PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 [143] 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Brand new clutch, cam upgrade, and fmic upgrade Q's??? Please help!!!
  2. Exhaust leaking near o2/mani
  3. 2.3l stroker question !!
  4. clutch paddel frozed !?
  5. help for engine light
  6. How much oil will you loose if remove oil return line?
  7. think to put RS diff. help please!
  8. Stock two step questions
  9. wired problem..... help me out here
  10. It has begun...
  11. What sealer to use on Turbo out to intercooler pipe?
  12. Upgraded injectors and no tune?
  13. JVT Racing Radiator??
  14. My AMS 3076R Install
  15. BR3065+pumpgas+25psi??
  16. AMSuicp
  17. Help! Car suddenly went lean under WOT.
  18. EVO 8 and EVO 9 gearing....
  19. Project 2.3 + 50trim Finished!
  20. buschur 3065 install on Evo IX
  21. Weird Noise coming from car...
  22. boosting problem HELP
  23. Injectors for FPgreen?
  24. Exedy Twin HD vs stock MR tranny info??
  25. JUN 272 V's Cosworth M2?
  26. Need advice on cam upgrade (from hks264)
  27. Trans or something else?
  28. only one cam???
  29. uicp
  30. evo 8 4th gear...why??
  31. Axel possibly going out?
  32. BC 2.6 stroker
  33. 2.3+HTA35R+FR twinscroll?
  34. Need help from all arizona members!!!
  35. Balance shaft removal kit?
  36. HKS down pipe from a '03, will it fit a '05
  37. Buschur Racing 3' SS downpipe Install
  38. Best turbo for running 91 octane and meth/E85...
  39. Water/Meth Injection, FINALLY installed
  40. GSC1 or 20g
  41. Brokern transfer case?
  42. Help Needed With Injector + Injector Harness Install!
  43. 2200cc injectors
  44. Piecing together my own 50 trim
  45. Does unplugging the rear o2 sensor throw the car in limp mode?
  46. Where to order new rear o2 sensor from?
  47. 2.75" vs 3" downpipe?
  48. Plug and Play Wideband???????
  49. Help!! Water Leak! Help!!
  50. firewall plugs issue
  51. Need Help Quick!
  52. which met h kit to get????
  53. Fullrace Twinscroll Kit or 2.3L Stroker?
  54. Hoe many GT35R owners experiencing spark blow-out
  55. EVO XI Axles and EVO 8 Axles w/o ACD
  56. Help! Syncro Break-in?
  57. Which transfer case is stronger one with acd or not
  58. Building my drivetrain... Help me out please
  59. I wanna go Slimfan
  60. Which DV/BOV?
  61. Porting??
  62. TurboXS downpipe & aftermarket o2 housing
  63. Drive shaft rattle?
  64. Is the Intake Manifold support neccesary
  65. Is this the good eBay o2 housing?
  66. Is there any demand for a spring t bolt kit?
  67. t4 flange pt67 or gt37r
  68. Questions about Carbonetic Twin Clutch
  69. SARD blow off valve
  70. stroker build - how many hours?
  71. Check Engine Light Came on...?
  72. trans went out? or just linkage?
  73. Megan headers have confused me.
  74. new intercooler piping question
  75. I guess ACT Clutchs are known for lock outs. Can someone tell me why?
  76. compression and boost
  77. ETS Short Route vs. Stock Battery UICP
  78. Drivetrain related problem ? Help
  79. FS Exedy twin disc
  80. I just made 455 WHP on 93 oct w/ the FP Green
  81. what can I do with $11,000 ??
  82. HELP! Car Starts then dies after CAM install
  83. Fuel Injectors?
  84. How to tell aftermarket cams??
  85. intercooler
  86. Modification sugestions
  87. Some Questions about my upgrades
  88. Oil Pres. drop on curves
  89. need a lil insight
  90. Po300 Finally Fixed For Me!!!
  91. Porting inside hole of O2 housing - good idea?
  92. Clutch bolts over torqued...what issues??
  93. need help with transmission fluid choice
  94. Redline MT90
  95. Ecedy Twin vs ACT Street - Clutch Life ??
  96. Has anyone changed out the rear diff bushings?
  97. Works Stealthback + no resonator on factory plumbing
  98. est track time?
  99. could this effect boost?
  100. IX 6speed tranny goes bad...! need help
  101. Help wanted!
  102. Just made a big purchase from AMS
  103. SRT-4 owner crossover to the dark side Q's??
  104. IX owners running megan test pipes?
  105. HELP Negative effects of Kevlar timing belt?
  106. Some Pictures of my Open Dump 02 Housing
  107. Shifter bushing kit questions
  108. Cams...stock? Normal wear?
  109. 2.4L stroker turbo AR and trim question.
  110. oil pressure for our cars????
  111. 20G with 10.5 Hotside
  112. Buschur cone filter?
  113. am i crazy jdm 9rs turbo (magnesium)
  114. Who else has a HTA 35r comming?
  115. Help!!! Buschur fr3065 or fullrace?
  116. afr question
  117. T.s. 3065?
  118. blew the motor...
  119. read my plugs
  120. My PCV valve keeps popping out of valve cover..Why?
  121. Most miles running 25+psi?
  122. Is this a sign of my clutch going out?
  123. intercooler
  124. Can't Decide
  125. Boost not holding
  126. Are there any negative affects on No Lift Shifting?
  127. Tranny shifting weird, is it my clutch?
  128. Tale of two 500 plus whp Evo 8's on the ICS AWD Dyno !
  129. Help! Car Wont Drive After Cam Install
  130. Injen 3" Downpipe Question
  131. Bought a 2.3L Evo..incomplete list of mods, what should I check?/What next?
  132. HKS mivec cams installed tuned
  133. Custom intake manifold work "sneak peak"
  134. part throttle/acceleration problem
  135. pic request: stock shifter
  136. Any one ever test out a SS chrome WG?
  137. RRE "No Name" clutch experiences?
  138. Rear-Differential Needs Replacement
  139. Mixing Trannsmission Fluids OK? (MR Diaqueen w/others) Experts Help Please!
  140. Weird Noise
  141. Tranny Question
  142. Has anyone had this problem or know what it is?
  143. BIG problem Need Help!!!!
  144. Buschur Race Intercooler FMIC on Evo ix 9
  145. Direct port N2O kit (Pics inside)
  146. Greddy Ti-C Silencer Removal
  147. First problem ever with my EVO!!
  148. Advice on my setup I am getting PLEASE!!!
  149. any documented ported cyl head dyno compares / power gains?
  150. Boost Problem.....
  151. Cbrd + Jam =
  152. Anitilag (Exhaust Flame Shooter)
  153. Best place to purchase one step colder plugs for the IX
  154. Car won't boost at all...help
  155. FP Evo Green Track Results- after the 487 whp results
  156. Invidia o2 Housing and Lower Heatshield
  157. Good Intake? Cause i just broke the stock airbox
  158. Another Engine noise diagnosis thread.
  159. Time to start adding HP
  160. mbc installation
  161. Leaking gear oil between trans & TC
  162. $1000 for power mods?
  163. Transmission Help Please
  164. Installed Ebay intercooler today
  165. help on evo stock boost gauge
  166. qtp downpipe
  167. Car DIED on way home lost all Spark..NEED HELP!
  168. how to get it more streetable
  169. attn. all intercooler engineers (Blitz vs. stock)
  170. Tightening spark plugs by hand...
  171. Looking for Intake Manifold Pics: stock and ported stock
  172. Evo IX fuelpump question
  173. Stock Differentals.
  174. Road Race Engineering Exhaust
  175. Should I go with Meth or cams?
  176. 16g turbo problems
  177. Oil lines?
  178. Lowest db, free-flowing exhaust? Vendors please chime in.
  179. Clutch Sticking and LOCKOUT!!! Whats the cause and how to FIX????
  180. 35R Buschur track results, and spark blow out
  181. Power with standard Exhaust?
  182. Need a little help hope u guys can help
  183. took off rear section BR ex- 20psi 2 step holy!
  184. Reasonable rate for a cam swap job?
  185. bleeding the clutch, no pedal pressure!
  186. Ted B's Dynosheet
  187. boost issue
  188. Hks cams Dyno by Import tuner
  189. ebay o2 housing??
  190. Clutch noise
  191. Soooo?? whatever happened to Buschur racings 50 trim???
  192. gains from fp green
  193. Spark plugs are too white!
  194. AMS 35 or 37?
  195. MT90 or 6speed tranny fluid????
  196. 5w 30 or 10w 50?
  197. Numbers/Times to Expect
  198. Would you trust this MBC?
  199. Need help on turbo option!
  200. What Gains for these mods?
  201. what is next for me????
  202. Exhaust Wrap? or no?
  203. HELP!!! problem w/ UNOS MBC!!!
  204. low rpm dip/stall #2 - help please
  205. clutch question maybe dumb one
  206. anyone whos done the 6 to 5 speed conversion...
  207. High Compression
  208. Turbo differences?
  209. Mitsu bolts
  210. Anyone else's '03 turbo whine?
  211. Ku Engineering intake manifold?
  212. engine boggin @ full boost???
  213. To those running high horsepower and stock MAF.
  214. Some of my Carnage this Year!
  215. WHat is the best turbo for 100 octane
  216. Whats wrong with my clutch?!
  217. CHeck Engine Light.
  218. The Greddy T67-25g Turbo?
  219. shifting woes
  220. Has anyone here used the Hondata intake mani gasket on their EVO???
  221. Any real difference between a PTE 50 trim to a Garrett?
  222. Which Turbo to Buy GT35, GT37R, or GT40R Twinscroll, Singlescroll
  223. Guess this part
  224. peeps running the bushcur 35r on the stock ecu, look in here
  225. Does anyone here have a 4.11 final drive with stock turbo????
  226. TME Compressor Wheel
  227. What psi to tune at
  228. safe rev limit? built head with stock bottom end
  229. length of nisei uicp?
  230. Cracking/Popping Sound
  231. TOB / Wedge Collar
  232. cam gear install wows......and pain
  233. high boosting problem???
  234. Need Help!!
  235. Perrin setup
  236. car is not pushing! HELP!
  237. injector leak
  238. Full Race Twinscroll GT37 on 2.0L
  239. BR35r impressions.
  240. removed broken tcase and this is what the shft looks like
  241. looking for sponsors?
  242. stock crank? whp
  243. evo clutch website
  244. Best route to take on transmission and clutch?? Shep VS TRE??? HELP PLEASE!!!!
  245. Agency Bov??
  246. So I went thru a Turbo and FP told me it was the motor...
  247. Car Dies at Idle
  248. Need Advice - Car bucks/ shutters from a stop
  249. constant wavering squealing/screaching sound
  250. transfer case trouble shooting
