PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 [223] 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Anyone install yet Tomei BOV for Evo
  2. Fuel system solutions..........
  3. BOV Clamps
  4. Help! Boost Gauge Install Question.
  5. Vishnu Exhaust ?
  6. Boost leak after clutch install.
  7. Well doing the 272 deed tommorow night, last words of advice?
  8. Installed HKS SSQ and have a few questions...
  9. engine break in questions
  10. 272in/264ex who's got them?
  11. so what would you do with $2000
  12. time to start modding!!
  13. what is the loudest exhaust for the evo?
  14. Muffler under 91 db for Laguna Seca?
  15. Synchronizer bad?????
  16. Turbotrix Turbo Kit pics, where?????????????????????
  17. Help!!! Fuel pressure
  18. Throttle Body Intake Poping Off
  19. RNR Downpipe
  20. Intake pipe Poping Off
  21. ECU questions....will any 03 evolution ECU work?
  22. lifter bleeding when installing cams??
  23. Boost reading - is it normal
  24. anyone running microtech stand alone?
  25. how much pressure is fuel return under?
  26. valve train ticking.
  27. Cam combo
  28. Available Valve Spring with HKS Cams
  29. Airflow meter
  30. Tuning path questions.
  31. ceramic coating the turbo?
  32. safc II, bov, mbc..
  33. Boost?
  34. Anyone running the Worx Tuning BOV?
  35. Tranny?
  36. Loose hose clamp leads to intercooler piping falling off
  37. Ready to buy! What is the best price on an Exedy twin disk?
  38. hks ssqv problems
  39. Engine/Fuel Management
  40. K & N drop in ?
  41. aem CDI for distributorless ignition vehicles
  42. Evo Clutch and Transmission Info...
  43. Valve cover sealing: Permatex UltraGrey or UltraCopper
  44. HKS RS Intake Dimensions
  45. Throttle Body
  46. exhaust ??
  47. tarmac, gravel, snow lights all on at a time..
  48. Timing Belt Tension tool
  49. Performance upgrade after 80hp
  50. What is normal EGT temp?
  51. Thoughts on dynoing!
  52. Royal Purple For Transfer Case
  53. Open downpipe?
  54. Bushcur Stage 4 Questions
  55. anyone try rebuilding the t case yet
  56. Exhaust Manifold EGT Tap
  57. Cam Gear settings with HKS 264's
  58. idle
  59. Dirt or oil on front of intercooler, looks like a leak??help
  60. hks rs intake question?
  61. Those running HKS 272's with no gears
  62. BLOWN: Crankshaft Angle Sensor
  63. Evo Diff. & Trans. Fluid Change Dealer Quote
  64. Stroke or Head? haha
  65. HKS Cams instock...
  66. intake and exhaust what produces power
  67. Installing cams,
  68. ATR Cat-back (MVPMotorsport)
  69. I need help with my HKS SSQV
  70. Greddy V-SPL Intercooler
  71. injen intake update?
  72. Car stalled and won't restart
  73. Banging/Grinding with the Helix DP
  74. what do I need for 264/272
  75. PLEASE READ...Evo going in for service
  76. Turbotrix's new turbo kit
  77. apexi gt spec
  78. Vishnu Turboback Question Cel
  79. GFB Stealth FX trumpet attachment
  80. Just installed SSQV from Vivid
  81. Why is my car so slow?
  82. Valve Cover Bolt
  83. Which turbo kit???
  84. Is the Typhoon Intake a piece of crap??
  85. direct bolt on turbo
  86. Owner of HKS EVC
  87. 1G/2G valves same as Evo ??
  88. Car Stock need tips on first few power mods
  89. Got to prototype some exhaust..
  90. Free Hp! Balance Shaft Removal
  91. APS 3.5 Exhaust
  92. 3" 02 elim RnR HKS Carbon/TI TB, All SS Piping
  93. Carbon Fiber Drive Shaft?
  94. Anybody Ever Got A P0102 Code?
  95. Evo MR / FQ upgrade
  96. Where is IC fuse?
  97. OK Once and for all, HKS exhaust Taper question!!!
  98. Views on AMS turbo Kit
  99. The dead horse, but I am ready to spend money: Cams
  100. boost controller?
  101. HKS 3" CARBON TI OR BUSCHUR 3"
  102. Espelir JGT 500 Review
  103. Are all high flow cats made equal?
  104. Hks Eids
  105. do u think will damage the turbo and engine
  106. Tomei PROcam 270
  107. Rear diff fill plug
  108. Is this HP normal?
  109. what sparkplugs?
  110. Engine, interior, or Exterior Modification
  111. Anyone installed a radiator before?
  112. Installed MR BOV, nice!
  113. vishnu turboback?
  114. Ralliart Spark Plug wires Installed
  115. Turbo kits vs (18G or 20G)
  116. Buschur upper intercooler pipe hose to intake
  117. Intake swap with reflash??
  118. Exhuast
  119. Size of Replacement Radiator Fans
  120. smart move or dumb move: buying SAE90 #3775610 Diaqueen oil to replace redline 75w90
  121. I Need Help With Tob
  122. flash with booost controller
  123. Manual Boost Controller Install Help!
  124. Help choosing A new clutch for evo!!
  125. BOV Clamps
  126. RVM intercooler pipe kit evo8????
  127. Why no flash tuner?
  128. pics of Evo head cam housing rebuild
  129. My TeamRip transfer case experience
  130. Well since everyone asking, how many people run 75w90 in diff/transfer case w/no prob
  131. Melt your head with a shot of NOS, pictures of before and after repair
  132. BG Syncromesh Fluid, all around?
  133. Does detonation sound like a pleasant door bell?
  134. Where to buy HKS SSQV?
  135. highest mile stock car
  136. Turbo XS utec for the Evo???
  137. Turbo surge with my APT 3071???
  138. oil/water/ext temp ... fuel/oil pressure?
  139. Newbie ? about exhaust piping sizes
  140. Replacing just the clutch disks on an Exedy Twin Plate
  141. Tanabe Titanium Medalion Exhaust
  142. CAMSHAFTS/CAM GEARS 272in/272ex
  143. evo 7 size injector
  144. Do I Need Larger Fuel Injectors Now Or Are They A Waste????
  145. 320whp
  146. My planned first round of mods:
  147. should i put it on or not?
  148. "Det Cans"
  149. Blow off valve and Waste Gate
  150. MR ACD into 03-04 EVO?
  151. Sparkplug results
  152. GM Syncromesh and Penzoil Syncromesh - Is it the same?
  153. Is your motor out of the car right now?
  154. Lost power! Bought 4 NGK BPR 7ES - Help!!!!!
  155. my new Helix o2 housing, thanks Gruppe-S
  156. helix mounting problems?
  157. AEM Intake - Boost Pressure Loss
  158. Wooo 12.2 @ 112 on the stock turbo!
  159. More Hp
  160. Gfb Bov
  161. Cleaning threads in head before installing ARP head studs...
  162. BR stage 1 combined with Injen intake kit
  163. Tranny coating?!?!
  164. TurboXS RFL woes? Get's stuck open :(
  165. Br500 dyno runs soon
  166. Got a few exaust questions.
  167. Question - HKS, PWR, etc... Headgaskets
  168. Short Shifter
  169. Help me diagnose this problem
  170. When are Injectors needed and which ones...
  171. Cams 264/264 vs 264/272
  172. David Buschur get's in done in 2 weeks! New Shortblock, New Head, New Tune!
  173. Buschur 3" TB exhaust help!!
  174. Cams will make you lean?
  175. Turbo Upgrade for evo8 "help me choose".
  176. EGT Gauge
  177. Real Horsepower
  178. My New Friend
  179. BOOST controller
  180. T bolt clamps.....what size to get?
  181. Lancer Owners advice for show car
  182. when is a good time to replace the stock head studs?
  183. Denso IW22 verses IW24
  184. Some more Hotel/Motel Info for this weekends DSM/EVO Shootout!
  185. AVC-r learn gear feature? help?
  186. HKS Metal Flow Filters
  187. Mods and emissions? What will pass?
  188. Help, what makes the car not "like" timing?
  189. Clutch "klang!"
  190. Aem Short Ram Intake- Evo
  191. Intercoolers that support 500whp
  192. Just put in my New HKS RS INTAKE and..............
  193. All season tires, revs up drops down (clutch slipping?)
  194. nitrous?
  195. HKS cams question
  196. Calling AMS
  197. HKS Racing Suction Intake Owners
  198. HKS Kansai Street Spec exhaust fitted
  199. 563whp on awd DTS dyno at XS
  200. Review on Esplier Cat-Back
  201. Evo Boost Issue
  202. Question for everyone who has put cams in thier Evo??
  203. What size filter does the HKS RS use?
  204. Boost questions???
  205. EGT on EVO
  206. Sun Automobile Hyper Voltage System Review
  207. Pump Gas HP numbers?
  208. K&N + Type S bov installed
  209. Does anyone make more solid motor mounts?
  210. Kartboy shifter bushings installed...
  211. picture request, jic exhaust
  212. HKS Valve Spring
  213. Will this make my car run lean?????
  214. What bolt is used on the Greddy Type-S?
  215. who has best price on cam gears?
  216. Split-Second Loss of Engine power over bumps @ light throttle
  217. Boost spike/dip and unusual fade
  218. Fabricated a new upper ic pipe and crushed 1g bov installed
  219. Gains from listed mods?
  220. 4th gear issues HELP
  221. Shop and mod time!! (when will it stop!)
  222. JIC true 3" TB possible?
  223. HKS 264/264 Cam Gear Settings
  224. Same old question, about how much power would I be making with:
  225. 1.23 bar = 17.8 psi am I low on boost ?
  226. HELP HELP Radiator leaking........
  227. Top end mods gains 5 to 7 k RPM
  228. Drivetrain leak
  229. I Made A Mistake!!!!!
  230. AMS - 667whp on boost
  231. Question about the HKS RS suction intake
  232. Help with HKS RS Suction Kit
  233. Evvo8Powers drag strip results with BR500!!!!!!!!!!!
  234. A little bit of help here?
  235. Dyno figures
  236. Titanium Strut Tower Bars
  237. RnR 50trim t3/t4 kit NUMBERS/REVIEW! + TTX tuning
  238. Please help....
  239. Knocking engine sound?
  240. What tuning kit to get?
  241. Dyno Numbers ATP Turbo Kit!!!
  242. Bucking in first and second at startup
  243. exhaust piping, what does what?
  244. timing belts
  245. Couldn't be happier HKS 264/272 cams
  246. Fidanza Cam Gears
  247. Need some thoughts on controlling...
  248. Exedy sliping
  249. Upgraded Turbokits with Stock bottom end
  250. Exhaust leak?
