PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 [146] 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Wideband reading question
  2. white smoke /low oil
  3. Fuel cut?
  4. possible to reuse heat wrap? what if i soak it before removing?
  5. My new setup
  6. HKS Clutch
  7. Transmission question.
  8. Can I use this in my ACD?
  9. Extreme Turbo Systems & Racing make 924whp! Cheap Dsm coils to boot & $250 BC cams:)
  10. Greddy Mivec Cams?
  11. New record set on Buschur's dyno today
  12. Rerouted EVO throttle cable...Is it bad for the car???
  13. Input on ACT price
  14. Calling Tanabe Ultra Med Owners
  15. ACT Clutch Problem?
  16. APS Intercooler (pics)
  17. Royal Purple = lifter tick?
  18. ACT or EXEDY
  19. 2003 EVO: Code P0300 how worried should I be?
  20. Evo 9 Turbo Question
  21. EWG for stock turbo?
  22. Has anyone done 2mm valve seats on their 1mm oversized valves?
  23. Buddy Club Camshaft Failure
  24. Creaking noise
  25. Differene btw Exedy SD and HD?
  26. Dialing in cams with degree wheel and dial guage
  27. proper way to install a tial 44 mm?
  28. Question about HKS RS Intake
  29. 50 vs 57 trim...
  30. What boost?
  31. HKS DLi-2 install question?
  32. p0300 misfire
  33. Exhaust configuration
  34. Extreme Turbo Systems - T3 50 trim, 57 trim, 58mm, 60mm, 35R, 67mm Turbo Kit Release!
  35. What fan to go with??
  36. about header !
  37. thread pitch and diameter of bell housing to engine block bolt?
  38. leaking oil filter
  39. Trans Prob
  40. Boost Leak Around Fuel Injectors
  41. to build or not to build...
  42. Grounding out ecu fuse
  43. Forge EVO 9 Actuator
  44. Meth injection question
  45. 2nd Exedy triple carbon=crapola
  46. Iridium spark gapping
  47. AMS GT35R Turbo housing sizes???
  48. 1000whp fuel setup for Paul Nelsons car
  49. need a new bov what should i get that dosnt leak?
  50. Substitute C16 on car tuned for 93 + Meth
  51. Shep Stage 2 t-case
  52. Gear Ratios for all EVO transaxles?
  53. In need of some help, please. NOISE
  54. Plugs for a lightly modded IX
  55. Anybody have a reciept to buying their Aem intake I can barrow?
  56. 4-Stroke Basics
  57. help with spark plugs
  58. Best Cams for an VIII stock turbo-gt35r
  59. Best Cams for stock turbo-gt35r
  60. Mobile 1 Transmission Fluid
  61. Electronic or Manual Boost controller
  62. Manf. R&R
  63. Clutch slip at 4500 rpr and up in 4th gear?
  64. ugh ohh boost creep
  65. EvoVIII & IX Lower Blocks
  66. Att all you guys with widebands
  67. Stock boost settings
  68. stock cams in an 05 diff from an 03?
  69. Any pics of the ebay turboback exhaust??
  70. What type of fan is the Evo 8 fan? Push or pull type?
  71. Problems, Please Help Asap
  72. HX-35 Turbo on Evo?
  73. ????'S About fourth gear??
  74. Boost Controller
  75. Hks Ssqv
  76. HELP! Evo 8 to Evo 9 Turbo install?
  77. Boost leak test materials for evo IX
  78. whats my next steps...
  79. Exedy Twin Rebuild Kit?!?!
  80. Evo 9 Upgrades without hurting low end???
  81. hks knockoff intake?
  82. Impression post test pipe!
  83. Exhaust Manifolds??
  84. Evo upgrades
  85. turbo
  86. Popping noise at sharp turns
  87. Recommend Cams for Evo9???
  88. Shift Calculator
  89. Resonator for 35r
  90. Defi Gauge Sensor Question
  91. Turbo help?
  92. 20g-lt + e85= fun
  93. Will the Samco Turbo Hose kit for an EVO 8 fit and EVO 9?
  94. Quick WB installation question
  95. waht benifits and gains from porting just the stock head
  96. Lost first and second gear?????
  97. tuning the AEM Tru Boost....
  98. Help with identifying a blown head gasket
  99. code po171
  100. what oil fitting for gt3076?
  101. Question: weird sound after intercooler installation
  102. engine swap?!
  103. Boost leak on throttle body - how to fix?
  104. Thought I had enough break in miles? maybe not.
  105. *NEW* ETS 57 trim turbo kit
  106. new cams, do i wait to tune?
  107. Exedy Triple Plate Chatter Question
  108. AEM Tru Boost.. Vac line routing??? help my confusion please!!
  109. PERFORMANCE SHOP (this is a must see, so check it out)!!!!
  110. dd
  111. Bolt on 400whp, pump gas only, is it possible
  112. Code P0300
  113. Where are people breaking??
  114. Help with finding TDC
  115. What's the cause of CEL p0011?
  116. ACD fluid
  117. TurboXS Downpipe Leaking Help
  118. Exedy twin retainer clip. need advice!
  119. Intercooler woes: Plz help me to decide...
  120. Downpipe
  121. Is this the right trany fluid # for the MR?
  122. expirience with NX Nitrous Express???
  123. New fuel setup
  124. AMS Power stearing delete kit
  125. MBC problem, not a leak, but sucks just as much
  126. Clutch won't fully disengage; can't put car into gear once started.... Help.
  127. QTP Dp/WBo2 question
  128. Buschur intall mini battery and upper ic pipes
  129. EvoIXMR Stroker kit
  130. Looking for feedback on HKS cat back
  131. br cast mani or tub with 3065
  132. built head and stock block?
  133. track time est?
  134. Blown Tranny at 30,000miles
  135. Question Reguarding Cusco LSD
  136. fpgreen twinscroll?
  137. best mods start on 03 evo?
  138. Looking for 300+hp on a budget with my 05
  139. Recommended boost level for a IX with basic mods.
  140. Manifold
  141. ACD lights when hot only
  142. stock battery install?
  143. WHAT MPH is 8900 RPM in 5th gear in an evo 9???
  144. GT37R turbo explanation
  145. Whinning sound? which could it be?! HELP!
  146. need help now please!
  147. Next Mods?
  148. Walbro 255 Replacement
  149. Jun actuator on an evo ix stock turbo
  150. Trans Help Asap Stuck With A Car!!
  151. anybody run this fmic
  152. help on exhaust manifold
  153. Help me understand Exhaust
  154. Klunk sound out of car
  155. TRE or Shep for quick turn around
  156. ????Need some help?????
  157. Buschur Coil on plug system
  158. Garret 60-1 Turbo
  159. Tuners in Nebraska?
  160. need a banjo bolt
  161. Tomei DP Kit for IX MR
  162. soo hard to decide
  163. Porting ebay 02 Housing ??
  164. Found the problem, what now?
  165. What aftermarket intercooler kit will fit with Atp gt35r kit?
  166. HKS EVC not regulating boost?
  167. Best way to test front differential operation?
  168. question on cams
  169. a lil help please
  170. Anyone have experience with the BR Evolution Pure Power Package?
  171. BOV flutter
  172. stock clutch specs?
  173. Engine: Evo Blew on first day (Help!)
  174. Boost leak? Fuel economy?
  175. 25psi feels like 10
  176. help... ticking noise??
  177. Ebay Intercooler Pics
  178. Turbo timer, countdown??
  179. Boost needle under idle HELP
  180. re torque cam bolts?
  181. Installed my Cosworth Cams!
  182. need help hooking up the stock boost selonoid
  183. RWD Conversion Questions?
  184. Exhaust Fitment Q: JDM vs USDM IX
  185. Makinng Driveline stronger
  186. how to build a proper high boost-safe engine
  187. OEM factory muffler.. NY
  188. Exhaust ?
  189. building head
  190. fuel pump and catback exhaust??
  191. o2 housing delete
  192. best clutch for around 500 bucks....or cheaper
  193. fuel tank, pump, injector cleaner?
  194. Retrofit ACD into a non ACD car?
  195. Transmission know it all's.....
  196. best cams for me
  197. Full-Race Twinscroll 35R
  198. Evo reverse question?
  199. Any useful info on this....
  200. lost 1st nd 2nd gear
  201. front wheels only spinning
  202. evo radiator
  203. Megan Racing Evo 9 black cat back
  204. Syncos? From 3rd to 5th
  205. EGT Temps...at idle and cruise?
  206. Oil Pressure on E9MR
  207. 10.5 hotside noise?
  208. Attention Vendors I Need A Turbo
  209. Aem Wideband (where to run the wire from the O2 sensor)
  210. thoughts on Buschur Racing stage 1?
  211. hks280+etc..WHP?
  212. Spline Shafts
  213. 10 psi problem fixed!!! FINALLY!!
  214. GT30 and GT35 Guys
  215. Clutch and Fly wheel question?
  216. 3,000 rpm problem
  217. looking for evo 7 or 8 rear diff
  218. greddy 20g turbo kit
  219. hks turbo kit
  220. Need advice on adjusting the Forge Wastegate
  221. Bent valves need to replace. Which?
  222. greddy t67 turbo
  223. exhaust?
  224. need info on how to achieve 350-375 whp
  225. EVO GREEN & 2.3 STROKER 352awhp & 358tq
  226. Downpipe Fitment
  227. Exhaust weight....
  228. OEM ECU Knock Sensor Logic
  229. MR Short Shift
  230. Launching with Spec staqe 3 clutch
  231. Dyno'd again... finally happy
  232. What would YOU do?
  233. Ordering parts need opinions!!!!
  234. BR 37r, EMS and VSR pics!!!!
  235. AEM Intake UICP question
  236. Mega DP- UR HFC fitment question
  237. Full Race Vertical Flow Intercooler Review
  238. jdm and usdm
  239. hks valve springs
  240. pic: det, blow-by, or both?
  241. What coolant do you use?
  242. help with code i have p00069
  243. Question about tranny gunk.
  244. Two transfer cases dead within 450 miles!!!
  245. Replacing the Gasket between J-Pipe and Turbo
  246. please help diagnose my engine problem
  247. please help diagnose my engine problem
  248. Waste Gate Actuator
  249. Basic performance mod questions
  250. Low Boost, Boost Leaks and No Resolve
