PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137] 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Dynotuning VS. Street/track tuning.
  2. 4g64 build, rev question
  3. 65mm TB Port causing whistle
  4. boost creep problems, help
  5. Tranny / clutch problem ?
  6. Records are meant to be broken....HTA35r again.
  7. Buschur FP3065 !
  8. slight hicup at idle
  9. AMS header hotness...back purging 101
  10. good bov/dv source????
  11. EVO head noises after really cold start.
  12. 2.4l 4g63
  13. timimg case
  14. leaky pcv valve
  15. so im pullin the head!
  16. motor mounts
  17. TB diamter/TB hose ID?
  18. parts on the way
  19. 2.4L 67mm - Ignition troubles galore!!
  20. Groden Aluminum Rods a must for serious power
  21. Need some help on our new setup. Octane limited???
  22. Coolant leak
  23. exhaust coatings??
  24. transfer case problems
  25. 2.3l
  26. $200 Turbo
  27. Vacuum Hose Length w/ EBC Boost Solenoid?
  28. The AMS HP shop is up and running!
  29. Replacing Stock Manifold without removing turbo. Possible?
  30. Gruppe-S 2.3
  31. tranny...
  32. drop in pistons and rods?
  33. tranny
  34. rear diff
  35. post what clutch you have
  36. post your green numbers w/mods!
  37. looking for VCU
  38. ACT street clutch problem
  39. Is this normal?
  40. Propane Injection in a gas engine?
  41. ichiba,topspeed,jic on my IX
  42. Can't get transfercase off help
  43. Drivetrain acting WEIRD!!!
  44. fitment problem
  45. 2.3, ported head & sheet metal :)
  46. What would cause this??
  47. Mod with only a 3" TBE and Intake
  48. Which Internals!!!!
  49. Valve cover coil bolts...a ground?
  50. Carbonetic Twin related to CEL???
  51. What clutch should i get
  52. Something broke during launch today :(
  53. Boost leak test
  54. Help.. Evo threw P0455 Code
  55. hks 272 mivec cams installed and dyno'd!
  56. larger than stock turbos + high flow cats
  57. whistles/ hiss
  58. evo green spool
  59. FULL RACE TWIN SCROLL 30R results and data
  60. 2.4L block - Cams + crank
  61. greddy t67 turbo??
  62. newbie and 700 awhp turbo
  63. Throttle mayhem...
  64. meth & nos
  65. quick question
  66. dipstick coming out
  67. Anyone considering a Magnus manifold, check this out!!!
  68. Exhaust manifold nuts
  69. Unreal Dyno Results...
  70. Who's manifold is this T3/t4
  71. Compressor surge
  72. T-case whine
  73. FMIC - If you don't need the xtra cooling
  74. Head flow #s?
  75. Exhaust Manifold...anyone running this?
  76. FPgreen VS 57trim
  77. less boost more whp?
  78. new clutch - grinding when turning
  79. PeakBoost HVS for TiAL vband turbine
  80. TiAL vband PeakBoost manifold
  81. fuel question!
  82. PPG on an EVO
  83. SC3431vsPT61
  84. quick turbo/boost question
  85. Engine Dyno
  86. Turbonetics question
  87. EGR elimination how-to available?
  88. 4th Grind on 6 Speed - Parts Needed?
  89. Help me pick a path.
  90. 3G 4G64 w/IX Mivec head?
  91. gains from adjustable cam gears
  92. too much oil in motor
  93. Turbo timer
  94. Present for a buddy
  95. might wanna check out this particular test pipe
  96. 600AWHP with a 35r!?
  97. what head gasket for 40+ psi??
  98. My 2.3 cam comparison...with dyno sheet!
  99. need help
  100. Transfer case removal?
  101. which turbo...on my built engine?
  102. Interesting Carbonetics Triple Failure
  103. 3" exahst flanges?
  104. **** Car revvs by itself HELP *****
  105. Huge Problem With Bov!!! Help
  106. Innovate wideband blinking non-stop
  107. Cold weather idle issue
  108. Looking at buying aftermaket clutch/flywheel.
  109. Engine Torque Damper
  110. gt35 on stock block?
  111. Question About Motor Rebuilt On Ix!!!
  112. Weird Bursts?
  113. HTA35R vs 37R
  114. oil consuption and dark oil
  115. GT3076R turbo questions!
  116. new car's #'s
  117. Complete Peakboost GT kit, opinions?
  118. ets or turbo xs
  119. Buschur tuned HTA35R evo fly by
  120. evo iv mods?
  121. evo 8 transfer case .
  122. cobb accessport vs. vishnu XFlash
  123. Has anyone ever tried putting the AYC in a USDM Evo IX?
  124. Drop in air fitler
  125. Boost issues after installation
  126. help!! i have questions about my 2.3 build
  127. CV boot torn, need help
  128. New Clutch Install now ACD PROBLEMS
  129. no boost?
  130. front axles
  131. gsc s1 cam with fp3065
  132. Engine/Tranny Removal???
  133. works throttle body shaft seals
  134. Need a new oil pan gasket?
  135. 06 lsd in a 2003 evo??? possible
  136. When choosing your parts how do you decide?
  137. FP 20g-9-5 rebuild?
  138. Exedy clutch uers, see this.
  139. bent valve?
  140. Perrin High Flow Cat
  141. Ralliart Clutch
  142. Got A Major Boost Problem, Some One Has To Know What This Is!
  143. Check Engine Light
  144. my goals..
  145. Project FQ-400
  146. Fitment issues with LICP
  147. Who has ported their ebay 02 housing to cure boost creep?
  148. Need to Change the Clutch?
  149. brian crower stage 4 288/288
  150. anyone else come across these turbos?
  151. buschur old filter vs. buschur new filter
  152. hta35r
  153. Evo Experts & HKS GT3240 Turbo
  154. Buschur mini radiator
  155. Should I replace my clutch myself or take it to a shop.
  156. o6 act t case in my 2003 evo???
  157. Question for the LSD on EVO 9 MR
  158. Garrett T04B Htrim
  159. JustDSM Fp Green E85 Tune
  160. Skunk2 Pro-series Titanium Cam Gears Mitsubishi Evo 8,9
  161. Turbo Boost problem
  162. Just installed walbro fuel pump and......
  163. AMS Parts and Dyno Run.
  164. 10.5 vs Evo9 Turbo vs 20G vs EvoGreen
  165. Cusco/Exedy Twin help finding a part
  166. Magnaflow Exhaust on my Evo8
  167. Buschur Guys
  168. HELP>>> My Idle went up then go down and it almost stall......
  169. MR owners question!
  170. bad sound from motor
  171. Need Help from anyone with a 35R
  172. Hearing a noise at idle...
  173. Uk GSC S2's on Stock Turbo Result
  174. 579 HP Stock Motor Daily Driver
  175. Car is running weird
  176. What should I buy to run 11s by the next 2 weeks?
  177. Tranny whine in 1st gear only
  178. Gt35r???
  179. Running rich as hell 10.0????
  180. Ignition is out... Any ideas?
  181. Rattling & Vibration from TC
  182. MAF adapter question. Need answers quick
  183. Looking for people I've tuned for some information.............
  184. boost lost top of 3rd gear need help
  185. boost problems..HELP!!
  186. Dynoed brog warner 362
  187. ACD fluid level
  188. bad engine codes
  189. VSS (Vehicle Speed Sensor)
  190. Stock rods??
  191. I might have a few issues
  192. motor build questions
  193. Fidanza 3.2 Clutch / Flywheel
  194. Am I crazy?
  195. Stay AWAY from Greddy turbo kits.
  196. Gauging Interest - GTSPEC 3" HF Cat
  197. Turbo removal
  198. Video of last night ProccoEvo
  199. Are DSM and EVO lifters the same part 4g63T?
  200. fullrace 30r advise on intake
  201. problem when flooring the gas pedal.
  202. look what i got so far!!!
  203. How much more whp using meth?
  204. Do I need a Fuel Pump
  205. megan o2 with pics
  206. Balance Shaft removal = PO300???
  207. test pipe flanges
  208. What did you guys pay...
  209. White Smoke!!! What are you!?
  210. Bearing wear?
  211. Downpipe problems
  212. Mis-Fire
  213. Do You Guys/Gals no What this might be??
  214. Clutch Stop
  215. A tenth in the sixty foot worth two tenths in the quarter?
  216. A different video of the BR "BAD BISH" 9.6 @ 151mph w/ Time Slip *COME CHECK IT OUT*
  217. need help with boost leak
  218. Vendors! Does anyone have a 156mm rod in stock?
  219. Odd thing happened while driving
  220. High oil pressure
  221. What Intercooler??
  222. What Cams For Faster Spool??
  223. 2.3L stroker...cam and turbo spec
  224. mobil 1 for transmission oil?
  225. ok so im buying a gt35...what am i gonna need?
  226. Drivetrain fluid change intervals when tracking car
  227. How good is the Megan Racing EVO Turbo Back Exhaust System
  228. **Help Me Pinpoint My Idle Surge Problem**
  229. what are restrictor pills?
  230. Exhaust studs
  231. confused about fluidampr
  232. 893 awhp & 646 awtq Titan Procco Evo 8 !!!
  233. Going for 900whp this Week!!! Pics Inside!!!
  234. ATP Turbo Kit
  235. Question About Taking Apart Br Tubular Header!!!
  236. Reflash, Green, 2 liters and 507 ft lbs/443 whp..
  237. HELP! Major Acceleration issues!
  238. Drive train question
  239. Different Styles of Lower Intercooler Pipe, which is best?
  240. Miss firing in multiple cyclinders
  241. Exhaust Manifold install sequence (tightening nuts)
  242. few questions
  243. Stock O2 sensor replacement alternatives?
  244. solid cams?
  245. turbo swap complete something is really wronge with car i need help
  246. turbo swap complete something is really wronge with car i need your help
  247. Best oil for Transfer case and Tranny
  248. Car problems... bucks and flutters?
  249. flywheel????
  250. More Power and Torque for OKIX's 20G-LT..
