PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Rod clearance issue with block. Need some advice/ help.
  2. Where did you install your Manual Boost Controller?
  3. injen piping vs ets and ams licp
  4. evo 8 bov question
  5. Tial BOV leaking during Boost Leak Test
  6. Which Clutch is Best for My Build???
  7. My new Evo IX has issues (big ones)
  8. transfer case
  9. Squash Performance Evo 7/8/9 Fuel System - tester needed ASAP
  10. Cylinder head oil passage question
  11. Found that I installed 1 Eagle rod backwards, is this bad?
  12. Wastegate Leak! Please help!
  13. questions about a TCASE
  14. Best Transmission and Diffrential Oil
  15. Boost controller not showing boost, only vacuum
  16. Does the Evo 8 Transmission/Clutch use a Pilot Bearing?
  17. HP COMPAQ 6720s laptop battery problem
  18. Transmission parts for 5spd
  19. Air fuel ratio in winter
  20. Mivec Delete
  21. coupler size for stock evo 8 turbo?
  22. anti freeze question
  23. FP 18psi wga, 14 psi max?
  24. E85, should I do it?
  25. Quick question about 4G64 timing question
  26. Reminder everyone, check your engine bay grounds!
  27. double post
  28. Evo 8 vs 9 Rear O2 Sensor connector
  29. Machinists or technical smarts needed inside....
  30. Share your drivetrain noises!!
  31. Stutters a bit
  32. stick with 35r or switch to hta green?
  33. Help splitting turbo
  34. ARP Main stud woes. NEED ENGINE BUILDERS ADVISE
  35. Question about oil squirters...
  36. will 1g dsm injectors work on lancer evo 8?
  37. oil feed question
  38. Seafoam at 45k miles? yes or no?
  39. Will there be any harm by running 100% water without Meth?
  40. Loud Timing belt?
  41. ACT clutch retaining clip?
  42. Quaiffe t/case?
  43. Changing wastegate spring?
  44. Transmission fluid leaking
  45. Turbo troubles maybe
  46. Some drivetrain stuff thats annoying me
  47. 5 bolt turbine housing vs gt vband
  48. Oil cooler
  49. Carbonetics twin disk
  50. Who's Running a Walbro (F90000267) 416LPH E85 Compatible Fuel Pump?
  51. dowel pin needed on crank??
  52. Can some one tell me if this is stock??
  53. Do this GSC cams affects my hp?
  54. Bad Tune?!
  55. injen piping vs ets
  56. stock turbo not efficient for 2.3 ?
  57. Help! My clutch does not disengage!
  58. 18g turbo
  59. Evo 8 build advice
  60. boost reference post intercooler?
  61. Zeitronix 3.5 Bar people come in
  62. Front support member bar question
  63. Anyone know the part # of evo 8 2nd gear
  64. Deciding tonight Gaters or GMB waterpump replacement
  65. Are the front driveshafts on an Evo 8 bigger than rear?
  66. Is there a way to know what type of Cams I have?
  67. TIMING BELT: Input/Picture request
  68. high compression question
  69. Is there a way to know what type of cams I have?
  70. drivetrain slop
  71. Any good aftermarket Cone Airfilter out there?
  72. HELP! Clutch master cylinder question...
  73. P0135...Searched, read and measure....
  74. Idle Problem :(
  75. Throttle kicker for a rotational idle
  76. Tranmission Oil in the Tcase AGAIN WTF...
  77. battery relocation
  78. Evo shuts down
  79. Anyone know where I can find this??
  80. Anyone know where I can find this??
  81. Balance shaft belt tension?
  82. Evo noob questions couldnt find in search
  83. Evo 8/9 injectors
  84. 2.4 questions
  85. Let's talk about burning oil:
  86. Exedy twin HD Help with Stm Fork clutch
  87. Car suddenly stumbling all over the place
  88. Power hungry! Next step?
  89. hta 71 OR hta 73
  90. 3rd to 4th help
  91. 2.3 stroker build parts suggestions
  92. Exedy triple carbon can't be converted to triple cerametallic? or is it possible?
  93. Transmission leak problem
  94. Greddy spec V fmic with E 85?
  95. can i use redline oil for a tans oil change?>
  96. Leaningn out Issues
  97. Finding TDC on Compression
  98. Any feedback on a Synergy 20G?
  99. tial pinched diaphragm causing over boosting
  100. What Head gasket size should I use ?
  101. QuarterMaster 8 leg install
  102. Death Whine Possibly?
  103. Good deal on the 4.11
  104. Rich idle and lean WOT problem
  105. FTW Racing fuel results!!! E85 vs Ftw PurpleDyno inside!!
  106. Engine noise diagnostics
  107. OK... What broke this time?
  108. ETS LICP touching A/C rubber hose
  109. Kinugawa Anti-Surge Turbo 20G Turbo Housing on Evo 9
  110. Hey Evo guys I need your help
  111. Evo 8 and evo 9 transmission question. Interchangeable?
  112. HELP evo 8 keeps dying on me.
  113. Recent crank case pressure and screwed fuel trims?
  114. Aluminum discharge vband flange for mvs38
  115. Oil Pump screw help
  116. Tial v44 over boosting problem
  117. Evo 8 Top Speed?
  118. Gear oil change need info
  119. Really weird boost problem going on!!!
  120. Boost Creep Question
  121. Piston Slab @ Cylinder 1?
  122. clutch problem? need some insight
  123. quick stall question
  124. bearings and cold weather
  125. 03 evo 8 clicking on turns and whinning in first deceleration help
  126. Ebay turbo 20G any success?
  127. Radiator cooling fan relay
  128. Well Something broke....
  129. Exedy carbon twin disc to triple conversion?
  130. HELP power steering line...
  131. Strange sound in my evo 5 trans
  132. evo IV thermostat
  133. Erratic boost and lean under WOT
  134. Front cover: special bolt for stub shaft on oil pump?
  135. ACT xtss with an act streetlite or an exedy flywheel.
  136. name this connector!
  137. Anything you can do to make an Aftermarket Turbo Spool Faster?
  138. Evo VIII 8 Mivec wiring help
  139. Looking for input on my car and mods.
  140. rear axles?
  141. Coolant temperature rises
  142. Does Evo 9 help to get more HP?
  143. Remove unused boost nipple from gsbcs?
  144. Best way to run the Double Pumper?
  145. Lancer evo 03 New owner =)
  146. how hot is hot?
  147. Partial throttle cut out
  148. Car won't start once warm up
  149. Evo 9 GSR squeaky sound at higher rpm w/ video
  150. Evo IX strange grinding noise on startup, vid included
  151. 6466 or JB 6765?
  152. o2 sensor
  153. Fuel cutting at WOT
  154. EVO Front/Side exhaust
  155. Metal clank when shifting into 3rd, changing trans fluid
  156. Evo 8/9 turbo hot side
  157. Recommended BOV
  158. Got headstuds?
  159. Let's talk clutches, shall we
  160. 10.5 single flapper hot side vs. 10.5 dual flapper hot side
  161. oil filter housing leak
  162. Air Conditioner
  163. hta35r
  164. Need advice: Tial 44mm wastegate setup with HKS EVC Boost controller
  165. Violent shudder or shaking upon full boost / load HELP!
  166. play on FP Red
  167. Evo 8 Megan Racing Exhaust
  168. Air coming out of engine during boost leak test. Stock turbo
  169. Valves Keep Touching Pistons...What to do?
  170. Cam question
  171. Sweet new Catch Can
  172. What cams are the best for a 2.3l with a lots of mods
  173. Idle/Driving Issues
  174. Sputter and maybe misfire? At around 2k rpms HELP. Ive searched
  175. AMS f1i manifold
  176. greddy Bov Help
  177. 04 EVO Misfire issue
  178. Is the EVO 8 stoc wastegate Vacuum controled, not boost?
  179. Any experience with MAP's 2000cc injectors?
  180. small coolant leak
  181. FP black red ? Turbo?
  182. How do you measure main bearing crush?
  183. What cams are these???
  184. Sub $100 Dual Catch-can Setup
  185. Getting the most out of an fp black on pump gas
  186. turbo switch
  187. help Identifying connector
  188. Where is the fuel pump fuse or relay?
  189. Low Trims floating?
  190. Anyone using a low temp thermostat?
  191. Injector #3 leaking fuel at the bottom [brand new] o-ring.
  192. Plugs
  193. Rpm Dropping!! Help
  194. The Perfect fuel and system at 700 awhp
  195. Blouch 760 XT-R Turbo
  196. Are Evo 8 & Evo IX Crankshafts the same?
  197. Ticking sound, mostly when cold
  198. 6 Speed Reverse Issue
  199. exedy twin clutch how can you tell if its in a car
  200. Throttle Body Research
  201. Shifting issues
  202. Running Rich?
  203. Grinding in 5th?
  204. rebuild gt to gtx
  205. need help asap no spark no fuel from injectors no start
  206. Uh-oh! Gearbox woes..
  207. FP black upgrade price?
  208. turbo advice
  209. changing out turbine housings??!
  210. Taking Off Camshaft Sensor Support
  211. Why suddenly Timing jumps around during idle logging?
  212. A Whining Noise a high speeds
  213. S90 TPS Adjustment problem
  214. Some GT30 HTA questions .
  215. power clutch!
  216. boost help
  217. New times with BR clutchless 4 speed
  218. Rotella 15w40 UOA
  219. wastegate dump tube question!
  220. which 2 step should i buy?
  221. whats teh proper way to bleed a hydraulic release bearing?
  222. 600hp high boost, when do i o-ring the block???
  223. low revs!! GSC 272/272
  224. Copper colord metal shavings in oil pan?
  225. Crank bore honed to outer limit - ok for high performance build?
  226. Strange coffee grinder noise off throttle
  227. Evo 8 Mystery Bracket
  228. Harness for Stock Evo 9 BCS
  229. weird clutch noises
  230. Pic Request: ATP GT3076R
  231. Looking to buy an evo need some advice
  232. BOV Sounds like someone kicked a dog
  233. Evo 9 sounds like a subaru
  234. Exedy Twin HD won't disengage...help!
  235. 2.0 Long Rod pistons?
  236. Magnus SMIM "RACE"
  237. 03 Evo 8, exhaust question!
  238. readiness?
  239. acd pump fluid question
  240. IX Oil Pressure Problems: Solved
  241. Metal plate between engine and trans...
  242. PTE Just came out with 3 new turbos
  243. Anyone using 71mm+ turbos?
  244. First gear whine
  245. need some help!
  246. Check your Clutch Fork Stops!
  247. Engine Rattle/Vibration
  248. Boost gauge install. Help!
  249. Opinions/experience needed on fueling
  250. CP Pistons
