View Full Version : Evo Engine / Turbo / Drivetrain
- Need help!!!!! 0 psi
- Wierd Drivetrain Sound
- maf translator question
- Stock Clutch Limit
- Installing Cam gear, front engine, and trans mounts, what order?
- Needed upgrades for a 400 WHP EVO?
- Porting
- evo x turbo on VIII???
- recommend me an intake pipe!
- Fuel injectors from mild to wild
- (T31 4bolt) Is there really a big difference between ported/unported Turbo housing?
- HP limits of stock coilpack/plug wires on Evo IX
- Check out this Head Gasket that I got in the mail, ugly !!!!!!!!!!!!!!!!
- 6 Speed Transmission Problems
- Questions about install: FP Red, JMF o2 Dump, Ported/Coated Manifold
- What IX Spark Plug? 1 Step Colder?
- Radiator different Evo 8 and 9?
- Boost Clamps sizes??
- Amsoil Help
- HFS-5, Maximum methanol to fuel ratio?
- RE: Upgrade to IX today!!
- AEM UEGO Wideband Install
- Air Filter Shootout Test - Results!
- Need Help!! How to Prime Turbo!
- Driveshaft vibration Need Advice
- Just got P0171 code
- Magnecore 8.5mm wires not fit IX?
- Turbo IX question!
- RNR 35r ball bearing on stock block
- About to buy used greddy ti, need some help though
- gearing
- Driving untuned with fuelling mods and COP?
- need to find 5v/12v
- Header Wrap......any recommendations?
- 3" or 3.5"
- comp 280 question
- CEL thrown
- Boost Gauge suggestions
- Looking for the correct size.
- turbo IX upgrade tomorrow!
- Spark plug recommendation..
- Injen upper ic to bov
- AEM wideband giving weird readings..help
- AEM UEGO Vs Innovate Wideband
- is this still good?
- any carbonshaft users ?
- o2 Housing drilling...
- How Much Power Will I Have With My New Parts?
- A few MIVEC tuning questions
- Lock the center diff
- People who run without an oil cooler, please chime in.
- Exedy HD or SD
- Stock engine, +400whp on pump, which turbo?
- thinking about an fp green,or cbrd full..
- Cryo treating questions for rotating assembly
- Possible MAF issue?
- A/C compressor probs
- hey please help boost problem i think!
- popping sound?
- Issue please assist
- I think my clutch might be starting to slip :(
- Need Help Guys Real Badly
- quick question
- sequential transmissions
- exedy twin not releasing
- evo 9 compressor housing
- Running 35r on stock maf
- Shell Helix Ultra
- evo 9 20g
- boost problem
- help p0234 wont go away
- So i think my two step was changed by previous owner
- Odyssey PC680 is a total POS (3rd one down)
- EVO 9/JDM MR BOV Inlet Size
- valve train noise
- Evo 8 Turbo with 20G Turbine
- Partial throttle hesitation.bucking/bad idle
- tomie 280 vs bf272
- Another HKS DLI issue!!!
- Check engine light faulty egr valve help me diagnose the problem.
- need help chosing parts. evo 9 only get one cam gear?
- Megan Manifold Anti-lag Port Bolts
- BR MBC Diagram?
- FP red setup help
- oil leaking from turbo pleaseeeee help!!!
- oil leak in turbo pleaseeee help!!!!!
- Intercooler Help
- Best cat placement in exhaust?
- question about tial bov
- Wideband position???
- what turbo should i get???
- Annoying RPM Drop
- ix mivec cam gear
- Wilson TB any opinions?
- ACD Removal
- How Much AWHP With These Mods I Got
- oil change to 15/50 and bearing failure
- Camshaft Install Question
- Car wants to stall in 1st gear and reverse. Need help!
- lean idle
- Opinions please on IC bottle
- another header
- It's a foking DSM afterall!
- power steering fluid
- Which Cams Combo?
- my gas pedal sticks help
- AMS oil question
- e85 vs 110
- Question about intercooler size
- How does ur engine oil look after 2k miles?
- Oil Cooler hose question
- bbk, red, green test drive orlando area??
- fuel injector size
- Waste Gate Actuator Findings
- Only making 11psi. Possible solenoid problem?
- Coolant hose heat sheild question.
- Upgrading to IX turbo this weekend
- exedy twin disk studder
- Exedy twin disk clutch
- HKS 2.3kit + GT3240
- cannot get my clutch out
- Exedy Stg1... Who's got one, what do you think?
- idle problem
- BSP AutoX IX build
- Random Starting Problems
- should i tune ?
- IV Coils and Wires on an VIII?.....
- Boost Leak Test w/ Upgraded Wastegate
- 20g turbo TDO6
- Can a 8 wastegate actuator be used on a 9?
- CEL light trouble........
- intake question
- Rod and Piston weights
- Gizzmo Boost Controller Gain Settings???
- Tick from the Head/Injector Area
- intake question
- need help with timing setup on 2.4L evo setup
- Cherry Bomb Vortext Muffler
- Let's see your Oil Catch can installs
- Do I have enough injector?
- Boost Leak Test - Help
- Possible Misfire?
- Planning a big build in chicago
- Walbro Install Help
- defog/defrost question
- Oil consumption ?
- exedy single plate
- lemmy's 4g63 build so far..
- fp red vs fp green on pump results
- Free Mods
- Twin Tial BOV's?
- Excedy triple disks?
- evo 8 tubular k member.. whos making one
- Evo III Water Pump Problem
- What does the E85 sticker look like at the pump?
- Clutch problems
- Intake Manifold Removal
- V band clamp Torquing?
- cometic head gasket size question?? PLEASE
- bogging
- Fuel pressure problem.
- gears
- Ebay Grounding kit
- brake pedal revs engine
- Car shaking and vibrating..wtf is wrong
- What turbo for my VIII ?
- Knock Sensor Replacement
- Tubular Header ?
- Ported 9 turbo untuned... Is it safe???
- Engine viration?? Need advise
- wierd noise at idle (maybe cam gears)
- Radiators
- Do Evo's have issues with crank walk ?
- Pyrometer Install... Placement ?
- COP with stock ECU, DSM Ignitor and 300m Coils
- Air Filter
- engine problem
- New AMS TBE w HFC Setup
- When do you hit full boost? evo9
- o2 Housing Affect Exhaust Tone?
- 100oct vs 110oct vs e-85
- Reliable Horsepower Numbers
- cant decide which clutch to get
- Christmas came a little early
- Vacuum readings?
- front o2 sensor replacement
- Question of Curiosity
- APS Twin Vent Adjustments
- Help me mod my car for trackdays (road courses)
- Stock Evo IX turbo PERFECT shape
- Car won't accelerate
- Clutch pedal effort
- What's not stock
- Valve Train Opinions:: Cossy,BC,FP,ST ? Which One ?
- engine light
- abnormal lag
- Head Studs :: ARP L19's or Cosworth's
- OEM knock detection on modified engine blocks
- Exedy questions
- Dsm fp3065
- cold issue...
- Tial GT35R housing
- Question for Hypertune Throttle Body users
- Tial's NEW 38mm Wastegate w/ Vband!!
- cut out?
- TOMEI Announces ARMS M7960 Turbine Kit
- Front driver-side axle oil seal leak
- Buschur Exhaust Fitment Verificaiton
- Samco/Perrin inake hose
- E85 vs Pump and Alky
- Deactivating the AYC??
- Evo 9 MR fuel problem
- My 4G64 block after machine work *PICS*
- boost drop off at high rpm's?
- Fujita UICP VS Injen UICP
- Boosting 28.8 psi & still doesn't feel fast
- Numbers With Turbo IX and Cams hks-264 or gsc1-268
- driftbox data
- Finaly got my engine out.
- Is the aeromotive fuel rail compatible with the AMS FPR?
- Sparktech non-cdi V.S. HKS DLI
- Need Help on T/C A.S.A.P.
- South Bend Clutches
- Ted B.'s HTA3582 Twinscroll Project
- mbc location
- gt35r upgrade to hta35r?
- ACD Question
- green on kelford evo 8
- GT35R Turbo Upgrade Question
- Major clutch install issue...
- *PICTURE REQUEST* TIAL ALPHA Q bov installed on EVO
- it looks like i have downpipe, midpipe, catback and no test pipe?
- AEM TruBoost Issue
- boost creep and service engine light
- Maf?
- Trick to removing flywheel dowel pins?
- Coolant coming out of exhaust manifold
- Biggest cams...?
- Huge problem
- Weird Noise!
- Built motor
- Briefly describe your built motor experiences
- HTA 3582 & 3586 LBS airflow?
- Fuel pump has no power!
- help gear fluid leaking after clutch install!!!
- Need help bad! winding and grinding noise..
- 2.3L and their max RPM's
- KOYO radiator real benefits?
- When are cams too aggressive for a setup?
- Help me pick a 2.3L
