- Which AEM Coils for Evo 4~8?
- tial BOV spring
- turbo going bad?
- BC 272 cam install info.
- Car wont rev past 5,000 rpms
- Competition Clutch, Twin plate comments anyone?
- Quarter Masters 8 leg HTO bearing problem.
- Exedy Tripple Ceramic problem
- Cracked Header
- BR clutchless 4 speed project.
- Realistic gains from upgrading IM and TB
- What BOV for 350~400awhp?
- Clutch or ACD problems?
- Crazy boost drop at 6k Rpm's
- Can a bad ignition switch cause no start with strong cranking?
- QUICK EGR/evap and fuel pressure solenoid/sensor delete question
- Galant STR/VR4 Non-AYC Diff on EVO IV - Possilble
- Pulled the engine today....
- Why is my 4g64 w/Evo VIII Head Perfectly in Time?
- cracked valve guides
- 4G63 Valvetrain Ticking
- Shifter base bushings comparison videos: stock vs aluminum
- cam identification help plz
- odd bark/urrp sound when engaging stock clutch?
- HKS EVC 6 Boost Controller Help?
- Fresh from honda land .... need assistance and guidance
- I'm looking for advice on transmission and clutch
- quick confirmation!!!
- Cams and turbo surge - what effect? TOMEI ARMS owners?
- Exhaust louder after build.....help?
- TURBO SPOOL TIME WITH 2.2L LR SETUP and 6266?
- Average removal of material in a deck/resurface?
- coilpack or something else?
- clutch pedal sinking
- Deatschwerk injectors, good or bad?
- Installing my 2.4L into my IX. Some random questions.
- Transfer Case and Rear diff noises after fluid change
- Anyone done valve seals with head on?
- looking for input/opinions on what cr to go with on a 2.3 build?
- Help!
- Head/Block Surface Cleaning Methods
- cammed lope
- fuel pressure issue
- 3" o2 housing
- High pitched whining noise from evo 8.
- Need a TON of help please...
- New lifters
- Anyone running 34-35psi on stock block?
- Thoughts on fuel surge tanks...
- Help me decide... T-Case / Trans rebuild
- Car misses and dies randomly
- Evo intake manifold/plenum
- !HELP! 03 Evo Vibration/rattling noise from driveshaft
- help, what CR pistons are these ?
- Gear select lever on gearbox slight wobble
- DO you recommend a Blow off Valve ?
- Off Topic but are Back seat Removals really worth it?
- top end engine rebuild
- EVO 8 HELP ! I have $1000 to Spend, What do i do ?! i want WHP.
- 6800-7000rpm.... .63 or .82 A/R??
- Boost Taper/Leak question
- Coolant Issues Need some help.
- Opinions on 8.5 MR RS turbo (Titanium wheel). Max ATW power?
- Wiring in the alternator to a battery cutoff switch
- can anyone give some common on the exedy twin disc?
- anyone one else probs with burning oil in buschur built motor?
- bbk lite
- Wga Flutter or Comp Surge N 5th WOT
- Ignition switch bad
- Help me unlock my MIVEC cam gear
- aem boost source with 35r
- Is this normal or not with the noise?
- Automatic A/C Off at WOT
- Evo 8 tranny sound help
- car wont go into gear running need help
- Boost Controller suggestions
- HELP? Engine totaled at Barber/Brminghm
- Dipstick blow out
- Help me identify these cams
- Little help guys
- Drive Terrain SLOP
- dialling in unknown evo 8 cams.
- No start, fuel pump priming
- How Screwed Am I? Head Gasket or Rebuild Time or Option 3?
- Alternator died? Opinions/Tech advice needed
- honeywell "dualboost" turbo
- Fp green only 12 psi?
- Which Injector Brand???
- AEM new Boost/AFR Failsafe gauge??
- p0243 DTC, but bcs is fine...?
- TOB popped off on me today
- Evo 5 Crank Angle Sensor
- 02 housing options?
- Changed lower clutch line, now.....
- Tranny/clutch thoughts??
- IAC valve help needed ASAP!
- Staggered 270/280 Tomei cams
- Wise choice?
- Best option for only drag block....
- TD06-20g EVO 4-9 turbo (Kinugawa Japanese
- Manley Pistons Pron to Slapping?
- Coolant wasted issue PLEASE HELP!!
- which lifters should i buy
- Exedy Twin upgrade to Triple?
- Tapping When Accelerating
- Throttle body issue. HELP! Very wack!
- Open Testpipe
- Evo 8 burning oil after full boost
- Rhetorical Question
- Issue with a dark plug on E85
- Having issues with throw out....
- Stock radiator fan control + manual switch?
- New Member Evo 9 Slipping clutch
- Evo ix with racist clutch.. need help
- Stock evo ix mr gauge help!
- Hows my motor sound ?
- question about oem retainers and fuel pump
- which one of these clutches?
- AEM Releases new Boost/AFR all in one Failsafe gauge!!! Info inside!!!
- Shifter feels out of place?
- Clutch Disk
- EVO8 5 speed conversion in a MR...
- ACD Problems
- Evo 8 Transmission Bearing Failure Help!!
- no boost and white/blueish smoke out of exhaust on idle
- Grimspeed 3 port
- Turbo coolant hard line keeps cracking. What gives?!
- Fuel cut?!?
- Is this evo head still good? pics..
- Leaking t-case help please!!!
- Noob question
- Upgrade from evo9 turbo
- Solid Lifters VS Hydraulic Lifters?
- Borg S300
- 608 hp @8000 rpm and falls badly after...
- ever lasting squeaking
- boost leak check issues
- Weird Turbo noise
- carbonetic triple with qm release bearing. issue
- DogBoxRacing Air-Shifter (video)
- ebay ex manifolds
- FIC 2150's or ID 2000's?
- Evo IX MR 6sp clunk
- My front diff
- Bucking?
- Stock clutch limits
- Tial MV-R External Waste Gate Cooling Idea??
- blown ECU help
- 6 speed Transmission rebuild
- Buschur Racing GT3582R upgrade to FP HTA?
- ETS 3.5 IC Wide Tank fitment problems
- ebay 4" fmic
- Clutch to the floor. Brake fluid leaking.
- popping out of 4 th gear
- Finally going to start building soon
- Any ideas on where to look next? Bucking, Stalling
- Car will not idle after BF272 install
- Resonated test Pipe
- CMC supposed to look like this?!
- 6puck question
- Rear axles
- Methanol safe thread sealant ? Meth. pump info. inside
- TunerSports.com - Great Experience
- LICP fitment issues
- Balance shaft delete kit
- E85 question...
- Anyone need the euroexport vavlespring tool?
- ATTN Omni map sensor users- reminder do not use the supplied o ring
- HTA 71, Here I Come!
- Will pay whomever leads me to the cause of my no start issue.
- o2 dump vs. o2 housing
- Question for all Engine builders
- Need some help with a Mivec issue?!?!
- need help, just randomly shut off.. fuel pump not priming!
- Car Wont Start P0335
- way out of my abilities
- My clutch(ACT Xtreme Street disc), short shifter w/extender and blox knob combo.
- Is this a buschur intercooler?
- Stupid Question: Can you "plug" a IX T-Case and use it in an VIII?
- Strange noise coming from cam gear area. (video)
- Having issues with wastegate actuator
- 5 speed swap
- whats size fmic to run?
- nevermind
- Quartermaster slipping prematurely.
- Front Crossmember bolt part #
- 87mm block o-ring questions
- Help identify this O2 housing, crap or good?
- Clutch Clip
- Help with rear o2 housing bolt
- Valve float question
- Acl aluglide thrust washer set – 4g64
- Speedometer stopped working, no check engine light
- Kinugawa Turbo on Evo 8
- Evo X & Evo VIII Clutch different???
- Is a clutch pedal stop required with a QM clutch and a HTOB?
- i need to increase the power of my evo (ur HELP)
- Can someone in the San Diego area look at some parts for me?
- Top Mount 6466 from MAP Sneak Peek!
- How to tell fp red?
- Low RPM Knock After Balance Shaft Change
- Evo build help, looking for 650+awhp
- AEM cai install funkiness
- anyway to get more clutch pedal travel?
- Borg Warner Bullseye S362 with a .70 AR T3 single scroll turbine housing
- EBay evo9 trb install kit???
- please help bad idle new motor
- Weird smell?? Possibly clutch?
- USDM rear end into JDM evo 9
- Ams motor mounts??
- clutch flywheel alignment pin?
- RC 1600cc Injector Questions
- Fuel Injector Connection, Anyone?
- Voltage jumps from 14 to 12 randomly
- engine whining noise help
- Yet another ticking noise
- killed mt tc-trans case
- help needed on evo 7
- optimal water temp ?
- Clutch recommendations
- Walbro 485 fuel pump?
- Leaking noise coming from under intake manifold/behind head
- 2 dowel pins for block to head part number?
- Advise needed on 2.0 LR
- killing thrust bearings in turbos
- Radiator hose on IC piping
- Starting Issues (not starter) (not cranking)
- Opinion needed! Kelford 280 vs tomei 280 cams
- boost drop after intake?
- Does this ECU look fried?
- Magnetic oil drain plug for IX
- Need help deciding on a turbo. Sell me your used Turbo?
- Replacing stock 8 turbo with a 8 10.5 turbo?
- Can't pass 10spi - No boost leak
- Interesting, cars dead, but has power to ASSC.
- Help: Transfer case
- Act 6 puck noise?
- evo 8 cams to go with????
- Quartermaster 8 leg twin disc- What flywheel bolts to use?
- Things I should have to complete my motor/clutch/turbo kit install
- Can't figure out where my oil is going
- Why there are different gasket kits for evo8?
- rear diff side bearing on evo 6
- Clutch issues
- How long will my ACT Street Disc HD last?
- 2003 evo 8 hitting fuel cut?
- Advice brand for evo8 rocker arms?
- 1 piece oil cap?
