which built shortblock engine for IX?
  83. Help removing Evo 4 limiter
  84. BC 2.5 Stroker in 4G69
  85. Help finding partnumber for thermostat
  86. Light smoke from exhaust (video)
  87. Wiseco piston installation problem
  88. Evo 8 starter issues
  89. Driveline noise and power loss to wheels
  90. older type of anti lag project idea for the evo 8
  91. 4G63 HKS GT III Sports
  92. Stange startup issues
  93. EFR7064 vs Evo 9 turbo
  94. Evo IX DBW e-throttle conversion
  95. Cam choices
  96. Engine rebuild
  97. Evo8 transfer case possible whine
  98. Need Help With Compression/Leakdown Test Results
  99. Engine build information clarification
  100. Motor swap!! Help wanted!
  101. Foreign object stopped up oil pump screen .
  102. Unknown 5 Speed Transmission Condition
  103. What is causing this spike and dip?
  104. Dog box lockout at high rpm
  105. evo 7 build
  106. Racing diffs tcase clutch packs
  107. EVO X AYC swap into EVO V diff ratios issue
  108. Cleaned MAF and now idles rough and bucks under boost
  109. What Next Upgrade?
  110. Switch from 3.5 varex muffler to 4 inch varex muffler
  111. Accidentally made my car RWD
  112. Fault code: P0710
  113. Down pipe for Artec vband
  114. DIY MIVEC Head Conversion - Crazy Idea
  115. Leak down test results + question
  116. Kormex trans transfer case ring and pinion???
  117. Evo4 manifold and turbo on evo 3
  118. Where to buy the rebuild 4g63t engine in Japan for my evo?
  119. ACT pressure plate grinding
  120. Biss screw o-ring size
  121. Anyone know what this could be?
  122. Evo cranks but doesn’t start
  123. Balance Shaft Spacer MD128107 compatible with 4G64?
  124. Balance belt crankshaft sprocket stuck on crankshaft
  125. Possible blown engine need suggestions for short block
  126. EVO 9 PRoK Stamp on head what does it mean?
  127. Correct gear oil for 5 speed
  128. Possible to drop crankshaft with engine in car?
  129. Evo 8 Downpipe
  130. Car shutting off
  131. 4g64 Idling ay 400-500rpm
  132. 80a enough for alt fuse?
  133. 2.0 vs. 2.2 vs. 2.4 engine build
  134. Engine "build" options for my "lower-HP" goals
  135. Anyone have experience with the Tilton Cerametallic Twin disk
  136. I tried Liqui Moly Lifter Additive
  137. Evo 8 Engine re-build/install
  138. evo6 can use GSR front gearbox with RS rear diff ?? ??
  139. Clutch Recommendation
  140. FMIC intercooler hose cut
  141. 2.3 stroker
  142. Exedy Triple Slight drag when warm?
  143. Will Evo X injectors fit on my Evo 4?
  144. Need turbo lag advice
  145. VCU / Viscous Coupling Unit question
  146. Evo 8 Buying Advice
  147. Adding oil squirters Airtrek 4G63
  148. Oil Catch Can Breathing Issues!!!
  149. Evo 6 Stage Kits in 2024?
  150. Evo 4 rebuild
  151. Evo IX Idle Issue
  152. Idling non consistent
  153. Evo 8 MR - EGR Solenoid Wiring Harness Plug Issue
  154. Evo X rear diff (ayc) into evo VI
  155. Metallic sound coming from passenger side
  156. Evo IX compression test results
  157. Timing belt tension Evo IX
  158. evo 8 starting and running issues
  159. AGT 62mm vs fp black
  160. Evo 5 Clutch Stop?
  161. Misc Tech: 2.4 (4G64) block effect on timing
  162. Wastegate hood dump left with water in it.
  163. OEM vs Billet Water Pump Pulley?
  164. High crankcase pressure normal at high output?
  165. Car won’t go into gear while running. Low mile exedy twin disc clutch
  166. Big Turbo Build Questions
  167. 1st and 2nd Gear Movement/Popping Out
  168. Evo 9 Problem
  169. R2 cam valve springs.
  170. Timing belt tension issues
  171. Air Filter
  172. Twin Disc Action Clutch
  173. Evo IV KAAZ LSD makes center-diff open?
  174. Clutch Release Shaft Sheer
  175. Timing issues
  176. Fuel lines
  177. Drivetrain noise on downshift and take off
  178. 4G63 Manley H-Tuff rods
  179. Unknown problem in engine bay
  180. Is cooling the turbo necessary?
  181. New Owner and Need Rebuild
  182. HELP! Evo 7/8/9 Oem Coolant Temp Sensor
  183. 2003 Evo 8 refreshing G35-900 ETS Quick Spool Build
  184. Advice Needed: Stripped thread on head and more!
  185. Help me choose a build.
  186. Turbo Analysis
  187. Compression & Leakdown test results before buying
  188. IVAC removal issue
  189. Immediate rattle after warm start
  190. My Christmas present to myself
  191. Possible low compression
  192. 4G63 Engine diagram
  193. Looking for an OEM-style flywheel
  194. Evo 4 Serpentine Belt Tensioner
  195. Turbo G25-550 vs FP54 Green
  196. quiet clunk noises and it holds back for a sec
  197. Recommendations on transmission oil for Evo 9 MR?
  198. Sputter/Misfire WOT
  199. Rattling noise
  200. Engine noise on first start up
  201. OG fp green Oil feed line question.
  202. Maperformance 2.4L LR high comp compression numbers
  203. custom cas solution
  204. Green, 54 Green or AGT 52mm to replace my 71hta?
  205. EVO 8 safe power?
  206. Stock uicp and silicone couplers
  207. Finishing up my build help please?
  208. Choose a different clutch?
  209. Any information on Manley H tuff rods?
  210. TRE Racing
  211. Evo 4 Whining Sound
  212. How much power can the stock pistons handle?
  213. Evo 4 transfer case slack
  214. Won’t go in Gear
  215. Do blow off valves need to be greased/lubricated?
  216. Hmm, what does that clutch sound mean?
  217. Baffled Sump
  218. 4g63 bolt pattern
  219. Fuel Rail Pressure Fluctuations
  220. evo 8 engine ticking noises
  221. Straight cut 3rd and 4th who wants them?
  222. 2003 evo 8 problems
  223. Gsc s3 cams - more or less timing?
  224. Crank and no start issue after storage!
  225. New CV-Axle bearings
  226. running rich/ break up under light load.
  227. Anyone else obliterated the S-AYC planetary diff?
  228. 4G63 Mivec Cad drawings
  229. Outlander turbo 4g63
  230. What is a built engine?
  231. Small brake kit
  232. Engine bay pics
  233. How to replace clutch pedal assembly?
  234. Garrett G30-770
  235. 4g93t Misfire
  236. Gearbox grind when cold
  237. Clutch Replacement
  238. 700hp evo 5 head gasket issues
  239. Upgrading to FP Red tips.
  240. What's new?
  241. Artec vs Hypertune manifold
  242. Evo 4-9 Throttle body shaft seals
  243. New Engine Build
  244. 4th Gear Not Engaging
  245. Evo 6 short duration cams with large turbo.
  246. evo 6 highway rpm
  247. Stumbling idle under load (alternator?)
  248. Evo 8 cylinder head in 2023?
  249. Valve locks Keepers
  250. Topline Oil Pump
