- turbo kit
- First mods to do...
- ecu flashing with testpipe then high-flow cat
- Downpipe Install Question?
- Help, not running after stage 4
- GReddy Type-S Blowoff Valve install
- Boost Gauge Accuracy
- 3 gauge panel for DIN opening
- Turbo XS rfl-Ti cat-back exhaust impressions...
- HKS GT3240 or GT35R
- thickness of the stock head gasket???
- dyno sheets and questions
- Recommended First Part
- AMS tuning in your neighborhood?
- Boost issues
- Just got the bigboy HKS GT3240
- pls help, need safc/safc ii dimensions
- Boost leak
- Radiator Hose Leak?
- EVO8 factory 02 housing
- FIC injectors
- TurboXS Type H34 Recirc Valve??
- Help with idling after injector/pump install
- Apex TT harness question
- Potential of the Evo VI's turbo?
- Trans Problem
- Dyno Results - New Quantum Racing Dyno
- Greddy Titanium Exhaust Owners - Gotta question?
- Mbc???
- Why is my car destroying Coil Packs?
- Who is the fattest of the ladies......
- Best Cam timing HKS 264 Int/Exh
- HKS Kansai Intake???
- Boost Gauge Sugesstions? Is an AFC necessary thing?
- New plugs, DV changed... still STALLING!
- 1st Oil Refresh?
- Blown engines
- Grinded 2nd once today :(
- mbc problem?
- site of most exhaust restriction
- My Review of Lancershops 2pc under hood bushings
- CEL after installing pump and injectors
- Brass shifter bushings, anyone have them?
- Rotated Cam Gears
- Ultimate Racing Staged upgrades?
- Ordered the Turbo XS rfl-Ti exhaust
- DP or High flow cat?
- Where to Properly Tee in your Boost Controller
- Installation Pa/NY/NJ area?
- P0300 Missfire FIX !!
- Buschur exhaust and hks carbon ti muffler
- Fuel injector plug question
- Three questions: Main bearings, balance shafts and oil pump.
- Does your Boost Controller hold your boost till redline?? Do you need a Air/Fuel?
- Need a quick answer - DynoFlash without MBC
- knock?
- Any Exhausts with less Bass?
- Best cam for ultimate HP
- Blitz FATT
- Strongest EVO gearbox...
- Can anyone fab this custom intake box?
- hks evc boost jump.
- Has anyone bought the Vivid Power Pkg 1?
- Playing with stock boost solonoid = 21psi boost
- Pull vs Push type
- stock car with K & N drop in
- greddy r-spl intercooler kit
- Does anyone offer indexed gears (fixed) cam gears for the Evo?
- People w/ Buschur Racing Stage 4, what cams do you recommend?
- What exactly causes the Boost on our cars to lessen at higher RPMS?
- Hallman MBC install
- Clutch talk...
- TRANNY HELP! My dealer is screwing me!
- What's wrong with the stock clutch?
- Greddy Profec B- Spec II Help
- cooling the intercooler
- Evo motor fit in a lancer?
- Cat Back Exhaust
- Car stalled out 4 times yesterday... Any other suggestions?
- Mini Battery $75.00
- Injector Upgrade?
- Waste gate actuator
- Defi Link Controller Install
- clutch noise
- Compression ratio?
- cat_back exhaust
- THANKS To Boost Solutions
- Stock Shifter issue...
- What front LSD is available now in the US.
- Installed a perrin boost controller today
- How to tell if TC is broke
- Built 1stgen 6bolt short block
- Installed Borla Headers, Nology Hot Wires
- 21 PSI 3rd and 4th gear
- Random Technology 3" High Flow cat & CEL?
- Water from exhaust
- Part #'s for "stock" tranny/diff fluids?
- Fuel pump dilemma(Walbro 255)
- Airtrek 4G63 Tuning Info
- losing boost...
- What Next? S-afc, EBC, Air Filter, and Cat Back
- God please help!!
- Stock upper ic hose!!
- Mine's VX stainless exhaust
- Turbo's question
- Whos got the Greddy Intercooler?
- Buschur racing exhaust or greddy ti exhaust?
- can i mount a wideband O2 sensor in the secondary O2 port?
- Should Turbo Trix build a better Transfer case
- Ultimate Racing CAI
- Standalone, piggyback? Which one is best?
- possibility of Limp mod?
- act 2600 vs act 2900
- hks intercooler
- Pics of transmission and diff internals?
- Need Help On Boost Guage Install
- Suggestions on Tranny oil other than Redline??
- Ignition Issues?
- EVO Drivetrain fluids
- My suggestion to the clutch issue.....
- does MBC have to be mounted a certain way?
- installed my buschur 3" turboback today...
- Megan Racing downpipe, test pipe, cat back installed
- Problem with Buschur Racing Magneflow muffler...
- Blitz Intercooler core
- Tomei
- Max Boost!!
- should i buy downpipe or not....
- Can't boost over .80 hkPa after "mods".
- Metalic "clank" when backing up
- high clutch pedal engagment
- RnR 2.4 EVO 8
- Problem w/Starter? Help!!
- Get gauges or just a electric wideband O2 sensor?
- help me with boost - mbc
- Stock Boost!!!!!!!!!!!!!!!!!!!!!
- Engine stalling
- Besides the clutch what is the weakest link on the EVO?
- Cat delete Question
- Only boosting 16 PSI?
- New 3" downpipes, offroad pipes...
- Question from a frenchie (sorry for the english!)
- too much oil???
- question about maps and all
- cam gears
- will a 1g bov solve the stalling and suttering issue??
- My EVO dyno chart
- Injectors
- Installed Clutch Masters Stage 4 Ceramic
- Noise from Tranny??
- Question about lower arm brace?
- 502whp on a dyno dynamics dyno - untuned
- Warning: Megan Catback exhaust
- Vacuum line on intake hose
- Downpipes and emissions....
- HKS Racing Suction users? New filter?
- rmr intake & buschur upper i/c piping?
- Which vendors sell the GD max overhaul kit?
- Anyone with the GHL exhaust installed?
- Newbie Boost controller ?
- Best Exhaust?
- Who has or knows anything about the NX Intercooler chiller kit
- Boost Conversion
- 4th gear grind =(
- HKS GD MAX twin disc clutch kit
- Quicktime performance 3inch downpipe with cutout
- Stalling problem need help
- Ultimate Racing turbo setup
- Ordered Cams - Have a few questions
- Coil Packs
- springs
- Aem Vs Fower Fc
- Euro and Jap spec evo's with 6sp and acd
- Intercooler sprayer
- Can the stock BOV be modified to be more efficient?
- NOS in EVO
- Which flange kit for Greddy Type S BOV?
- HKS 272 cams, Idle AFR
- Tuning my AFC2
- Greddy titanium
- Stock pump goes kaput!!!
- Part Number Help
- Will Supra fuel pump work??
- Buschur Racing Stage 4
- slick 50
- clutch bleeding
- Looking to buy Upper and lower IC piping for 03 EVO
- Evos With Apexi Power Intake
- Need some help troubleshooting....
- Octane Boosters
- Help- car won't turn over???!!!
- Clutch/1st gear problem
- Random Tech Hi-Flow Cat: Anybody know where I can get one?
- What size injectors come in Lancer Evolutions?
- Arp headstud question??
- Evo Mid Pipe?
- big problem, please help
- Clutch Line????
- B&B not straight through...
- Intercooler Upgrade add HP?
- Engine surge under acceleration: 2nd, 3rd, 4th gears
- plugs are white
- Quick question?
- Boost Guage Power Source
- boost
- what fmic is this ?
- clutch/drivetrain
- ATS Clutch
- EVO VIII MR Will it get a better clutch?
- Dejon Tool Upper Intercooler Pipe
- 70% short throw review!
- Our Stock Clutch and Flywheel - Interesting discussion with RPS
- mbc still not holding boost
- “Stuttering” boost?
- B&M shifter problems
- WORKS p2 brainflash
- anyone used a garret t3/t60 60 trim ?
- A/f ratio datalogging??
- Oil changes
- HKS exhausts, anyone have exhaust rattle against gastank sometimes
- Where can i go to get a pressure test done
- HP estimate with this combo???
- BG Synchroshift??
- FS New Evo 8 Turbo
- Clutch - Mitsubishi's warranty
- hks ssqv questions
- Mini battery kit question
- Anyone with P0401 CHECK ENGINE LIGHT?
- Cusco Intake?
- Help! JUst installed e-01 and i have a problem
- hks exhaust
- 02 housing question....
- SAFC Wiring diagram
- arc induction
- HKS Turbo timer
- Evo Stalling
- what oil to use for track day?
- Anyone know where i can get cheapest hks filter?
- vibrating gas pedal
- My type S experience
- having trouble with spark plugs
- I found this
- holding boost =X plz advise
- Emanage and external blow off
- ACT Street Clutch
- Some weird problems with my valve/leaking/boost
- Bolt onmods to EVO
- Having some trouble
- Installed Bushur's MBC have a question
