- Am I going to need injectors?
- Open element recommendations
- Just Dyno'd The Evo Thursday
- boost problem after tubo install
- Stock IX BOV
- intake question
- Greddy Ti & Fujitsubo RM01A dyno # plz help
- Megan manifold!
- BOV swap has me confused.
- Larger turbo flows more at same boost pressure?
- Evo VIII to VR-4 Galant
- Boost cut or something else?HELP
- ACT Flywheel, who's running it?
- Oil filter option
- Car will not start after cam install, need help.
- whats ur spool up like on a gt3065
- Loudest Exhaust???
- Question about a BOV configuration, for someone that REALLY knows
- Turbo Whine...Normal
- Is this normal?
- Greddy Cams, who running them? Jun? Toda? any word one when they are coming out?
- Exedy or ACT
- Driveshaft Issue - WTF
- cheapest replacement clutch disc source
- Injector know it alls
- Where to get plugs.
- BR tuned new best times!
- Car is boosting 5psi!!! HELP
- ACD lights..
- Those that have a HKS intercooler Kit!
- Defi BF Gauge Ranges?
- Invidia 02 housing hardware
- Whats the New Transfer case break in procedure?
- What size injectors would be appropriate?
- Help!!! i can't boost past 18lbs of boost.
- HKS ssqv recirc.
- 06 evo 9, custom block mods!!! pics inside!!!
- Little dilema... car wont idle :\
- Anyone running Buschurs BF272's
- Why does wastegate spring matter?
- Does who have HKS intercooler Kit!
- 19lbs boost... no pulling like it should?
- topmount 35r turbo?
- Short shifter
- My ebay o2 housing
- evo green turbo.
- 35r on a IX ?
- knocking??
- 'White Rabbit" turbo
- what dp and test pipe should i get?
- any idea on hp estimate?
- fly wheel ?
- Can you hear your AVC-R click?
- Manifold
- meagan 02 and stock ported mani.
- Not holding boost?
- Dumb question on UICP
- Quick question about the catalytic converter. .
- any vendors that have Brian Crower Stage 2 cams in stock??
- Which is better? 2020cc or 2100cc?
- Is my tcase dying?
- Is my tcase dying
- Built 2.0 Motors! Need Help
- weird flutter in fifth???
- Exhaust
- Cams and Turbo lag
- want your input on cosi cams ix cams
- Bring Back the GReddy Evo2 exhaust thread
- Power gains from Buschur Ported Exhuast Manifold
- Any body purchase a gt30r or gt3082r from ATP recently?
- any vendors have gsc s2 280/280 cams for the ix in stock?
- SMC Control Box ??????
- CANT GET MY STOCK TURBO TO GO PAST 12.1 in 1/4 mile
- Fuel Pressure Regulator Install?
- need some help on turbo selection
- Shifter bushings?
- Turbo upgarde
- Fan in front of a/c condenser
- Anyone play w/ Piper 290's or 300 cams yet???
- Amsoil
- boost and 1/4 mile times
- ATP kit question
- P0172 Code Causes
- Turbo Mods??
- Quick question...
- Info About Titek
- ticking sound near the belt?
- Downpipe.
- 10.5 hotside
- Sputter after changing spark plug wires?
- motor toast, help please
- Starter gone? Battery? You guys can figure this out.
- Exedy Stage 1?
- ACT HSD001 240mm clutch disc
- WHO is on the Waiting list for FP EVO GREEN? Who has received theres recently?
- clutch went out today
- Drivetrain Interchangability
- Injector Input
- Preferences for a MBC fitting a IX?
- Help with PO139 Code
- EVO 3 gearbox and transmission case
- Cams
- Meth Injection
- Trent's car on pump gas, low boost...not 600..yet;)
- Sorry, another 600 whp thread.........
- GT35R Numbers that should be expected (HP)
- 295 hp, 272 tq, 1 bolt on, Mase tuned.
- Who Sells Turbo Replacement Gasket Kits??
- shaft play
- Who does the best turbo porting, and manifold porting?
- Best anti surge housing for gt35r?
- highest psi on stock fmic
- Lightweight pulleys for 4g63... any updates?
- Poll: Which Motor Oil do you use or recommend?
- Greddy Performance Camshaft Easy 4g63(evo9)
- Mobil 1 15W-50
- whining noise coming when boosting
- Shifter Problem ............. PLEASE HELP!!
- need some help about clutch
- Buschur Stage 2 Questions
- injectors for Evo Green
- Intake Not Clearing IC Pipe
- Ecu Immobilization code at Mitsubishi dealership(am I getting screwed)
- Most PSI on Boost Juice
- Clutch Installation at Home Questions
- ? about Buschur Air Filter Kit
- meth kits...buschur??
- Shearer Evo Street Brawler Turbo Kit?
- Doughnut Gasket Replacement
- Shifting Question
- IS anyone running a SLS turbo kit?
- Stroker
- Got tuned at GST Motorsports yesterday. +42whp +53wtq (Filter & catback only)
- Which vendors sell JAM lifters?
- The Evolution of a Street Machine
- 20gLT vs 3076
- how do i reset my dash light?
- lots of boost and race gas ?
- Buschur Race vs. Buschur Deluxe FMIC
- Which meth kit for my build?
- A few shots of the turbo install
- Help
- Any 2.3/2.4's 20g-LT on pump dyno charts?
- Need advice about driveshaft vibration
- Octane VS. Boost
- Help!! I stripped my axles!!
- Anyone running a revhard manifold?
- Buschur Racing.........
- whats wrong with my car??
- GSC S1 -GSC280(older model)
- Buschur racing build
- big power 37r guys...
- installed dejon boost controller and...
- knob on the top of a TiAL bov??
- Wiseco Pistons
- Cusco differential noise?
- Fluid capacity difference between 6MT and 5MT?
- Hydaulic Release bearing Help!!
- 11.5lb Mini Battery for $60
- 582 WHP with Pump + Alky on Flash!
- hey guys newbie here need some advice
- 600+ whp again, this is getting boring....
- Machine Work Vs. No Machine Work On 9k Evo 9 Motor...
- Aluminized heat barrier wrap
- giving up on boost spike.. about to burn evo to ground
- How easy or difficult is it?
- intercooler questions
- Where can I get these??
- is there any way to improve power at low RPM? (1-2.5k)
- evo8 cams 272or280
- ebay turbos:
- Exhaust Cutout?
- Excedy or Carbonetics??
- Max'd Out Stock vs. Non-BB 50 Trim
- Why mount the diverter valve on uicp?
- Paging EVO Green with 9.8 HS
- built 2.0 or 2.3
- Help me understand why my MBC does not function properly
- thoughts on slowboy racing?
- Clutch problems on new Evo IX SE
- upper and lower ic pipes- who has the best for the buck???
- How A Twin Disc Clutch Works???
- so is any company ever going to make a 280 intake cam for the ix?
- GT30R #'s on 91 and race gas
- Will the real Ebay 02 housing please Stand Up? (video)
- who offeres the best deal on 880cc injectors and aeromotive fuel pumps?
- GSS342 for Subaru fitment
- cat replaced check engine light on
- Tanabe Concept Blue & Emissions!!!!!
- Look what UPS dropped off
- TTP engineering flash
- Vendors: Need Info on Greddy TI Catback
- OEM Fuel Tank+ Fuel Cell hook up
- 320 to install o2 housing?
- tranny HELP
- ARC intercooler fitment information
- Clutch Travel Question
- HELP me put my shifter back together
- Please post 50 trim pump gas dyno charts & mods
- Gear oil dripping
- dip stick...low oil(HELP)
- mr turbo
- rear diff out - large crack on the top
- Help with clutch
- Aeromotive A1000 pump+stock intake=over kill?
- motor mount recommendations good bad ugly
- waste gate spring???
- Different kind of boost problem... (i think)
- how much would it cost to rebuild evo9 motor9
- GT35R and N20, anyone run this setup?
- Boost drop/leak
- HELP!! new plugs arn't iridium!!
- factory boost solenoid
- evo8 20g/evo9 20g difference
- Stock Exhaust Manifold and coating Q's
- So...who's mixing in a couple gallons of E85 with their premium?
- Stock shortblock, stock head, new record numbers for the EVO Green turbo
- BOV Question
- Boost controller help with pics
- E9 Tune with Cosworth Cams- Dent Sport Garage tune
- oxygen senser test ??
- Exedy Stage 1 Clutch Reviews?
- help
- another tcase ?
- AEM ugeo questions
- Redline Fluids???
- TD05 20G for evo IX...
- 5th Gear part numbers for Evo IX
- Evo 9 (or FPGreen) turbo in an Evo 8 w/o the install kit..YOU MUST READ THIS FIRST!!!
- Intake temp data [request of speed density users]
- Water temp adapter piece
- compression numbers
- Ebay o2 question
- XSPOWER(ebay) intercooler, I bought it...
- superchargerr sound?
- Buschur Power FTW! (Video Inside)
- Injectors for a GT3076R???
- FUEL line thread from firewall?
- Does Old Muffler = Less Power??
- mivec solenoid control?
- Help with 280 idle
- who has a 60 TRIM??? INFO NEEDED
- transmission noise
- i need a transfer case
- just changed o2housing..hotside..now hear new noise
- Fuel Cell Expansion/Replacement for Evo 9 SE
- Exhaust Centering Q? Tips? (Megan Racing)
