PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 [101] 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Help!! Throttle Sticking!!??
  2. IX MR Transmission fluid
  3. Spark Plug Recommendations?
  4. E85 hurting fuel injectors
  5. Best Twin Disc Clutch?
  6. Problem with turbo need help !!!
  7. Exedy twin disc hd or Quartermaster twin disc?
  8. 57 trim numbers on race gas
  9. FP Red and 880cc injector install
  10. Buschur Build/Tune + BBK = One Broad Power Curve!
  11. WTF ! My tune sucks and my car is slow - what next ?
  12. T3 o2 housing???
  13. Upgraded oil line for fp red turbo
  14. JMfabrications, making turbo dreams come true! Tial V-band manifold
  15. Getting ready to install GM 3port
  16. Just bought 06 evo! Problem!!!!
  17. Car not moving
  18. Walboro 255lph
  19. Valve cover is ****** up.
  20. stock turbo charge pipe.
  21. Case Hardening Shop?
  22. 3076 from 1g dsm to evo ix
  23. Question about Boost Solnoid
  24. Hallman MBC
  25. HTA 3076 and stuff on my IX MR
  26. Oil Feed Fitting? (Want to replace banjo bolt)
  27. muffler delete
  28. What spark plug?
  29. t-case seal!-t-case leaking fluid. SUGGESTIONS?
  30. LICP install help
  31. Muffler help
  32. Stock turbo SS Lines
  33. buschur racing intake pipe couplers
  34. Boost Problem
  35. Problems
  36. is an 03 evo8 turbo the same as the 05 evo 8 turbo?
  37. BR Double Pumper install?
  38. Injectors? Size?
  39. removing the honeycomb!!
  40. Please provide opinions on drivetrain noise
  41. How does this happen?
  42. T-case
  43. new evo motor parts...?
  44. Please help confirm/identify the issue
  45. Boost Problem
  46. Motor mounts
  47. Injector size limitations with EcuFlash?
  48. Exhaust header studs
  49. hey some one help me
  50. Gsc 280's any good?
  51. Spark Plugs
  52. Whining noise in rear.
  53. Stock exhaust on RNR downpipe?
  54. Can anyone tell me what turbo this is??
  55. Rear engine 4WD
  56. Head studs
  57. Release bearing?
  58. strange problem with p0136, p0505 and p0170
  59. Re-torque Head Studs?
  60. Test Pipe question
  61. Walbro 255 low pressure good enough???
  62. Help with clutch or slave cylinder issue...
  63. Twinscroll 35R or HTA35R
  64. 124k EVO IX MR maintenance
  65. IX MR owners
  66. need help!!
  67. Front O2 Sensor replacement Q?
  68. Has this ever happened to you or anyone you know?
  69. GT35r low end power
  70. Throw-Out Bearing wont Release
  71. Please Help MIVEC Intake Cam install Questions???...
  72. arp rod bolts!!
  73. I discovered this bolt was loose and leaking... [HUGE IMAGE]
  74. Exedy Stage 2 clutch vs ACT XTSS
  75. How high can you rev HKS Cams
  76. Cylinder Bad?? **PIC**
  77. Help! Off centered steering wheel *pics*
  78. Need new cylinder head. Looking for suggestions
  79. Alternate thermostat options?
  80. newbie build help
  81. 2005 lancer evolution rs
  82. need evo 4 axles
  83. Dsm head on evo8 block??
  84. Aftermarket BOV
  85. Kelford 272/280 IX cams
  86. 500WHP on 750cc's and Meth??
  87. how far to push a Green and 680's on pump?
  88. Opinions on shifting problems
  89. intake messing up MAS readings?!?
  90. 2nd Gear lockout
  91. fp green to paper weight ...
  92. Getting ready to install evo 9 turbo into evo 8.
  93. Fuel gauge not working
  94. Weird noise after Buschur FMIC install!
  95. 4" intake pipe/stock maf
  96. Buschur Racing 2.1L stroker kit now availible on the BR website
  97. evo ix ignition with msd dis2
  98. Cam TDC Marks
  99. New evo owner, help please, big problem
  100. Do you occassionally have light grind in 5th at high speeds?
  101. random misfire, EGR flow insufficient
  102. Idle all messed up...help needed
  103. Taping valve cover for large breathers
  104. Anyone heard of Pro Blend products...?
  105. Grind going into 5th at high speed
  106. boost questions....
  107. Lenght of Accessories Belt
  108. What are the differences between the EXEDY Twins?
  109. Bleeder Nipple on TC / Transmission ??
  110. place to get banjo bolt other than dealership?
  111. tell me what clutch to get.
  112. Which order should I install these parts?
  113. Tune or MBC?
  114. brian crowers 280/ 288
  115. Going for a tune...Do I need headstuds?
  116. Power steering fluid for the EVO???
  117. HKS Twin PLate Clutch
  118. Which cams..HKS 280's, Comp 280's, or FP 4R cams???
  119. my evo is tuned for a stock turbo to 340 i have a red installed on my evo is it safe?
  120. Which Engine Oil is the Best
  121. what turbo should i get
  122. What is this?
  123. getting rid of maf ?
  124. Aftermarket manifold on stock turbo
  125. should I build my engine? and to what
  126. Cam gear bolt snapped...thoughts?
  127. what is this?
  128. Greddy Boost controller issues..
  129. ? on block
  130. Type of oil to use with HKS cams?
  131. lol i knew this would happen!!!
  132. problems!! need help car will only go 20 mph
  133. Ok the FP RED is out, Whats next?
  134. 1600cc & stock ecu & e85
  135. no boost?
  136. Anyone have before and after dyno results of MAP downpipe?
  137. Bad Bish Update - Turbo Comparisons
  138. 05-06 evo factory 2 step
  139. What Cams are U RED guys Using 4 Street/Autocross?
  140. mishimoto line m intercooler ?
  141. Anyone Running Magnus 2.3L Stroker?
  142. Low oil while cruising??
  143. EVO 9 turbo
  144. Mystery Camshafts...Help Identify
  145. Problem after Clutch Install...
  146. Anyone have experience or info on Precision's new line of HP turbos?
  147. Boost help!!!!
  148. need help quick
  149. Question about setting timing.
  150. Need size of upper cam cover bolts for clear cover..
  151. doing something crazy and need some technical info
  152. Question about CC clutch kit! HELP!!
  153. no boost slow boost
  154. ix bov
  155. Spark PLug Gap ?!?
  156. cam install = no boost?
  157. transmission part number help please
  158. Just finshed my GSC S1 install
  159. 600hp short block options?
  160. fp red or atp ver.2 gt35r
  161. no boost with boost leak tester...
  162. arp rod bolt
  163. Question on ARP headstud install
  164. 1g or 2g dsm oil filter housing? Fit on evo
  165. Engine Loosing power and hesitating under load
  166. Trans help w/pics Need a used gear and slider
  167. aftermarket FMIC that fits on stock IC pipes
  168. CBRD BBK or Red for 2.3 stroker?
  169. hks mega suction
  170. EVO MR ACD mated to a EVO 8 5 Speed?
  171. Carbing Undertray and EPM o2 dump
  172. Sort of ACD issue?
  173. fp white anyone?
  174. 02 housing help
  175. Fp Red, 30R or 35R?
  176. Help, I drop 1 new injectors to engine (outside)
  177. Help Exhaust Leak
  178. While driving on the highway...
  179. Whats an IX engine harness worth? ( I have one)
  180. 4g64 and cam shafts
  181. What Is This?
  182. Harness for Map sensor ;(
  183. Resonators/mufflers/quieter exhaust? Where and how?
  184. Vendor for 9 Turbo compressor O-ring
  185. Diaqueen fluid clarification
  186. Spark Plugs - Are all those fancy plugs that claim increased power/mpg worth it?
  187. downshift noise????
  188. need help
  189. Perrin, Aem short ram or Buschur intake
  190. Triple Disk Rebuilt..Carbon to cerametallic
  191. used 8 head price
  192. More torque at wheels without any engine mods.
  193. Rebuilding my Transfer Case
  194. Any suggestions for my FP RED set-up?
  195. Is this the correct way to install FP Inline filter
  196. Motor Mounts
  197. Suggestions on LICIP and UCIP?
  198. Balance shaft removal question
  199. Question about my build
  200. What is normal oil Pressure ???
  201. Has Anyone Ever Seen Anything Like This?
  202. Evo 8 Mivec Conversion - specifics
  203. Wahlbro Question
  204. need part# for oem oil cooler
  205. anyone running fp5s?
  206. Apexi Power Intake
  207. Transfer Case Advice...
  208. P0132 cel
  209. o2 housing bolts!?
  210. 2.3 just in, question about some smoke.
  211. I'm stumped!!
  212. Drivetrain clunking, video inside
  213. TDC with no timing cover...?
  214. Clutch Pedal is stuck
  215. ACD oil
  216. 400whp on stock injectors?? Has it been done?
  217. idel problem
  218. Did your Evo IX fuel pump have this hole ?
  219. ? for those who have ebay short shifter
  220. egr code cel after clutch install
  221. What do you think i can rev to?
  222. Gear Synchros - Evo III
  223. Turbo surge on FPGreen or 20Gs
  224. Guess what I found while changing Spark Plugs... (look inside and help)
  225. fuel pumps (new)
  226. HELP please.. car wount start
  227. Rough Idle
  228. Thoughts on setup?
  229. Transfer case output shaft help
  230. Boost Issue
  231. Daily Driven Twin Disc
  232. Stock 2004 EVO 8 Throttle body size?
  233. Transfer case fluid and..........
  234. windage tray?
  235. can anyone help? wheel hub bearing
  236. Need Help on what to do about dump/dp exhaust leak
  237. Help!! New Clutch but throttle sticking.
  238. Stock WGA problem
  239. turbo problem
  240. Throttle Position Sensor adjusting help?
  241. Clutch problem need help ASAP
  242. Install Replica Tial BOV???
  243. Fuel and Spark Issues PLEASE HELP!
  244. Fuel and Spark Problems
  245. stock turbo
  246. rods and pistons?
  247. car has been down for almost a year now...
  248. debating 400+ whp recipe
  249. Whats wrong with this oxygen sensor?
  250. Wicked Twin Disk Rattling
