- 2.3 Build....Which Pistons?
- TOB and pressure plate help
- Clutch Help
- FABGUY EVO8 Build Milspec Carbon & Kevlar
- Oil spraying out of filler cap, head being pressurized under boost???
- Odd fuel cut/starvation
- AMS VS. HKS. VS MEGAN RACING exhaust
- Indication of boost leak?
- Timing belt installed wrong?
- balance shaft question
- How to tell if i need to replace intermediate plate in twin disk
- knocking noise coming somewhere
- What is this sound?
- bored head gasket
- Shed some light?
- Final verdict (IMO) on oil cooler vs. no cooler debate
- IX oil temp sensor ripped away.
- i need parts willing to pick up nyc area
- Pics needed US spec rear diff fron X member bodey mounts please .
- Valve Guide Seals? Help.
- any experience with manley cranks , forge or billet
- Help Evo VI motor in an Evo VIII
- Do I need a 4" intake pipe for the HTA Green?
- Transmission rebuild and new clutch flywheel trouble
- Clutch problem
- Stock air box brackets?
- AMS 850R owners
- sputters at WOT
- question on tps sensor..
- 6262 T3 .82ar vs 6765 T3 .63ar
- Normal Idle AFR's??
- 2.4 Long rod rev limit suggestions?
- Replacing 3.312:1 diff with 3.307:1 diff
- FP Red with Garrett Housings ?
- Rear Diff clutch plates installed incorrectly from factory
- REALLY need input, advice, and opinions. (engine builders/gurus)
- Rough Idle, no power
- Is the ARC heatshield discontinued?
- advice, clutch, Spec mini twin clutch
- Advice please, car wont stay running when warm
- Congrats Mike S.
- Evo 4 downpipe
- qtp cutout downpipe on evo 8
- Suddenly running lean and missing while cruising...
- Wheel bearing
- Outlander and evo 8 water pump the same??
- Difference between 2004 and 2006 Viii Engines
- What motor oil should i use?eagle rods,wiseco pistons, fs635 turbo
- clutch master question?
- Rear diff leak (pics inside)
- ATF through axle seal
- Clutch on it's last limb? Bucks in 4th gear
- AMSOIL airfilter
- Timing belt noise..
- I did a FULL BUILD and my Car wont start?
- ACL bearings
- AN radiator hoses What size to use?????
- Pulling WG line off for max boost
- Drilling Evo 7 manifold for MAP sensor
- Evo 5 - Hesitant on WOT above 5000 rpm
- Paint chipping inside oil pan?
- Contraindications for using Motul gear 300 in 6spd/TC/rear diff?
- Hallman MBC ?
- Mysterious Water Pump Failure
- Built evo act hd street vs 6 puck
- Rear Diff Evo 8 and 9 the same?
- QM v2 owners report in
- Max rev limit for std 2.4
- buschur racing solid diff mounts. any gain from these?
- Leaning out up top
- BBK Full Rebuild...
- Whining narrowed to serpentine belt pulleys....Now what?
- Full Blown dual hanger fuel gauge problem?
- Got turbo drama need part info/suiggestions...
- Anyone running without Front Bumper Crash Bar
- Full Race/ETS Exhaust Manifold (T3 Single Scroll )
- What turbo setup should I pick Help!
- Input shaft bearing replacement
- My Little White INLINE RACING EVO
- please help me find mysterious oil leak
- egr help
- What to upgrade?
- Hydraulic Release Bearing ...
- cracked rings???
- EVO 6 head same as EVO 9?
- exhaust leak/ slow spool stock 03 turbo 100k
- clutch help
- 800 whp build list?
- clank noise from clutch area with new clutch
- Car is short of power , but why??
- Has anyone actually pulled a FP turbo apart before?
- Really weird noise from passenger side of the engine
- Evo 9 & 600 HP Project
- Tranny out of car, 3&4 are sticky
- I lauch my car 5 or 6 times a week, what clutch should I buy?
- injector question
- Cam help please! Best cam for stock frame turbo/ Road racing
- Qartermaster Twin VS Exedy Tripple
- Help with transmission and random. please?
- Which seal is leaking?
- slow spool - bad BCS or WG
- ported head and cams, or cams and $ for something else
- engine still ticking after lifter change
- which exedy should i use?????
- Spark Problem after cruise or full throttle...
- ETS Intake Install #FAIL
- cam install help
- eliminating bpv = more tq?
- this time it's GSC vs. supertech
- 600 AWHP EVO 6 project with your help ( updated)
- evo 6 4g63t clutch replacement
- DC sport True 3" down pipe??
- Slave rod fell out.
- thrust bearing
- Clutch issues - recomendations?
- ACT clutch adjustment question difficult to engage at a stop
- Spec twin disc ST trim...How do you like it for DD
- Something wrong with my evo
- T-case tail bolts?
- What cams for HKS 7460 turbo?
- Running Out of Fuel - Video Inside*
- FP WG actuator question!
- Mpz magnetic friction reducer
- Can we remove the Engine Oil Thermostat?
- Replacement air filter for Injen intake.
- E85??
- 17psi wastegate actuator=better top end?
- Underhood Fuel Pressure Gauge
- Stock pressure plate aftermarket disk?
- Question about bad rings possibly
- CBRD- Something unsual inside-
- how much difference in spool from 8.5:1 vs 10.0:1
- FP 5R cams vs Kelford 280
- Late Spool
- Evolution Motor Sports Diverter Valve
- I found some piston damage, need your input, pics inside.
- issue with my evo.. help!
- Cbrd custom exhaust manifold! It's nasty!
- What power or numbers am I looking at??
- Engine Noise Question
- AEM Series 1 VS series 2
- 4th gear grinding when downshift.. whats the problem?
- Brian Crower springs and retainers VS. GSC Beehive Springs
- Evo IX stock cam lift??
- World's cheapest 2.4L Build
- Roll off WOT smoke?
- Turbo boost level problem.
- Can someone confirm i have dialed my cams in correctly???
- Twin scroll vs Single scroll housings flow equivalences
- Twin Scroll T4 with Recirculated Wastegates?
- NonACD Tcase with Wavetrac.. What fluid?
- FP Red Owners with 2.3 or 2.4 engines please reply
- cylinder heads differences HELP!
- 5 speed sheptrans won't go from 3rd to 2nd
- No acd lights ! Help !!
- pro/con on deleting the pcv valve
- best 272 cam on stock valve spring
- what is the best low expansion alloy Piston?
- Piston Questions
- crankshaft endplay evo 8 engine
- ever seen a clutch fork do this?
- MR 5 speed swap
- Please help identifying ECU wire color for narrowband input PICS
- Help! Best turbo/motor set-up for Time Attack and Road Racing?
- GTX 3076R (0.63 or 0.82) On Build 2.0L
- I need help
- Vibrant MAF Adapter
- I have a question everyone
- How can I do that??? fire!!!!
- sloppy clutch feeling after rebuild?
- How to remove intake manifold stud on the head?
- A/C compressor stays on
- AC on, idle problem
- Aftermarket diff advice
- Aftermarket mount question... noise?
- Is my engine safe to tune?
- Injen intake with stock uicp?
- Flywheel housing cover help
- Check Engine problem
- How to Improve my GT3076R Response?
- need help on remove engine!
- HKS RS Intake Installed AFR Changes
- Motor sputters with clutch in
- Car will not start please help
- Cam decision/guidance
- Evo trans mesurments
- i need help!! in a bad way w/ motor problems
- LICP Coupler Angle
- Clutch pedal sticking to the floor!
- 6-Speed fluid in 5-Speed trans??
- Project FP Black DBB
- Oil from head to turbo plug
- i need a new clutch
- Clutch
- Possible bad synchros? Or what else could it be?..
- Compressor Surge & Stalling in1st Gear Due to Something Other Than BOV?
- Apexi Intake + Evolution 8
- Head gasket leaking?
- Need some help/advice deciding on turbo and injectors
- ADVICE, 2.3l comp tbb turbo 67mm PSI?!?!
- exedy twin HELP: cant get in gear when the car is on, and its dragging
- Buschur exhaust on my evo ix
- Exedy stages
- Lean+unsmooth idle on hot start
- What to build?
- What's these parts?
- Noise from power steering pump or something else?
- PTE 6765 vs AMS 950R
- A bit worried
- Removing my drive shaft questions...
- BR Ported Exhaust Mani doesn't fit properly?
- Can an Ogura Flywheel match with an OEM stock Clutch?
- 2 stroke evo
- Filler hole on top of transmission what is it for?
- ugh here we go again with boost problems.
- Gearbox oil help
- hks twin disc GD MAX power rating?
- Drive belt tension question
- new BR motor likes to get hot, overheating help!
- what cams for 50 trim?
- A few strange issues after motor mount replace and stall out
- Just another dead clutch or more?
- Tomei 270 procam timing
- Please share Bee-Rev Limiter?
- All 3 ACD Lights On - Unique ACD problem?!
- 2.4 waterpump spacer/ modded pump questions
- Exedy Twin too much for DD?
- Overheating problem need help
- Nisei UICP?
- center diff issue? Or VCU issue?
- 9 Turbo WGA crushed?
- Carbonetic Multi plate rebuild
- Spal fan install input
- Accordian intake vs hard w/stock airbox
- Can a cam gear cover cause engine failure? In short YES
- EVO VIII Idle problem (with video)
- Rod Bearing Clearance Issues. HELP!!!
- Greddy turbo timer question
- From 6262 to 3586 worth it?
- Any information will be helpfull. Drive train problem
- T4 twinscroll manifold
- Evo exploded out on the track yesterday!
- Increasing actuator preload??
- help with i/c piping
- Newly built 2.2 engine use alot of oil...
- oil ring gap crazy
- help lean afr
- Is this ignition installed correctly
- Having boost problems
- Reverse lights out
