- F&S Motorsports Twin Disk
- Competition Stage 3.5 Clutch? Or Act HDSS? Or?
- Evo 8 block for evo 4
- Regarding AYC issue for US Evo IX
- What size injectors?
- How much oil should be in the valvecover
- Transfer case. Casting mark, stress fracture or crack?
- misfire driving me crazy HELP!!!!!
- EVO 6 transmission in EVO 8?
- Evo 9 BOV Ststs then wants to stall
- Question about 6266 turbine housing
- EVO IV Transmission specs
- Coil Pack
- Clutch or leak? Accelerating problem
- Keep on getting boost cut or misfire with anything above 20 psi
- Adjusting BISS without evoscan
- BOV ring?
- Evo IX Head refresh/belts/WP/Exedy twin disk HD/Head Hot tank
- Evo 7 drives heavy and sluggish
- Help! Milky oil... but strange circumstance
- 950whp+ Turbo Suggestions
- Installing evo 8 engine help!
- Does anyone make a Greddy to Tial Flange?
- Time to rebuild the block
- Evolution turbo hot side. There is a number 49378-13060 105.
- From evo 8 turbo with 20g billet wheel to fp71hta good idea?
- Big build fueling? Can avgas be used? Please read
- Possible valve cover leak, any insight?
- Throttle body question
- My Evo RS gearbox sucks for drag racing can I put an FD on it?
- Need help identifying a part.
- EVO 9 MISFIRE at 3000rpm
- Another idle issue, bad alternator?
- 2.1L serpentine belt chewing problem! Help.
- clutch
- Lean AFR at Idle
- Exhaust leak at o2/downpipe
- Buschur double pumper
- Advice on tb for street tune
- Balance shaft delete rubbing?
- SS FP RED for road race?
- Clutch Fork Stop with Comp Clutch Stage 2
- Evo 9 No start after parked for 10 months
- ticking noise evo 8 mr after clutch change
- Diaqueen GL5 LSD banned?!
- Temp spike when stationary
- LSD gear oil stop-sale
- knocking noise coming from lower timing belt area
- Diy valve springs
- Exhaust Recommendations
- Turbo Cleanse
- Recommended source for MHI turbine housing?
- Lifters completely full of diesel OK after cam swap?
- Vrsf intercooler
- Next 3 gauges for Evo
- Valve Cover baffle removal
- Valve cover baffles
- Drive Shaft Vibration - lower speeds
- Which brand cam gear has the most concise and accurate indexing?
- Ams VSR intake manifold with KU Engineering TB
- Cp9a evolution 5 iacv
- Cam HELP
- Turbo not hitting full boost
- Coil or cam position sensor?
- Symptoms of Bad “Collapsed” HLA a.k.a. Lifters?
- Missing a Bolt on the Engine Block for the Inspection Hole
- Timing belt skipped - Looking for advice
- Which OFC for 2.4 build
- Another T case going out
- Bummer
- Best way to hit 400whp in evo 8
- Gas tank installation
- Evo 7 GTA Turbine Housing
- New ID X series injectors (video)
- Why can’t I run more boost?
- Main cap & Rod Bearing Clearance
- Misfire near peak boost: no CEL or leaks, (detailed diagnostics)
- Injector Dynamics ID1050x vs 1000
- Need Advice, Evo 9 Turbo Swap
- Pistons for 97mm crank
- Intermittent Clicking sound
- I have a question about this BOV from Tomei.
- Turning up the boost evo 8
- Valve seal install
- Double pumper!
- not able to step on the gas
- Evo 9 possible diff broken ?
- Evo 8 fp green equipped oil for cold
- Silicone intake induction?
- Oil temp Increase under full throttle
- Evo 8 mr has no drive
- Oil pressure swtich
- Annoying Oil Leak
- Questions regarding evo build
- Fuel Pump Hanger Compatibilty
- Question about Exedy clutch choice!
- help!!!
- evo 8 issues rough idle after fill up and random noise up front
- gtx 2976 or gtx 3076
- anyone has experience with gtx 2976 on Evo i searched and not found nothing
- EVO 8 Transfer case / ACD issue?
- manual boost controller problem, need help!
- mopae crankshaft 88mm same part # as evo
- 3-port boost solenoid recommendations?
- Error P1777,
- Soft fuel cut under boost 2.3L evo 9 Help appreciated!
- Buschur 2.3
- Evo bogging on WOT and stalling when shifting to neutral
- EVO 8 crank but won't start (fuel system issue)
- Thoughts on borg warner s366sxe
- Help 6 speed pops out of 5th gear
- My engine just popped, now for the rebuild (Need rotating assembly answers)
- Blew Up Heater Hose. Heats up On Boost
- ACT ME2-HDSS review
- Clutch gurus please help!
- Fuel system upgrades
- Build 2.0 normal for pistons to do this?
- Clutch fork position/TOB, SEARCHED
- Extreme Turbo Systems Thanksgiving/Black Friday Sale
- My evolution is blowing constant grey an blue smoke what is tthe cause
- Building my head, need some opinions
- Black Friday/Cyber Monday 2017 - Deals Start Now!
- Question about retune
- Monoloc hates OEM Tob?
- Hot Head Temp?
- 4g69 destroker questions
- Cleaning corrosion from inlet side of turbo??
- Pinion angle
- TD06 downpipe elbo
- Clutch fork position issue
- Water pump block off help
- Competition twin disk vs Exedy twin.
- Jdm Exedy twin clutch
- *New Turbo Time* Fp Red BB vs Blouch 2.0xtr
- Slipping
- Questions about my Gt3582r w/7-blade billet wheel upgrade
- Mopar 75w-85 Syn Manual Transmission Fluid Part Number 04874459
- mopar 75w-85 part number 04874459
- New Borg Warner S372sx-e
- exhuast questions
- all three acd lights on evo 7
- wtb: evo 8 or 9 rolling shell. Northeast but willing to ship
- Cold Start Stutter
- Need help identifying my turbo...
- Re-Install BS
- EVO IV without oil squirters
- IAC valve/sensor
- Valve spring installed measurements?
- Another coil upgrade. Bad misfire at wot.
- Throw out bearing removal help
- Is there any better clutch for street than exedy twin hd?
- new transmission
- Radium Double Pumper
- Car stalling at idle after removing battery cable
- old school green 400 whp 450 tq on 2.3 stroker kit on 93 octane
- Aftermarket Valve springs
- Best Chatter free street clutch 700whp
- Conneting rods
- Evo 8 transfer case removal help!
- titanium to stainless?
- Tomei catback - worth it?
- Garrett G-Series turbos
- Stock frame downpipe bolt holes too wide fix?
- Timing jumped
- What to do
- Turbo oil return line
- Megan downpipe V2
- Idle issue?
- evo8 or 9 rear diff and axles for sale?
- Stock extractor and downpipe max power output
- Wagner Tuning Intercooler
- Installing FP SS Black; what clutch to run? (Also what numbers to expect on e85?)
- Valves rattle at 2500-3000 RPM only after bleeding
- Evo 7 8 9 transfer differences? Which is strongest ?
- Transfer evo 9 to evo 6 chassis
- Delete ACD pump and work the transfer without oils
- Flywheel Mounting Flange Damage On Crank
- Evo 9 Front diff/center diff suggestions
- Car jerking coz of rich afrs?
- Replacement Heater Core Hoses
- FP SS housing question
- My build advice
- Evo 1 New Clutch Recommendations
- Rad Fan Starting before cold/first start?
- Hardrace vs Cusco vs Torque Solution
- Car still doesn't start
- No start no spark or fuel from injectors
- ACD Bleeding, 2 person method. But When to stop?
- Just discovered a huge hole in my intake filter, how worried should I be?
- EVO IV bearing questions (Mitsubishi noob) :)
- Transfer Case Diff ID
- 4G64 with Evo8 Head cam timing?
- ATP gtx35/82 stock frame
- Looking for a new clutch.... any suggestions?
- Blowing seals doing boost leak test?
- Does it sound like a bad MAF sensor?
- Wha turbo, engine build , gearbox ratio for 1st gear roll street racing up to 600 m
- Valve cover leaking from bolt/rubber washer
- FP red or black?
- Throttle position Sensor
- Leftover fiberglass = more air flow
- How much hp can my stock engine handle
- whats needed to go e85 on stock turbo?
- Mfactory 1.0 way rear diff, who has info?
- Should I block off these holes?
- AMS IM or MAGNUS IM ??
- Car jerking and smell of gas
- rear axles for EVO 8 or 9 needed
- EVO 8 diff
- New upgrades, no car won't start
- Funky Fuel Problem
- Clutch grinds as it's disengaging from a stop
- ACT Throw Out Bearing
- Water pipe on the back of the head
- Output Shaft Issue
- No start issue. Not getting fuel
- Clutch pedal went low close to the floor
- Strange Buildup in Turbos Oil Feed Port
- Alot of gunk in turbo with stock intake?
- Shifter Bushing question, probably different than you think
- Timing question.
- Forward facing setup
- Bw 7670 retaining ac
- Issue with my built please help
- Re-sleeving a 4g63
- Rebuild my evo 7 engine
- Storing a built block
- 272 kelford in evo 6.5 tme
- 4g64 parts info
- Buddies Evo 8 wont start
- FPR not holding pressure with surge tank
- Play in my axle! HELP
- Evo 6 Radiator on 8-9? Anyone running it?
- Clutch disengagement issues
- what 272 cams are these.
- Quartermaster twin disc help
- Head Gasket Help
- Are these stock cams?
- Normal driving and one cylinder shuts off and cames back randomly???
- 71HTA, which WGA
- Cylinder 2 and 3 with fouled plugs
- Any Help for this setup ?
- Advice on connecting rods
- Driving with these mods untuned
- Help Needed / Modifying a Evo 6.5 Tommi Makinen ?
- Weird cut at low speeds need help
- 450-500hp stock longblock safe turbo
- ACD problem
