PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 [122] 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. 2 Exhausts
  2. GSC S1's or GSC S2's
  3. SES light flashing all the time ! help !
  4. FP Green, Megan 02 housing, Forge WGA
  5. Anyone surging on their FPgreen setup?? High gear low RPM surging on spool up?
  6. ExoticSpeed Catback?
  7. Redline light shockproof and LSD additive ok in our rear diffs???
  8. Buschur Coil On Plug ignition system!
  9. Grindin 3rd & 4th
  10. Noob Question
  11. gas mileage poor after intake and exhaust
  12. Titanium Retainers vs. Chro-Molly Retainers?
  13. Indy Intake Manifold power bands and availability.
  14. MD dyno tune of my 03 evo
  15. Successful USDM Evo 8 ECU swap into Evo 6 TME
  16. NGK Racing series spark plugs for Evo 9
  17. plz help
  18. Hta35r VS Hta37r ??
  19. Heavy Rain
  20. AEM UEGO Install
  21. need some advice, p0300
  22. Invidia O2Housing
  23. A full 37r build top to bottom...COMPLETE!
  24. Car trouble, Died while driving
  25. Evo VIII - HKS 2835 KIT
  26. An fittings on stock hardlines (fittings?)
  27. Forced Performance Evo Red Turbo data
  28. what is GM boost solenoid?
  29. Car died when alternator went out, Now no power, Please Help.
  30. who has a Eco maf translator in stock?
  31. clutch for light upgrades?
  32. Please help diagnose an issue with my setup
  33. Lars takes the AMS 2.3RR/GT42 and runs 9.36@152...ON E85!!!!
  34. Oil Pressure Concern
  35. Tapping Noise!!??
  36. Wow the IX bov can be loud!
  37. White smoke?
  38. Oil Pressure
  39. extreme power cut falls on face!!!
  40. i Hate My Evo! help me!
  41. Greddy TT features?
  42. Load before & after mods
  43. Low Boost
  44. need help, broken pressure plate bolt
  45. GT4294R preliminary results....
  46. need help: installing exedy twin HD clutch
  47. Soon-to-be EVO IX RS owner looking for 400whp on stock turbo...
  48. Has anyone actually dyno'd a Fujitsubo RM-01A Exhaust and seen if it lost sig. power?
  49. Rear Diff bearings?
  50. Are there 2 version of the Invidia o2 housing?
  51. Broken Front diff
  52. pump issues
  53. Devo Quartermaster vs carbonetics twin/triple
  54. New Agency Power GT30R Kit
  55. my evo wont start
  56. Clutch Master cylinder or just cylinder
  57. Subframe Bolt Stripped - Any Ideas
  58. Cam gears now or later?
  59. Boost issue
  60. need help
  61. Really Hard To Shift In and Out 6th
  62. ShepTrans or Team RIP
  63. GSC Single Valve Springs w/Chro-Molly Retainers...
  64. The Perfect Turbo-Back Exhaust?
  65. Buschur V Full Blower in-tank dual Pump
  66. Making less power - and having more fun ? Gt42 to Gt37
  67. hks264s to hks272s on fp green
  68. APS or GFB????
  69. where to find evo 5 push style clutch cover
  70. Walbro Whining Noise
  71. Anybody have the apexi rx6 turbo kit? I have ?'s for you!
  72. Buying A New Clutch
  73. Abnormal noise...
  74. Full Blown Dual Pump System - Things You Should Know
  75. Oil Temp in Extreme Hot Weather
  76. CEL flashing..NO CODES??!!
  77. T Case Ring and Pinion
  78. Check Engine Light: Speed Sensor Code!
  79. Was sold the wrong f-ing clutch
  80. I need a hot side for stock IX turbo
  81. Calling out all GSC S1 cam owners..
  82. Should I upgrade APR head studs?
  83. sparco intercooler?
  84. fidanza 2.1 vs ACT HD
  85. Exhaust Help...think I got screwed
  86. Cam timming: one tooth off = how many degrees +/-?
  87. will this pass smog?
  88. GT35R to 30R
  89. Exhaust help
  90. CIMOTORSPORTS??! HELP anyone dealt with them??
  91. Kelford 280's Idle
  92. Transfer Case questions
  93. Gruppe S manifold
  94. Reverse gear problem
  95. Another pump gas beast hits the streets of Ohio
  96. Exedy Twin to Triple from AMS - Plus poll: How long for break-in?
  97. Boost Leak Test
  98. 180 psi is this too high
  99. New Mods, Suggestions???
  100. Installed Forge UNOS MBC!!!
  101. damage to intercooler... Can it be repaired???
  102. Gates Timing belt vs. Greddy or HKS timing belt. Which is better?
  103. question on mechanical CEL Fix
  104. ACD Lights/Warranty Rouen Mitsubishi
  105. Who needs the A/C?
  106. revolver 280's stock valvetrain?
  107. 9sec9/OKIX's EVO, ROUND TWO!
  108. 373ft-lbs / 352awhp stock turbo, 91 octane
  109. Ported Head Gains...
  110. clicking sound after exedy stage II and fidanza flywheel install
  111. DTM's RB 2.3 and HeadGames Make a Perfect match!!
  112. Hks Twin Disk Or Exedy Twin Disk Hd
  113. What next?
  114. Epoxy Resin Maf Honeycomb
  115. Mistake not doing O2 housing with fp green
  116. GSC1's VS. Cossie M2's
  117. Fuel Rail Problem
  118. Buschur 3065 Turbo Upgrade Q's
  119. turbo and coolent
  120. need some help guys ,,,plzzz
  121. acd fluids low!!! help
  122. Hissing sound at idle near firewall
  123. ets exhaust
  124. bad fan belt sound
  125. Cold Clutch/Flywheel Howl
  126. How Do These Plugs Look (PICS)
  127. 750cc injectors & 255l fuel pump - Maxed out?
  128. Clutch?FlyWheel Questions
  129. stock turbo taking a dump?
  130. Alternatives to mini-battery on blow-thru setup?
  131. First time Evo 9 Transmission replacement
  132. HELP! licp keeps popping off
  133. Questions... HKS DLI, 1000cc and more
  134. Urethane bushings specific to Evo? esp. the rear hanger bolted to the Subframe?
  135. Can someone help w/ AEM NLTS
  136. Time for new timing belt
  137. t3 manifold
  138. twin dump vs single dump
  139. acd fluid level check
  140. help with turbo upgrade!
  141. Valvetrain rattling, major misfire.....
  142. greddy intercooler
  143. Got dynoed today, not sure what to think
  144. NLTS questions
  145. Got about 300$ what should next mod be?
  146. Atp
  147. EVO 8 FP 4R Cam
  148. MR OEM oil drain plug vs non-MR
  149. Redline for HKS 272
  150. Car shakes at idle with AC on.
  151. Aps Bov Help!! Asap!!
  152. Magnus Intake
  153. Help Please!!
  154. Turbo Guru's Opinion
  155. Think I fried my clutch tonight
  156. Idle Problems...need new IAC?
  157. clutch question
  158. BR Racing, parts testing, new best MPH and some thanks.
  159. HELP! No Boost!
  160. blew motor, suggestions?
  161. Nitrous on stock head and block?
  162. We did Steve's Clutch job yesterday!(TTP Tuned 377 WHP Mustang dyno)
  163. What's this/wrong?
  164. Could a Clutch cause loss of power?
  165. My Transfer Case whine problem solved... or solved?
  166. what else should i do???
  167. AWD Motorsports/Jestr tuned evo ix fpgreen. 424 on pump!!
  168. Difference between Exedy Twin SD vs. Exedy Twin HD?
  169. Boost pill and truboost
  170. Additional Parts Needed for AMS GT35RL Kit?
  171. What Happens...Valve Float Video
  172. Evo 9 stock turbo,upgraded intake manifold and throttlebody ?????
  173. thanks fsms
  174. Boost Issue
  175. leakdown results... suggestions?
  176. clutch question?
  177. what do u think???
  178. my shifter feels clunky...
  179. Exedy tripple matallic clutch problem!
  180. RRE Perforated/Louvered Resonators Question
  181. My Twin Pump custom build
  182. Oil return line..
  183. Shift noise??
  184. New for 2008. HKS AFK
  185. Cant get Diaqueen in time...Redline?
  186. any one using these?
  187. Results from Precision 6265 Turbo on Evo IX!!! 469whp on Pump!!
  188. Boost controller problem(maybe)
  189. blown oil pump seal
  190. sbr stage 3 head how much hp gain ?
  191. Evo ix T Case
  192. HKS valcon pro
  193. Blew my stage 2 shep transfercase tonight.
  194. Race Head
  195. Fluid capacities and recommended lubrications
  196. Need a little help here please
  197. Dyno sheet of E85 Tunned @ AMS
  198. Just how bad are the MR 6-Speed Transmissions?
  199. Oil Light Flickering
  200. Is there a slightly bigger turbo than the Green?
  201. Cams or Fuel pump?
  202. 320 Whp 309 Tq
  203. oww, my drivetrain! =(
  204. M2 Questions
  205. Unstable AFR at low throttle
  206. New FP White turbo
  207. BR Evolution Custom Dual Valve Spring ?
  208. Anyone running the TURBOXS HYBRID 50/50 BOV?
  209. Clutch Suggestions...
  210. Got my car dyno tuned at AMS today...you will not believe what they found in my BOV!?
  211. 5and6 Speed Manual which is better?
  212. Blown clutch<good news
  213. tranny/t-case fluid question (no, not about what kind to use)
  214. Difficulty getting into 5th after shifter bushings
  215. problems...knock sensor?
  216. Evo 8 5 speed with evo 9 first gear
  217. Help, engine shot dawn
  218. who sells aftermarket oil coolers?
  219. Popping noise @ high RPM @ 6500 til rev limit, poping noise then Stutter..SPARK PLUG?
  220. Should I change my spark plugs? Please advice!
  221. Top Level Hot Import Nights 769hp/601tq
  222. HKS SSQV Racing type II vs Tial vs ....
  223. E85 numbers from AMS and other issues..
  224. Steady boost (tru boost)
  225. ETS Turbo Back?
  226. megan exhaust
  227. mind boggled
  228. ACD Fluid??
  229. Boost stays at 12 psi
  230. Compression Results
  231. VIII turbo vs IX turbo
  232. evo 9 front o2 sensor q.
  233. Engine help
  234. Engine Problem
  235. CBRD and JMfabrications stuff...
  236. Max WHP on 680 injectors??
  237. Vendor Help, exedy Triple Cerametallic Disc and plates
  238. What do you think? (exhaust question)
  239. Installed a HeadGames head: dyno tested – new records!
  240. Indy Evo / Wilson V0 Street Manifolds In Process!!!
  241. ACT clutch/flywheel jobs. Lots of pics!
  242. Megan or Greddy Ti-C CBE
  243. DynoTuning
  244. Front Clunking noise
  245. BR's dyno testing and new parts development continues...
  246. Temps of our exhaust manifolds?
  247. Are O2 Sensors Delicate?
  248. New Synapse MBC: Looking for pre-market feedback
  249. ARC UICP Fitment. ??? Please help...
  250. Getting the EVO ready for action!
