PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 [132] 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Funny smell, probably okay?
  2. fuel injector upgrade needed?
  3. Stainless, aluminum, titanium bolts/nuts
  4. Wanting to have my 2.0L built by Buschur, but need a little imput on the total cost!
  5. 91 oct. + FP-GRN = 409whp on a dyno jet
  6. Boost Pill advice
  7. Stock turbo question
  8. Opinions on what to do...
  9. throttle body vacuum ports
  10. need help greddy profec b spec II wiring
  11. 3071..3076...3065
  12. Should I be disappointed DYNO GT30R
  13. Intresting Engine Pic
  14. Stock MAF Blow Thru?
  15. Anyone know what boost controller this is?
  16. Transmission/Drivetrain Info
  17. piston four chunk gone
  18. Got GT3582FP turbo
  19. blown engine in a evo 7
  20. Is this possible?
  21. question on trans case
  22. weapon-r intake manifold
  23. Benfit to Replaceing O2 Housing?
  24. proper leak test question?
  25. What is the fastest spooling turbo?
  26. bearing question
  27. Walbro 255 variations and that pressure relief valve ...
  28. Even More Boost?
  29. random cylinder misfire problems
  30. check this out for me
  31. P0234 + 3" turbo-back
  32. ebay clutchs
  33. Why are BOVs that VTA not good for MAF?
  34. What's important and what's not for making power...
  35. Just got my DNP manifold ?!
  36. Anybody running that HTA37R yet?
  37. 6 speed bad?
  38. Will I gain or lose power..2.75 or 3 in O2 housing?(HTA 35R)
  39. BR cast mani vs tubular
  40. Issues with fitting Buschur Heat Shield
  41. Cosworth ix cams, arp headstuds, install: how much did you pay?
  42. Engine rebuild Evo 5
  43. Greddy turbo kit for e9
  44. Borg Warner s256 VS Gt30r!!
  45. Extremely rough idle this morning
  46. Help with slave cylinder install
  47. Boost Creep.
  48. Tanabe Downpipe?
  49. Crower titanium retainers
  50. Tranny rebuild time
  51. Hooking up Tial wastegate to MBC?
  52. OMG,will someone tell me what bov to run that is loud and wont screw up my car
  53. Is there like a 11.2 hotside for the stock 8 turbo?
  54. Engine Noises!
  55. Gscs1 Cams, Are They Marked???
  56. AEM or ECU FLASH
  57. Hey does anyone know if Blitz Nur Spec R drones at freeway speeds?
  58. shep tranny/ 1 & 2 doesn't work
  59. Need Help!!!!
  60. Differences between housings
  61. BW ET50 Trim Dyno
  62. Fifth Gear Slip?
  63. Boost noise
  64. Another Engine Whine Thread
  65. cosworth crank scraper
  66. ACT clutch - real or fake?
  67. Fuel Injector Question
  68. Weird problem with the car being in neutral
  69. Where and how much u pay 4 tune?
  70. No I Do Not Have An Hta37 Or A Red.
  71. Is my clutch starting to slip?
  72. HELP! anyone.
  73. RRE X Clutch and Flywheel! Noname
  74. Megan Exhaust Mani Arrived
  75. Tomei Powered Stroker Kit!!!!!!!
  76. has anyone heard anything about skunk 2 parts
  77. so what about a greddy bov
  78. P0171 Lean Condition - Could be EGT Sending Unit???
  79. Stock block with Gt35r and nitrous
  80. Brian Crower Camshafts??
  81. WitchHunter Performance or RC Engineering for Injector Cleaning?
  82. Hotside porting and coating...
  83. DC Sports exhaust manifold
  84. Oil fittings
  85. Stock IX JDM MAP shows full boost at 4000RPM
  86. abs fuse and the acd
  87. Running atmospheric dumptube with beatrush undertray?
  88. Prosport Manifold
  89. tuning questions, just a few
  90. Megan Manifold Precautions
  91. Got more parts today to complete my 10sec street car project
  92. anyone running this?
  93. Titek downpipe and Ebay o2 housing question
  94. Tranny issues?
  95. Comp Cams For the IX
  96. Check this out. Timing Belt/Head Gasket
  97. Pedal Vibratation. Need Sherlock Holmes
  98. What are the Best Evo IX Cams??
  99. Evo making a couple strange noises??
  100. Air Filter for GT35R Evo8
  101. Opinions on Brian Crower cams!
  102. new clutch
  103. Exedy Stage 1 clutch...questions
  104. Divided housing number?
  105. 500whp on stock rods and pistons?
  106. Shops in my area
  107. SIZE="3"]Since venezuela That turbo? Gt35r or t67 ballbearing
  108. How is this TDO6 20G?
  109. Sheps Syncro trans or Sheps dogbox
  110. Which power pakage ?
  111. Another Clutch Thread
  112. How much faster would a evo lap around a track compared to a evo without acd?
  113. WORKS 70mm DP and aftermarket o2 housing compatibility
  114. I Think My Turbo is going tits up
  115. Cant boost past 10psi
  116. AEM intake question.
  117. Attn: Martin of VIP
  118. car will not stop throwing p0172 and p0500 codes
  119. Read My Plugs
  120. risks with cams?
  121. compression test. need help/info please
  122. drivetrain help
  123. fidanza clutch
  124. dp - o2 housing leaking
  125. fp green
  126. OFFICIAL: Tanabe Concept G Blue Evo 8 & 9
  127. meth or turbo?
  128. oil cooler
  129. what cr should i go with
  130. dp help
  131. DO NOT USE PULSTAR PLUGS!! i repeat do NOT install these in EVO's
  132. ARP head stud failure.
  133. BR Turbo Kits...Post what ya got!
  134. E85 usage
  135. sensor problems
  136. O2 Housing Question...
  137. ATP kit strikes again!!!!
  138. Intake Manifold
  139. Problem with FP EVO Green Turbo
  140. question about my new setup
  141. JAM lifters
  142. What is the deal with Full Races Twin Scroll?
  143. I have 2 questions for all you EVO owners..
  144. BR 3065 turbo kit w/ tubular manifold lots of photos!!!
  145. Evo Not Running Right After Storage
  146. Greddy intercooler?
  147. ETS Water to Air Intercooler. In progress...
  148. Plugs fouling..help!!!
  149. boost creep
  150. "Neutered" my EVO 8 today, didnt want to though....
  151. NGK Spark plugs gapping?
  152. boost problems HELPPP
  153. Weird clutch issue....
  154. Buschur Downpipe and SS 02 housing issues...
  155. AYC in a American Evo VIII?
  156. TD06SL2 Reverse Turbine details ?
  157. Byc Fmic ?? Any good
  158. Whining and sometimes a jerking
  159. GT3076r or GT3582r ??
  160. Boost raises above 27 PSI and up!!! Need help! Hallman MBC
  161. Profec B Spec wiring routing options?
  162. FP HTA35r Dyno #’s w/ Meth
  163. p0031 and p0130 - Help!
  164. Fuel Injector to Manifold ring/plastic?
  165. Weird MR Tranny problem
  166. JUN 264's on a Green
  167. Will a SlowBoyRacing DSM GT35R work on an EVO?
  168. EVO 9-20g 6 blade
  169. Anyone Tuned By ICS ?
  170. Idle Surging Problem
  171. vaccum lines
  172. fp green typical track times
  173. Bye-bye BOV flutter
  174. How much HP can a EXEDY ORGANIC CLUTCH hold???
  175. Injen UICP havin weird???
  176. What could be causing my turbo not to boost??
  177. Evo 8 and Evo 9 LSD's
  178. 2.6L EVO - every been done in the usa
  179. 4G64 2.4 stroker with evo MIVEC head......Help!
  180. Very small chips on Exhaust Turbine...
  181. Problem when accelerating
  182. Is this really just a 9.8 hotside?
  183. Evo VIII Build - Dominican Republic (pics)
  184. gscs1 cams Ok with std springs
  185. Greddy Type-S on stock ECU?
  186. 20glt
  187. Something wrong with my clutch
  188. puzzled by low compression #'s
  189. Q16 Fuel
  190. Will the 4B11 coilpacks fit 4G63???
  191. 2.3 build in progress.
  192. Help with possibilities please...
  193. 9:1 Compression
  194. what do you guys think of this cam setup
  195. suggestions on cam for my set up?
  196. IX crank in a VIII - question
  197. Evo IX Problem Help
  198. MBCs: What you don't like
  199. New Redesigned AMS Evo Pistons
  200. Rear subframe torque specs and others
  201. what exhaust should i get
  202. Clutch pedal doesn't fully return to resting point?
  203. Short shifter for 6mt
  204. P0141.. some help please?
  205. 93+Meth vs C16 vs VP Import
  206. Apexi AVC-R boost and setup problems please help.
  207. Help with identifying some gaskets
  208. Infinite Speed & Performance Turbo Kits
  209. Green or Gt3076 ?
  210. Which ACT EVO Street Disc Clutch Kit?
  211. Fast Dd Evo
  212. new at this new 2.0 build
  213. Some positive input on testing intake manifolds
  214. HKS Carbon-Ti vs A'PEXI N1 GT-Spec
  215. Where is everyone getting there 12v switched power for Wideband?
  216. Spark Plug Question?
  217. Spark Plug Indexing?
  218. Is anyone running the FP Green with only minor Bolt-Ons?
  219. RRE X Clutch Or Exedy Stage 2
  220. bov on 06 mr?
  221. 16 year old Harry's Buschur Powered Gt35 R 2.3L Stroker Street Sweeper
  222. HKS EVC VI settings??
  223. 50 trim dyno'd
  224. Starter problems
  225. Intake manifold for 3076r?
  226. o2 Housing Install
  227. EVO STARTING PROBLEM.....(electrical)
  228. HTA owners quick timeframe question
  229. Can Gt3076r hit 460 whp 93 pump??
  230. Where to buy crush washers to fit stock coolant line on 3065?
  231. Front O2 sensor question
  232. What size is the coupler on the hotside of intercooler?!
  233. Can a GT30r run 11's?
  234. EVO 8 Axles and Evo 4 axles Are they same?
  235. Sudden squeal
  236. Innovate WBO2 & HKS HI Power
  237. Promised Pix of Ebay manifold
  238. Adjustable Cam Gears and effects...
  239. External Wastegate on Stock turbo
  240. WHP with these mods?
  241. will i have to do a retune
  242. NOS for spool up
  243. Boost issue help would be appreciated
  244. Active Center Diff Info Needed
  245. exedy twin plate clutch rebuild kit
  246. Borla turbo manifold???
  247. Options- i need more.
  248. brian crower 272s
  249. Spring/Retainer Install HELP!!
  250. just got my buschur racing hta 35r kit in the mail... pics inside
