- Unorthodox Pulley set Evo VIII
- 3 SS Inch RMR Downpipe with SS O2 bung
- car stalling issues
- how to run tubing for greddy catch can???
- trying to find the right turbo mabey...
- Finally getting decent power out of the gt35r
- Evo 9 Stock at 21psi=1.48 bar
- Any "underhood" Methanol explosions yet?
- Poll : Which Exedy Racing Clutch do you use or recommend?
- 2nd gear grind
- Unhappy With Exedy Clutch Whats Next?
- MAF Sensor Orientation Question
- Anyone running new Perrin Boost Solenoid?
- Crankwalk?!?....wtf!!!!
- fidanza flywheel question
- Time for a heart attack?
- another downpipe thread.......
- WorxTuning BOV
- Regular Oil in my Evo
- Question about Karman reading
- Best shop to get car worked on in NYC
- Fighter's Garage LICP Warning!!
- Help Help ?
- EGT temp...winter vs summer
- Stock Boost Line Availability
- the second from the left spark hole...
- What boost should i run?
- Has anybody seen these codes?
- Is oil supposed to be here?
- cutch disk/pressure plate question
- cams installed... engine dies out sometimes
- 2.2 stroker questions
- Anyone here this "mysterious" evo loss in power?
- Fuel lines, will they be enough?
- how tight on ARP headstuds??
- "triple" clutchs
- Clutch pedal problem
- buschur smc alky road race
- Shifter pops out of 1st
- Alky and higher boost
- 775whp, no nitrous
- exhaust
- More new parts from Buschur Racing
- wtb urgently cash at hand
- Brand New MR, Spun Bearing, (1500 Miles)
- Whats wrong with Buschur alcohol kits
- custom dynoflash vs turbotrix
- Going for alcohol, what #'s should I expect w/35R?
- Roar Filter
- 2nd Gear Grind
- 2.5" VS 2.25" IC PIPING ?'s
- Anybody smart enough to figure out...
- anyone using the Greddy FMIC with the HKS UICP?
- Ported turbo?
- how much of a loss in power does a boost leak cause?
- Help me Diagnose a Problem (plz!)
- highest boost question
- 6.5 TME with 9.8 housing?
- hp per psi??
- Maximum Boost on Stock '05 Turbo
- How important plug gap is...
- stroker kit
- BR exhaust owners!
- the cams from hell
- intake exhaust
- Which oil filter?
- External Wastegate???
- Help With Hoses
- First Modifications
- White Rabit and Manifold:)
- Who sells Piper Cams in US
- What next for my EVO
- Intercooler installed..Boost dropped
- Boost problems (AGAIN!!!) Could be wastegate?
- Smokedmustangs Dyno at Dyno4mance!
- Lower Temp Thermostat
- New Forge RS BOV
- how high can I rev my engine with these mods?
- B&M Adjustable Short Shifter Question
- Retaining Torque
- Will bolt on mods cause........
- Saw my Boost bouncing while on the Dyno
- Will bolt on mods on the Evo cause.......
- SS Auto Chrome Turbo Back Exhaust!
- Boost dropping at 4000 rpm
- First Mods for newbie?
- I'm not gonna make my tune am i?
- Buschur GT-35 impressions.
- More GReddy Profec B Spec II ****ery.
- Why power/boost drop after Intake install?
- Lost HP/boost after Injen intake/UICP install
- Tuner help with Ign Timing please
- Which wide band should i run?
- serious boost fall off
- Proactively changing fuel pump
- Help! Spark plug #1 fouling
- Is it my throwout bearing or my pressure plate?
- Any Buschur BB GT30R Turbo Kit owners?
- Boost Drop Question?
- 5th gear grinding!!
- In the middle of WR turbo install...got a question
- Just installed cams (no cam gears) and got P0300
- ATS Triple Plate Install Question
- HELP,SES Light ON ,2 Engine Codes
- Engine Problems....!!! Need Help!!!!!!
- Buschur GT 35R install questions!
- What's with the Ultimate Racing's 3"....
- Scored cylinders and Pistons!!!!
- p0300 Fix/patch
- Issues with the B&M short shifter...
- Boost/ Vacume Problems
- Am I getting compressor surge?
- have you seen this evo commercial?
- 03 Evo needing new TC...best route?
- higher boost and over heating
- Help!! My car wont start!!
- Another Walbro 255 ?
- striped out turbine housing
- Help me with my HFC decision..
- Stiff gear box after clutch install
- helix intake intall ?
- Buschur race "chip" - a big success
- cam installed...getting backfire
- Tranny Fluid Question
- Please help with my clutch issue
- Top speed for the stock turbo?
- Hallman MBC on STOCK 05 MR
- Build head power increase
- Tale of two intake manifolds - is bigger better?
- When do I need new injectors/pump?
- Anyone have similar mods?
- QUestion about AEM intake & MBC/EBC...
- Who makes the best cylinderhead for my EVO
- my evo is acting up pretty bad need some help
- Walbro Fuel Pump Question?
- Buschur/SMC alky injection troubleshooting...HELP!
- rear differential
- Upgrade to ATP GT35R?
- Checking transmission oil level?
- Anyone running the ATP turbo kit
- Type S boost Controller
- Greddy boost gauge, buy a TT harness to ease install?
- Correct BOV orientation
- GReddy Profec B Spec II Boost Spikes - Need opinions
- TSB's for 03 tranny issues?
- Oil leak, please help!
- Look at This!!
- Service Engine Soon - code P0430
- CAMS or Injectors or other
- Audio & Video of Evo sidepipe Now Showing!!
- Fidanza Cam Gears install Q
- Advice needed...
- HKS cam gears ???
- Stuck at 610 WHP!!!
- Walbro 255lph info??
- how to achieve 400WHP on pump gas...
- Quick Performance Question...
- Anyone out there have the turbosmart dual port bov?
- HKS SSBOV adapter part number
- Can I safeguard against boost spikes with BOV?
- Cam lift questions??
- Just tuned...a lil low...nice drive tho
- spun bearings
- Boost problem?
- What brand of Fuel Injection Cleaner?
- I need a low profile radiator fan... (2.5" deep)
- Check engine light not working?
- Where is tranny,tc,l.s.d located
- Removed Exhaust. Cams, Sprockets Okay?
- ....Yay or Nay.....
- would switching the two vaccum lines on my MBC do anything?
- please post pics of your SSQV running recirc
- good or bad??
- Car started bucking today, any1 know why?
- 2004 RS Trans oil
- Need some help. (Measuring Stock Cat)
- Are there any Aftermarket REAR LSD's?
- Does Ralliart Filter need oil?
- Cams/ HKS or Buddy Club
- MITS giving me a tranny
- Just got my ECU reflashed
- Dynoflash is the best!!
- Jun&Hks cams?
- evo pistons
- Evo clutch help~
- Evo 8 Viii Tranny Trans Transmission Clutch Noise Chatter Grind
- Stumbling at low rpm...advise
- F our drivetrain... VENTING but speakin truth
- Best Catch Can??? Such Thing?
- My one month review of Rnr FMIC
- which intake manifold?
- 3 S.M.A.R.T. ways to make more power with more safely
- NEED HELP! I am having a whinning sound from the car under load.
- Ceramic coating shop in Denver???
- ecu sent to dynoflash.
- Oil in Coolant overflow?
- How much AWHP should this make?
- wana here some bs
- Clutch doesnt disengage correctly
- first gear thunk.
- Dyno comparison of stock vs GT35R
- Accuracy of HP calculator question
- Buschur gt35r with a flash
- Need advise for ALKY!!!
- DiaQueen part number?
- 272 cams.
- looking for RS rear diff setup
- Leakdown/Compression #'s?
- Maybe you guys can help
- questions about dynoflash/safc2 combo?
- Koyo radiator (2 questions)
- 10.5 hotside question
- boost advice please
- max hp from stock MAF?
- picture of under the valve cover?
- ....another ATP question.....
- Act 6 puck and Stock PP. Good combo?
- Codes I scanned...worry?
- Engine clicking sound
- Change Fluid and WORSE
- Speed or Quickness? when do you stop?!
- hey guys weird noise...
- <----- Possible WRX to EVO Conversion: Couple of Questions...
- Timing for 280 cams?
- Anyone running a GT35R at high altitude (5000ft or above)?
- Blown Front Diff?
- Stock turbo seal leak??
- What should i run Race gas or Alky
- 280 cams
- Cams and ecu!
- cel light
- better stock turbo 6.5 tme or new 9 turbo
- Is it redundant to use race gas AND Alky?
- a serious tuning question
- AMS GT35R or Buschur's Ball Bearing GT35R???
- Where can I get fuel injector o-ring other then dealer?
- New way to calculate size??
- Curiosity Question on those VTA and running fine
- How does a broken rod sounds like?
- manifold gasket
- are the heat shields important?
- ??whats going on with my Evo turbo??
- Turbo problem? Need help!
- My 5th gear pops out into neutral HELP!?!?!
- Coolant question
- Trans Oil (I know it has been beat to death)
- Which tranny for evo 8?
- Did I break sometihing?
