PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 [241] 242 243 244 245 246 247 248 249 250 251
  1. Utec, Vishnu, Reflash...What to do???????????!!!!!!!!
  2. Best turbo timer?
  3. HKS RS kit installed... where's my midrange power?
  4. Need a new tranny
  5. Blown differential pics
  6. A little light on the lingo...cam gears
  7. 6-Speed Gearbox and Clutch on FQ300 vs. US Evo8 Version
  8. Interested in a front LSD for US Evo 8?
  9. Anyone replaced just the muffler?
  10. Intercooler water spray Science ® by http://www.CarPhoto.net
  11. Evo 7 clutch..Help..
  12. HKS SSQV with Recirc. Kit
  13. BOV for Evo
  14. ECU swap
  15. Front LSD
  16. Cat Delete?
  17. EVO Meet - Pruven Black top secret Evo to debut! Dyno runs - Pizza - DJ - November 1
  18. HKS drop-in filter to cone upgrade
  19. I think I have way to much boost happening
  20. Turboback exhaust and high flow cat...boost spike?
  21. Looks like oil in the coolant... [MERGED]
  22. o2 voltage equivalency?
  23. How to tune stock evo
  24. HKS Cam? What adjustments required
  25. clips, popped themselfs out of the engine bay??
  26. My car keeps stalling, WHY??
  27. EVO 7-8 turbo on DSM motor
  28. Doin' the Dyno flash!!
  29. Whoops Vivid did it again!Headers and Fuel rail
  30. Just got my JIC exhaust installed
  31. Down Pipe: HKS or RMR. Which one is better?
  32. Speed Box Turbo!!!!!
  33. The turbo for the Boost Solutions race car is here:-)
  34. oily residue in BOV and intake tube
  35. Least problematic Intake/dvBOV combo??
  36. Power FC initial Dyno tunning
  37. Sound clips for the HKS Ti exhaust?
  38. electronic boost control or AFC???
  39. Aem Intake Heat Shield Removing
  40. Best Sounding exhaust?
  41. Brake in
  42. Anyone else drooling over the AEM EMS?
  43. Will an Evo VII Exhaust Manifold Fit a DSM Head?
  44. DynoFlash
  45. Well, Pocket Logger works on the evo!
  46. Boost Control
  47. US spec EVO 50/50 torque split? Also another question...
  48. AC compressor going off during hard acceleration
  49. Gota love Sunoco turbo blue!
  50. Does HP Cary between gears?
  51. UR 3" High Flow Cat & UR 3" Test Pipe
  52. i have just been flashed! (long)
  53. new here...
  54. JDM 6-speed gearbox on ebay
  55. Newest dyno sheets - 291 WHP!! w/ Exhuast and EBC ! 93 octane
  56. Hayward & Scott - Video/Sound Clips
  57. TX Tuning Dyno Results
  58. WAI effect on air:fuel ratio on tuned SAFC car
  59. Hks Tt Help!!!
  60. evo throttle body specs?
  61. B&B Turbo-back VS. JIC Spartan catback
  62. Problems with GReddy Profec B - II
  63. HKS EVC Setting/Tweaking
  64. anyone have any problems with high flow cat or cat delete?
  65. TD06 Upgrade
  66. BR muffler delete pipe and UR cat delete combo!
  67. How strict is Mitsubishi when it comes to warranty?
  68. Hypothetically, can you run an EBC from the manifold pressure line like an MBC?
  69. What do you value the most in an exhaust system?
  70. HOLY BUSCHUR!!?!? 600HP WRX rollin in canton?
  71. No exhaust system setup
  72. Problem with HKS BOV? Stall?
  73. High Altitude Mod
  74. Longer Lasting Clutch!
  75. Greddy Profec Spec B and SAFC settings
  76. Stalling (Crankshaft Position Sensor)
  77. Is there any mods for fuel economy?
  78. 278 WHP with DYNOFLASH!
  79. Exhaust, Intake useless for hp gain??
  80. EVO8 Redline
  81. So this is what the dealer told me after seeing my oil catch can...
  82. xede vs. power fc
  83. should i buy turbo XS bov?
  84. My boost tapers slightly even with MBC.. is this normal?
  85. HKS Type 1 TT
  86. K&N intake w/ HKS Kansai Box set-up
  87. Got my cam's in Finally
  88. evo5 clutch
  89. Bad Backfiring. Please Help!
  90. dynoflash
  91. buschur stage 2
  92. should i put this forge DV on...?
  93. Fuse on Battery
  94. Evo w/ Buschur Exhaust and EBC - 330 whp w/ Dyno Flash - dyno sheet
  95. 274 whp bone stock EVO Dyno Flash - dyno sheet
  96. Knock count
  97. Anyone have the Perrin catback?
  98. Borla Exhaust?
  99. Tranny & Diff Fluid Choices...
  100. AEM EMS for EVO8
  101. Need Help on tuning the APEXi AVC-R
  102. best recirc valve.
  103. Feed back from Evo owners with after market clutches???
  104. quick fan question
  105. Anyone use Power Enterprise parts?
  106. Port and Polish
  107. HKS Carbon-Ti Exhaust question
  108. Installed Catback Exhaust
  109. EBC or MBC if you can't record peak values with boost gauge?
  110. Gtech Results of Pill vs. No Pill
  111. Stock Block, Max Power
  112. Residue in my intake
  113. Anybody running an AVO Turbo Kit Yet?????
  114. All my tranny noise gone:)
  115. Almost to 12's
  116. HKS EVC boost controller install
  117. what kind of wastegate do we have?
  118. Need Help... Please
  119. Utec available in 10 weeks!
  120. HKS Suction w/ forge re-circ valve
  121. stupid question
  122. Looking for a tuner
  123. Tired of Searching... Where to get HKS DP?
  124. Clutch problem-anyone threatened lawsuit?
  125. b&b turboback w/ test pipe: throwing a CEL?
  126. Sound clips of the RNR turbo back exhaust?
  127. Which exhaust for me???
  128. Dynoflashed
  129. Yes Im A Nube I Need Motor Help
  130. Dyno Flash vs. Works vs. Stock Dyno Sheet
  131. Buschur Racing's Intercooler
  132. Anyone run Amsoil fluids in their transaxle, trans or rear diff?
  133. Exhaust Review Database!!!!!
  134. HKS suction kit install
  135. Does a tubro back raise boost?
  136. Performance upgrade to 400bhp.....
  137. dumb question
  138. RMR or Buschur "DP"; why?
  139. MIL eliminator O2 simulator options
  140. New washers and oil/fluid changes
  141. PE Boost Controller Settings Questions
  142. Oil Catch Can brands
  143. Wastegate Arm and diaphram for EVO 8's turbo???
  144. the DOWN PIPE thread
  145. help for a BPU supra owner.
  146. Is that whining noise from the turbo or tranny??
  147. Hayward & Scott exhaust installed
  148. killed the clutch after 6800...
  149. those of you witn turbo back and no cat/testpipe
  150. My BOV Sounds Strange
  151. ran 12.6 @ 112 --- broke the car
  152. Please Read!!!!!!
  153. EVO mods arms race
  154. Today I got Dynoflashed!!
  155. F-con and MAF
  156. Tips: installing the HKS racing suction intake
  157. Evo turbo header dyno results?
  158. forge dv **poll**
  159. Does anyone else here wish they had a gear between 4th and 5th?
  160. leaky BOV
  161. Help... I fried my spark plugs!
  162. Transfer case for Evo8
  163. HELP!! Suction pipe leak
  164. Cat Delete Power?
  165. 292 At the wheels with only 2 Mods!!!
  166. MAF/Airbox
  167. JDM Evo 8 recall part pix
  168. Anyone got XEDE with non-vishnu exhaust?
  169. AMS turbo kit results
  170. just installed MBC.
  171. ARP Head Studs
  172. What is the difference between turbo and cat back?
  173. installed boost gauge and huge problem
  174. Help with Exhaust!
  175. Underdrive Pullies...
  176. About spiking and knocking...
  177. Is this HP gain for real?!?
  178. ? about mixxing 100 octane and then going back to regular pump gas
  179. Boost Kicks In EARLY but hits MAX late why ?
  180. JUN camshaft
  181. O2 Eliminator Downpipes?
  182. Everyone Please Read! Advice Needed!!!
  183. HELP: New Evo seems to be leaking water?
  184. jic exhaust info
  185. K26 Or T3/T4???
  186. Anybody have the Perrin Cat delete pipe?
  187. Getting big injectors to idle...
  188. HKS Exhaust & DP Questions
  189. dyno test
  190. Turbo Spooling
  191. HKS BOV - VTA or Recirc?
  192. Off the line power?
  193. boost vs rpm
  194. Intake Chatter Problem??
  195. Mad Performance Products axle back dyno plots & sound clips
  196. First EVO8 APEXi Power FC installed
  197. DEFI BF Boost Gauge Reading!
  198. how would you spend 10k on an evo8
  199. same engine set up?
  200. hallman mbc
  201. HELP: Bone stock EVO is overboosting
  202. Penzoil 5W-50 vs Castrol RS10W-60
  203. HELP! I need rims!
  204. Eclipse and Evo Engine Parts compatibility
  205. 0 psi at idel! Normal?
  206. Clarification on Turbo Terms
  207. I got chosen to be on MTV
  208. Buying a new EVO
  209. For those with the 272 cams
  210. ???????'s to answer?
  211. Mobil 1...Black after 2700 Miles...
  212. MAF metered cars and VTA BOV's
  213. HELP: Resetting the ECU?
  214. Forge BOV - compressor surge issues
  215. Nitrous question for people who're using it
  216. Tested all the mods!!
  217. Blow Off Valve for EVO VIII
  218. For sale! Factory Guage Package
  219. IC Sprayer not working
  220. Twin Disc vs Single Disc...
  221. BOV problems
  222. Turbo back exaust...
  223. Turbo XS is going to be making
  224. 91 octane Fuel - Colorado
  225. Anybody hear word of the K&N intake?
  226. Turbo idling when restarting?
  227. max boost @4500rpm !!
  228. Fluid Change Help...Tranny, Diffs and Trans. Case
  229. Yeah, I know it's not an Evo....
  230. Installed HKS downpipe Help ~~
  231. SAFC loses all settings when car is off
  232. anyone heard of this pipe?
  233. Boost Characteristics on Evo's
  234. SAFC/AVCR settting help
  235. Exedy Twin Disc Clutch Kit
  236. any more B&B dyno graphs?
  237. Greedy type-S mod Problem
  238. VTA and Recirc. BOV
  239. i took out the cat and it was slower
  240. Mod suggestions...
  241. Difference between US Evo and US FQ300?
  242. E-manage
  243. turbo xs boost control install
  244. Blitz Nur- Spec R Info?...
  245. motor OIL
  246. Buschur Racing Stg 3&4 dyno numbers..
  247. BOOST LEAK?? WASTEGATE?? Don't know whats wrong???
  248. Emission testing
  249. aftermarket turbos
  250. Scared to mod!
