PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Turbo Info...
  2. Which will perform better?
  3. Turbo rebuild
  4. Low boost and dropping
  5. red issue on blade direction
  6. Power Steering..
  7. HELP!!! no start
  8. Setting the TPS
  9. engine light and water sucking
  10. Car shuts off with AC on.......
  11. Injector size vs power potential
  12. Drivetrain grinding and noise......
  13. FP Black?
  14. Few questions about 30k checkup
  15. Best exhaust manifold?
  16. RED LINE 75W-140: Can I use this in my transfer case?
  17. 2.2 engine and FP Red - what boost should I run ?
  18. Am i running too lean?
  19. Weird, Weird, Weird Issue!
  20. Low boost and dropping
  21. Warranty Question
  22. Idle control error
  23. Idle Control Error
  24. throttle body gasket replacement question
  25. Timing Belt Slipped
  26. turbo timer install?!
  27. black smoke when decelerating
  28. Synapse synchronic bov
  29. n2o... Why don't we see much of it?
  30. Older 4g63 parts compatability
  31. Headlight broken bracket
  32. Battery Help
  33. replacement valves
  34. Official Boomba 75mm Big Bore Throttle Body Review and Dynotesting by TTP!
  35. about ACT cluches?
  36. Bad clutch or Bad wastegate?
  37. Ceramic Coating question
  38. Tilton twin disk
  39. Problems.....
  40. Has anyone tried the Kamak HP WGAs
  41. The best forged piston money can buy!!!
  42. SFP turbo kits?anyone?
  43. FP Red vs. CBRD Version 2 BBK
  44. post cam install problems??
  45. noticed some sort of leak on driveshaft
  46. FP Green
  47. Need replacement injector clip and outter plastic clip
  48. Take a look at my slave cylinder... think its been replaced wrong
  49. Location for Greddy Oval Catch Can?
  50. Turbo Upgrade!?
  51. [ETS vs Full-Race] Twinscroll HTA3582... Opinions Needed!!!
  52. QM clutch rebuild cost?
  53. Sumping stock fuel tank
  54. 37R or P67 Billet turbo question
  55. help me get more power out of this car, what next?
  56. Precision Injector o-ring size?
  57. Turbo oil/water lines and drain tubes? what to use?
  58. Tighten' up MR 6-speed?
  59. Magnus vs Driven Innovation intake test
  60. Can't get my downpipe to seal to my manifold/ o2 help!!!
  61. 3.8" Garrett IC vs. 4" ETS IC
  62. Coolant Leak Around Back of Motor. ( With Pics )
  63. Hallman MBC install questions
  64. Help me Identify this turbo.
  65. Cams question
  66. Strange problem trying to install new spark plugs
  67. removing power steering without ams kit
  68. Any advantage to running Mitsubishi turbo kits like Buschurs over twin scroll?
  69. Fp hta green
  70. headgasket?
  71. IX owners with upgraded cams
  72. Thoughts on AMS vs. ETS IC cores
  73. Help, Issue With Turning! Loud Bang
  74. question about t-case
  75. Another stock vs aftermarket intercooler thread
  76. Weird noise under acceleration...
  77. people with big turbos please HELP!!
  78. Anyone else got a leaking Mocal oil cooler
  79. need help have qustion on turbo 9.8 to 10.5
  80. JMF race and drag manifold your thoughts
  81. What torque for manifold bolts/nuts - fsm conflics PICS inside!!
  82. will tears make this okay?
  83. Which is better: HTA35 or twin scroll HTA35 on 2.0 motor?
  84. Question about Porting Exhuast manifold
  85. Iac valve
  86. Fuel shuts off when turbo goes into boost.
  87. Deatschwerks Injectors and E85 = New motor
  88. Greddy full auto turbo timer
  89. How long did you wait for your red?
  90. Greddy T67 25G problem HELP!!!
  91. Help With Delphi Injectors part number
  92. Timingbelt Service Question
  93. ATTEN: AEM Short Ram Intake users
  94. Wastegate size
  95. Aem Intake Filter diameter size?
  96. Clutch runout numbers
  97. What cams to use with CBRD BBK FULL Turbo
  98. evo9 turbo wheel
  99. 35R with Meth Injection
  100. Which spools faster: FP HTA GT3582, FP HTA GT 3586 or PTE 6262?
  101. HELP Bolt Fell Out While Driving!!!!
  102. Finally, she is coming together! (Stroker Build)
  103. 2.3l + 20g
  104. MR Trans 4 gear stiffness
  105. problem. lines cut.
  106. opnions 4' ets intercooler
  107. Oil on spark plug
  108. Flashing SES light, did do a search....
  109. where does this line go??!!
  110. WaistGate and Boost Solenoid HELP!! Plzz!!
  111. 2 piece oil pan?
  112. Oil Filter
  113. ETS super value/gt35r/pt61 questions.
  114. Coverting GT3582 to the new HTA3586
  115. Question regarding Evo w/ACD
  116. BG Syncro Shift II Vs. Amsoil MGT
  117. Boost fell off 6psi..
  118. need help: greddy profec B spec-2
  119. aem meth kit nozzle size
  120. Question about EDM/JDM 7/8RS ACD w/o AYC pump and placement
  121. Transfer Case Install
  122. timing issues?
  123. HTA gt35r vs PT6262
  124. Clamps Size?
  125. is there something wrong with my clutch?
  126. ac delete
  127. act break in
  128. FP Red Supporting Mod. bottlenecks...
  129. Evolution 6 Setup - need to know FWD tranny
  130. Cam question for new build
  131. Upgrade path...
  132. 3'' vs 3.5'' FMIC
  133. Strange WBo2 readings -- Bad MAS?
  134. Trans swap questions
  135. misfire
  136. pulling engine
  137. Noisy ACD pump?
  138. AMS Turbo Back Exhaust with HFC and Resonated Test Pipe
  139. Amazing injectors 2200cc, no double pumper needed
  140. 05' RS "Service Engine Soon" Light Flashing, Not Solid.
  141. Kelford 280's ???? should I do it....
  142. Variable Turbine Geometry for Evo?
  143. 1/4 mile times with HTA Green?
  144. Tomei Arms 7960 Turbo
  145. Open Dump sound??How??
  146. Help! Boost only w/ full throttle and above 4,500
  147. $12-13K! How would you create 500WHP+ Monster?!?!
  148. Oil pressure sensor relocation / Summit woes
  149. Help Tapping for Oil Lines(Turbo) and Oil Gauge Senders
  150. Head work.. Am I over looking something here?
  151. Mest method to remove seized rear diff drain plug.
  152. 60k Service in San Jose area
  153. Knock on start up
  154. p0172 and stalling issue
  155. Tubular Manifold Help
  156. Intercooler Pipeing Help
  157. Engine Compatibility
  158. Starter Screech?
  159. Tranny, Rear Diff and T-case Fluids
  160. what is this?
  161. Bled My ACD thoroughly and still have all 3 Lights lit up, any ideas???
  162. In the Process of Adjusting Clutch Pedal Please help!!
  163. Any of you have any experience with these CEL/Error Codes P0462/P0183
  164. I have a bad squeal now and it seems to be the altenator pulley
  165. possible C.V. boot or axel damage ?
  166. evo mr tranny
  167. Simple questions I guess :)
  168. Headgasket questions
  169. got a CEL and Overboosting!!
  170. What to expect with a buscher head on stock block?
  171. Big Cams Cruise Tune for the Evo 8
  172. Boost cut on Evo 6 TME &
  173. act vs comp
  174. Little Noobie help
  175. Improved BBK
  176. Clutch runout numbers help
  177. How many REDs on stock block?
  178. When does the Slim Fan on an aftermarket turbo kit turn on??
  179. Blew 4th gear again Evo 2... Cryo?
  180. Looking for 170 degree thermostat
  181. Magnus help!
  182. I think I need a new sump/oil pan - help
  183. Stock boost gauge
  184. FP RED 80 or regular ???
  185. Injectors leaking boost
  186. Stock motor w/ HTA 35R?
  187. Buschur is what is needed for a reliable 9sec DD!
  188. Fp red not sure how to tell a 80mm!
  189. Bought a used turbo and found this...
  190. Amsoil Manual Tranny MTG vs Amsoil Severe Gear SVG
  191. Evo ix, fail safe? (limp mode?)
  192. Engine management needed?
  193. Help on my clutch runout #'s please
  194. How much whp will i make? do reply
  195. HKS Cams or Cosworth Cams
  196. Nisei FMIC
  197. 5757?
  198. Fp red budget build what is needed???
  199. Injector question
  200. Just put engine back together... STUMPED
  201. ac not working
  202. Backup Switch
  203. Anyone make an air filter heat shield?
  204. quick question about walbro 255lph pump
  205. Weird sound when at higher RPM.
  206. Feedback on the Buscher 35R cast manifold kit
  207. Trying to drop the tranny
  208. 2.3 stroker Rev
  209. Stripped Oil Pump Screw, help please
  210. boost leak symptoms?
  211. AGP vs Agency power lower solid front engine mount question
  212. Twin disk help!!
  213. Donut Gasket, where to buy???
  214. Advice on setup
  215. Mitsubishi Lancer Evolution Garrett Turbocharger Products article
  216. Pushing coolant?
  217. Priming the Engine?
  218. AMS manual bc issues?
  219. boost cutting
  220. broken IX transfer case
  221. Exhaust manifold help
  222. oem exhaust
  223. ECU part
  224. 2003 EVO Idle Stall/Dies
  225. GSC S2 + Stock Evo IX Turbo
  226. Were to buy replacement rear o2?
  227. Motec M800 Universal vs M800 OEM PnP - Customize
  228. Undoing Blitz "4mm hose join" ??
  229. Another ACT lock up..!
  230. ACD Lights Turn On During Long Drives
  231. bullseye turbos
  232. Rebuilding an EVO; ACD Unknowns
  233. Found this in my combustion chamber...help
  234. build 2.0L & E-85 take a look!!!
  235. Anybody getting boost creep issues with maperformance o2 dump pipe?
  236. Replacing Stock Vacuum Lines
  237. Imaginary build questions
  238. EVO 8 OEM rods vs 1G DSM Bog Rods
  239. 3rd gear issue.. trying to fix today
  240. Question on my car
  241. Price for rebuilding synchros
  242. Help..Having Boost Issues
  243. Difference between Exedy SD vs HD...
  244. wierd WOT issue...Help
  245. Timing mark question
  246. Evo 8 3-bar MAP Question
  247. clutch makes a sqeaky sound when down shifting.
  248. 2.75" downpipe to 3" test pipe - which gasket to use?
  249. Help please - clutch line bleeding
  250. Advice please!
