PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Reuse timing belt?
  2. Exedy Twin Disc weird noise(not rattle)
  3. IGN-1A coil
  4. Dsg transmission swap
  5. Short shifter
  6. Can anyone tell me about this turbo kit?
  7. Act New Twin Disk Who Running One?
  8. Machine shops in the midwest
  9. Evo IX warm oil pressure at idle
  10. Evo 9 Mivec cam gear gasket
  11. Block filler?
  12. First turbo car / running rich issue
  13. Evo 8 stock turbo compressor cover leaking boost
  14. Biggest twin scroll turbine
  15. ACD to Non-ACD wiring harness?
  16. Evo IV dies, sometimes/high idle
  17. Oil System Recommendations
  18. Head gasket leaking oil
  19. Evo 8 clutch/flywheel issue?
  20. Top 5 Turbo Kits Evo8
  21. Evo 4 crank no start
  22. 1st 02 sensor ohms readings?
  23. 3.5" down pipe
  24. Transfer Case Going Out?
  25. Newbie engine rebuild questions.
  26. Valve Cover Refinishing
  27. Clutch pedal dropped to floor (Release Bearing?)
  28. Exedy Twin Issue?
  29. 2.2L top end advice
  30. Evo 8 shifter cables?
  31. Throttle body and ported stock intake options
  32. Bearing Clearance
  33. Cosworth Camshaft ID
  34. Oil Mods and other bulletproofing mods for 4G63T (DIY and Paid to do)
  35. Greddy Airinx Filter / Apexi Filter any good?
  36. Evo IV Transmission / Rear diff
  37. Best Street Focused Piston-EVO 6
  38. Has Walbro changed the 450lph (#274) pump design?
  39. Misfire/cutting out
  40. EVO IX RS 5pd trans - what’s it worth?
  41. STM High horsepower intercooler size and reviews?
  42. Evo8 fuel pump ground wire?
  43. Turbo ID?
  44. to reach 500 HP with your help
  45. Compression off every other cylinder?
  46. IACV , all the same??
  47. 153mm rod suppliers?
  48. 64 block sourcing in Australia
  49. Torque solution mount
  50. Engine build
  51. Max power on cast FP exhaust manifold
  52. Ignition system stopped working
  53. Evo 8 turbo on Evo 9
  54. Pressing out bushings for rear control
  55. Short Block Options
  56. Intake Manifold Porting
  57. Torque specs for o2 Housing Studs, not the nuts
  58. Evo 4 death whine or not??
  59. Anti surge on an fp turbo how much power does it add
  60. Wrist Pin failure
  61. Tactrix wont power on and no fuel pump voltage
  62. GTR R35 cop... Need remap?
  63. Rear Diff noise
  64. Torque solutions transmission Mount torque spec?
  65. Problem with ABS sensors
  66. Is my 2nd gear okay? (pics attached)
  67. In gear when in neutral?
  68. In gear when neutral
  69. Tomei M7963 Turbo
  70. E​​vo 8 Weird noise after replacing Headgasket
  71. Evo9 stalls after new serpentine belt and tensioner install
  72. weird sound after track day
  73. Evo 8 built motor. Head ticking? Lifters?
  74. Can somebody identify these injectors?
  75. Tips for Muse UICP?
  76. Advice On Head Gasket Install
  77. Any suggestions? Internal snap ring gtx30
  78. Best CDI kit
  79. Bov valve
  80. Exhaust manifold
  81. Question on head install. Very basic question
  82. Carbonetics replacement parts
  83. Big power without dogbox?
  84. Transfer Case Whine
  85. My fp red turbine housing cracked it was mhi
  86. 94mm crankshaft options
  87. Evo 8 Oil Pressure
  88. What is the size and thread pitch of the pressure plate to flywheel bolts
  89. Turbo advice sell or rebuild?
  90. small+big pump double pumper
  91. PLEASE HELP! Take a look at my timing belt tension.
  92. Vacuum Line?
  93. Help identify these cams
  94. Won't build boost or exceed a certain rpm
  95. Gas Leaks when filled over half tank
  96. EVO 8 dosent want to go into gear. (Video linked)
  97. disengage push style clutch
  98. Evo 4 transmission
  99. Turbolabs 25G made 505 pump or FP Red DBB
  100. What a weird problem: 2 out of 4 injectors not firing?
  101. 6870 options/recommendations
  102. Sheepey vs other manifolds
  103. ECU boost control
  104. T3 6466 capability?
  105. Single t3 entry manifold limiting factor on 6466 or gyx3582?
  106. New Build - 4G64 2.2 Long Rod
  107. Throttle body vacuum
  108. Full throttle issues
  109. Serious question. I may be a dumbass.
  110. Clutch issue
  111. Megan Racing Hardened Rubber Engine Mounts
  112. Koyo rad half radiator kit for daily driving?
  113. Is this built transmission and what diff is this one?
  114. External Oil Pressure Adjustment for Stock Oil Pump
  115. 25K on Gates Timing Belts and WP - Inspection
  116. K&N short ram intake still junk? (I know the Typhoon kit is crap)
  117. Utterly confused
  118. Help please! Rounded tcase tail housing bolt
  119. Changing Evo 9 Mivec cam gear
  120. Eco 9 block repair/advise
  121. Anyone put a 09 ralliart diff in a evo 8?
  122. Main bearing ATI failure?
  123. Timing Belt Removal Question
  124. Compression opinions?
  125. No 4th gear. Trans refreshed 2500 miles ago
  126. Oil leak - cam area
  127. Newbie turbo kit question
  128. Wastewater flapper arm snapped
  129. t3 twin scroll manifold
  130. Boost leak?
  131. Turbo Options
  132. JDM Airtek/Outlander Engine Questions For Build
  133. ACD Lights (Faulty) Need Help
  134. Evo Experts Opinion on T Case Upgrade
  135. Evo9/BBK Full flapper failure (video)
  136. A few power questions/advice evo experts please?
  137. Bbk full laggy mid range boost Gm 3port?
  138. Help Identifying Loud Vibration on Boost
  139. Low oil pressure only during cold start
  140. What to replace after blown engine
  141. Does anyone run: Exedy Hyper Single VF Clutch Kit #MH01SDV ?
  142. What fittings are needed for a full fuel system
  143. Evo 8 will not pass 15Psi
  144. What helicoil kit do you want for exhaust manifold studs?
  145. Bent FP54 compressor fins - what’s the cause
  146. Daily drive dogbox
  147. EVO 8 missing drivetrain
  148. Sudden Loss of clutch
  149. Boostlab 25g Turbo
  150. Rev9 Manifold
  151. Anyone on 7675?
  152. walbro low pressure 450 dying or what ?
  153. Turbo or Valve seals?
  154. New VIII Build (Turbo Decision)
  155. Compressor Wheel Failure on 20G
  156. Electronic Boost Control Issue
  157. Exhaust manifold stud replacements
  158. Anyone try MSD Blaster Coil Packs yet?
  159. Got R35 GTR coils working on my Evo
  160. Oil Feed Inline Filter on Journal Bearing Turbo
  161. I have 4 DTC codes, abs & acd lights always on -EVO 8
  162. Kinugawa sts advanced ball bearing turbo
  163. Clutch disengagement issue
  164. who can rebuild ball bearing fp turbo
  165. Who makes a 300m 153mm rod
  166. Running rich/stalling after getting gas
  167. Help with compression/leakdown results, buying car
  168. Clutch for breaking TOB finger
  169. Doing a full build and have a few questions
  170. Puzzled on oil leak
  171. Hks 7460r
  172. Evo 8 won’t crank
  173. Carbon fiber or fiber glass air duct!
  174. Evo VII EGR Delete rough idle
  175. STM forward facing intercooler piping direction
  176. 120,000 Service
  177. Traction loss
  178. Best clutch for 500whp -420wtq
  179. Turbo Decision
  180. FP Turbo recommendations
  181. Temp gauge not moving after turbo removal
  182. Forward facing turbo intercooler piping question?!!!
  183. STM v1 Sealed Catch Can Hiss/Whine Sound at Idle
  184. How much mivec advance before piston to valve contact?
  185. Valve spring compressor tool
  186. Turbo oil return! Will what I’ve done work guys???
  187. Looking for a functioning used IACV for my Evo 8!
  188. Evo viii cranking problem
  189. Evo 9 alternative spark plugs - will they hit the piston?
  190. What balancer/damper are you running on your stroker crank?
  191. Maybe I hydrolocked years ago and now won't start?
  192. Need help with timing belt tension
  193. Evo 5 clutch master cylinder upgrade
  194. 8500 rpm evo ix whats needed
  195. R35 GTR coils on an Evo 8/9?
  196. evolution 8/9 thermostat help!
  197. Want Honest Opinion on kinugawa turbos
  198. Oil leak after boost leak test
  199. Porting and upgrading head
  200. 2.3l fp black fueling questions.
  201. Evo 8 AC?
  202. evo 9 oem vs 2.2 spool
  203. New engine blown 😕
  204. Evo VII timing belt slack
  205. Heavier Spring or a 4 port?
  206. Curt brown ported stock intake/s90/fuel rail dilemma. Help!!!
  207. S90 throttle body question
  208. Fp black direct bolt-on requirements ?
  209. Oil in Cyl 1 & on Spark Plug
  210. xona rotor xr69s
  211. Rear diff bar stud seized
  212. Evo 8 Bucking at 5k rpm WOT
  213. High flow PCV valve
  214. Motor Mounts??
  215. Spark plugs show signs of Det
  216. Broken Rear O2 Sensor Dilemma and Question
  217. Turbine wheel clipping
  218. Exedy Twin Help
  219. EVO II 3 inch downpipe options
  220. Looking for Rubber Boot/Cover part
  221. FP 54 green bb
  222. Not enough fuel
  223. Car shuts off after driving it
  224. BW S366 SX-E (6668) TwinScroll Experiment
  225. evo 5 FP
  226. Ticking noise after replacing timing belt
  227. Clutch slip and hydraulic throw out bearings
  228. Clutch recommendation help
  229. will Wiseco Boostline fit stroker 2,3
  230. Good intake for stock evo 8?
  231. evo 5 turbo
  232. 1st Evo: Engine rebuild help
  233. Evo 8 Trans Drop issues
  234. Flywheel Bolts stuck
  235. EVO VIII weird compressor surge with stock X BOV and intercooler pipe install.
  236. Action Twin Disc , or any twin disc question
  237. A/C Fan on cars with no A/C?
  238. What else can I check/lubricate for my shifting?
  239. Low oil pressure when pulling
  240. Fp hta71 fitment
  241. Comp Turbo 6262 Stock Location
  242. Recirc BOV
  243. Black build up/sludge in the Air intake
  244. Evo 5 headgasket
  245. Oil Filter
  246. Boostin Shifter installation
  247. Stock boost solenoid help
  248. DTC p0112
  249. Air intakes
  250. Searching for 5th gear ratio evo viii 0.720
