- Clutch replace or rebuild?
- RS Belt?
- When is it time to upgrade from the stock ignition?
- Engine break-in on e85?
- the right turbo for a 2.3L stroker
- What more can I do to improve my shifting?
- What oil filter do you use?
- Do I have a Boost Leak ??
- Anyone play w/ BW s300 series turbos?
- Solid Lifter Camshafts
- Transmission whine?
- Clutch Job
- Need some answers...
- turbo question
- what cam's should i get for my 9?
- Timing belt loose
- how much whp will i get from this setup. do reply plz.
- Pics of my new 80mm FP Red and head work
- Swapping gears in the transmission question
- Tanabe Concept G Pictures (56K fail)
- Help with the hotside
- Jun BL USA
- Stock and leaner tune produced the same HP & TQ curves
- Intake question for those running a speed density/MAP/AEM EMS setup
- Rod end caps: which side faces the flywheel?
- Whos running Kelford 272's on stock turbo?
- Hotside V-Band Clamp Torque Spec
- fp actuator and profec 2
- Modified wastegate actuator
- Best Turbo For 06 MR
- ACT Street Disc Clutch Abuse....
- Maf Sensor Question?
- A/C issues..
- 35r install. Oil and Coolant Lines.
- Turbo Oil Feed/drain lines
- A/C Problem
- Question about tuning Lancer EVO 03
- What bearings?
- Car cranks but won't start, Check Engine light blinking...
- Having a Problem. Can you Help?
- turbo sounds strange
- Intake install...
- Fp red?
- Stock Evo8 Pistons VS Stock Evo9 Pistons (Compairason)
- All 3 ACD lights on..
- Making the rear diff stronger - Cryo treat?
- Cruising in 5th gear @ 10.0 AFR
- Low oil after 1000miles!!!
- evo 1 injectors/fuel rail wont go all the way on
- Strange noise when in 1st gear only`
- White smoke that smells like fuel?
- Anyone have a Clutch Masters?
- Evo 9 Timing Belt
- Battery/Brake lights on..
- power steering reservoir cap leaking??
- IX and X stock BOVs the same?
- Need help, Idle, afr issues
- Camshaft Position Sensor trouble?
- balance shafts?
- Weight of a 5 speed transmission
- Engine Overboost code at 11psi??
- oo Brass shavings in my oil!
- 1st gear is 3rd, 3rd gear is 3rd and then 1st finally comes online after downshift
- blown motor, thinking about swapping a jdm motor in the car
- Shearer Stock Frame Turbo Tubular Manifold HAWTNESS!!!
- SAS/ALS install usdm evo 9
- 2 very different exhaust systems... but which flows better theoretically?
- Cant get into gear
- Transmission Fluid Volume Question
- Piston Top - Front Marks (Dots) - What do they mean?
- o2 sensor replacement for hi rollers
- Garrett or Bullseye T04e 50 Trim?
- Evo 8 to 9 engine swap
- CompClutch
- Just bought a QTP downpipe and electric cutout for my 100% STOCK car....Any thoughts?
- Question about discoloration on Pressure Plate
- Thinking about making a straight pipe TBE
- evo 8 evo 9 o2 sensor
- TurboXS FMIC??
- OEM spark plugs vs others???
- Stud Extenders
- Car Not Starting after putting HKS exhaust on !! Help !
- Samco intake setup for a stock Evo 8
- Couple Questions...
- Amsoil VS Redline evo8 trans fluid need your input
- removing silencer from greddy ti-c
- No power to fuel pump!?
- guys i really need help
- wiseco pistons?
- EVO IX MAS Bolts Stuck! HELP!!!
- help id this licp??
- Wierd clunk
- clutch
- Need help in installing turbo smart boost controller on evo 4
- best Head gasket
- Non ACD Transfer boxes
- Need part number asap!
- idle/stalling issues
- Sudden jerkiness when let off throttle
- Question from a newer owner
- blown motor please read, (its not a story)
- pressure in rear diff?
- evo9 starter on evo8
- Has anyone dyno'ed the new Greddy or Titek v2 turbo outlet aka O2 housing
- Oil light flickers on and off at idle?
- Exhaust manifold......
- Evo rear diferentia convertion for mirage
- Water temp overheat
- fidanza test pilot elect?
- Best intake pipe for stock ecu ?
- fpred 80mm option
- short shifter
- BIG PROBLEMS!!!!!!! I need help
- Upgrade 35R or GSC or Kelford cams
- VSS bolt size?
- this isn't a 9 BOV is it?
- how resolve this type of surge?
- How to keep the crankshaft pulley in place.
- Cam Timing... An excerpt from a friend
- acceleration grind???
- GSC s1 or s2 cams for fpgreen
- Normal Idle
- help
- problems with my new shep trans install
- Look what i did to my front diff
- Parts for Evo V-VI??
- Overboost Problem
- Noob Question about Starter Location..
- Did anyone tried Pulstar Spark Plugs?????
- Hallman MBC Pro RX ceramic ball
- HELP Experiencing Shift Failure
- T-bolt clamps
- looking for GM maf delete
- EVO 7 parts on an EVO 8
- where would I find this jdm part
- what sensor is this....???
- changed the intake and got idle issues
- AMS turbo kit problem with hta 86...
- are these hks cams?? PICS
- EGR Solenoid Removal + Replacement
- Oil leak need help!
- roller tip rocker's
- need wire diagram: evo 9 gauge cluster harness
- Anyone running 20G???
- stroker
- Quick boost question
- Wastegate Actuator Arm Came off
- sputter / backfire (e85 evo)
- Need some help with something
- Clutch Problems please help...if possible
- reduce hot air
- Boost problem. 10 PSI only.
- DIY: 35r kit, wisdom from those who've done it
- where is ignition power transistor?
- metal shavings in oil...
- Igniton help!!
- Help! Hesitation on throttle
- Rattling exhaust problem
- 2003 EVO car completey turned off after sharp turn
- HELP! no 6th gear!?!?
- acceleration problem
- Rewire Walbro?
- Alternator problems??
- HELP!! Can't get into 5th gear
- Help with diagnosing an engine sound..PLZ
- Need Help ASAP!!!
- How different are the Cossworth M2 and Kelford 272 for Evo 8
- Tcase install?
- Meth Kit or Bigger Turbo?
- water pump- oem??
- Revolver cam help...?
- Need help with oil leak!
- blown transfer case or not?
- Stuck TOB
- T04Z Turbo
- What PSI Is Safe On 110 Leaded Untuned? Evo IX
- Third gear stutter
- "Hiccups" around 5,500-6,000 when flooring it
- What size intercooler to get?
- Cylinder bore type and pistons needed
- sheptrans or buswacker???
- help plz
- Confusing Problem?
- oiled filter
- P0340 Code. Only...!! no start.
- Quick SLAVE CYLINDER question
- Greddy V-Spec intercooler
- O2 Housing vs. Dump
- Oil Line to turbo
- Bottom end rebuild questions
- Dyno numbers WTF?
- Can someone give me pics of stock turbo lines
- Tomei vs. BBK Full vs. FP Red Flow -- Flow Data
- transmission fluid..PLEASE READ
- Anyone using competition stg 4 clutch
- Evo 1 water pump
- So... my engine mount broke, but not how you would expect...
- Changing Clutch: What Oils to Use??
- New Turbo suggestions
- Help with rattle. Not Throw out bearing
- Buschur racing 2.3L break in
- ACD Fluid rising and falling
- Quad Turbo Evo
- TC whining and lessons learned
- How To Prevent Cracking Aftermarket Exhaust Manifold From Cracking
- Spark plug crushed... how bad am I screwed
- quick radiator question
- bov HELP!!!
- Turbo ???
- TOB keeps coming off pressure plate
- Most def couldn't be happier
- Got my Shearer stock turbo header today (pics)
- compression
- Inline fuel pump...
- Clutch Vibration???
- Quick question i cant seem to find anywhere
- School me on the FP Turbo differences
- Urgent
- aftermarket o2 housing or stock?
- Boost Coltroller HELP!
- need some info on turbo manifolds!!
- Differences between evo 8 and 9 J-pipes
- Anyone have info on a borla turbo manifold?
- Help!!!!!!!!!!!!!!!!!!!!!!
- Question about BR intake filter
- random idle problem
- Idle Problems
- 6spd build.
- Synapse BOV...does it just NOT work for some cars?
- how about this kit?
- titek vs invidia 02 housing
- Help Engine high rpm knocking
- clutch fork!?HELP
- Transfer case parts
- TiAL BOV Question...
- Water pump leak / defective?
- Wideband O2 Sensor/Gauge installed in Test Pipe ??
- cam question
- Stock or Aftermarket?
- Need a new clutch
- how much whp?
- Oil on top of spark plugs?? Help!?
- Burning oil, or not burning oil...???
- Help starting issues pic inside..
- Tial wastegate help!
- Ethanol fuel conversion
- Evo 9 Intercoolers and Piping
- little bit of cam help
- ATTN people with 5th gear grind...
- Modding?
