- Best Top End mods???
- Misc. news from Buschur Racing....
- Cooling problem
- Evo 7 ACD repair?
- agin mi ams evo
- AEM EMS and the Stock Turbo
- 20G and Dynoflash
- AFRs at 10:1 on Dynoflash. What can I do.
- Installed wideband and now my SAFC doesn't work?
- Tell me about Twin Plate Clutches.
- Do you think my 280 Ex cam is hurting my power
- My Dyno :)
- what kit is better?
- BOV or not?
- headbolts toqure
- Catback remove help!!!
- Boost Problem After Mbc Install
- what size turbo to get?
- Resetting ECU
- just finished clutch install...what fluids and how much?
- Stock boost?
- Installed MBC and have backfire problems.
- Clutch may be slipping already?
- Please Help!...Emergency! Fuel problem? Engine?
- Crazy idea but... *BOV Related Question*
- Will Cam settings offset the A/F?
- ams 3076R
- Transfer case carnage courtesy of evodave
- slight misfire...any help?
- White Rabbit vs TME turbo dyno comparision
- What's up with all these bolt-on turbo's...
- ams evo8
- OIL in the INTAKE??
- Engine Removal cost or hours
- Apexi TT Question?
- Boost Problems... only above 6000rpm
- Boost pressure Question?
- new clutch install, wierd sound
- defi bf warning question
- Will the Helix O2 housing fit on Buschur DP?
- Next Performance Mod Advice Needed!!
- nEEd iMmediate answer!!!
- silicone/custom piping radiator hose replacement ?
- buschur racing cat back fit ?
- act clutch problems
- Bad Over Revving
- gains from a dp..
- how many HP gain from HKS 272 Camshafts
- Greddy Profec B II Boost Control
- daiqueen oil
- Valve cover gasket
- installed tbe today. no check engine light?
- Turbosmart eboost-2?
- engine build
- which one??
- arp moly lube question
- ACT Clutch Break In (Need Definitive Answer to Specific Question)
- New clutch break in???
- Swapped Upper IC pipes...ALKY QUESTION!!!!!
- ic piping
- after tbe exhaust and BOV what else
- stroker kit blancing
- cam intstall with out tensioner
- HKS intercooler qyestion
- alky injection response time?
- New clutch... question?!
- TSB for tranny rattle, where is it?
- clutch install!!!
- Highest boost levels with stock turbo
- Weird boost problem, please help.
- OEM Eng bearing grade differnces?
- I can't get my boost to go up
- what is causing my idle stumble?
- Maybe just me.
- Hallman Pro RX and the stock boost solenoid
- All the damn turbos I am sooooo confused.
- any more installed 20g stories?
- WBO2 Data Logging
- Cam installation cost
- HELP!!! what is this???
- Noise from top end
- hole in W/G actuator?
- Your opinion please!
- Skunk 2 Cams
- Exedy Heavy Duty Twin Carbon Clutch? Who Has It?
- Service Engine Soon?
- tranny probs?please help
- Anyone Running Crower Cams?
- Crower rods or Manley Performance rods
- Power Enterprises Boost Control/Gauge
- Stock cat fit on aftermarket TBE?
- Idc?
- Vibrations are CRACKING my oil pan/flywheel cover!
- Stock Ported 02/Helix 02
- Streetable Cams?
- no boost past 3k... won't even rev past 3500?
- BOV piping diameter
- APS air intake
- Need Help Idling Problems
- fmic weights
- GReddy Oil Catch Can problems
- Headbolts retorque?
- hitting the rev limiter?
- Is the 10.5 hotside worth it?
- flash
- Removing engine??
- O-ring on injectors.....
- twin turbo evo..
- ams turboback
- Bi Turbo - Twin Turbo
- Catback or UTEC
- is this for real?
- wtf - bled brakes now clutch engages higher...
- Manifold+Hotside+O2 Housing=Noise?
- EcuTek & Injector Scaling Questions...
- Please Help Muffler will not center
- Slave cylinder question
- Boost question.
- Dynotuned at BR.....
- make more hp?
- when will injectors be needed?
- Weight of wheels
- Turbotrix vs. Precision Dyno Tunning? Inputs please!!
- HKS CAMS 280 vs TOMEI 280
- Does the HKS DP come with a gasket?
- radio harness / guage splicing
- will this set up work?
- Anybodys evo do this?
- Best Turboback?
- race gas
- Exactly which cylinder head is in Evo8?
- Prostreet brandX bov = Greddy RS???
- broken exhaust stud
- More APS BOV feedback.....my experience
- 4"intakes ??
- Alcohol Injection
- Power Enterprises 60mm Boost Control/Gauge
- does everyone have problems with GREDDY TYPE S
- What should I buy?????
- Do i have to cap stock bov for pressure testing..it's leaking bad
- witch intercooler should i get?????HELP
- pushing 500whp on Fujitsubo RM01A exhaust a good idea?
- Getting locked out of gears
- How is the Greddy Type RS BOV Suppose to sound?
- Shep racing dogbox now available.
- Anybody use a Tilton clutch
- What reduces turbo lag?
- Which HFC fits between an HKS DP and HKS catback exhaust?
- Radiator fan gone crazy!
- ATP 3071R install problem. Downpipe resting on AC line?
- Oil pan... stripped... what...?
- Is a flash my best option with this turbo?
- Weird AC problem...
- MBT - maximum brake torque timing
- Jdm Mr Bov?
- Odd missfire after Coil on Plug Install
- works 3 inch down pipe?
- Smoke comin out of my exhaust!!
- Evo bogging down and backfiring when accelerating
- Just got back from KTR in Ayer
- recommended clutch???
- BEST MODS w/ $1500
- CONFUSED PSI Qs!!
- Interesting software...
- 272/264 cams Idling bad?
- Alky questions
- Apex'i Active Silencer
- 3rd gear..6k..no boost..loud vaccum noise
- Good Cam Tech Tip Article
- Cams without tuning
- whining noise... can you verify?
- HKS Drop in ok? and BOV?
- Does new BOV give more power?
- Clutch problems
- What turbo is that ? GT3071 ??? Please help...
- External wastegate on stock turbo????
- evo4 dilemma what to do next (need advise)
- gears w/ stock shafts - shafts w/ stock gears
- Burning oil / running rich?
- IC sprayer switch pinout?
- turbo studdering @ 3-3.5k rpm
- Not Boosting at ALL
- Al Dynoflash ?
- HKS SSQ VTA- My Experience
- AMS 2.3L stroker and RNR GT35R results
- What is normal boost taper?
- GT40R Instock??
- First impressions of the *NEW* Hydra EMS plug and play
- What else is needed in clutch install?
- Want to know how much boost is the WR capable of,and a what point does it over speed?
- High rpm gear lockout SOLVED!!
- Dyno conversion factors.
- bov, VTA vs. Recircu.
- 05 Clutch Installation
- Once again..Buschur Racing Dyno Thread.
- dang installs
- BOV guide
- boost is boost??
- broke cam tensioner tool...help
- How do the Helical LSDs on the 05s compare to the Quaiffe?
- Understanding cam choices. Please advise
- Greddy Profec B Install Questions
- CEL w/ Ultimate Racing test pipe?
- New RnR Products RELEASED!!!
- Out of control dyno days at Buschur Racing.....
- Cams Or AEM?
- 2nd gear lockout/4th gear light grind?
- Any Evos running the Emanage Ultimate yet?
- SSautochrome header bolt question
- EGT bung on O2 housing...........
- negative factors with short shifter?
- Turbo leaking oil?
- cam gains
- 3" vs 2.75" vs 2.50" DP
- WTB: Stock MAF Sensor
- hallman MBC freaking out!!
- bad day..cam question
- How screwed am I? cam gear question
- any gains
- real quick ?? about MBC
- Cleaning HKS Foam Filter...
- Another example of how good 05s are!
- My TT numbers...why is the torque so low?
- Clutch question ACT
- Max bore for 4G63 stroker?
- Best Throttle Body on the market??
- Yes i searched Exhaust Info Needed!
- Stock turbo shot @ 20K miles?!?!
- transmission rattle
- APEXi new exhaust
- Best Intake for the 05 Evo?
- Who Is Making Over 450 Whp On A Cusco Twin Disc With No Problems???
- Best Alky Kit
- Installed RNR 50 Trim Turbo Kit
- Evo 8 buld up pics
- o2 houseing w/open dumptube, anyone make em?
- New tranny stiff shifting
- Intake?
- The Ultimate BOV Thread
- P0300 after 22k miles?
- clutch question
- Quick HKS SSQ question
- Anyone have results from Buschur 20g?
- hks carbon ti exhaust for sale
- WTF A/C problem...?
- Radiator liquid problem.. Need help
- Forge Actuator 25psi straight to Redline!!!
- ordered hks ssq ver.2 HELP
- Variable Geometry Turbo, anyone heard of this?
- Help!! Cel Help!!!!
