PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. oil pressure drop-what is dangerous??
  2. new built motor! smokin a little wen cold ???
  3. Stock internals - rev limit
  4. What size oil feed line should be used for a 35r?
  5. OEM crank vs Eagle crank?
  6. ses flashing at wot
  7. Tcase question!! HELP!
  8. casting imperfections?
  9. Diff Clunk
  10. 4g64 block with 4g63 trans
  11. Speed Sensor Leak: Removal?
  12. getting CCI Clutch, Can I reuse stock TOB?
  13. Boost leak bucking caused diff noise?
  14. 6-speed shifter vibration question
  15. HKS SSQV not working
  16. Mynes 3076
  17. Urgent Pully help needed!!
  18. help plz
  19. easy way to remove stuck doughnut gasket on dp?
  20. Normal for used set of cams?
  21. intake/clutch
  22. Is it my tune or o2 sensor?NEED HELP!!
  23. Lets play a game, whats wrong with my engine?
  24. pte 1000 cc install issue º
  25. Installed ETS Intercooler, UICP - some questions about hoses
  26. Idle Oil Pressure
  27. Boost leak test performed today.
  28. oil pump questions
  29. What is your highest injector duty cycle stock turbo and injector?
  30. exedy lightweight flywheel
  31. Not getting into gear!!!!
  32. Exhaust 2,5 with 2,75 ralliart or all 3 inch.
  33. yet another timing belt/tension problem, please help
  34. cel for o2s when they work fine?
  35. Aftermarket clutches wear faster?
  36. Maf Adapter and Cone Filter questions
  37. new LICP and O2 dump do i need a tune?
  38. Evo 8 shortblock in a 9? What's it take???
  39. Lets talk: Radiator Surge tanks!
  40. FP Green vs. FP RED vs 35R (non hta)
  41. Stud for top intercooler bracket snapped
  42. Megan Racing testpipe question
  43. P0171 and P2195 codes thrown while car idled for a while
  44. Does this sound like a blown headgAsket
  45. Having a P0335 issue
  46. Ecu code p0603 (help)
  47. Having a P0335 issue
  48. EVO 8 Stock Internals
  49. clutch and flywheel
  50. Cooling Fans stay on??
  51. Block surfacing needed?
  52. More wideband issues
  53. Oil pressure drop-when to act??
  54. Fp Red vs Fp Black Direct Swap #'s
  55. Stock Motor FP Red Thread
  56. Some Clutch issues?
  57. new in town
  58. hks blow off valve
  59. After lower intercooler pipe install, problem starts.
  60. lost all spark! help
  61. Grommet Question
  62. Pulling timing - possible leak, knock?
  63. Help - What size bolt/thread for tensioner release (for changing cams)
  64. Spool
  65. Help me identify this fitting size for fuel rail
  66. Transmission leak
  67. Not just another clutch thread.... hopefully
  68. Help! Mod test-pipe for Buschur Slip-fit??
  69. crankwalk
  70. Oem vs. Stainless steel Oil return line
  71. shifting issues
  72. Can't stop boost creep on 6262 w/ AMS turbo kit
  73. Help!! My car hates boost!!!
  74. Boost gauge needle vibrating/shaking
  75. Can I see any performance gain on FP Red with basic bolt-on ?
  76. Help choosing cams! HKS 272 to ???
  77. titek o2 users, need some help!
  78. Need a picture of the clutch fork installed in the bell housing
  79. Sbr-t67
  80. help, this is tricky...
  81. Engine Noise (Video)
  82. Throw Out Bearing Question
  83. FMIC or Meth kit?
  84. im wondering what is the max boost u run in fifth gear with the fp red
  85. Whats the best solution to clean the sock filter in walbro?
  86. Misfiring Help
  87. About how much does it cost?
  88. Cam question
  89. Custom water to air IC build??
  90. R/TErnie 3in. 02 Dump Video
  91. Best Tool to Install/Remove Valve Sten Seals?
  92. 10:1 4G64 MIVEC Build Suggestions
  93. Please Read Timing Belt Came through cover
  94. FP red vs HTA3582 pics
  95. Stutter at 18 psi??!??
  96. Sounds like STI, lots of smoke, no coolant, failed gasket/cracked head?
  97. Do they make a block guard for EVO9?
  98. crank angle sensor quick help plz
  99. Boost gauge only reading 15psi, Possible boost leak?
  100. Bullet proof bottom end?
  101. FP Red+SS LICP+Buscher Deluxe=bad fitment
  102. ACT clutch adjustment???
  103. Need help!!!
  104. AWESOME information and results, take a read.
  105. Valve Springs
  106. aftermarket intake manifold?
  107. Tomei Poncam in stock now!
  108. Megan 02 housing or Ported Stocker?
  109. BR presents the new FP BLACK HTA82!
  110. help with removing front subframe
  111. clearances on wiseco pistons
  112. toque help needed
  113. creader for p0300
  114. Money to spend...
  115. Teaser pics...my 4G64 build
  116. Which Turbo Kit is this?!
  117. New pistons for E85 engines
  118. Question regarding E85 for long term use
  119. Drivetrain noise...again
  120. Whats my turbo worth?
  121. GL-4 in '05 LSD Trans?
  122. Wideband readings.....
  123. Timing
  124. Ebay ss Clutch line
  125. Is this a normal evo o2 sensor set up?
  126. MIVEC: Kelford or S2 cams to idle like stock?
  127. whats better Shep or buschur?
  128. Need a new alternator I think
  129. where to start first on my build.
  130. HELP! Boost leak?!?
  131. Transfer case bolts - size and pitch?
  132. Headstuds question...
  133. Mivec Cam advancing at random at idle
  134. Help: Clutch Pedal Vibrating Violently
  135. Will I be ok with stock plugs?
  136. Competition Clutch Stage 3 Gears Sticking at low RPM s
  137. SD Kit or Recirc?
  138. Exedy Twin SD - noisy & difficult 1st/Rev selection from stop
  139. thick oil in overflow tank(HELP)
  140. Jumping Accelerator
  141. Exedy Twin Metallic HD vs Exedy Triple Metallic
  142. aftermarket turbo
  143. Air Cleaner Bracket removal... help please
  144. Can't get into gear while stopped
  145. Forge DV Bucking
  146. exedy twin plate clutch judder
  147. Smoke from Hood
  148. Used Exedy/Cusco Twin Disc: What is it worth?
  149. Maxxed out stock turbo vs. Red or HTA Geen turbo
  150. White smoke from my muffler....please QUICK HELP!!
  151. acd reservoir relocation help
  152. waste gate dump question
  153. mod list..what do you guys think
  154. How big of a gain will I see going from GSC S1 > S2 on this setup.
  155. NGK colder plugs, smoother idle???
  156. Bad BOV?
  157. question about HTA 37 and GT4088?
  158. T Bolt Clamp
  159. 4g63 carnage - Post Mortem
  160. Fluttering with IX BPV
  161. Transmission diagram, top 3 bolts to engine block
  162. Camshafts.. how to choose ?
  163. My port & polish works
  164. Rear 02 sensor plug
  165. ACD Lights
  166. Missing Bolt at Hotside to O2 Connection
  167. Buschur intake fitment issues
  168. Transfer case locking up?
  169. Help me choose a clutch!!!!!
  170. AEM dry flow filters?
  171. Mod List...what do you guys think?
  172. 60k miles water pump: keep or change?
  173. Just bought a 2005 EVO 8 turbo AND a 2006 EVO 9 turbo.. Can't decide which one to use
  174. Ets intake w/o Tune
  175. TILTON Twin Cerametallic / Organic REVIEW
  176. high mileage evo rear diff
  177. Erratic idle after Sparktech non-Cdi COP install..WHY? Need suggestions..
  178. p0335 issue
  179. Clunking Noise from driverside (Another Clutch job issue)
  180. Keep coilovers thru winter? or not!?
  181. Rear Muffler
  182. DO hitting TC
  183. hks 3037 manifold problem!!!!!!
  184. possible bent valve?
  185. valve spring install question (without pulling head)
  186. Buschur's aftermarket water pump
  187. FP GREEN 73HTA Question
  188. Help, rain raped my motor
  189. JohnBradley's 2.2 long rod build
  190. WEAPON-R oil Catchcan setup>>pics
  191. need help(alternator)
  192. Evo 8 engine ticking/knocking noise (425 bhp)
  193. Intake Coupler Fitment
  194. FP Black Turbo
  195. exedy clutch help
  196. Intake pipe fittings/bungs
  197. Heater not working after radiator flush
  198. Time to change spark plug, what should i get?
  199. Need help or advice. (n00b)
  200. 03 viii 5spd into an ix mr
  201. Precission 60mm turbo??
  202. Clutch slipping
  203. Cam install costs
  204. Project: Evo6 Powered Mirage
  205. Hypertune Manifold
  206. comp 272 cam timing?
  207. 20G greedy turbo
  208. 2010 Borg Warner Airwerks Turbo catalog
  209. Oil leak after timing belt install...
  210. Looking for Clutch, Got $650 to Spend!?
  211. Exhaust question
  212. HELP Buschur Double Pumper not working
  213. Bad transfercase or just the cold weather?
  214. Exedy Twin Disc?????
  215. Bad diff of something else?
  216. Clutch question
  217. 4g63 vs 4g64 - 2.0, 2.3, 2.4L ?
  218. Can a bad Tune blown an engine?
  219. Blown head gasket or not?
  220. T-case
  221. Connecting brass fitting to intake pipe
  222. IC Piping Upgrade
  223. Cooling system question?
  224. misfire problem
  225. Cam gears from VIII work with IV
  226. Clicking metal on metal right front noise
  227. Turning boost DOWN in the WINTER?????????
  228. Converting to E85?
  229. Next Upgrade for Summer 2010, Crap Octane here!
  230. DIY oil catch can
  231. Some wideband ?'s
  232. My IX struggles to start??
  233. Evo VIII MR Turbo Question
  234. Balance Shaft Vibration , Help !
  235. hks gt2835 ball bearing turbo rebuild
  236. Highest HP FP GREEN on PUMP AND METH?
  237. help-ignition break up with 30psi
  238. WTF happened?
  239. 4 inch intake ????
  240. Strange Recall
  241. BBK Full or HTA FP Green?
  242. turbo inlet and outlet gaskets purchase
  243. GSC S2 Cam Settings
  244. The reason for my EVAP code - Check this out!
  245. Buschur Ported exhaust manifold, how much was YOURS ported?
  246. Will I have an exhuast leak?
  247. Fuel tank thump?
  248. No boost till 4th and 5th Gear
  249. 35R Comp Housing keep rotating towards the radiator?????
  250. Quick intake install question
