PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 [142] 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Having boost Problems Help!
  2. HKS bov bad for evo engine?
  3. IX turbo, boost dropping, then returning?
  4. HTA GT35R Dyno results right here!
  5. HTA3582r who has it....
  6. Question about Greddy BOV
  7. Any chance of an FP3065 HTA soon?
  8. Cosworth Evo 8 cams???
  9. Loud VibrationNoise
  10. 2.3l?????
  11. Slipping clutch Q
  12. over radiator intercooler piping ? !
  13. Random misfire occurs @ 6000 rpms, need help.
  14. WTB:Front Axle RIGHT SIDE
  15. Problems with clutch pedal to high?
  16. Scram/Ram Jet engines
  17. EVO9 JDM rear diffusers finished and ready
  18. Intake Manifold Flange
  19. 4.11 gear question
  20. Q45 throttle body?
  21. Noise after clutch install....what did I mess up?
  22. transfer case
  23. do i need injectors?
  24. exedy twin release bearing popout!
  25. Royal Purple Syncromax...
  26. question about revolver cams
  27. Help pls:3rd to 4th shift not working...
  28. Evo IX Performance Upgrades
  29. 1100whp or Bust! this Monday
  30. Not an evo but...
  31. Just had Exedy Twin installed, questions about pedal adjustment.
  32. Exhaust manifold....:(
  33. Is this the stock clutch kit? Or do I need to buy everything seperate?
  34. How to find out CC's of unknown injectors?
  35. A/F Ring Options?
  36. evo torque capabilities on stock block?
  37. PLEASE HELP: Serp. Belt Tensioner Broke
  38. Full-Race vertical FMIC with FP Green or stock turbo?
  39. Questions about Cusco clutch.
  40. Apexi GT Spec
  41. Longer Stroke + No Balance Shafts = ??? re: Vibration
  42. Next step
  43. EXTREEME NOON QUESTIONS!!!! (intake)
  44. ets fmic and uicp
  45. Fuel pressure??!!
  46. P0300 help!!! TUNERS READ!!
  47. Dumb ? on exhaust
  48. Intercooler spray!!!
  49. Which Clutch?
  50. Fmic
  51. tranny problems
  52. 6 hour turbo back install... need some advice
  53. My Exedy Twin Disk HD Review (From a Exedy Stage 1 to Stage 4)
  54. Need Tranny help!
  55. Started car with MAF disconnected
  56. any good??
  57. BR 3065 cast mani kit to Tubular mani conversion?
  58. Boston area shops for clutch install?
  59. can anyone help me get this part.
  60. Why we love mitsu motors... ouchie!
  61. 5 speed conversion kit?
  62. I gave it some power and...
  63. Compression numbers help
  64. Another satisfied customer with TT turbo kit
  65. Oil Pressure acting funky
  66. checking a turbo..
  67. quickest way to 20g?
  68. Head Problem Please Help!!!!!!!
  69. Head Studs...
  70. Couple drivetrain issues
  71. Turbo kit next in power after green?
  72. Tune with upper and lower IC pipes?
  73. Forge RS blowoff valve opinions/help
  74. Stock ECU swap
  75. blown trans or x-fer case?!?
  76. Confused about fuel lines...help!
  77. Buzzing noise
  78. Who is using an ETS turbo kit?
  79. GT35R & JDM MR recirculation valve
  80. ARC Super Titanium twin tail muffler/ exhaust
  81. Cosworth 272 IX Owners In Here Please
  82. GT35R perfect for a high 10 second street car?
  83. ECUScan Logs - Knock Question?
  84. What meth kit?
  85. Boost leak test need help??
  86. Hose Dims for Stock Intercooler
  87. Grandmaster of Bling
  88. What Do I Need For A Clutch Install?
  89. CBRD Radiator Install...
  90. transfer case, diferential oils????
  91. TiAL 44MM Wastegate Question.
  92. Brian Crower 272 setup
  93. Driveshaft for the evo
  94. Weird ticking sound, Need Help!!!!
  95. need info on evo9 turbo
  96. WB in stock o2 location?
  97. Need Help car not boosting!!!
  98. turbo upgrade
  99. Idle Issues With Intake
  100. Which Cams for Bigger Turbo?
  101. Garret turbo question
  102. anyone replaced timing belt?
  103. Turbo XS Type H Hybrid BOV
  104. high rpm problem??
  105. Oil Temp vrs Oil Press - do i need both? how do i interpret them?
  106. Tranny fluid.
  107. Strange RPM issue after boosting
  108. Fluctuating Boost?
  109. Magnetic fuel savers...
  110. AEM uego reads......
  111. Did I Damage Anything?
  112. Looking to get green turbo
  113. no power to front wheels? drivetrain issue?
  114. LEAN AFR - Possible Injector issues?
  115. How MucH boost on a GT35R w/ Meth & 93oct?
  116. Effective duration of Buschur Racing BF272 Cams?
  117. Transfer Case?
  118. Vibration in the car!!!(how to adjust the balance shaft?)
  119. Damn licp! Help
  120. Oil Pressure gauge??!!
  121. Which Spark Plugs?
  122. why do my plugs look like this????
  123. AMS Turbo
  124. speeed crazy
  125. Ticking noise after letting off throttle?
  126. Can someone explain the benefits of clipping a turbo?
  127. MR Transmission Problems HELP!!
  128. Greddy bov flutter?
  129. AMS 6 Speed shifter bushing HELP!!!
  130. shifting problem
  131. twin scroll hype?
  132. BR3065R or AMS3076R
  133. 30 PSI with meth is TOO MUCH?
  134. The Great Dyno Equalizer
  135. Installed Buschur o2 housing/licp thoughts and feedback.
  136. Tilton or Exedy Twin disc?
  137. Weapon R Intake Manifold
  138. EVO9 Dyno Results - Pump vs Race
  139. how much boost
  140. My JAM 2.3 50-trim dyno at CBRD
  141. First ride in my HTA35R car
  142. Fujita Intake and UICP
  143. Good Clutch?
  144. Um yeah 2step not working
  145. Would dealer notice a reflash? Warranty claim?
  146. Big problems on my drive home, blown motor?
  147. Intake Manifold Upgrade
  148. When changing tranny, t-case, and diff fluids
  149. exedy question!
  150. HELP missfire problem
  151. HTA GT35R on an AMS kit!
  152. OMG!!! Just opened the air box...
  153. dp
  154. Dead battery....
  155. first time to drag strip tomorrow
  156. ets gt35 kit - needs vs wants
  157. end all 2.3 2.4 2.1 stroker big block thread
  158. My cam compare data
  159. Greddy Oil Cooler Kit
  160. Highest whp 2.0L EVO on 91?
  161. performance problems
  162. For those who have ported FP Green hotsides
  163. Got tuned today...340.6 hp!
  164. 16g to green PLEASE READ
  165. 2.3 gt37 what cam?
  166. Need help, car won't start after breaking Exhaust O2 sensor
  167. Hallman mbc boost problem....
  168. Best test pipe
  169. EvoGreen w/ 9.8 housing
  170. Engine clearances/tolerances
  171. Exhaust "ding" bell sound?
  172. Evo 8 service manual
  173. Couple of DP/Test Pipe/Sensor Install Questions
  174. How much power on stock injectors?
  175. Blowthrough Users
  176. Megan Racing Exhaust
  177. Help with clutch smell
  178. Strange clutch slip. Video
  179. has anyone swtich from a Non-DBB to DBB turbo?
  180. Cause of black spark plug electores
  181. Buschur Racing Intercooler ?
  182. arp head studs (yup im gonna pull the head)
  183. Evo 8 Mr Vs Evo 9 Turbo?????
  184. Exhaust Manifold ?
  185. Neo Mtf
  186. Max Boost Level & Rpm
  187. RPS 6 Puck
  188. Safe Boost Level
  189. Max RPM rev limit??!!
  190. horse power numbers
  191. 600+ftlbs cars, please help choose a clutch
  192. RPM when cranking engine
  193. oil presure light
  194. 501whp 37r Ems Stock Block Ix!!!!
  195. what clutch and flywheel are you 6spd guys using
  196. 3rd to 4th problems????
  197. Tanabe Concept G Blue, any good?
  198. Finally found out what happened to the motor
  199. which clutch would be better for me
  200. EVO 9 HKS cam=hollow??
  201. Diagnose my in-cabin oil smell?
  202. transmission problems
  203. Ball Bearing Or Twin Scroll
  204. Read this about ALS, anything on the market for EVOs?
  205. Cam Position Sensor Harness Help
  206. diferences gsc 280 vs S1
  207. What CAM for a 2.3L with a 50Trim? Experts weigh in
  208. Replace stock "spring bolts"?
  209. Clutch gone?
  210. FIC 750 injector questions
  211. 2step water pump/head gasket failure
  212. exhaust question
  213. PTE vs GT
  214. Backfire at 5k
  215. Ever seen this JDM 02 housing??PIC
  216. Serious 4 cylinder power
  217. HKS DownPipe Question for the Experienced
  218. Attn: FullBlown twin pump users......
  219. Oil inside intake pipe
  220. CEL came on.
  221. Ebay 57trim?
  222. What turbo do I want? EVO9 or GREEN.
  223. help on dyno numbers
  224. Finishing up install on AMS 35R and I need help
  225. BOV vacuum line
  226. Buschur Racing 8.88 @ 169mph *Video*
  227. Just Ordered ACT HDSS
  228. how is this possible...?
  229. Raced, in the cold..oil light randomly comming on..car not boosting/running like shi
  230. Help! Drivetrain/engine issues!
  231. Port and polishing turbo housing for 9?
  232. need help choosing cams
  233. where does this thing go?
  234. oil line feed sensor
  235. plateau of 16035.95 afr hz when logging?
  236. EVO IX Oil Leak
  237. need help car making bumping noise and vibrations
  238. New Dyno #'s
  239. oil pressure?
  240. ZEX Spark Plugs???????? HELP!!!
  241. Quaife front LSD vs ACD
  242. tach drive
  243. Perrin Evo Intake hose (hard silicon pipe) question.
  244. DP with WB o2 ??
  245. Buying Timing belt
  246. Forge or TIAL.?
  247. Finally.......8.88 at 169.4 mph, Buschur Racing
  248. Speedometer broken?
  249. Starter Issues
  250. Need mod advice … please !!!
