- Trouble with A/F ratio
- 03 Evo dropping a sylinder at idle
- Turbo gone bad? Diagnosis question. Pics!
- wastegatge question
- short shifter for the MR 6sp
- weird problem
- My 50trim numbers
- Need Help Again Boost
- Cutting the Cat O2...
- Boost and Tempatures
- Evo a/f ratio question
- Running rich after tbe install!!!!
- Drivetrain noise?
- At what power level does a 3" intake become restrictive?
- Shaft play
- what clutch do i need?
- Acetone as Fuel Additive
- will the pull fan thats inside the engine bay come on with the car idle?
- Engine blown?? tranny is gone ??
- GT Series turbo, which is the water feed and return line...
- Stock Evo8 and Evo9 o2 housing?
- Transfer case problem
- Cams to use with 2.3 stroker?
- Redline MT-90, where to use?
- boost problem
- really worried need help ASAP
- Almost done with the full-race turbo kit install...
- transfer case
- Help!! Problems With Hallman MBC
- Meth Question
- o2 problem
- Know of any mechanics to install new clutch? NJ
- MBC install with a few problems!
- easiest way to access wastegate?
- FP HD WGA on 20G
- Car Trouble: Slipping Clutch??? Not Sure, Help!
- Car Trouble: Slipping Clutch??? Not Sure Help!
- XTD clutch and flywheel? anyone use it yet?
- Full Race Gt37 Turbo & Manifold - Dyno Sheet
- Transmission ?s
- Which Exhaust???
- Custom Intake Manifold
- Partial throttle boost.. ruins engine?
- turbo xs blow 50/50 hybrid blow off valve
- In Car - Valve Spring Install Alternate Methoc
- difficult to shift
- Best Tuned MPG?
- Transfer Case issue
- IX Engine idle noise (belt?) (video)
- Got a busted Cam position sensor--ok to drive?
- How is this tuning method accurate?
- For those of you that think twin turbo is better
- HOW can i hold more boost????
- Head unit install = CEL?
- DNP divided t4 manifold
- IX Cam Gears?
- oil leak after cam install
- After removing the clutch restrictor
- Anybody using the Blitz LM intercooler?
- royal purple in my 6sp now i need a rebuild
- Please Help!!!
- What do you guys think about all poly mounts
- TRE or Shep trans??
- HKS 280/camgear impressions
- full race GT kit running 14 psi.....
- What are the effects of 9.8cm puck failing?
- my cam installation - halfway done!
- intake????
- APS FMIC Help please
- How much HP/Torque will a reg Exedy twin disc hold?
- Hesitation/Slight Bogging with Throttle
- Will headers make you run rich???
- prime new turbo?
- Will I get compressor surge runnning 30psi on a perted atp gt35r?
- ebay o2 housing gasket question
- GT35R w/ stock IC piping
- 4G63 2.3 versus 4G64 Long-Rod 2.4
- Beatrush @ Kamispeed
- The cause of my TC's whine.
- Tial on 50Trim Install..
- Is this BAD???
- Vendors: Rebuild Kit/Package?
- has anyone try using Amsoil Synthetic Motor Oil ?
- What are the differences between good Evo's and bad Evo's??
- Stock maf + cold air?
- any tips on installing tranny and t-case
- Srs Light??
- What is the best anti surge hosing for atp gt35r?
- What are the 3 most important gauges?
- started tearing her apart for the full race kit...
- clutch pedal mybe???
- safe psi without tune?HELP!
- Please Help me....
- easiest way to run 2 maps
- Looking for parts
- will a evo 8 turbo manifold fit a 98 eclipse gst??????
- AMS Ultimate Fuel Pump Test
- Weird 2nd gear problems
- Fuel Setup Needed for 2.3/35R
- 8 and 9 turbo
- Need 20G-LT hotside help ASAP :(
- boost controller help
- Exedy HD tiwn plate clutch problem with reverse gear (help please)
- Big turbo guys, lets reunite and show off
- new GT35R setup for my 2.3...
- t-case fluid
- Cam Profiles
- Turn around time for a Green?
- drive with 280/272 w/no tune unsafe?
- 2.5l - 10.25:1 compression - EVO IX motor pictures!
- Need some informed opinions on Clutch replacement
- spark plugs on the 9.
- Black Smoke
- Tomei exhaust/turbo parts
- Ppi Ftw !!!!
- AMS vs HPF
- anything else before cams?
- Possible boost leak - anyone have a picture of which hose(s) I should check?
- Cleaned my MAF Sensor - Great Results!
- Cat Back With Stock Cat
- How to get 450hp
- Rear diff drain and fill
- fuel pump noise
- When is a new clutch needed?
- Buschur Cams BF272's here I come!!
- David Buschur's RS, just finished up with new pics...
- Suggestion Fp3065 Or Aem Ems On Ix!!!
- Pistons
- Transmission Blow-Off plate..?
- What plugs?
- Pics of 50 trim install
- Install another fuel pump on passanger side
- HKS Carbon Ti owners-Please Read
- HOW MANY PEOPle OWN A EVO GREEN TURBO
- What do i need to take off at 7k rpm ?
- timing and belt question
- On my way to fuel independence..........
- Whining. Possible rear diff, maybe?
- Check valves, Catch cans, and Vacuum for the PCV (discussion)
- Buschwacker is getting done
- DC Sports CBE.. Anyone have it?
- Question regarding my GT35R kit
- Another Clutch Question!!!!!! which one for 600 Please Help
- Getting ready to load a Jestr tune!! (and a couple questions)
- GT3076R so laggy ??
- turbine housing flange? help.
- Quick question about hotside
- broken axel?help?
- Cant find the EBay FMIC anymore?
- A question on injector size!!!
- Works exhaust?
- Can a o3 Evo transfercase be rebuilt?
- HKS EVC V problems?
- can anyone explain to me about the clip on the other side of the pp for tob?
- Which(size & brand) cams are you running with your ported head?
- Transfer Case Weight ?
- HKS DLI-II ignition on a fairly stock car?
- How to install different spring in Forge MBC?
- Thinking of 2.3L stroker
- Interesting testing - cosworth cams - 100 octane fuel and test pipe tested Evo IX
- Compression Test @ altitude question
- Charging issues!! Any suggestons
- yes another wierd noise thread...
- Power Loss???
- Swaping 9.8 to 10.5 hot side, help/sugestions needed
- need help, and pics of the stock evo8 turbo/housing.
- ARC Intake Box filter help
- Bost Creep, o2 or 18psi Wastegate?
- boost levels on stock internals
- Is Buschur Racing's Modified Walbro a good way to go???
- Would a broke rear axle with a busted abs ring stop the ACD from working???
- i neecd help BIG TIME
- Possible drive-train damage???
- Can I install a Walbro 255lph fuel pump without a tune?
- 06 evo9 Transmission Drain Bolt Size? bigger than 21mm
- Looking for PIN out of 04' 8rs and 06' 9MR
- Timing Belt Noise
- Quick question about ultimate racing test pipe
- ~~~~~~Race Gas~~~~~~~?~~?~?~
- 2 quick cam gear questions
- Has anybody put a mivec motor in a 8?
- I am thinking about drilling my compressor shroud on my atp gt35r turbo to prevent.
- Shep Tre or Bushwacker????
- Stock evo IX turbo
- exhaust questions?
- Buying My AMS GT35R Kit tomorrow and have a question
- Install time question
- ANNOYING!!! How many people have experienced this?
- Transfer Case Removal Help
- hi flo cat
- Checking for removed Clutch Restrictor
- Boost leak test:Cap I.M. or not
- EGT differences - at the runner / collector / O2
- Grinding In 4th gear... 2005 evo 8 mr
- upgraded turbos? 500 whp?
- Invidia header?
- Front driver's side wheel NOT SPINNING
- How much abuse can stock rear axles take?
- 10.5 Hot side
- Bushur or turbo xs
- Cam install and knocking like a SOB?
- Exhaust mani bolt sizes for heatshield
- The path to BR BB 50Trim
- Anyone ran a Green on an IX?
- aftermarket rod bolts
- 119mph VIII E85
- HKS Twin Power DLI II???
- next set of mods.
- Clutch for Evo 2005 VIII
- valve springs and retainers? Do u need em
- Daily Driven without many mods
- What is the proper way to solder in a new O2 sensor???
- Forge Rev. How much boost?
- AMS 50-trim vs 20Glt whats better for daily driving?
- AEM owners: what do you do come inspection time?
- evo IX not boosting?
- Need Help With New Car
- cone intake vs stock airbox
- Mobil 1 15-50
- Boost leak at throttle body (throttle linkage)..How to fix?
- Evo 7 rear diff gear ratio?
- Silicon hose any good ?
- Want to know what a tcase whine sounds like? Video Inside.
- Which would help more? Intake Manifold or ported head???
- High or low boost.
- 548whp / 440tq, Evo IX, stock ECU!
- HELP!! I think something bad happen to my engine
- Revolver sound clips
- My New Rps Max Clutch!!
- Nisie intercooler test question
- Tilton clutch wierd noise. HELP PLEASE!
- Mobil 1 Fully Synthetic or not?
- Break in period for cams ?
- when do i need to start tuning
- Car's acting crazy. Need advice!
- Some pics of Forge MBC mounting locations?
- AFR'S are way off. HELP PLEASE
- Wire Mesh over Turbo Inlet
- My 280 cam / tme dyno numbers
- Installed IC Piping Car Will not go into boost.
- 03 Evo into 1st gen Talon TSI???
- 50 trim times slips
- Greddy Type S BOV. help!
- P0420 doesn't effect performance my a$$
- questions for 2.3l guys
- Motor Problems car wont start
- Tomei Cams
- EVO IX full bolt-ons dyno #s
- BPR7ES copper vs BPR7ES non copper
