View Full Version : Evo Engine / Turbo / Drivetrain
- More power with bigger intercooler?
- Will Evo IX 6 speed trans. fit in Evo VIII?
- Flywheel Bolts
- Is Front OEM Undertray Necessary?
- Bleeding The Coolant System
- 100oct vs E85
- ACT Clutch Poll!!!
- tranny build ?
- I've need your help!
- Used cams - Useable or not? (Pic)
- Slightly used cams
- clutch pedal gripping?
- Max HP/TRQ on the stock clutch
- What turbo kit?
- tranny code
- Larger FMIC+winter temperature+same tune=lean condition?
- Hks Racing Suction Intake Trouble!!!!!!!
- ACD transfer case specs
- JIC Ti catback w/resonator
- Air Fuel Goes to 10 when slightly lifting foot off gas?
- Clutch Engagement ?
- low end response versus top end power
- Cx Racing Radiator
- Cam gear settings?
- transmission problem, fifth gear
- Convince me to not pull the motor and build it...
- Side Mount Turbo for EVO?
- FPRed Vs 35R
- rerouting the throttle cable
- Car cuts out with Test Pipe installed
- 860 WHP on the Buschur Dyno
- new clutch!!!!need help
- My AMS 2.0L build
- Evo 4 and Evo 8 differences
- FP Red custom LICP
- spark plugs and 02 sensor
- 3" to 4" filter 60whp gain!
- Boost response really slow? wastegate stuck open?
- Possible blown head gasket or coolant leak... help
- Difference between EVO VIII and IX head gaskets?
- Random Tech vs 100 cell cats?
- idle Vacuum and Recirc flutter
- Can your stock appearing turbo do this?
- Wich Fluid Help Plz
- FP Green Hotside Question
- AWD Motorsports RS.. 9.63@149.95.. Round 1..
- Making the car shift better.
- TurboXS FMIC Fitment
- Tranny Failure... Need Help!
- Weird shifting problem
- Clutch grinding at take off
- wastegate failure
- volient idle v2.
- AgencyPower short shifter sitting off to the right?
- 20g TME turbo?
- FPRed vs 35HTA
- Weird Tranny/Clutch Issue
- EVO 9 TD06 20G Turbo?
- Best high HP and quickest spooling Turbo??
- ARP Main Studs? should I install them also. ARP Rod Bolts, ARP Head Studs
- Clutch Suggestions
- cam question.
- wrap for upper radiator hose?
- Help 5th gear grinds a little
- STM's Ricer goes on a diet...
- 4" aluminum tubing
- Flames
- Quartermaster Owners Chime In... Install Help
- need help asap!!!!
- My starter died. I need a new one.
- Cam install Part 2...new problems!!!
- Aftermarket BOV on Stock UICP
- Need Advice (Gauges, Mounting, etc.)
- To E85 or not to E85. That is the question
- help ,plz
- rwd evo?
- Boosting Problem - Any Ideas?
- Hi, guys. Your help needed. EVO8 390 whp burned 2 coils
- Evo 9 20G Turbo AWHP Numbers?
- Forge MBC?
- Blowing the rear end
- buschur small battery
- Stock Cat-back max power numbers
- Turbo headaches...
- A little Help?
- CEL Engine Light came on out of the blue?...help!
- Build questions
- Cam install...having problems NEED HELP ASAP!!!
- Whinning noise?
- Fuel injector clips missing. Needed?
- boost goes,hesitates,then goes?
- 382whp 332wtq stock turbo IX, built and tuned by AWD Motorsports
- Excessive smoke from exhaust? Causes?
- Kelford 272 Springs and Retainers
- Time for new clutch =[
- 4G63t Engine Book? Engine Build
- Battle of the turbo's FS635 vs. GT850R
- Kelford 280I/272E evo8, who's running them?
- Cosworth 2.2L Rod Length and Rod Ratio
- I think i have a problem
- Tranny Noise??
- Am i missing part of exhaust?
- Flywheel Good? (Pics)
- problem with testpipe
- MAF gone bad?
- Axle Problems
- Show Off: Synapse Synchronic or APS Twin Vent BOV?
- need little bit advice on catbacks.please help
- Pistons rings clearance
- White smoke from engine when under boost
- HELP?! Flywheel...ACT or Gruppe-S
- Gearbox identify ?
- ported and swain coated where from
- Explain the tru-boost settings
- ACT clutch disk question
- Short Shifter?
- Messed Up With Test Pipe
- Need some opinions please! Getting ripped off?
- help with pictured tcase leak below, please!
- Anyone running a T3 setup if so what are Good Trims
- Does anyone else have compressor surge?
- 12x12x2" radiator is it enough?
- EPM 02 Dump hitting Radiator??
- Gauges
- Driveshaft studs
- Oil pressure is WAY to high HELP new motor
- possible to bypass or delete the stock fuel filter?
- How does Twinscroll Work?
- Spec stage 4 clutch???
- 10psi. . . 15psi . . . then works fine???
- help ,plz
- First impressions:Twin scrolling the T4Z HTA88
- FP RED W/Ext Wastegate?
- stock turbo possible leak??
- Battery Issues! Need Help!
- Oil Report(Blackstone)&K&N Air Filter
- Confused? suggestions!!
- FP4R cams
- Question on removing head and timing belt..
- Pistons part numbers Need help ASAP SOS
- proof of break in of an engine
- Who makes this header?
- Oil Leak + Popped out dipstick
- Stock Wastegate Arm
- FP RED How long did you wait?
- A few pic's from my buster rear end
- Question about exhaust
- Megan Turbo Manifold. Good or Bad
- big turbo input needed
- 9 turbo or something slighlt bigger?
- Feedback on ssautochrome t3/t4 manifold and downpipe?
- Carz Performance *TEASER VIDEO*.. Thanks JohnEB!!
- Does the wastegate stay open at idle?
- Short shifter?
- EVO9 Turbo on a 240SX?
- Did a boost leak check... heres what I found
- Clutch Install = Me Stressed
- School me up fellas
- boost leak issue...or not?
- Stuck manifold bolt
- new head gasket :mad:
- I think my clutch master/slave cylinder went out
- 400WHP on pump?
- 2.3 35r 880cc stock ecu
- Difference between evo 8 and 9 turbos (pics)
- Stock evo 8 piston question?
- Pure Tuning Borg Warner S259 Dyno Results!
- transmission question
- Garrett GT 30 OR GT35.pls help
- Evo Red For An 8
- Can my 500 WHP EVO VIII benefit from a 4.11 FD??
- viii block ix head
- clutch repair price$
- Help my car wont start!
- Oil squirters close to piston skirts
- Drivetrain making weird sounds! Need some help.
- very low idle and stalling
- Turbo wont spool until 5K, stock evo 8 turbo, no boost leak..HELP
- My evo 6 so far......
- Dont know what to do. Need Help!
- No Boost!
- FP Red + Meth?
- Can't decide on turbo kit.
- CBRD possible drag radiator...
- Little help/Info
- Piston to valve clerance problem
- Convince Me: E85 or Meth?
- Evo IV drivetrain problem
- My FP Red Setup
- The Correct Way to Install a Head Gasket?
- stock boost questions
- Shifter cables popping out of the console assembly...
- Stock Intake Mani VS. Other
- Oil Return pipe bolts
- Cosworth M3 Mivec Cams
- Turbo Suggestions for EVO IX
- EVO 9 Turbo problem.....
- FP Red... What Valves/springs?
- insane bov flutter
- Hks Bov??
- Oil on turbo housing makes me nervous...
- EVO Heater Core Removal - Help
- stock cam markings
- price of ams tcase rebuild?
- HKS 264's
- In-car Hallman boost controller question!
- Clutch needed: withstand MANY launches & 450 TQ
- Coolant Temps some what disturbing?
- ams or buschur for mustache bar
- Clutch or Tranny Problem??Help
- coil on plug system
- Engine Tick
- transfer case repair manual
- 4th Gear Problem
- boost fluctuation
- oil light flickering what's it mean?
- help please
- high 400+ hp owners chime in
- 9sec9/OKIX, BUSCHUR RACING, ROUND 3..
- 20g or GT28
- Are Iridum Plugs worth it for E 85 & Hi Boost?
- Final #'s for Fulll Functions Evo 40R / 2.1L / E-85
- Not Holding boost
- Tilton went out on me
- Gear problems
- lifter tick after oil change
- engine blow back on idle if oil cap off
- What is a fair price on a built evo 8 head?
- weird problem on my evo
- cutting out between shifts? NEED HELP
- P0300 and P0138 codes. Need some insight.
- Ams 3076 Turbo Upgrade And Minor Headwork?
- Meth Injection ratio?
- resurface fidanza??
- Nitrous in Evo IX
- The perfect transmission oil
- P0243 Boost solenoid error
- fidanza clutch
- Check engine light
- 2.3 35r 880cc injectors need help confused
- Just some praise for EvoPowerMods
- boost gauge
- Vaccum at Idle on boost Gauge
- which wideband?
- 3" Intercooler piping.
- Transfer Case tricks
- Car starts running bad when warm...
- Best Break in for an Exedy Twin??
