- Ok so I bought a friends 2.0 IX block
- Need help confirming Cams
- Buschur SD rear muffler anyone?
- Can a Evo 5 Center Diff & AYC use this oil???
- Bearings
- GSC S1 cams reving to 7,800.
- What clutch for road racing/time attack?
- built2.0/balance_delte_NVH??
- Head work for my Evo V RS
- My first evo 8 tranny rebuild
- ACT Heavy Duty Street Clutch Failure
- Clutch Torque rating Inquiry
- STill dnt knw what to do??? HELP ME PLZZ
- when to consider installing ARP headstuds?
- Help! What´s the right 1st synchro for VII?
- precision 6776h journal bearing turbo
- Proper Internally Sound 4G.
- buschur stock ported o2 housing
- Will the Innovate MTX-L work the same as a LC-1?
- All 3 of these codes a coincidence?
- best Downpipe + O2 housing for stock lokation Turbo
- 3" vs 2.5" IC piping
- Evo V gaskets problem
- Evo Ix under power
- Center Diff Oil???
- Worried about Tranny
- dom 2.0 turbo
- Weird Whine in 5th gear
- Can the trans hold it?
- help with p0505 and IAC
- Five speed gearbox and diff ratio options ?
- Act - disc splined wrong
- 10:1 cr on 92 oct???
- Works 2 clutch kit???
- Power Steering Questions. Need some help.
- 10:1 cr opinions on 93 oct
- How many of you not running oil squirters in your 2.4l
- New BW EFR Turbo Thread
- Thread Pattern & Size for Fill Plugs?
- Shifter Linkage Contact 2nd Gear ??
- RSR Downpipe Alternative
- What would you do to this block 4G63
- CVT -> TC-SST Tranny swap
- Evo 8 hesitation at hard throttle???
- *HELP* Clutch job TOB issue! FML
- Opinions on motor mounts needed
- Q45 tps schematic. Where to find one?
- Should I upgrade my BOV?
- Clutch Problems need some advice
- Clutch install went bad, does it make sense?
- NGK PLX Wideband?
- HTA Green and Reliability
- Turbo outlet for Evo 9
- 2.3L Stroker kit opinions.
- Oil leak help
- Shifter Assembly Help!!!
- Problems with over boosting.
- evo 8 build
- Are adjustable cam gears needed?
- Clutches and cold weather
- what cam gears for a 2.4 VIII build?
- port and polished head
- Silicone spray to prevent rubber cracking?
- Anyone make a oil/coolant line kit?
- Knock issue? - APS BOV made it worse?
- Light green/golden oil color at back of motor
- Help, Trany and Clutch issue.
- could i get some diagnosis help. (VIDEO)
- Help ON Surge Tank !!!!
- Can I make my own E85 with pump gas + VP M1?
- Std or LR 2.0
- Individual cylinder - no ignition.
- 1200cc injectors and 255 with pump gas
- Top mount manifold
- Stuck in snow - Not everywheel spinning
- Way to find out if shortblock and head is a virgin or aftermarket?
- help P0170
- pros-cons of exedy twin carbon clutch
- Hta3586 vs. Pte6262
- Turbo Blown?
- reverse light trigger
- Coolant lines to TB; EGR delete
- Cost to upgrade to HTA from regular 35R?
- 4 Precision injectors with different numbers on them?
- Bushwacker trans hard to go into reverse, anyone else got this problem?
- New QM 8-Leg twin !!
- ECUtek or OpenECU?
- Exhaust smell inside of car on boost only
- NEW Rear Differential Upgrade from TRE
- Apexi turbo timer
- intercooler drain.
- How to get great response with stock turbo?
- cosworth .001 extra clearance bearings and some engine building ?
- Stock fuel pres regulator Max HP?
- replacing stock clutch disk
- car wont start :/
- Cosworth M3's
- Evo Throttle body
- Rolling forward in neutral??
- Anyone have TD08 Compressor Map?
- whining noise while driving
- Clutch Slave Cyl: Oil Line & Bleeder Location?
- Tranny or clutch problem!!! Help
- hey i need help asap! big problem!
- 2.3 build
- T4 no more?
- ets licp and beatrush undertray
- Need help finding a part!
- Evo 9 FP 5R Cams
- Read, if u have an MR with aftermarket gauges
- Tranny fluid???
- Best clutch for less than $1,000 and can hold 500whp/Tq?
- 2k rpm idle?
- do i need a fuel pump or injectors?
- Using penzoil synchromesh
- Supertech Vs. Ferrea. Either better than the other?
- car will crank but not start
- apexi intake and now p0234 (engine overboost)
- Mt FP red dont want ONLY 14psi?
- HTA3794 vs PTE 6765
- 5speed conversion
- ams fuel line - retune necessary?
- 280 degree cam, is it ok for a stock bottom end.
- Need advise before re-tune
- Compression Test Result - Pls Advise
- if the IM has vac on decel: what relative psi in EM?
- evo wont start after removing alternator and intake manifold
- Walbro fuel pump failure?!?
- Ported Intake Manifold/65mm TB vs More Aggressive Cams
- 4G64 build
- 04 EVO VIII RS MAF Sensor
- Spec Super Twin Vs QuarterMaster 7.25 V-Drive Twin Clutch
- The Misfire That Wouldnt Go Away! Help!
- How to check a good or bad Coil & Plug Cables?
- Megan o2 housing gasket??
- How to clean an Injector?
- Sheps T-case stages.
- Slight grinding first few gears
- rexpeed cf lip and beatrush undertray please help
- rattle noise when i turn left!!!! please help!!!
- Exhaust Gaskets??
- Best spark plug and wires for Evo 8
- weird question.. drive train / power placement
- So who's running amsoil, fp red?
- worn or cheap shifter?
- what powers these components ??
- Running out of pump?
- What cams are these? Help please
- This is interesting...
- Boost leak test with HKS 272 Cams
- devo driveshaft
- Evo Transmission Limitations
- Anyone use a HD pressure plate with an OEM disk?
- RPM Spikes HELP!
- ecu bracket part number
- XTR Racing Clutch
- Yes, Another help me pick a clutch thread
- Best valve springs?
- FP red on stock motor!
- Ultimate Racing EVO
- GT30r setup options
- Tilton Clutch
- MY......girlfriends 05 evo 8.5 MR ballin on a budget build
- FMU for e85?
- Boost
- Hta3586 vs pte 6765
- Boost drop off new intercooler
- Spark Plugs help me read please
- need quarter master help quick
- pulling driver's axle from 6 speed trans (WTF?)
- Idle Issues
- Balance shaft question
- clutch retaining clip
- OS Giken triple VS QM twin clutch review
- Grinding/whining noise when I get above 5mph
- Wide Open Throttle RPM DROP Problem: EVO 9 MR
- Gymkahna build?
- New "Stock Location" EVO Turbos from ATP
- Turbo Outlet
- Is 04 EVO A MAF or MAP
- Compressor wheel design, Garrett GTX
- FP Red turbo spool up sound or boot leak?
- Do-Luck Torque manager HELP!!!
- Forward Facing Stock Turbo Manifold??
- 2.1L Cam Gear question!
- Well... I broke my turbo
- Some current oil analysis info, ongoing testing.
- 4G64 Block, 4g63 head HELP!
- Valves and lifters
- 04 Evo 8 slow drip coming out of the transfer case
- Turbo Time
- problem with clutch/tranny AGAIN!
- Motul 8100x, 50400/50700, or Pentosin
- Switched from Red to Black...
- Already tuned for 93/E85..getting FMIC...need retune???
- HELP! turbo surge under full boost..(vid inside)
- Help! "binding" noise
- Gear box locks up
- Fp black & s1's?
- JMFab manifold
- Cutting out
- Competition Clutch and others review
- Random Thought on O2 Dump
- JMFab Drag intake manifold
- Stock IX Turbo
- evo IX custom cams (big cams)
- whats this part number !?
- 80k miles stock clutch finally blew
- Need info on MAF Translator
- IAT & BOOST questions
- Has anyone had FP Black Issues?
- should I upgrade from my 20g 6 blade?
- Do I have a short shifter
- Evo9 Clutch Install Problems
- HTA 86 or PT 6262? On a built 2.0
- Most boost in a OG FP green
- Tranfer Case fuild is light Purple HELP
- Pulling the motor
- wtf is goin on !?
- I cant tell if my exhaust manifold has been ported
- boost pipe jumping off cause turbo shaft to bend
- AMS 900X Package
- signs of a clutch going bad?
- Turbo oil supply from block
- Need help!
- Race Gas question
- Bad lifters?
- buschur cast hta35
- NEW ETS 4" FMIC & NEW CBRD Radiator
- Evo 8 transfer case o-ring help!!!!!
- which turbo with the 2.2l?
- BBK-Full Tuning Issue!!
- Rear Differential Ring / Pinion?
- Clutch Problems, Need some help troubleshooting
- pressure plate or slave cylinder??
- 4G63T Cyclone vs. 4G63T
- Built trannys
- Stock Evo 8 - is 20 psi boost ok?
- E-85 Swap few questions
- Misfiring Issue I Searched.
- Buscher Buschwacker Tranny Oil change
- problem with my head and cam. take a look
- evo 9 mr sticky gears?
- need help with idling issue?
- Oil Leak After Cam Install
- Fuel pump won't turn off?
- Car wont stay on!! need help!!
- 500whp Stock block & turbo goal
- Wierd problem... I need your help!
- Upgrade advise on stock 560cc Injectors...
