View Full Version : Evo Engine / Turbo / Drivetrain
- Best possible intake for Evo8?
- Why cant i hold 20psi?
- Buschur upper I/C pipe?
- J&S safeguard any one running it on the EVO
- 02 and ses light
- Is this normal?
- 50 trim T3/T04E vs GT30R ???
- My EVO sounds supercharged
- clutch drop at WOT
- Stock Boost Characteristics
- Perrin Catback Installation
- Question about TurboXS RFL BOV
- Greedy BOV Type S
- Need help removing clutch restrictor
- The FINAL Clutch answer?
- buschur exhaust
- SAFC and Flash
- Evo 8 Turbo Upgrade Need Advice
- Tech Gurus: Help Me!!
- Anybody have Alternator/Generator problems?
- O2 Sensor Problems
- Documented Clutch replacement
- typhoon intake screwing with my ECU..
- 4g63 Oil Pressure?
- Nitrous to spool turbo?
- Best Cam Setup??
- intake HELP!!!!
- Works skidplate
- Intake temps
- NX Wet kit
- My Evo at the Dealer 2nd gear grinding. PLEASE ADVISE ME
- RB Motoring Titanium Exhaust
- act clutches?
- Boost Controller
- Cam Installation - Installation Prices?
- P0300 misfire fix not downloading
- What shops tossed the stock rods out the bottom?
- Ridiculous problem
- Radiator Options?
- Perrin downpipe
- Oil smell after shut off
- Toda, Tomei, HKS, which is best
- Koyo radiators? Any opinions?
- My Check Engine Light Comes On
- Strock rods in EVO8 forged or not???
- Car does not build boost when just revving?
- New Intercooler
- Replacing the battery with a smaller one to fit a custom intercooler pipe
- JIC exhaust loud?
- ECU Upgrade
- Seriois Stuff
- Anyone tried Piper cams?
- oil change!
- whats Kpa translate too!??!?!?!
- Anyone with a HKS DP , 3 inch test pipe and HKS SS 30th setup?
- Defi Oil Pressure & Temp Sensors
- Threw a CEL tonight, any ideas?
- Check out my NEW heatshield
- Radiator Leak
- REAL results (Dyno, SAFC Settings & More)
- HELP ! MY EVO is at the Dealer PROBLEMS any one knows why ?
- ABS vs Front LSD
- BOV questions
- 494.4whp 400ft.lbs at 24psi
- Mbc ???
- HELP...i need exhaust tips
- Buschur Racing offering financing....
- XEDE to Dynoflash
- Timing Belt
- Need help with settings on afc 2 and boost controller
- dyno'd today w/new boost control
- Who here vents their BOV?
- Perrin...CEL or no?
- Clutch for modded cars
- Anyone use Amsoil?
- Looking For and evo 4,5,6 engine
- Buschur "budget exhaust"
- Is there a QUIETER muffler for the Buschur 3
- Garret Website Please?
- Unorthodox Hardpipe kit
- HKS Catback Tip Angle
- Engine Shutter at highway speed
- JDM 3 inch exhaust
- Hey guys, my EVO just died
- The power of ECU
- GFB Stealth BOV's anyone have them installed?
- 'Service Engine Soon'
- Who else has blown off intercooler hoses?
- Dynoed today, w/MBC
- Clutch options and opinions
- can't figure out how to get this recirc kit to work
- Changing fluids today myself, PLEASE HELP!! Don't want to screw up
- Magnaflow
- HKS EVC 5 help!!
- Modifications: How far can I go with my warranty?
- boost gauge parts
- Is it possible to use oil temp gauge to know how long to cool down?
- Well installed my MBC, & boost gauge. Have a question or two.
- de-cat adds boost?
- Who Sells Perrin Downpipes?
- HKS Adjustable Cam Gears FOR SALE
- To anyone that has vibration in their clutch pedal...
- Greddy T-67 (25G 10cm Housing) Vs. AMS GT35R Turbo Kit
- How much PSI are you boosting?
- problems with my evo
- Best Intercooler?
- Toulene and Xylene?
- t sport launch control
- What exhaust has a small tip?
- US made forged pistons and rods for EVO8?
- Hey Al..have a question about reflashes
- Evolution
- helpppppppp
- Question for all specialist ( EVO Engine mods )
- Buschur MBC!!!
- Blow off valve flutter?
- Misfire and low boost reading
- blow by
- NOS On Evo VIII
- Buschur filter
- Best Turbo Timer
- Clutch Line Install Question
- HKS 3037s turbo kit
- Best way to go for more power??
- "normal" oil temp
- ZEROSHIFT!! Unbelievable
- Strange
- ***1st mod before you do ANYTHING else***
- greddy type-s BOV
- Why does the evo idle so rough?
- High Temperature Exhaust Resonators
- Engine misfire
- WHP BC will add??
- What to do about bad rear diff?
- Hallman Pro RX kit
- clutch pops out of 1st
- CEL light... Error on Pre Cat?
- weird noise from bov
- What to do when overfilled from the factory??
- Anyone with full stage 1 on evo?!?!
- cam questions
- B&B muffler discussion
- Buschur Racing has Exedy Twin Plates in Stock!
- NYC EVO Owners
- AEM wideband
- They're Fixing it!
- Which way to go ?
- Need help with blitz ss bov
- Air/Fuel gauge
- NEED IMMEDIATE help
- To idle or not to idle.. that is the?
- P0300 misfire code fix!!!!!
- Re-dynoed after DYNOFLASH
- Tech Question
- Weapon R's Evo intake kit
- Anybody Gut The Stock Converter
- To those of you w/ the Ultimate Racing HKS BOV kit...
- Quick MBC question.....advice please.
- Works 269 pass sniffer test(emmissiona)
- Where does this Radiator hose go?
- Greddy Profec B Spec2 Issues
- Perrin DP
- Apexi N1 Exhaust?
- Any exhaust system out there over 3 inch??
- Problems with Greddy Profec B Spec I
- Turbo XS Exhaust System
- For those of you throwing Check engine lights....
- bov question
- the new Oil poll: Synthetic vs. conventional consumption
- microtech,aem ems,haltech,vishnu xede,power fc,autronic,motec etc..
- dp or afr first?
- what do you guys think of this bov?
- Another turbo kit
- Quiestest turboback on market (like stock)
- Clutch, is mine gone????
- Backfiring Evo 8
- timer help plz
- New turbo
- Question for Al...
- bushurs lower plumbing intercooler pipe
- sequential shifter
- Place to tap for Manual Boost Controller
- Steel clutch line, What's up with that???
- evo's clutch acting weird
- Buschur Racing AFC?
- Downpipe bolts....
- For all those with a CEL and no cat
- Gram Lights 57 Dragon or ApexI Hayabusa
- HKS Hi-Power
- Cold morning, EVO wouldn't start...
- WOW! Buschur stage 2.5
- Cams and passing emissions
- Does anyone kno about the AWD system?
- Click noise when depressing clutch?
- Open Downpipe? Ecutout?
- Anyone make a 3" titanium downpipe?
- Check this Dyno Graph!!!
- Fluttering stock BOV
- TurboXS HPBC hex size?
- Coilovers for street
- Where are the spark plugs?
- General Concerns
- EVO 8 RS LSD, when will it break?
- Obx Fpr
- AEM Intake and Buschur FMIC
- Best Clutch
- Is This Normal????
- Stock EVO + Cam Gears?
- The Oil Filter Question
- Intake Evo 8
- Clutch Pedal Vibration
- Streetable car
- Stock EVO 8 Fuel Pump Flow Rates
- als dyno flash vs bushur flash
- Calling out to Dave Buschur
- AWD=Awesome Launch???
- Borla Catback
- cusco vs. exedy
- hks tt?
- 4G64 block into an EVO??????
- Installed my Hallman MBC
- bushur racing mandrel bent ss 3 catback
- Whats my Problem??
- Fuel Pump and S-AFC?
- Post all your exhaust sound clips here
- Nitrous?
- Microtech Ecu Wow!!!!!!!!!!!!
- exhaust dB question
- Anybody elses car die in 4th?
- Whats you think of the APEXi AVC-R electronic boost controller?
- Break/Clutch fluid? What kind should I refill with?
- BR bolt on's...
- Dynoflash????
- clutch tech -- why do ours suck?!
- Cel, Reflash ecu, Flashing back to stock?
- AEM EMS evo dyno 303hp, 314tq
- Dynoflash Delivers!!!!
- Racing Pulleys
- Big dyno show down today?
- 255 lph inline pump same as 255 intank?
- A question to tuners about spark plug
- I converted dual stage muffler to wide open!!!
- HKS Super AFR owners discussion.
- Buschur Racing turbo kits & dyno numbers
- Walboro 255 fuel pump???
- Buschur vs. Vishnu tuning
- RalliArt Parts worth the it?
- MBC boys and girls
- HKS 272 install, stright up or +3?
- Best way to install oil pressure gauge
