PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 [206] 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Loudest catbacks?
  2. Question for the gearheads: drivetrain-related . . .
  3. what does my spark plugs tell you?
  4. How do you remove the studs from the fly wheel?
  5. should i consider a fuel system?
  6. need help with selecting head gasket size
  7. stock cat direction
  8. trunk mount batterys??
  9. how much boost?
  10. opinions on 280/272 combo.
  11. HKS SSQV Blow Off Valve (Vent to Atmosphere) Stuttering Fixes?
  12. Fmic swap 2.25" to 3" need something
  13. Cam Gear Setting
  14. Ordered my BOV today...
  15. The loudest BOV
  16. Agency Power BOV, need help
  17. New FMIC with upper and lower IC Piping!
  18. BOV Supply hose.....
  19. Springs and retainers bring it on
  20. AEM EUGO- Why only 11:1?
  21. Limits of stock valvetrain
  22. HKS SSQV on 1G piping...
  23. HELP! Need new driveshaft...sort of...
  24. Alky Kit
  25. coating on ic pipe?
  26. BR330 question
  27. Koyo + Injen Fitment?
  28. 2003 Shift Linkage Diagrams
  29. Aps Bov Help
  30. Question about USDM Evo 8 MR
  31. New turbo Kit
  32. Can't shift to 4th as easily
  33. Blow-off valve performance?
  34. 21G vs. TME turbo
  35. Lightweight Flywheel????
  36. The EVO VIII vs EVO IX compressor housing
  37. Question for those with 264/264 cam combo
  38. Buschur vs. stock TBE
  39. My ATP 3071 dynoed…
  40. Akward noise??
  41. No highway / cruise drone axleback?
  42. How to get rid of knock???
  43. 2 Step Launch Control
  44. Lower i/c pipe: One of the best mods I have done.
  45. Stock turbo question
  46. Greddy profec b spec 2?
  47. clutch replacement...
  48. Just installed GSC 272/264 cams + Blitz BOV
  49. Intecooler Pipe Kit and 10.5 hotside..
  50. same psi on larger turbo makes more power than smaller turbo
  51. Ferrea or Supertech valves?
  52. ignition system question
  53. Need help-cant get donut gasket off!!!!
  54. Torque Spec's
  55. running Evo on 87 octane w/ water or H2O/R-OH injection
  56. Headstuds, are they really worth it???
  57. 100 unleaded and Alky... Boost?
  58. clutch height is getting a bit high...how to adjust it down
  59. HP/TQ increase from 1psi/0.069bar increase in boost pressure on stock turbo
  60. water vs. water/R-OH injection
  61. So I went to go get flashed...
  62. Any vendor has TME turbo in stock?
  63. GT3076 Owners: Please post opinions...
  64. Sick Evo.. need a doctor.
  65. 2.3 stroker + 6.5 TME
  66. Changing synchros - replace clutch?
  67. HKS 280's?!?!
  68. perrin exhaust
  69. The real deal in exhaust cutouts!
  70. Oil Cooler Leak
  71. Headers? Megan Racing quality
  72. need some help.. only running 4 - 5 lbs boost
  73. Need to know ASAP!
  74. Best Exedy Clutch for $1500
  75. Blitz boost controller for sale
  76. Is my clutch gone?
  77. Damnit, someone just tell me the friggin Truth!
  78. estimated hp?
  79. BOV adjustment *help!*
  80. a little mod help...
  81. Need help asap, MR DV or APS BOV?
  82. 2.3L stroker and stock turbo?
  83. Should I turn the boost down or leave it as is?
  84. boost cut
  85. Different gear fluids for 2005 Evos?
  86. Can someone post pics of their installed HKS R-SPEC FMIC?
  87. Need 3037 info, pls
  88. Intake - BOV mishap?
  89. A clunking noise when backing up...!
  90. ATP turbo kit ?s
  91. INSTALLED: Buschur TB, Cusco Rear Sway, and Perrin Endlinks (long)
  92. HKS 30th Ann. worth it?
  93. How do You, launch/shift/drive your car?
  94. hallman boost controller and buschur boost controller
  95. Piston and Rod question
  96. highest boost at stock?
  97. HELP! my Evo is only pushing 14.5 lbs
  98. Poll: Helix TBE or RnR TBE
  99. Best Stroker Kit?
  100. Problem when power shifting?
  101. Borla Exhaust Manifold is peeling can I scrape it off?
  102. Anyone with aps piggyback/performance kit?
  103. Not just another boost leak
  104. Cat back results.
  105. ACT street disk/400 plus whp
  106. best way to mod your car?
  107. EVO JDM MR Diverter Valve from Z1 Performace
  108. 3" 02 housing yeh or neh
  109. piecing your own turbo kit
  110. HKS engine lubricants
  111. Straight of Helical cut ?
  112. Where to find 3'' turbo outlet pipe @ & header
  113. Read Me!! ACT Clutch review
  114. WHP limit on 93 octane
  115. Engine running lean. what's causing it?
  116. Running lean, what's the problem?
  117. Boost Surge, or do I just not know what I'm seeing?
  118. Need new turbo !!!
  119. Max Boost on stock injectors?
  120. HELP!!! Need service manual
  121. It's so pretty.......
  122. My Evo will hardly crank or stay running..Help!!
  123. Need Help!!
  124. SAFC II Cel????
  125. Problems with Synchro? 5th Gear?
  126. Installed APS BOV... Almost stalling/Revs drop in 1st gear
  127. Effectiveness of a Turboback Exhaust
  128. Crowns and pinions.
  129. missing parts, missing boost.
  130. Forcefed vs Nisei
  131. Front Area Value For Datalogger?
  132. Twin disc clutch sound under deceleration?
  133. Maximum engine can take?
  134. NORMAL READINGS for EGT, FUEL PRESSURE, OIL PRESSURE, OIL TEMP, WATER TEMP
  135. ATR catback??
  136. no boost
  137. Spark Plugs, replace
  138. is my clutch gone?
  139. question about pulllies
  140. Knock and Detonation
  141. Dry nitrous install EMS
  142. MBC with SAFCII?
  143. Installed my JDM Diverter Valve tonight (MUST READ)
  144. are you using 272 cams?
  145. P0340 & P0355 wtf
  146. whinning noise
  147. two problems linked?
  148. Cutout ?
  149. intake temps with stock intercooler
  150. DP/Loudness, and cat question
  151. Gear whining noise ideas?
  152. Anyone Try Blitz Induction Cover
  153. Starting COP set up
  154. 04 evo ecu install into MR?
  155. ARC Intercooler Question
  156. 272's or ACT street?
  157. Will mitsu fix my syncros w/ my mods?..
  158. Getting cams and what ealse?
  159. Ralliart Dog Clutch 5M/T Kit - Streetable?
  160. Hunting for idle after 264/264 cam install
  161. I want 400 whp!
  162. cams 264 or clutch?
  163. guys w/ aftermarket cams, what is your idling vacuum
  164. evo ix turbo vs viii
  165. What PSI on Race Gas (Stock turbo)
  166. GSC 272in/264ex idle videos
  167. Evos with exedy carbon
  168. Help, car is stalling when lifting off throttle
  169. i need more help please
  170. How to electronically eliminate ACD from 2005 evo???
  171. Spark Plugs?
  172. has anyone replaced the clutch rod??
  173. APS BOV, NEED ADJUSTMENT>?
  174. Any Problems with Greddy BOV
  175. Rough idle when power equipment on
  176. Odd driveline noise...?
  177. power out of stock turbo
  178. How much can the stock fuel system handle
  179. Help!! Boost leak maybe - stock
  180. Idle issues with injen intake?
  181. Does the GReddy Oil Pressure Gauge Fit?
  182. Buschur Stage 4, What should be my next step?
  183. Oil on Spark plugs
  184. Tapping after CAM install
  185. wich is better for 0-60 & 1/4m tims !
  186. Any1 have BUSCHUR INTERCOOLER with aftermarket front bumper?
  187. Hole in Downpipe/Effect on Tune
  188. plug or unplug boost solenoid w/ MBC? That is the question!
  189. Best Price - OEM Flywheel
  190. which downpipe to use with rmr catback?
  191. Turbo going out?
  192. Foam Filter Efficiency
  193. air intake (cone) or drop in high air flow filter??
  194. Has anyone Sleeved?
  195. Intercooler gains
  196. ams turbo kit ?s
  197. Forge DV: Which color spring are you using?
  198. '03 Evo 6500 miles: dead tranny?
  199. logic performance tbe?
  200. weldings on the manifold runners
  201. hey guys i really need some help..
  202. Service engine soon light came on at the track?
  203. porting the head...got question
  204. PO243 code ???? Anyone???
  205. Best way to achieve 375-400whp on stock turbo?
  206. Tial wastegate and leaded fuel?
  207. injen intake question
  208. APS bov and injen intake set up
  209. weird popping noise
  210. Hp and torque gain?
  211. Working on an engine swap, mid mounted 4G63T - couple Q's
  212. Whats the best INTERCOOLER for under $1000???
  213. need help mounting intercooler
  214. Anybody have an EkuTek reflash yet?
  215. FREE INVIDIA PARTS- need test monkey
  216. ATR exhaust sound clip?
  217. P0300 Issue.
  218. Going on a boost hunt
  219. need 22psi profec settings
  220. What do you think about this crap.
  221. GT35/40R vs. AlienAuto Turbo! CHECK IT OUT!
  222. Recommended Header for Stock Turbo
  223. I just notice something about BR
  224. MR DV. How much PSI will it hold????
  225. clutch noise on downshift....?
  226. Crack sound before goes into gear?
  227. TurboXS RFL-Ti Exhaust installed
  228. Help on Check Engine Code.....
  229. A few boost questions
  230. Installing stock bov backwards......
  231. BR500 Turbo Upgrade
  232. Downpipe & Test Pipe suggestions
  233. Greddy Type-S knock off? Any luck?
  234. Anyone else have this problem with Buschur turbo-back exhaust?
  235. Out with the old DYNO in with the new!!!
  236. hey i need help with gauges on my evo..
  237. mechanical or electronic boost-gauge?
  238. Walbro problems?
  239. Wild boost chase
  240. Timing and AFC fix help or ideas
  241. Larger Fuel Pump Needs a larger FPR????
  242. 650cc Injectors...?
  243. Hesitation at WOT now?
  244. Needing Clutch.. Exedy Twin Disk?
  245. Cams acd CELS?
  246. Flash without fuel pump?
  247. Diff between HKS SSQV & SSQV version 2?
  248. Transfer case question
  249. bought the HKS EVC, boost cant get past 14.5 psi
  250. hks hi power with 3 inch pipeing
