PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. fp red question!!
  2. cant get axle back on, help
  3. CLutch pill removal
  4. noobie bad turbo questions?
  5. 16V Battery Updrade
  6. Don't know what's wrong with my clutch
  7. Apexi neo afc
  8. Can't find a part # for this transmission part
  9. Whats good out there today?
  10. Injector cracked at plastic cover under the bottom seal
  11. Need help removing ecu pin
  12. Mbc
  13. fluid from drivers side axel
  14. Clutch Poping/Clicking Please HELP!
  15. Bleed lifters after cam install?
  16. I think I have a stuck gear!
  17. Oil in number 4 exhaust port?
  18. Vibration/Whine after 4k - Timing Belt Change -
  19. Moly lube for ARP's Question
  20. Help Identifying Parts from the Head!!!
  21. 2.4 block help
  22. is there a specific way to put spring in bov?
  23. boost controller help
  24. Any idea what turbo this is?
  25. Mbc vs ebc
  26. Crankscraper: which one is better? Cosworth or Tomei's?
  27. MELLON RACING Gary's Evo 8 Project Build Begins Now !!!
  28. twin plate exedy plates????
  29. ERL Performance
  30. Ticking noise at around 6k rpm
  31. Weird vacuum reading at idle
  32. Bad luck with FP turbos
  33. exhaust manifold thread pitch
  34. Evo 9 boost at 15 psi ? need help or idea for problem !
  35. Vacuum hoses
  36. Oem Crank Damper vs Aftermarket Damper?
  37. GMB water pump
  38. Evo 9 Cam-belt change
  39. Should I get my cams machined?
  40. Evo 8/9 MR Transmission oil ? (2011)
  41. Good value clutch for 400atw
  42. Valve stem seals - Need advice.
  43. Very Low Fuel Pressure.(((
  44. Aem wideband sensor problem?
  45. Stock Evo 9 Turbo Pressure
  46. Question on the Best Muffler and Air Filter.
  47. Reusing Exedy Twin
  48. 4g64 Teardown
  49. AEM inline UEGO?
  50. how increase oil pressure???
  51. Cam selection help
  52. anyone pushing 650-700whp on the stock evo IX bypass valve?
  53. Greddy Ti or Fujitsubo Super Ti
  54. Black Smoke+ Low engine response
  55. blowing ign fuse alot and get shocked when exiting car
  56. rod bolts - reusable ?
  57. Overboost
  58. Tapping sound from hell ending BAD :(
  59. Can someone analyze this problem?
  60. Tranny Suprise
  61. P0300 only while on the freeway
  62. Cam swap and timing belt questions
  63. Smog Test P0420 Failed - Advice?
  64. Fuel Rail spacer on the intake manifold?
  65. How to Increase Torque?
  66. Start up issues after build
  67. Changed T-Case ACD question
  68. ACT XTSS clutch
  69. P0069 Code
  70. oem clutch, fp green turbo?
  71. Here we Go again....misfire problem
  72. over gap the secondary ring
  73. FP White ..
  74. Cruddy/Corroded Valves? Pics Inside...
  75. timing on evo 9? Mivec adjusted
  76. Stock Spool Feel, Decent Power.. Questions
  77. bad uego?
  78. need advice about cams
  79. Worth porting/polishing the head?
  80. How resilient are the ACT HDSS clutches?
  81. Intake manifold install, so I forgot..
  82. It's here!!!!
  83. what intercooler is good for me
  84. Need help reading plugs please...pics attached
  85. Need HELP. I am willing to buy someones AEM map
  86. Screwed my launch at the dragstrip,... heard a snap....what was it?
  87. Need to find exedy triple rebuild kit.
  88. compression test results 105k 03'evo8,fpblack ect..
  89. Weird bog problem
  90. To people running synapse
  91. Strange Clutch Problem
  92. Replacing motor mount
  93. Spark plugs
  94. bov opinions over 450whp?
  95. MEGAN 02 housing
  96. Evo ix mr bogs hard at 5k
  97. Can I use the stock oil feed line with the HKS GTII 7460R turbo?
  98. Cam Sensor??
  99. Ceramic Coating Manley Piston's...?
  100. Help! Rear Main Seal leaking!
  101. GTX3071R and Questions
  102. Backfire/Misfire Issues Throughout Rpm Range
  103. Setup suggestions vets?
  104. 2.4 block ?
  105. Evo wont start??
  106. Turbo Smart BOV Dual Port Review (Longterm)
  107. Gas Tank Swap ??
  108. Built Evo 35r Spun rod bearing on cylinder four twice!
  109. 5th gear grind...
  110. Supertech dual valve spring users, please answer some questions.
  111. Compressor surge on stock BOV
  112. Supertech dual valve spring users, please answer some questions.
  113. Clutch Question?
  114. ETS manifold/ dump tube/ tial wastegate/ v-band downpipe
  115. ACD error codes please help!
  116. Crankwalk on new engine
  117. Coolant Overflow - Retorquing head stud
  118. Inverted BOV
  119. Baffles in valve cover necessary?
  120. ACD Predicament
  121. AMS Intercooler With Stock Coupler?
  122. ACD Pump Fitting
  123. Whine slightly returns???
  124. 2005 bad second gear? what to do next?
  125. Need Turbo Help
  126. Big oil pressure problem?!? please help
  127. rough engine turnoff help
  128. SS braided turbo oil water lines question...
  129. Timing Oil Pump with Stubby Shaft
  130. I need more power.
  131. i need front transfer differential evo 8
  132. doing a evo 9 turbo HELP
  133. supporting mods needed for 350-400whp?
  134. MAP Exhaust
  135. My Compression Test
  136. 03 evo transfer case problem?
  137. Need start up tune AEM evo 8
  138. Running without timing cover?
  139. Bedding new Clutch
  140. New Carbonetic tripple clutch installed
  141. burnt piston rings, can block just be honed?
  142. Walbro super loud after track day
  143. Aftermarket intake manifolds - still using pcv setup?
  144. Clutch type lsd knock?
  145. ETS Titanium Muffler... 4.0?!
  146. Evo breaking up / missing under full boost
  147. oil pressure gauge install - what size allen needed to remove housing plug?
  148. Not having good luck with tunning
  149. ferrea dual springs with hks 280's??
  150. Removing Head, but won't budge
  151. Bearing cap torque spec confusion
  152. Engine Break-In
  153. Bbk full ported.....$$ bought$$!!!
  154. how to identify pistons ?
  155. dynatek+300m coils
  156. Which gaskets/bolts/oil lines should I replace when doing a turbo swap?
  157. EGT sensor install in front 02 sensor bung?
  158. long term drop-in piston and rod users chime in
  159. What could cause roller in head to 'pop off' the lifter?
  160. fp black on 91????
  161. will the fp oil line kit fit an evo 8?
  162. Tomioka Racing TD06-20G
  163. low compression.......
  164. Steel braided vacuum lines w/ Earls style fittings?
  165. what fluids do you guys prefer?
  166. what belts do you all prefer?
  167. Shake When Going to Neutral
  168. Help me with cam selection
  169. evo 8 and evo 9 turbo hot sides
  170. Whats wrong here?
  171. Intermittent rod knock?
  172. 1600cc injectors
  173. Clutch Fork Spring Question
  174. New product for changing trans and transfer case fluids.
  175. Acd issue
  176. GTX3076R RevHard Conversion
  177. Greddy exhaust?
  178. 3" downpipe dump w/ resonator?
  179. T-case help.
  180. kelford 272 good for my setup?
  181. kelford 272 good for my setup?
  182. My goal is 450hp and 350-375tq, what my moves to get there
  183. drivetrain noise...need help
  184. Help with MR shifter cables...
  185. high pitch squeek/squealing noise over 20mph?
  186. Do i need to flush the system after clutch install?
  187. Those who use Full Race prostock header...how did you tighten the top right nut?
  188. ebc or mbc
  189. Cooling system being pressurized??
  190. Radiator/Cooling System Pressure Tester?
  191. New motor, immediate new tune???
  192. weird motor ticking help
  193. EGR valve
  194. Boost Leak Test: Am I Doing it Right?
  195. Need an AEM EMS base map
  196. Best Cams/Stock Frame Turbo for a 2.0LR Build
  197. Eagle rods, fail!!!!!
  198. Slamming/surging when trying to accelerate
  199. Aluminum rod cap failure?
  200. Idle problem, missfire and too lean HELP PLEASE
  201. Kelford 272 fakes??!!?
  202. Anyone heard about 2.2L into Evo from Fairlady?
  203. Valve cover PCV fitting removal?
  204. OMFG Electrical Gremlins... need help
  205. Anyone ever use these?
  206. Zero Positive Pressure
  207. RC 850 CC injector scaling
  208. Intermitten vibration and clunking noise
  209. How long are the fp blacks lasting??
  210. Weird banging noise under full throttle driving
  211. Boost leak test...Problem?
  212. IV powered OZ.
  213. i need a block!
  214. act vibration???
  215. CBRD "F1" Evo Manifold... yep different
  216. So I took apart my rear diff...
  217. Is there aftermarket couplers for stock UICP?
  218. Cam question 272int 264exh
  219. help something is not right........
  220. bad lifters
  221. whats the best cam for fp green
  222. My Evo 9 is idling to high check engine keeps coming up.
  223. gearbox warning and "boom" sound during shifting
  224. What could cause idle misfire besides plugs?
  225. Meth / Alk upgrade?
  226. My kingdom for a set of SC S3's. LOL
  227. Tial QR
  228. help! need diagnosis.
  229. Help with choosing cams, valves, springs, retainers
  230. Slowboy Front Mount and LICP?
  231. Weird clutch issue
  232. pressure plate for exedy twin??
  233. Head Studs Question
  234. Pushing out old motor mount bushings
  235. Phenolic spacer, how should I go about this?
  236. Question about Synchronic BOV
  237. high compression reading?
  238. Exedy twin lockout!!
  239. 6 Speed transmission rebuild kit?
  240. And the fun begins..
  241. Plz Help Water leak above water pump?
  242. low rpm rattle after cam install
  243. Need fuel pump relay diagram
  244. Stock MAF Adapter?
  245. Increasing Wastegate Spring from 1bar to 1.5bar
  246. Shift linkage FAIL!!
  247. Replaced the disks in my QM twin... found something odd.
  248. HKS to Greddy
  249. Evo 8 best cams????
  250. Tial 44mm WG?
