PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 [126] 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. hta 3076.82 with cosworth m3 cams video
  2. E85 Evo Green best e.t 11.3 best mph 123
  3. Agency power gt35 on e85 gas results
  4. Greddy charge piping question
  5. Innovate Db AFR gauge issues
  6. Need a 02 housing?
  7. Clutch troubles
  8. Radiator Problem!
  9. Turbo upgrade gone bad
  10. ok i just got my tbe why do i have an 02 bung for the catback?
  11. Anti Surge housing problem
  12. Resurface ACT pressure plate?
  13. Confused: No boost leaks Idling 10.0-.8 afr
  14. Timing belt help (tension)
  15. Timing Question
  16. fuelpump/spark plug question
  17. How many months before the Buschur 93 octane record is broken?
  18. IX turbo or 20g VIII
  19. stock turbo identification/info
  20. Exedy Tripple toasted with cheese please.
  21. Cam install problem on my new stroker
  22. Clutch Slave Cylinder
  23. O2 Sensor - too lean (Bank 1)?
  24. HO alternator yes or no
  25. Hks Dli-2
  26. skunk2 cams anyone used them
  27. experts needed
  28. Does Anyone Know If The Hks Intake Cam For The Evo 9 Is Stamped By Hks???
  29. NEW HTA GREEN tested at Buschur Racing
  30. Magnus Race Intake Manifold OR AMS VSR Intake Manifold?
  31. Buschur Racing-Indy Evo-Weld Tech
  32. Guys with GT35R what BOV do u use?
  33. Hey big turbo guys (GT30/35 Plus,,
  34. Turbo problems
  35. HKS or Greddy timing belt?
  36. Turbosmart E-boost 2?
  37. ultimate racing test pipe
  38. Just Received My ETS HTA 35r T3 Twinscroll Kit and More! Check this out!!! 56k No!
  39. Slim Fan ????
  40. Anybody dialed in their Comp 280 cams?
  41. I Finally Got My Evo VIII Back
  42. ACT HDSS longevity
  43. used Evo, stroker or no?
  44. should I convert my exedy twin to a triple or buy new.
  45. Tcase/ACD Question
  46. So my clutch (HDSS) is toast, but it did well...moving on
  47. does evo 7/8/9 have the same ACD pump?
  48. GSC S1 IX Cams Vs HKS IX Cams
  49. Back on the dyno GT3OR ....
  50. Ebay timing belt kit???
  51. Need Help Please
  52. Need 35r rebuilt
  53. Will a stock EVO 9 Turbo fit an 05 WRX?
  54. The turbo's full potential
  55. Need help. . .
  56. Buschur Racing, HTA35r, 93 octane and 10.0's
  57. Engine Guru's in here (vendors welcome)!
  58. grind from 3rd to 4th
  59. Boost issues?
  60. New GT35 Killer Turbo - GT850R
  61. witch mbc should i get hallman pro or hallman rx pro??
  62. new clutch?
  63. 4th year in a row into the 9's - Buschur Power FTW! Wild 9.69 pass on a slippey track
  64. boost leak?
  65. boost controller help
  66. TRE vs Shep T-Case Rebuild.
  67. FWIW, Just DATE your parts, Don't MARRY them...
  68. What kind if A/F's are you guys seeing
  69. Full Wiggen's clamp'd intake tract and more custom fab
  70. Evo 9, GT35 and cams for stock Valvetrain
  71. Turbo break in?
  72. 3rd gear grind
  73. Wire Question
  74. Regular garrett to HTA? Buschur,AMS,ETS
  75. AMS FMIC install pics
  76. vid of stock clutches last day at the track
  77. 30R / FP Green / Stock IX Turbo Comparison
  78. problems with using used hks cams?
  79. Help Quick..
  80. Ultimate Racing Downpipe question
  81. New ETS Stuff!!! UICP/LICP/Intake pics!
  82. engine cleaners??
  83. Record DSM 35r Dyno Numbers.
  84. BF272's
  85. What are the best cams out for the EVO 8????
  86. s3's on a stock turbo 9
  87. Ams Evo Cam Test
  88. 4G64 Crank - Which Mitsu did it come in?
  89. Not the pump gas dyno record I was looking for.
  90. Evo IX compression check
  91. AFI TS Data
  92. FPGreen Owners: Anybody notice their FPgreen surging during low RPM hard pulls???
  93. AEM and Knock - eg: Paul Nelson Datalog
  94. TPG Tuning in Pittsburgh
  95. BBrooks tuned 600hp pump gas
  96. Act clutch problem
  97. Best turbo kit for the street not track
  98. (superscout03) my 2.3 monster build, tons of pics
  99. Turbo size =Efficiency
  100. Which turbo to pick and how to choose
  101. Which 35R setup is the best? Three Different Shops, Three different answers.
  102. a/f ratio
  103. My Stock turbo dyno#
  104. NEW PARTs
  105. Dll
  106. Buschur Skunk Works
  107. Gsc Or Hks
  108. Help on tranny/diff how to replace fluids EVO with ACD
  109. mobile 1 synthetic oil~ what do you think?
  110. Evogreen + EvoIX= low hp gains
  111. Testing out my new build today. 38psi 160mph!!! Aem log and more
  112. AMS 50trim + stock block
  113. Diff / TC oil change result pics
  114. Dallas Fort worth help
  115. 1680WHP - Buschur Racing Pump Gas Domination!
  116. Buschur Pump gas Evo's hit the track **VIDEO**
  117. Downpipe/test pipe/O2 housing questions
  118. 110 leaded?
  119. Forced performance cams anyone??
  120. Another flutter issue
  121. Evo VIII Engine Build
  122. Clutch Needed (Not basic Clutch)
  123. strange noise when clutch is floored,please help
  124. New "Indy" CNC cylinder Head
  125. *help* possible fuel cut out in MR
  126. Full Race 35R Twinscroll going on
  127. Works Evo IX Short Shifter with Bushings Review
  128. Gear Oil Gurus!! Redline Oil And Oem Fluid??
  129. detonation?
  130. How much will it take me to upgrade my 20g 10.5 turbo to a green.
  131. Pulled the head on my IX and found this! Any ideas?
  132. Broken front Diff...What next???
  133. Dyno tuned 357awhp stock turbo on 93 open dump *video* Top Speed tuned
  134. 353whp on stock 9.8hs,stock cams, stock o2 housing.
  135. Has anyone heard of BYC racing?
  136. throwout bearing help???
  137. Would you do it?
  138. Hks 264/272
  139. What Intake for the 35R?
  140. oil leak help
  141. Cam differences and Performance
  142. Greddy Profec B-spec users help!
  143. Cosworth M2 Mivec IX Exhaust Cam No Engravings.
  144. Oil Pressure Drops With Throttle?
  145. i have an odd boost leak anyone with ideas please?
  146. Is my idea in the right place? MAF Translator
  147. Whats the cheapest place for Excedy twin plate?!?!?!
  148. JAM 2ltr shortblock with fp green mapped today.
  149. Spring and Retainer install ?
  150. Help diagnose clutch issue
  151. Hey guys! HP on this evo = ??
  152. Brian Crower 272 cams/dyno
  153. AFI Twin Scroll Gt3076r kit.... 56k click before your nap...
  154. Eliminating the emissons/charcoal canister..
  155. HKS mivec 272
  156. Does ECU have any control over boost?
  157. *sigh* flooded engine
  158. 499 awhp on pump gas on MD
  159. PPI Ported Exhaust manifold. Extreme Porting or Regular
  160. wierd boost leak i beleive any ideas please?
  161. Norman Evo: 10.6 @ 128 with green turbo
  162. 20g compressor wheel evo8
  163. Extreme Turbo Systems - Twin Scroll HTA35R Turbo Kit - Twin WG Dumps!
  164. atp gt35r or greddy t67 25g
  165. WORKS ABM and 76mm IP
  166. Using a evo 8 wastegate acutuator on a 9 turbo
  167. best cams for DD FP hTA turbo
  168. Buschur Exhaust bits and FP Turbo
  169. New clutch needed
  170. Coolant Pump Exploded...
  171. pretty simple clutch question
  172. Oil light on dash Problem with Oil pressure sensor
  173. vacuum hose for boost gauge
  174. help plzzzzzz
  175. Tranny and Tcase carnage
  176. Switched 12V
  177. CBRD secret sauce turbo upgrade!
  178. Need help with P0172
  179. preloading the evo9 actuator
  180. Drop In Filter VS. Cone Filter
  181. Buschur Racing Double Pumper Fuel System
  182. Where to find 1G Flange for Forge RS
  183. "Indy Technology" for the EVO intake manifold
  184. Ralliart LICP question
  185. Power Coming out of the woodwork in the last year?
  186. Injector Size Recommendation
  187. ACT clutch questions
  188. Whats BETTER a KOYO or PWR Radiator?
  189. 4g63 or 4g64?
  190. MLR Thread - Remapped Evo X on Dyno Dynamics
  191. Nice thread off MLR on a 2.3 build with pics (also TS 35R)
  192. 50trim and hta3076R dyno plots.. and notes..
  193. Questions about crack in head
  194. HTA question?
  195. Do upgraded cams change
  196. Any how-to for replacing Alternator?
  197. bore size and piston clearance
  198. Engine Damper? Best?
  199. EVO 8 Oil pump Gear Play, need a confirmation.
  200. How would you go about removing this bolt?
  201. should I preload
  202. vacuum lines/effect on boost
  203. Air Filter Question
  204. Has anyone heard of this company???
  205. My Evo Green vs. Stock IX Turbo Dyno Results
  206. New CBRD build.... some cool stuff..
  207. Cam Timing
  208. Smoke on startup
  209. Cam Timing
  210. Switching Tcases
  211. My eBay gt35r Kit
  212. Cosworth M2 Mivec IX Cams need Valvesprings?
  213. wideband info
  214. Just got my Buschur 35r turbo kit in!!
  215. MBC hose size and spool/taper
  216. Evo 7 clutch
  217. 272's or 280's or mix
  218. rear diff
  219. what are these?
  220. Does your transmission chatter with the A/C on?
  221. More 93 octane numbers, another record by just a few HP
  222. knocking noise help please
  223. Stock IX boost reading on OEM gauge?
  224. borg Warner
  225. Oil temperature probe location - filter housing or drain plug?
  226. knocking noise..please help
  227. engine rattle noise
  228. How to rebuild an APS BOV
  229. Anyone using the recirculating Perrin BOV ?
  230. Anyone using the Samco BOV / BPV
  231. HTA35R First Impressions!!!!
  232. Why stock gear for drag?
  233. 370AWHP 341AWTQ now what?
  234. Boost on 3rd gear pull vs boost at the dragstrip
  235. Cams, meth, or front mount?
  236. Fs: 6 Speed Trans
  237. Redline Water Wetter-other products?
  238. exhaust manifold
  239. camshaft upgrade
  240. Gt35hta on a stock block
  241. Boost to high?
  242. downpipe boost spike
  243. Car not starting again.... P0335 code
  244. Flywheel question
  245. Are these numbers average?
  246. drivability issues
  247. TF is leaking BAD!
  248. Crush the IX BOV?
  249. Tial 44mm wastegate
  250. Fixed my Lockout problem with my ACT HDSS
