- EVO VII Clutch
- ECU diagram layout
- Pleeeeaaaassseee heellllppppp!!!!
- ECU's and Fuel Cut Defencers...
- Evo with NOS?
- EVO stock turbo and fuel specs?
- Trust TD06 and A'PEXi AX75 the difference?
- TD05H turbo
- Stock Evo 6/7 exhaust diameter
- Can I
- EVO 7 gear/ratio
- Ralliart ECU for Evo 7
- Is a Air/Fuel controller worth buying?
- Replacing the rear diff
- Hks Cams
- Really good deal for an M800
- evo 4 fault codes
- Help needed config Apexi RSM G Sensor
- Propane Injection
- Motec vs. Gems - Best for Street/Track/Ease of Tuning
- evo 7 clutch
- Engine Swap
- Has anyone seen the APS front mount??
- Update on my poor dead turbo
- EVO III Turbo Header
- If you had $4,000 to spend....
- can 18g or 20g bolt on to evo7?
- Clutch going?
- Turbo
- Engine Swap
- EVO 5 acceleration in 3rd gear and up prob
- Evo VII turbo question?
- Changing Gear Ratios
- Max boost on EVO VII turbo
- How to setup Apexi SAFC, AVC-R & RSM for new GT-A
- Evo IV octane query
- Lancer Evo Performance Tuners
- The Best product to get first?
- Difficulty of maintaining an EVO6
- Whats wrogn w/ the boost
- Spartan 503s
- Evo VII or VII Mods
- Boost cut-off
- Lancer Evo V how do i import!!!!!!!!!11
- Power Loss Through Drive Train
- Keep your PCV valve clean and here is why...
- 272 cams on an Evo 5
- M800 at work...
- which diff to use in fwd
- APEXi Hayabusa Super Light Muffler
- exhaust help anyone?
- Blitz iD-SBC instructions?
- Ecu
- Blown Engine(piston no.4)
- Blitz NurSpec Type R exhaust
- here 's another setup ... running 1.5BAR
- 1.5 Bar
- Where's the best place for oil temp sensor?
- Electronic Boost Controller
- EVO VII stock boost celunoid?
- Autronic for EVO VII
- evo VI TME burned
- Evo Intercooler
- Cusco Diffs
- What is crank walk?
- What is the Misfiring System?
- Evo Racing Harness Installation Help!!
- engine suffercating
- Mine's VX-Rom in US-Spec Evo7?
- EVO tuning???
- engine swaps
- can someone give me a price estimate???
- boost on an evo V
- intercooler sprays
- HKS VPC, FCON, or different ECU
- Overboosting or Fuel Cuts ?
- Evo II Stock Boost Setting?
- Evo VII engine
- Evo turbo timer?
- Fuel Pump and Injectors
- Twin down pipe / twin dump pipe
- Make an Evo 5 Twin Turbo ???
- Unplugging the AYC on an Evo 6
- Boost gauge doing weird things!!, what could it be??
- Fuel Cut VS. Detonation
- HKS Oil Cooler
- Emissions
- Injectors
- Can anyone help me.
- Blow-off valve doing some weird.....
- "Headworks" on my Evo 5
- A'PEXi Power FC
- Which ECU???
- E6 Cams on E4
- HKS EVC EZ
- watery/oily mix in catch tank
- rhd to lhd
- Air Filter ?
- new here, have a few questions
- JUN Ultra Light Flywheel
- EGT Probe
- Dreaming of 600HP!!!
- DSM Turbo According to Forced Performance!
- turbo upgrades
- Question about my evo
- Check your oilstick!
- 1991 Mitsubishi Galant GSX swap to vr4
- Cusco Front LSD
- non functioning speedometer non-shifting tranny
- looking for aftermarket parts
- Evo VI in BraZil ..
- turbo sizing spreadsheet
- Lancer Fuel Efficiency
- How to remove mesh grille for cleaning intercooler?
- Drifting FWD US Lancer
- Spark Plug Cables With Condensator
- EVO7RS AYD
- Turbo kits for EVO 5 or 6?
- first mods to do?
- engine swap
- HELLO2
- Claudius: 'rewire' cold start pipes??
- Groaning/rumbling noise from AYC?
- Realistic Limits....
- blitz settings for MichealK
- vacuum operated fuel pressure regulator
- AWD coversion for Lancer/Mirage...
- What spark plugs??
- Stock Evo VII Turbo...
- Evo tranny pics?
- EVO6 maintenance question
- Evo VII dyno chart anyone?
- turbo
- Help with AVC-R and S-AFC Settings needed
- Cat back on
- Uprated fuel pump??
- MBC's
- fuel pressure
- High Performance Manifold
- Ap Organic Plate, new clutch release bearing?
- Aquamist, who tried it?
- HIGH HP ON A STOCK MOTOR
- Tacho install
- ACD question
- How could I add a engine system like the movie initialD?
- ENGINE SWAP
- Boost Question?
- when to change oil in gearbox and AYC
- crankwalk...
- titanium pistons
- Torque Question
- Semi-Auto System from 5Zigen!
- Induction Box
- GRRRR...
- Similarities bewteen JDM 2.0L "Cyclone" Turbo and US 2.0L Non-Turbo?????
- Going over 1.5 boost is considered dangerous with current fuel quality!
- >>>High compression engine advice<<<
- Oil filters
- Red line for Evo 6.5 TME
- New Evo 6 FAQ Section
- exhaust system
- Changes to get more HP from my Lancer
- ALS or ralliart ecu on an eclipse
- Transforming Mirage to Evo
- Cylinder Head
- clueless
- Turbo types
- After Market Parts
- Special US turbo makers?
- New Gearbox Needed
- Come on you Americans!!
- old Apexi ECU/boost controller
- Blitz Acess ECU
- Turbo'd lancers...
- GEMS ECU and Ralliart
- ACD - Different setting on engine start
- evo engine swap
- E7 Parking brake turns!
- evo VII compressor wheel
- wiring diagram
- Tranny strength?
- merging a mirage and an evo
