PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Lean Code Problems
  2. Carbonetic carbon plates wanted
  3. Full Blown 70mm Throttle Body Crushes, Falls apart, Where Did The Bits Go? (PICS)
  4. Metal Shavings :(
  5. Drive train maintenance
  6. 2.3 evo 6262 0.82 or 0.63 hotside
  7. 2.3 Crankshaft Science
  8. Inducer Size for CBRD BBK-B BB?
  9. Hta 71
  10. Injectors
  11. Bad IAC valve or possible boost leak?
  12. Brake/clutch line insulation solutions
  13. 1jz owner with Holset need help
  14. Oil pickup - small holes around the edge
  15. Quality Turbo Rebuild Kits
  16. RPMs get really low when driving or revving
  17. Help!! 2.1 timing tensioner compressed all the way
  18. Boost Gauge Issues
  19. Issue with boost/what are these nipples?!
  20. Custom Pistons
  21. I'm torn on which turbo to go with....
  22. 2.3 or 2.4
  23. Pin 48, fps is that the only ev1 style plug in the engine harness - fuel inj
  24. Has anyone seen this engraving before?
  25. ANOTHER lifter tick thread
  26. Clutch Fork Stop adjustment
  27. just put stock recirculating valve back on
  28. Coolant Leak
  29. TITANIUM axle castle nuts and lock washers.
  30. Building a high hp pump gas 2.4L
  31. maintaining a 2.3l stroker
  32. Head Gasket
  33. bypassing clutch
  34. Remove wiring harness without gutting car?
  35. Help, Very lean startup cold or not!!!
  36. Need help quick please
  37. throttle hang issue
  38. Car will only hit 26 psi on 5th gear
  39. What pistons/compression to use on 2.4LR 1000whp goal?
  40. Fuel pump question
  41. Transmission / T-Case questions
  42. turbo heatshield bolt sizes
  43. Which oil do I choose! 2.3 Stroker fp red
  44. SICKSPEED lower engine mount Review
  45. WTB Tial 1.03 for my hta3794
  46. AYC & ABS Lights flashing Please help
  47. Fuel regulator set up verification
  48. Can't get car into gear. Any ideas?
  49. Rear OEM AYC LSD Diff evo 9
  50. quality zip ties
  51. new starter problem help asap
  52. Look at these pics of my turbo
  53. evo 8/9 tranny
  54. Transmission problems
  55. car died on highway today
  56. Evo 9 Cold start issue
  57. Rattle/Clanking on Startup
  58. Keep T4 twinscroll kit or BB Fp Black on 91oct???
  59. T3 Turbo on stock location manifold?
  60. Fluidampr hitting timing belt cover
  61. who has used Os giken Clutches ?? TS2B need info
  62. Battery relocation questions
  63. Nvidia N1 Exhaust JDM Fitment
  64. Kinugawa 20g notice on **** down
  65. PTE turbo Rebuilt!!
  66. bushwaker tranny oils?
  67. Rough idle - Cold weather?
  68. Comp Clutch stage 4 or 5?
  69. A1 cardone PS pump experiences
  70. 2.3 evo 7 questions
  71. 2.4 guys, what clutch are you using?
  72. Timing Belt Service
  73. Name this part:)
  74. Some Clarification on Clutch Adjustment
  75. Comp Clutch vs. 450HP
  76. Dented downpipe - restrictive?
  77. TD04L-TD05H Differences?
  78. all stock EVO 9, power ? with oem airbox/exhaust
  79. Engine repair needs
  80. Silicone heater hoses
  81. Spark Plug help
  82. Air control
  83. 700WHP Build recommendations
  84. Engine dies/stalls when the clutch pedal is released during idle (After clutch swap)
  85. Purchasing new turbo and other parts
  86. L19s... Do you re torque after heat cycle?
  87. Car acting up as temp drops, BOV, backfiring
  88. Pop in third gear, but no issues
  89. need to reconize what camshaft are this ! pictures Inside.. !!
  90. IAC pin out
  91. HTOB clutch question
  92. Rear end Clunk when shifting hard
  93. size of evo 7/8/9 transfer case ring gear/ diff housing
  94. GSC R2 cam + 2.0L Evo 9 experiences?
  95. Test Pipe Retune? Myth or fact?
  96. Evo VIII Front Diff Freeplay
  97. HELP! High Idle Issues With New Motor Install
  98. I think i burnt out my clutch...
  99. Plz Help, Ticking/Koncking Noise in my Evo VIII.
  100. Tune after cam install
  101. HKS 274/278 vs Kelford 272 Vs kelford 280
  102. Rear Rotor hat thickness
  103. Corrosion proof spray for bare shortblock?
  104. Toxic Fab ingenious stepped FF manifold with BILLET collector!
  105. Best rod and piston setup on 2.4 for over 800hp?
  106. urgent need help asap
  107. Who runs a 156mm Rod and 94mm Stroke on a 4G63?
  108. Wideband issues.
  109. Evo 8 Almost Stalling/Oil Pressure
  110. Turbosmart evo 8 internal wastegate replacement upgrade
  111. Logo On ETS Manifolds?
  112. Lightweight Rods
  113. Help w/ strange ACD Issue
  114. Serious HG failure on a built O-ringed 2L.. possible cause? (Pics inside)
  115. Help me identify my turbo please!
  116. I-beams on 4g64, do i need to do any block work?
  117. Low boost after new manifold
  118. Softer Spring for a Synapse DV
  119. What could have cause this bearing issue?
  120. Sitting for a cpuple days let it warm up blowing black smoke
  121. Help! Removing control shaft on transmission.
  122. Clutch disk size 4 vs. 8
  123. exhaust maniofld leak or ?
  124. New manifold or o2 housing?
  125. Help. Look at these valves
  126. Surging / stalking
  127. Evo clutch engagement/clutch going out?
  128. **Need Help. Misfire under load and idle issue when cold**
  129. Damaged MIVEC Sprocket
  130. 2.4 Stroker Running on Stock Turbo, Kit ideas?
  131. stock 10.5 turbo !! kelford 272 or 280 ??
  132. Freshly rebuilt turbo: White smoke & milky white liquid in tailpipe
  133. Engine load is too high, causes boost cut/power loss.
  134. 71hta question ..
  135. No g force pull feel !!!
  136. weird engine noise,need help!
  137. HKS 7460r
  138. Double pumper setup
  139. Ruined Clutch?
  140. Evo 6 / 8 Intake Manifold / Throttle Body
  141. white smoke from back of turbo
  142. Evo bogging
  143. Does my motor need to be built for the following mods?!?
  144. Its tcase, gear trans, or what? (Video inside)
  145. FP3582HTA tune - need to turbo swap
  146. Lets talk simple fueling for 850-950whp
  147. WGA bad or somthing else? taper issues (screenshot inside)
  148. Gsc s2 driveability problem
  149. Howling noise in 1st gear
  150. Rear Diff problem
  151. Eliminate balance shaft or put a high end balance kit?
  152. need help
  153. Safest Tune with Summer or Winter Blend Gas??
  154. what diameter runners for custom manifold ?
  155. Oil recommended for a BB Fp Red
  156. Fuel Injector Seals
  157. Rear Differential Problems, Help!!
  158. First big turbo install. Questions!
  159. Evo 9 anti lock light and acd lights on periodically
  160. Built transmission oil-leak
  161. fp turbo install smoke
  162. What size rods to use for 4g64 block and 4g63 evo 8 head stock oem crank
  163. Cam Install - Did I slip a tooth??
  164. transmission diag.
  165. 'Spark blowout', Fouled plugs?
  166. 65mm Throttle Body Fun
  167. PERFECT bs inspection hole vent alternative
  168. What do i need to do a 2.4L/4g63 head conversion
  169. Opinions needed
  170. Evo map sensor bung
  171. Getting rid of engine idle noise
  172. 3-B on Alky/Meth
  173. Need Evolution 1 torque settings??
  174. Axle Issue
  175. Easiest way to empty e85 from car?!?
  176. Valve cover gasket
  177. Drivetrain noise coming from the rear passengers side
  178. Car WAY Oversteers During Lane Change
  179. CELs p0138 p0141 p0300
  180. trying to find oem part number with no luck
  181. evo 8 transmission clunky
  182. Engine Temp - Evo 6
  183. Clutch will not disengage
  184. Exedy triple carbon conversion??
  185. evo 8 no spark no fuel
  186. Leaking coolant only under boost.
  187. difference between evo8 & evo9 starter?
  188. Evo 7 clutch noise
  189. Best parts for 700+AWHP?
  190. As I was finishing timing belt, saw leak.
  191. Worn out clutch pedal?
  192. To Those Who Have a MAP Performance Engine
  193. O-Ring or not to O-Ring Head w/ 6g64 block
  194. Doing clutch on my 05 SSL - Trans. Filter?
  195. Help! Fuel issue....
  196. maperformance rev3 intake mani and thermal spacer
  197. CBRD BBK turbo Identification
  198. HKS Hi Power exhaust
  199. 4G64/4G63 hybrid issue
  200. Mid-south tuners? flashing ses light
  201. evo 8 axle and tcase problems
  202. IX MR 6 speed underhood bushing install ?
  203. Arashi Turbo thread
  204. 6 speed transmission help
  205. Evo 8 ARP question
  206. Best Steet/Strip Turbo for 2.4L LR?
  207. Soooo... This Just Happened!!! :-(
  208. Transmission install - pull engine or suspension?
  209. Low compression numbers.......now what?
  210. evo 4-9, same clutch specs and oem maintenance parts
  211. Air bubbles from Clutch master to Brake master?
  212. Tranny, Driveline,Diff Recommended Fluids
  213. Stock TurboFP Evo Flow Advancement Port Cover available again
  214. JDM Evo7 acd transfer case into Evo8 non acd
  215. Another "Help! Leak!" thread. Gold/yellow fluid
  216. Brainstorming spark issues. Who wants to join in?
  217. Evo 8 Overheating problem.. head gasket?
  218. High RPM Lockout + Grind Help
  219. IX engine into VIII
  220. what plug is this on evo 9 engine harness
  221. Need some help with valve spring install
  222. Which FMIC is This?
  223. flywheel need resurfacing with only 8900 miles
  224. Another evo 8 only getting 12 psi
  225. Cheapest Way To Pull Codes?
  226. Boost leak questions
  227. Bought an 03 evo 8 not running
  228. 92 GSR Problem
  229. whining noise month after motor install
  230. Effect of adjusting the suspension on drivetrain components
  231. Help with another HKS cam ID
  232. Replacing HLA "lifters" quick question
  233. Clutch feels notchy/sticky all of a sudden
  234. Need help serious problem!!!!
  235. Engine start help
  236. Which Turbo next ef2.5 or 3?
  237. Fuel issues around 7-10psi
  238. ACD ATF FLuid Leaking from Passenger Axle
  239. ACD feed line sprung a leak, lolwut
  240. New ACT ME2-HDSD - Thanks TSCOMPTUNED
  241. 1400 USD turbo option
  242. Boost Leak?
  243. Evo IX issues
  244. Help with EVO 9
  245. Please Help Gasket Issue!
  246. Allpurposepipes Intercooler?
  247. 8 speed semi auto gearbox
  248. Volume of air
  249. Evo 8 MR BOV
  250. What does this mean? Video inside
