- My 5 Speed Tranny Hard To Engage Gears
- cosworth m2 compared to kelfors 272
- To do list before tune?
- HTA 3586 don't really KICK until hit +28psi??
- Ex.Mani M8 stud torque spec?
- Clutch pedal
- New PT6466 and built shortblock :)
- EGT probe, which cylinder?
- Cars been sitting for a month with E85........
- Exedy Twin Rebuild Kit?
- SPOOL'N UP COP or DIY COP
- whats the difference between TCASES
- Evo4 ABS sensors are same with Lancers' of the same body?
- Identify this head please.
- Need a Clutch....
- TO bleed or NOT to bleed lifters on install
- Gears grind shifting into 5th
- Can't find this fuel issue! Need ideas!
- Blown turbo or something else? :(
- what setup qualified for Tune !!!
- megan 02 housing vs stock 02
- What is considered running HOT? (coolant/water)
- Marvel mystery question
- Exedy Triple Normally Loud?
- ETS short route w/ Tial VTA fitment ?
- ATP 1200cc Injectors
- Mivec Swap Question
- is the MAP EF4 too much for my setup? should i get a FP green/red instead?
- Oil Pressure Question
- Quartermaster 8 leg question
- Divided Wastegate issue
- Pulling the head..
- clutch back in!!
- Transfercase leaking!!!! PLEASE HELP!!!
- looking at buying a SLS top mount manifold.
- ACT clutch failure
- ICS valve or something else?
- Misfire codes messing with me
- Clutch for light modded evo
- 29.5psi till 6k? 23-24psi by redline?
- turbo size?
- How much overlap to dial out to reduce lope
- Exhaust Burning paint
- sd advise
- Strange Noises from New Exedy Clutch
- ACD warning light: only fault code 65
- Adj. cam gears on JDM 8MR cams - anyone done it?
- T-stat=what is this.. pics inside..??
- So what exactly is wrong with my DEFI RR boost gauge? (video inside)
- ATP turbo problem???
- electrical or fuel problem?
- HTA Green failure
- Need opinions on street/weekend set up..
- fuel pump upgrade?
- Car is running super lean
- Clutch recommendations for a bolt on evo?
- blox racing...? mbc
- P0365 Evo 9 CEL
- Fluid leaking where Transfer Case and Transmission Meet
- TDC question!! 60k service
- Odd Cold Start Issue - Evo 8
- noisy at high mph
- could use some input about changing back to pumpgas only
- What's your GSC S2 Peak Torque/Cam Settings ?
- just retimed my 2.4 need advic
- Shepp stage 2.5 transfer case?
- Tomei 280 cams
- help!!!axle seal
- Drivetrain Input
- how long did your jb fp red last?
- Diagnose my high oil temp
- Porting and Polishing: Please Share Your Tips!
- Minor clutch issue...
- ACD Issues
- Burning Oil
- Few Questions about ACD
- suggestions for a solid front motor mount
- fuel pressure probs again?? help !!!
- just did drivetrain fluids and..
- Misfire help!
- New to evoM, where to buy?
- Stock metal BOVs: Yellow and silver caps
- Will reducing IC size improve Turbo Response?
- A little confused and could use a slight bit more info
- Quick de pinning question
- Clutch recommendations for a daily 335HP ATW Evo
- possible evo 8 boost leak?
- Need opinions on best parts and place to buy!
- Test pipe or high flow cat? Your opinions.
- Cylinder Compression and Leakdown Test Results
- popping out of 4 th gear clutch??
- evo 7 smoke help!!
- Proper Mivec Timing Marks 2.4L
- LICP same for stock frame and pte
- Any ideas why im not boosting?
- What turbo do you think this is?
- Bad Lifter Still Pressurize?
- EVO 6 RS2 internal wastegate actuator problem
- New turbo setup. Where do I connect these?
- Rods and pistons?
- Help please
- powerfull water pump
- 2006 GSR IX timing chain?
- Motor not breaking in properly?
- What is the Max AWHP for Stock 560cc Injector?
- Driveline Problems..
- What Conventional Oil's do yah'll use for Break In?
- I opened my ACD pump.
- Broken Piston Ring - Need Advice
- turbo options
- Which motor for my build?
- RS and Evo 04 rear diffs
- Hard time selecting 1st and 2nd on my evo9!
- Eeo 8 transmission issue
- Wrap tubular manifold or not??
- What cam setup to go with?
- Vr1 20w50 user?
- HELP! Car wont start
- Decel noise high rpms
- 4G63 with super long rod and 88mm crank
- Oil change coming up...change brand?
- Rear of Head Leaking Oil??
- Question on 2.1 builds
- Is something wrong with my turbo?
- disable p0031 via periph
- fuel line e85?
- Out of these turbo setup ups...
- Diagnosing help needed.
- UICP on EVO 8
- I think i want a new clutch.
- What Trans/T-case/Dif fluids to run and how much?
- Another 3 ACD Light Thread - Code 47 ?
- boost spike?
- Fan Control Module
- GT30R and stock bottom?
- Clunk Noise when hard shifting after new clutch
- Looking for TB Rebuild
- OEM Turbo Gauge Vacuum Tube HELP
- Japanese Downpipe
- Throw out Bearing Stuck... Tried everything
- Compression test results, head gasket issues?
- Valve Spring Question
- AMS Balance shaft eliminator help
- LICP and UICP for my Evo 4.... some questions!
- Small oil leak with pics (please help)
- Turbo Manifold advice needed
- Transfer case won't go on...
- Evo ix cant get it into 1st gear even with car off
- Can a 7 8 9 Throttle Body use on Evo 5?
- 2.4L EVO 9 First start up =D
- running without BOV
- Manifold advice needed
- Is there an Injen intake recirc hose that works with the stock UICP/BOV
- Fresh 2.4L in evo 9 will not start!!!!!Help.
- Car drenched in oil (Pics)
- Exhaust leak from dump side of muse external dump
- Tilton Clutch Removal?
- damaged stock wga nipple!
- Reoccurring wiring issue
- Evo 8 o2 housing install cause turbo to not spool. HELP!
- Opinions on Line Boring?
- help with stuttering/hiccups between 2500-4000 rpm
- Trans fluid change help
- 15k or 30k on the drivetrain fluids
- Need help with COP system
- oil cooler relocation WITH a/c (front mount?)
- What ever happen to Shep working on a 6 spd upgrade?
- to install or not to install
- Valves, Keepers, and shims
- Need some help, compressor surge/flutter at WOT
- 06 evo no start p0335 CPS circuit
- is it ok to use a stainless exhaust bung in titanium exhaust??
- Does anyone recognize who's dyno this is? FP Black and has monstrous torque
- rev limiter - to bounce or not?
- Cylinder Head
- P0443 Code
- Ivey tune Trans rebuild... results are in!
- Issues with fabbing 4" SD intake, Input?
- No Boost Until Redline
- Pls help me to pick a Manual Boost Controller brand
- why my brand new walbro is not working to it's full capacity??
- Evo 9 Recondition head.
- 05 Starter different part #
- load rescale help!
- epm O2 dump and muse lower intercooler pipe clearance?
- Balance shaft inquiry
- comp stage 2 question
- Tomioka Racing 20g Turbo - any experience?
- evo 9 transmission
- Expanding Valve Cover Valves?
- Will Over Rich Causes Knocks Too?
- used wastegate install help
- lend an ear (t-case)
- Service Engine Soon light - here are the codes I get
- are IX and X metal bovs the same ?
- Evo-9 full modified 6766 and dyno results.
- Car goes lean then dies
- What size injectors?
- need stock engine pictures (read inside)
- Pics of stock clutch with 99K miles
- Exedy install on 2.4 Help!
- What cams to go with these days?
- HKS GTII 7460R -> external wastegate?
- OEM cat / emissions dilemma
- Evo 1 T3/T4 fuel pressure?
- 1st gear stutter?
- hvac, abs, and acd failure please help
- blown turbo and found this...
- Any dynoed the Extreme Tuners 80lb turbo?
- anybody knows diff weight ?
- which gsc valve springs should i get??
- recommend me a street clutch: 475whp/400wtq
- Build questions.
- Rough start, rough idle, sputtering on throttle
- car doesnt crank stuck on the road help asap
- evo 9 fuse 8 keeps blowing while driving...PLEASE HELP!
- AYC Pump "Groan?"
- Compression score
- Tial 44mm boost problems
- quartermaster twin disc life????
- HTA GT3076..How many ( psi ) to maxed out it?
- Transfercase rear seal leak, help me verify
- bov springs
- The deal with people insisting on 6262
- Oem 4g64 crank
- Who is running competition clutch twin?
- Best Spark Plug to use
- strange pulsating vibration at 45MPH and higher
- rev limit question...
- dropped some rag into coolant gallery
- oil catch tank question
- Competition Twin disk clutch issue
- Underpowered PTE 6262 setup??
- Problem with FP Ball Bearing Black, Oil burning!
- Buschur licp question
- Major Problems!
- Clutch Chatter and Motor Mounts
- Shepherd Transfercase
- Evo/P0335/duralast/tow truck help....
- How much for a short block
- boost leak test FP Black w/84mm housing
- stock engine question..help needed!
- exhaust manifold question
- MR gauges
- STM or Buschur
- New six puck installed Help!
- Did I blow my turbo?
- Synapse BOV + 3 port wiring
- A strange problem i have, AFRs lean on idle only
