PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 [208] 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. What kinda tune for cams?
  2. Low Dyno Numbers
  3. ? about rev limit
  4. Difference between Evo 1/2 and 3 Passenger 2-piece Drive-shaft ??
  5. High revving ACT upshift
  6. hks 264/272 on stock tune????
  7. 4G63 Head
  8. Stock Bov?
  9. GSS342 255 fuel pump
  10. how to install HKS DLI2
  11. underhood bushings on ebay
  12. WHP=11 in 1/4 mile
  13. Need Help!!!
  14. Front diff rattle
  15. Is this how a cam should look?
  16. Which mods to do? Approx 4G's with Install
  17. Evo will not accelerate in 5th gear --Help--
  18. I need help reconnecting a hose!
  19. Anyone have a Blitz Powermeter?
  20. Intercooler sprayer question
  21. Where to buy nuts/washers for Fidanza cam gears?
  22. Who sells / makes Racetek Pulley's?
  23. What do you think...........?
  24. Reason why Magnus is the **** and BJ is not...
  25. Fao Rnr
  26. Intercooler project
  27. Bov Help...
  28. Most you should strain your stock clutch with?
  29. K&N dropin filter > cone filter?
  30. Stupid Actuator!!!!
  31. Boost Gauge Needle shows boost holding, but shudder...wtf?
  32. Stroker Porn
  33. 3 psi pressure drop Buschur stage 3?
  34. What is this? PBC boost Controller
  35. waste gate type?
  36. what is causing my RPMs to DIP?
  37. Which boost controller should i buy? Profec b spec2 or Profec type s
  38. evo MR 6 speed vs. evo 5 speed
  39. Questions about PWR Intercooler
  40. Buschur's 3"TBE magnaflow part # and size? (+questions)
  41. FS:HKS 3037s Vishnu Stage 3
  42. Authority O2housing/turbo outlet
  43. new FMIC, less hp?!?
  44. Rear diff making noise
  45. fujitsubo RMO1A
  46. How much difference in daily driving does a sprung clutch make?
  47. How many running HKS Hi-power?
  48. APEXi Power Intake + upgraded intake pipe?
  49. My experience so far w/various part upgrades/additions
  50. Issue: Buschur Deluxe Front Mount
  51. hks ssq owners please read
  52. Injector Question
  53. installed cams, loud lifter noise
  54. WARNING: Helix o2 Housing
  55. WARNING: Weapon-R Engine Damper
  56. Myevostore: Any update on Nesei Kit?
  57. ACT pressureplate.... and RMR clutch.... ? ?
  58. Bad Hesitation after VIPER alarms install
  59. Hypothetical Poll:
  60. Does Buschur IC piping hold?
  61. Tranny problem please help!!
  62. Ultimate Racing High Flow Cat
  63. VR-4 engine in an evo?
  64. how does a MAF sense boost?
  65. rpm max
  66. Help on picking my EBC
  67. Notchy shifting. Synchros or clutch engagement problems?
  68. At WOT if my rpm's start raising but car doesnt go faster...
  69. leaking throttle body
  70. o2 sensor question
  71. EGT probe install ?
  72. My Turbo Kit Experience....
  73. Strange Feeling Powerband
  74. Defi Oil Pres Gauge Install HELP!!!
  75. 9 whp gain after TBE install??????
  76. What to expect from this list of mods? Any suggestions?
  77. clutch install today
  78. Authority O2 housing fitment
  79. Twin clutch or single carbon?
  80. seized turbo. should i be worried?
  81. perrin o2 sim
  82. HKS 30th Anniversary Hi-Power Review
  83. t3/t4 turbo
  84. Those with a GT35R question
  85. Will Perrin Cat delete pipe fit in my TurboXS 3"
  86. greddy evo2 + dc sports dpwnpipe
  87. HELP! Boost creep
  88. Intake Without A Tune?
  89. EGR Block Off Plate
  90. safe boost or no?????
  91. GSC 272/264's installed
  92. Buschur Racing modified EVO's available at Medina Mitsubishi
  93. Downpipe For the 05 EVO
  94. 05' Turbo outlet/O2housing fitment
  95. HELP!! My CEL Light went on.....
  96. questions about turbo upgrade
  97. Buschur Racing modified EVO's available at Medina Mitsubishi
  98. break in of twin plate clutch?
  99. wtb complete evo 8 motor
  100. log run/ evo WOT pulls help
  101. Strange vibration/rattling noise at idle
  102. Anyone have instructions on how to install a clutch?
  103. really interesting!!!!!
  104. ARP Rod Bolt ?
  105. Just want a CF muffler
  106. RPS twin disk > HKS twin disk?
  107. My EVO is hurt
  108. Adjust clutch engagement
  109. Clutch pedal floored!
  110. High flow cat to test pipe.
  111. HELP!! i cant get into any gear
  112. GReddy Type-S BOV question
  113. 20G Turbo Question
  114. b&m short shifter. kartboy yes or no
  115. Intercooler install pics
  116. Problem with my gt3076r setup
  117. "solved my gravel in the clutch sound!"
  118. not sure what sound is?
  119. OBDII Interface Cables - Where to get a good set for cheap
  120. PO335 & PO340 codes on CEL
  121. MBC PSI Question
  122. Tranny diagram...
  123. Replacement filter for intake
  124. help with aem ems
  125. ***downpipe question***
  126. Walbro 190?
  127. How much power can stock clutch handle?
  128. Attn all Evo owners running MBC!!!!
  129. To those with Tial wastegate and Profec B spec II
  130. Walbro FP actin up...
  131. Lsd and times
  132. Help me enjoy my EVO again .......
  133. Engine part & labour pricing for a fully moded engine ?
  134. does mitsus warranty cover the clutch?
  135. will Espelir dp fit 05 MR?
  136. dynoflash????
  137. are JDM and USDM internal EVO parts different?
  138. Ohh yeah....FedEx was good to me today!!!!! :)
  139. Couple BR intercooler shots
  140. ACT client assistance
  141. feedback on nology wires
  142. doe anyone know ?
  143. Pulling it apart
  144. HELP!! Leakin oil in timing cover
  145. Weapon-R Secret Weapon Intake
  146. Boost cut w/ no CEL?
  147. Stupid Question...
  148. kansai intake questions...
  149. Vishnu diffuser qns
  150. Vishnu diffuser qns
  151. Sorry to bring this up, axle back.
  152. Exedy Hyper Carbon Single
  153. How to locate a boost leak....???
  154. Remove resonator?
  155. Precision Turbo Engineering Fuel Injectors
  156. acd service question
  157. Autometer Oil Pressure Gauge Help
  158. stick a shiftfork in it.
  159. Traction Action !
  160. JDM Mr diverter valve
  161. Tanabe Ultra Med.
  162. What mileage to re-torque head studs?
  163. Hp Limit of the stock or TME turbo?
  164. 376whp/375wtq pump, 422whp/415whp race STOCK TURBO!!??
  165. I need a new clutch, suggestions?
  166. FPR- When to upgrade
  167. Engine Help!!!
  168. AFR Goals Question
  169. SARD R2D2 BlowOff Valve
  170. Question about Perrin Cat Delete pipe
  171. Restrictor Pills
  172. need stock parts for good ones
  173. Sad day
  174. evomoto camshaft install wanted!
  175. Best clutch for a 10 sec daily driver?
  176. stock boost?
  177. Downpipe For Mr Evo Viii
  178. Helix Downpipe for the 05 EVO
  179. Near Stock 05...I hit 24psi?!?! Where's boost cut?
  180. MR Transmission and T-case oil
  181. Need lifter reseller
  182. what should i do....water in the engine....
  183. Evo Awd System Vs Subaru
  184. is my head gasket gone or head cracked?
  185. AlienAuto is COMING! First Product Revealed!
  186. Test Pipe Noise
  187. Kakimoto GT1.0Z Exhaust
  188. Looking for high quality vacuum hose
  189. Turbo Boost Fluctuations
  190. Highest HP Stock block pump gas?
  191. ACD controller
  192. More Full-Race manifold pictures
  193. Best downpipe for stock catalytic?
  194. mod questions
  195. Question: Hose routing for my 38mm Tial and turbo?
  196. MR 6spd swap into an Evo 8?
  197. clutch question
  198. Part Number
  199. Question on boost
  200. Mitsubishi Turbo on a V8?
  201. Build your own FQ 420, 450, ...
  202. anyone presonally tried 272i/264e vs. (264/264 or 264/272 or 272/272) cams?
  203. Transfercase
  204. best turbo kit under 4k
  205. abnormal sound
  206. My new intercooler
  207. changing stock 02 w/ Wideband 02 sensor?
  208. BEST Drop in filter?
  209. Is the plug on the right fouled? see link
  210. Can't make boost, need help!
  211. got new Transfer case (team Ripp)
  212. Clutch Problems.... RRE No Name Clutch....
  213. Resurface flywheel?
  214. Buddy Clup Spec III Cams/Gears
  215. stock turbo
  216. HELP! evo axle rebuild NEEDED!
  217. Had a couple of questions about RnR turboback!!!!!!!!!
  218. Please help!!! I need your opinion :(
  219. pics of CAR, Fried Clutch, New Plate
  220. GSC 262in/272ex Cam Dyno Results (dynoflashed)
  221. MSD coils
  222. Aftermarket clutches update
  223. Quick questions on drivetrain fluid intervals.
  224. Looking for boost readings from turbo nipple vs. intake manifold
  225. Getting the best 0-60 mph time?
  226. Is this a dumb idea?
  227. HELP... evo sputters at high boost
  228. Limits of components in Evo 6
  229. need help with alternator diagnosis
  230. Help on BOV flange
  231. just bought intercooler spray co2 n2o
  232. Tommi Makinen edition 6.5 RS titanium alloy turbo
  233. ARP Headstud install?
  234. Transmission and t-case oil/fluid
  235. Can someone explain the purpose of a fuel surge tank.
  236. Cleaning my lifters today
  237. HELP...Diagnose my problem please!!
  238. EvoStore.com Reflash
  239. Magnus intake manifold, what kind of gain i have to expect?
  240. Brass Restrictor in Wastegate Hose? And a Leak!
  241. GReddy T88 in an evo III?
  242. Anyone know where I can get a Helix DP
  243. my cel light wont go away?
  244. Beware: Clutch Masters clutch explodes!!!!!
  245. Blow off valve?
  246. Inline Fuel Pumps
  247. GREDDY SPEC-R intercooler, ARC intercooler, HKS TYPE-R intercooler
  248. 412 tq (stock turbo) on 93 pump gas with Dyno Flash and Alcohol kit
  249. Cam timing question.....
  250. Broken exhaust manifold studs?
