- weird cold idle problem
- Need some opinions
- ETS intake question
- Please give me advice for choosing cam!!
- Excedy twin disk with 6sp
- Which is a better coupler?
- Track Day Clutch
- BBK FULL or BBK Ball bearing
- Intake for VTA BOV
- new clutch install, slave not pushing enough
- longtube header stockframed turbo with SAS?
- wich sparkplugs for E85 600 hp?
- Slow Evo!!
- Do your 60k service ahead of schedule!!
- cometic or stock headgasket and L19 studs
- Diveter valve that doesnt flutter
- strange noise and car buck on acceleration
- wrist pin pressing in/out question
- Oil Change...
- Seafoam?
- Ideas for a new setup
- Starter disengaging but still grinding
- Low Compression on all 4 cylinders
- Machine Shop for Valve Job in Eastern PA?
- Transfer case differences
- ebay oil pump and waterpump
- Possibly stupid question inside...
- Petrol on Pistons Head?
- High hp guys do I need up grade keepers
- Milky Oil issue
- 3rd Spun bearing on motor in 1 yr!
- Idle issues after BOV install... NOT your typical atmospheric BOV thread...
- Exhaust manifold suggestions??
- 5-speed trans rebuild - shimming & selecting a spacer.
- Very torn on which turbo?????
- Worn valve guides??
- Oil flow inside engine?
- Cam Cap Bolt Size
- lifter bleeding counterpoint
- upgrade oem lifters
- why wiesco 1400HD pistons over wiesco non HD
- Engine hesitation after new clutch?
- Non MIVEC 4g64 owners. What timing belt and settings do you use?
- Turbo map info
- Clutch chatter?
- Looking for some clutch advice
- Boomba Racing Fuel Rail VS OEM Fuel Rail
- what turbo timer is this?
- 4g64 with lancershop wiseco stroker kit?
- FP71HTA vs BBK Full
- Which oil to use ? Recon engine
- tial newb question...
- Do i need a bigger WG?
- Evo X alternator in Evo VIII
- aem uego no gauge redout but does have power??
- E85 and water
- AYC error codes 32&34 - what does these mean
- drivetrain vibration and clunking
- HKS 7460 GTII 'Kai' - Failures?
- EVO VI clutch question..
- 73hta boosting issues
- Ticking noise at idle only not lifters
- HELP!!! Car Wont Start After COP's!!!
- Evo ix 2.3l build help!?!?
- Carbon build up affecting idle
- Hks 264/272
- Issue after BR double pump install...help!!
- AEM EMS to Stock ECU SD
- P0134....I'm 90% sure the O2 sensor is good
- need help please - how to know faulty AYC ?
- 2.4 long rods??
- Reese Tuning Cams??
- Havin a oil leak prob....ned help
- Injector question..
- Tial QR, from recirculated to vent to atmosphere
- will an oil catch can help me?
- Intercooler
- 3rd gear grind Help
- FP Greeen BB results???
- Stainless Steel/Show Quality Engine Fastener Kit?
- Wiseco HD piston users in here......
- Oil every where :(
- Whos running a Walbro 400LPH FP?
- FMIC question?
- Turbo Questions
- Running on wastegate but not wastegate boost?
- Not the way i wanted to start of the 2012 season!
- Evo 8 stock turbo and wastegate
- transfer box isue
- transfer box isue
- OEM evo 9 air box
- where to buy composite h/gasket ?
- Thoughts on 70 mm/88mm billet wheel
- builting evo head questions
- HEAD Gurus
- Best cluth for 500whp daily driver
- 162mm Conrod
- oil drain for evolution 6
- Can't go full throttle without getting knock!
- Magnus Sheet Metal Intake Manifold Differences
- clutch
- OEM h/gaskets - mls or composite ?
- Question on CR and Gas Octane
- Looking for Feedback on Kelford 264/260
- Differential Clunk fix opinions.
- Very low compression! Help!
- Would you run this crank
- 2.75 mufflers/resonators available in US ?
- At what point does the stock FPR become insufficient?
- Tie Rod End Boot Replacement.
- Been doin homework and looks like time for clutch....
- Setup Help?????
- Spark plug gap question...?
- blown turbo?
- hoot or whine from clutch?????? not TC
- Aftermarket Throttle Bodies
- Why I will never go back to a 2.0L
- HELP!!! engine breaking up at higher RPMs
- Wich engine oil do you recomend
- Evo IX clutch comes up only halfway
- Mbc question..
- Aftermarket radiator question
- Intercooler question
- my timing belt slipped!!
- Anyone use Green Performance Air Filters?
- Clutch replacement in pa? I need it in ASAP !!!
- should i get a new flywheel
- wpc treatment?
- P0340 Code Update w carnage pics
- Crazy lift cams
- My 9 Sec 2.0 LR Build - 2012
- How much power can original Coils make?
- Oversized valves worth it
- Going twin disk
- advise needed. Map FB 70mm tb vs Mil.Spec 65mm tb
- vacuum lines
- Comp Stage 3.5 Street/Strip Series 2600 Clutch Kit
- (Video) Boost Activated Cutout - My new favorite mod!
- AMS 900X Turbo=?
- Megan manifold - any good ?
- Clutch problem
- 4g64 headgaskets
- Pedal to the floor. HELP!
- 5speed conversion
- 5speed conversion
- Jmf Evo Stock replacement Tubular / Fp black
- How to get more HP/TQ up top on Evo 9 Turbo
- 5th gear vibe
- Help me with my drivetrain noise.
- drive train noise
- Building my first engine for a local customer
- Belts Replacement?
- bov fluttering at ~0 vac/boost
- Need some input on turbos
- Turbo question?
- Evo engine rough and dies at idle..sometimes?
- Fuel system cleaner when running e-85
- ticking/burning oil
- Collant Question
- Downpipe Bolts
- Who is still on their original clutch?
- exhaust flange
- New Megan 02 housing
- Oil Pump Upgrade. Need or not?
- Help with loud ticking sound from the Fuel Pressure Regulator area
- My Nightmare...
- Weird clicking
- adjust vacuum with balance shaft delete?
- evo 9 greddy cams!!?
- vacuum lines?
- some CBRD 2.3's and turbo kits- inside ;)
- evo 8 transmission no quick shift
- Shuddering at turns
- How Can I change from internal to external wastegate?
- turbo header question
- 4.11 final drive can't decide?!
- Anti lag and launch control for a evo 9
- Mivec Cam gear question.
- Best oil brands for first oil change??
- hx35 oil line questions
- good compression, bad leak down. Why?
- Wastegate code
- Throwing PO300, PO335, AND P0340 codes NEED HELP
- Transfer Case Death Whine?? *Video inside
- OEM headgasket question
- High idle related to oil pressure?
- Evo 8 turbo MAX psi?
- Something about the Manley Billet Crank
- Will adding passenger side mount lessen vibration ?
- 5 speed to 6 speed swap
- Help Precision 6266 CEA Advice Needed
- Just pulled the 03 Evo motor. What to do now
- difference between HTA & non HTA
- Would this cause my clutch to slip??
- Any systoms when Compression is down?
- How do I know if my turbo is shot?
- First gear lock out
- Main studs causing problems?
- Hard Shifts Grind From 2nd To 3rd
- ACT 6 Puck Race Clutch. DD?
- 2.3 BC stroker and FP black turbo.... Is this boost flutter? Or BOV flutter? Or what?
- How to get such exhaust sound?
- Brake kit options for 15" wheels.
- Sticking injectors when letting off throttle completely
- EVO rod weights
- Exedy Twin Clutch BANG - Diagnose?
- 340 intank & 044 inline
- What thrust bearing is better for evo 8 eagle crank
- Compressor surge- what are the options?
- TiAL vs Synapse BOV's for 700whp+
- Evo 8 engine build
- need some injector help:(
- Do I need bigger injectors for my setup?
- Help me decide?!?!? FP Black, ATP GTX3076 or ATP GT3071 V2
- Engine for the Circuit
- ***DST built evo 8 RS***
- P0340 Cam Sensor Code Help
- Redline 75w85 gl5
- The Mellon Racing EVO head mysteriously lifted and the culprit has been found!
- camshafts
- timing belt job. what is needed/not?
- 2.3 v 2.4lr
- how to remove valve cover baffles (how to clean your valve cover)
- Cam Gear Cover
- Boomba, AEM, AMS fuel rail
- Mahle drop in pistons
- Any body using Godspeed intake manifold in a evo 9???
- Front Case/Oil Pump bolt sizes + leak
- Odd check engine light "No activity bank one o2 sensor"
- Best/cheapest place to buy Hks/Kansai or Jun surge tank/Intake manifold?
- new evo viii, and its gonna be epic!
- HELP!! bad cam sensor
- Ultimate Oil Catch Can Evo 7/8/9 +10
- Attention expert welders
- Alternative to Penn 20w50?
- Cheap way of compressing valves to get keepers out!
- My cluth is starting to go... when to replace?
- too much exhaust noise
- Gt35r parts?
- Possible Ethanol Gunk Explanation
- FP race outlet IX turbo
- Oil leak?
- kick that throttle! hold that bang.
- GTX3582R Or Pt6262
- transfer case
- Stock dv and boost?
- ACD-Tuning Autocross Map
- Help! Noise coming from the lower timing belt area - 2006 EVO IX
- My piston rings just broke in a million pieces..CHECK OUT THIS PIC!
- 3 port catch can?
