- Leaky hose problem....need suggestions
- IC Coupler Size?
- Noises
- Poll: FMIC - Front Mount Intercooler
- boost problem...
- IX - mbc and tbe safe w/o flash?
- Megan and AMS exhaust question
- signs of bad head gasket?
- anyone change clutch in 05 MR yet?
- New exhaust-ordered!
- TILTON C/C vs EXEDY TRIPPLE CARBON
- Need Evo Gurus Help. Boost drops off at 6K
- Slowboy Intercooler?
- Carbon Fiber Drive Shafts
- Oil catch can necessary on 05 EVO??? I have a Greddy one sitting here...
- Evo 9 transmission grinded been solved?
- Evo fan
- Knock Sensor: At what voltage will the ECU pull timing?
- ordered 20g-9 from Buschur
- New Turbo
- AYC oil
- GT42 v. T88 v. T51R SPL
- 3037 exhaust housing vs GT35r's ex housing ?
- 50 Trim turbo vs. ALL
- ebay 02 housing???
- CAM Gear settings for GT35
- RnR 02 elim downpipe
- crank shaft
- Forge MBC
- Ebay Intake Adaptor .....
- Fuel cut on almost-stock EVO?
- Torque damper installed!
- Evo differentials
- Engine Starting Problem
- titanium stretch
- APS BOV, not blowing off
- timing belt. I need help quick!
- HELP: Final Gear Ratio
- Oil leak easy question
- evo spun out... now CEL
- how bad would it be to drive with a spun rod bearing?
- wierd problem...help?
- Vibrating from clutch at tip when about to engage?
- EVO9 mivec question.
- a good buy? new turbo
- What cams to get for the EVO IX
- GT35R vs 50Trim
- Cast Iron VS Aluminum BLOCKS
- I can't make up my mind!!
- exhaust leak
- low oil pressure light at idle
- overheating problem..or so the gauge says.Please read.
- cams: HKS 264/272 vs. 272/272
- Intercooler Piping with stock air box?
- Evo 8 20g TME
- Again!!!
- Ralliart Thermostat - 03 EVO
- Which electronic boost controller are you using?
- eids or grounding kit?
- Short Throw Shifter (B&M or Authority)
- New Car, Trans Problems?
- throttle body is sticking.
- idle, throtelbody or ecu
- intake question??
- Rough Idle & Bogs when you give it gas
- boost problem
- Weather temp. changing the hp
- Forge Wastegate w/ Halman MBC
- Intake for map conversion... help?
- Clutch help
- BOV's have stalling issues?
- anyone got soundclip of a stock evo with kn&n air filter & aps dualport BOV?
- RNR, Full Race and Ebay 02 housing testing by Buschur Racing
- How do you guys check your boost?
- Napa T-Bolt Clamp Listing | great tool
- Running Rich?
- Another EVO IX Dyno...
- Heavy Modifications on my Evo 7
- Turbo upgrade question...
- MSD DIS-2 Launch Control
- invidia cat back
- gsc 272 cams installed, no power?
- EVO DN Stainless 02 Housing
- How much boost can the car handle?
- P0243 Turbocharger Wastegate Solenoid A Malfunction
- boost spike?
- Is it time to replace my stock BOV?
- does our evo eats up oil???
- evo9 turbo
- how to brake in new engine
- please help...Idle/low Rpm issue
- Aftermarket ECU Driveability
- Cam gear bolt stripped and stuck. Help?
- rattling issue??
- Destroked 2.4 block to 2.1 liter. Who has one?
- break in period for clutch
- Any APS users here?
- Randomtech cat
- The end all comparisons between two dynos
- GSC Cam Sec Release!!!!!!!!
- Buschur Catback Question?????
- Powerflex is all good... (56K problematic)
- RPM drops fast during gear shift
- Where to buy MAF (Mass air Flow sensor)
- Holy overboost batman! well over 2 bar
- WG behavior and actuator questions
- Evo IX turbo needed:
- Once again...another cam post (I did search)
- Where to BUY HKS SSQV...?
- HKS 280's over 272's on 2.3 stroker
- what is stock boost?
- Ziegler Nichols tuning method
- exedy twin disk premature wear?
- new clutch...
- Dyno numbers with a small shot
- trans nosie or normal
- 2.3 with ported head and HKS 280s question
- good turbo outlets?
- logic 3" exhaust???
- exhaust diameters
- Evo Fq400
- Shepard Racing or T.R.E.?
- Who has the best prices on Exedy single carbons?
- [Vid] Boost on launch
- Any IXs with Megan TBE? Let me know.
- Clutch Suggestion Economy/Sports
- How do you prevent wheel hop
- single disk clutches???
- ACD Article - Answers for everybody!
- stupid question
- Turbo Information
- ACTman Only please!
- Chatter sound after new clutch/flywheel install
- Poll: 20g or fmic&alky
- WORKS TRD 340 kit
- exhaust emissions...
- Heat discoloration ...
- Shifter bushings
- Clutch sticking
- Forge MBC
- Poll: People With cams look inside
- Exhaust help needed.
- Buzzing/Vibration from powertrain.
- AFR Questions
- How does UR testpipe prevent CEL?
- noob question, BOV flutter...
- vta bov
- 5-speed EVO 8: Short Shifters....how many people using them?
- Need a little help with a decision.
- o2 Housing +exh manifold or Turbo Internals
- Helix HFC vs Helix Test Pipe
- Turbo Lag
- HELIX oil catch can INSTALL
- Strange stall...
- ix fuel cut at 17lbs help
- between these two exhaust...?
- precision dyno and my 03
- Round III: IX + Ecutek + Nisei + Precision=:)
- Just got Ceramic Coating done...
- Spark plug question
- what is this noise at high speeds?!?!?
- Gear oil questions
- my exhaust...tips?
- 2.75" vs 3" downpipe?
- what should i choose???
- Clutch Help question about buying a used clutch.....
- Parts from 8 fit on 9?
- VTA or Recirculate more?
- MR BOV to Stock BOV
- Owners Only ... Perrin Intercooler ...
- Exhaust Problem
- HKS 264 ex. Cam Question
- Which oil to use for Front LSD / ACD ?
- Cylinder Pictures
- SES light and oil levels
- my ams stg3 dynoed at 310awp/480FtLb
- How much air flows into your engine?
- car dies at idle please help
- MOTOR REBUILD!!! Need Help.
- Support for cams Cams
- Reflash for your ACD Controller
- Fighter's garage lower I/C pipe review
- Hallman In Cab MBC
- Buschur Throttlebody & Intake manifold
- Logging Stock MAF readings?
- Unorthodox Racing pulley
- What size injectors to go with??
- Evo IX MR compatible exhaust thread...
- Injectors for 94 DSM on Evo HELP
- Pressure plate and clutch disc or just disc?
- Diagnose my Transfer Case
- 280 vs 272
- I/C Pipping
- aps bov installed
- JDM MR DV -> Forge RS DV (initial review)
- My Own Stage 1 Almost Complete!
- Japanese HF cats
- Can't stop the knock
- Looking for a wideband with a switch power output, like user setable
- Over Rev!!!!!!!
- What Is Best Turbo Upgrade?
- 20G turbo & Magnus/Tubular Intake mani
- down pipe wrapping and torque?
- 4G64 vs. TOMEI crank
- MAF Sensor problem or not
- Intake for map conversion?
- Car keeps stalling out
- Help with clutch
- Dumb Question???
- What is the turbo on the FQ-400
- Intercooler Tech - Bar and Plate vs. Tube and Fin
- n00b NOS question
- Buddy Club cams = 12hp & 4ft/lbs???
- Has anyone else seen this?
- Probably a difficult question to answer, but
- what the hell is this noise? got sound clip
- What's the difference?
- Newest numbers from TopSpeed!
- SS clutch line..has anyone ever...???
- Evo IX power thoughts, questions.
- Detonation?? please help....
- anyone got the new Buschur racing TBE system lately?
- Help Broke the spring bolt on downpipe
- GFB BOV setting
- Rebuilding Tranny
- bov on ic pipe or intake
- EGTs Cold Weather?
- HELP!!!!! oil temp. sensor wire!
- Crappy gas mileage after just a turbo-back?
- Cam Gears!!!
- Buddy Club or HKS CAMS
- Most power for the money?!?
- Kill switch for an alternator
- Are cams worth it?
- Please help me find a part for my EBC
- Drivetrain prob?
- HKS cam gears slipping?
- Drivetrain rattling question
- My stock 05 EVO clutch rattles at idle?
- **Dyno question**
- The "Real Truth About Intakes" ?
- Clutch driving help for all
- can somebody read these plugs for me??!!
- Catch can goop on breather side
- Initial thoughts on Vishnu IX tune
- Air to Water?
- Any other multi switching systems for air/fuel failsafe?
- For those who have AFR gauge
- ams bov and k&n drop in
- Part iden help please
