- How do you check for exhaust leak?
- Buschur cat back Vs Greddy Evo 2 cat back?
- Coolant Hoses - Trouble
- nos evo dyno vid. This normal? (MERGED)
- issues after 10.5 hotside, o2 housing, ic piping install
- Manifold for GT30/evo6
- EVO7 OverHeating Problem
- Parts and Performance Review: Buschur ported manifold, 10.5 Hotside, and Ebay 02
- Dynoflash my IX
- Throttle Body Coolant Bypass - Trouble
- Over Boosting.!! Why??
- My bolt-on turbo that I KNOW is worth the $$
- 20g-9-5 guys...need some help with boost
- Pics of my cracked piston
- Hondata Heatshield
- Has anyone tried those $199 Ebay TBE's?
- Evo 8-9.8 vs Evo 9 turbo Dyno results
- Installed a IX turbo on my VIII
- Stock motors
- My New Toys: RNR GT40 KIT/2.3L Parts, Pics
- pressure regulator
- syncro??
- Sputtering
- LPG Direct Injection
- Timing belt tensioner??
- Buschur Parts Just arrived **pics** inside :-)
- new toy COSWORTH cylinder head
- DC Sport Downpipe
- breaking up!! (not w/ my girl)
- please help
- Garret GT2871R
- Turbular Manifolds, Daily Driving, and Rain
- Please ID these two turbos
- The time has finally come...
- long startup cranking time...
- Another IX Dyno (Baseline) .. have some questions.
- HKS 264 Cam Timing
- Couldn't Find For Ix Intake !!!
- Will I need a retune for AMS LICP & Works Drop in?
- Engine Service Soon O2 code with HFC
- Just dynod car 2005 evo!!
- New IX MR, thoughts on these mods?
- CEL/SES Code P0138
- Boost
- Buschur Racing tunes 3065 turbo kit....on race gas
- i have a lame ?
- Comp Cams 280
- ix only need exhaust cam????
- How much boost.. big turbo, pump gas?
- High engagement point on pedal with ACT clutch!!!
- 4G6-MIVEC Valve Clearance Adjustment
- Walbro 265 Fuel Pump Installed **PICS**
- Which manifold Dnp or dc sports?
- More Power EVO exhaust
- WHP to BHP
- How clean - cam install
- Lose of power after o2 housing/header install
- Mitsubishi OEM turbo specifications (including flow rates)
- MBC and constant elevation change...yes or no?
- 2k to spend on 2005 evo what next?
- Greddy AFR warning memory guage
- dc sports exhaust
- 13k miles and f***ed up clutch
- Turbo Gurus Please Read
- Evo VIII Oil filter
- how to dyno on a two wheel dyno?
- Thinking about buying the white rabbit turbo?
- Alignment on the Balance Shaft belt.
- Invidia Cast O2 Housing (pics)
- which is better 272in/264ex or 264in/272ex?
- 700whp EVO 8
- E85 Ethanol in a WRX. Good INFO for EVO?
- Just Dyno'd and Also a Few Questions
- 9 engine
- Oil pressure dipping?
- Elbow Racing Intake Manifold
- Anyone here used a "Cutout"
- Rear Axels
- Mostly stock with Boost drop problem
- Wheres the tranny fluid plugs and how many quarts is it?
- More Boost issues for me.... help if you can im lost.
- TME and E IX compressor maps/ flow#'s?
- Evo build!
- New IX. Boost gauge installed. Few questions re: boost.
- whats my problem?
- New Advanced Tuner Forum Announced!
- Big Al's next trip to Buschur Racing May 19 & 20
- Love Fab Evo Manifold...
- Cam gear settings with GSC 272s
- ATTN: RNR Racing
- Just cams and fuel pump
- anyone running a 2.3 stroker from buschur
- Good old P0401 won't go away.
- Conclusion to blown turbo
- O2 housing question
- New Dyno #'s with CAMS
- 272's or 280's?
- Cel from test-pipe Gruppe-s
- Dynopack dyno compared to other dynos
- Undercar photos of my sidepipe!
- hks cam valve events
- ACD Reflash ????
- If the Evos TC is weaksauce, then whats the options?
- Cosworth M2 High Lift Cam Specs
- Help me with my times and mods
- Turbo upgrade?
- should I change my sparkplugs at every oil change interval on my EVO??
- 174mph Data Log - Do I need a new FMIC?
- IX Decel Whine
- my 3rd gear problem
- Can you run a wastegated manifold on an internal turbo?
- Front Diff broken?
- Decel Noise
- Who wants a turbo that spools faster than stock but with more top end?
- need to change throw out bearing on clutch install?
- driving without a cam cover?
- To Sequential or not
- 680 injectors Drivability
- Manual Boost Controller : yes or no?
- srock intake for sale?
- Question about O2 fixes for test pipes
- Help Diagnose my Idle Problem
- Driving with an Exedy twin...
- Cleaned maf (now runs like crap)
- Friends 03 dyno#s!!
- Really need some help after Cam install guys
- Major Major drivetrain issues, any help is more than apriciated
- What Is The Stock 03 EVO Fuel Pressure?
- turbonetics t3/to4b on an evo?
- BR8ES or BR8ES Solid?
- Can you run methanol injection without geting it tuned?
- HKS SSQ Recirculate
- problem bleeding clutch line
- Fuel Pump Options?
- Removing stock injectors on an 05 Evo?
- Spark Plugs and Wires??
- RM01A Review - No Dyno #s
- P0335 and P0340 Codes after cam install
- Cam ? (Noise depending on Cam Timing)
- i need help
- dnp Manifold how are they in the evo's?
- why aren't there many short shifters for the mr
- Does the Sard 280lph fuel pump work on Evos?
- boost leak??
- question about MBC and turbo wast gate actuator
- What cams to go with?
- clutch/ tranny noise? please help!
- caution when buying from one fab
- po 300 and slightly rough idle
- HFC with a catback
- Please Help
- idoling problem
- help me choose the cluth plz...
- Sandwich adaptor question
- LS 3" DP W/Flex,UR HFC and Apexi N1- will this work on EVO IX?
- JDM E9 RS bolt up to 04 E8?
- intake manifold
- Stock Evo Ix Mr Boost Questions!
- Intake problem
- boost problem
- Anybody have fitment issues with their (APS 3.5' TBE) on 03'-05' evo's?
- Buschur Racing ready to"Attack"
- Brand new IX leaks oil everywhere at 2k miles
- HKS hurry the hell up
- MAXED stock turbo pump gas
- The highest safe boost for evo
- forced performance cams
- HKS DLI II impact on coils
- Thank you Matt Gold
- intercooler question
- What's wrong with this picture?
- Oil Return Line, Need Help!
- HKS Valcon
- tap for water injection?
- help loud tranny noise
- Help needed...MR won't start
- Kaaz rear Diff
- bought some 264/272 cams...
- what size of flange should i use??
- What does it take to rev the evo over 8500 rpm?
- Putting in exedy twin hd, should i keep the restrictor pill?
- UR testpipe Bung
- New Cam Install. Difference in Pull.
- gas smell from exhaust? stalling after recirculating?
- Passes the Wife Test, thanks to David Buschur
- Cusco LSD's for IX
- Trapped 109 (almost) Next mod please!
- For people running 37R kits ?
- XS Engineering Power Pack Ignition Amp V2
- Coolant line washers part number
- Problem after the 1/4 mile! T-case???
- Another Stupid Exhaust Tread ... need some opions
- clutch wont disengauge!!!!!!
- Drivetrain issues - Help!
- trany fluid help plese
- Oil feed...-3 or -4?
- loud booming clunk on fast 1-2 shift
- LICP install ? on a IX MR
- Tanny problem
- aftermarket clutch issues
- Where is this oil leaking from (Pic)
- Oil Catch Can
- First test intake manifold (lots a pics)
- Valve question
- TBE + Down Pipes fit ix w/o heat tc/oil pan
- new clutch problem....
- 50 trim "custom" kit in the works....
- grindy fourth gear
- exedy twin plate clutch
- How many passes have you got on your trans?
- Injector question?
- Greddy 20g turbo kit info?
- Exhaust/DP Fitment on Evo IX
- Exhausts that don't hit driveshaft.
- Quiet Turbo Back Exhaust with no cat
- Boost- control + Blow-off valves
- "Crank Walk"
- what dealerships in mass are mod friendly?
- Time Attack, Black EVO, battery kits etc......
- Weird problem when raining...??
- Evo 9 and HKS 280 Cam
- ACPT carbon shaft
- Pulling the engine
- Dumb power question
- Cosworth Cam Specs Finally
- clutch slipping?
- P0304 Code on 06 MR, help please...
- CEL ... need some advice
- .82 a/r question with 3076R
- Manifold ? for GT turbo
- Open her up after 2k mile break in today and my new IX already broken ?
- emissions and cams....
- Noise on cornering
- Compression 101
- Turbo Coolant line Bolt Size?
- want to buy 20g-9 turbo now! where?
- Rocker arm came off the lash adjuster
- Exedy Twin ?'s
- I searched in vain, re: boost leak testing
- OEM Clutch Maximum HP?
- where to fill ACD??
- Low oil pressure on Defi BF
- Broken bolt in hotside...0....me...1
- just got my car running after new motor, oil has air bubbles?
- 20G Turbo without cams?
- Boost problem..
- DC Sports turbo manifold not verified for Evo IX?
- Turbo Guru's
- My 20G-6-9 = Dead
- 05 MR Stock only @ 10psi
