- turbochargers.com TME Evo9 20G
- PCV and crankcase breather vent
- Buying a Exedy Twin Disk, does any clutch alignment tool work?
- GSC 280s + Supertech Sptings/Retainers =Boner
- Help with Full Race turbo kit.
- help with weird compression numbers
- Car shakes upon ignition turning off
- Anybody with an educated guess?
- Help me understand typical DynoJey numbers...
- Stock Cams Size...
- Making a fast all around Evo
- Clutch/Flywheel/Drivetrain Service near Atco, NJ?
- 50 trim installed Vacume line mess
- losing boost?
- 550+whp...What headgasket are you using?
- boost leak around injectors
- supertech single valve springs
- Question for those with BR turbo kits.
- Forge EVO15 springs?
- Max boost on 100 octane?
- 2.2L Stroker Kit
- Looking for 8 ports discharge for Greddy Type RS BOV
- Twin scroll style T4 GT35R
- Tranny Sealant??
- Alternator goes at 104k
- Boost Issue, need some direction
- God%@*& p0300 - need vehicle specific advice
- Best turbo without Meth/Alky?
- reflash reset??
- Who is FASTER? Shep or Trans
- stock evo bad idle problems
- 2.3 L with 35R and meth...WHAT CLUTCH TO CHOOSE???
- car wont start if oil is too low???
- engine code
- Alky injection + checkvalve = BAD
- Where to look on an Exedy twin to determine if it is the HD or SD?
- Mirage EVO AWD Conversion
- another 02 housing question
- Best Ported stock exhaust manifold?
- 3065 and 3076 kits owners,please post your dyno sheets!
- TurboXS DTEC-BC
- EVO Green Dyno #’s w/ Meth and C-16
- help! 2nd gear gone
- Brian Crower IX cams?
- what is the easiest way to drain fuel tank?
- Flow Charts
- ETS Short route UICP stock air box?
- think to buy FULL-RACE 3076 0.82 twinscroll turbo kit!? comments?
- Bad Knock Sensor?
- Evo IX, stock turbo, Aquamist HFS-5, 30 psi. Dyno Results.
- Some stock EvoIII & EvoVIII Questions
- 35r, few questions/want some advice
- CBRD new dyno record...
- ATP a load of crap?
- Vacuum Reading...
- trans
- turbo timer issue... HELP!!!
- Blocking off E.G.R.
- Spark plug problem...
- JUN High Lift Camshafts for 4G63 Mivec
- XTD stage 3 clutch
- Best product to switch maps with?
- Is Buschur exhaust mani worth headache?
- Which oil to use?
- Question for those spraying NOS
- Ets 35r
- Throttle Stop for Aftermarket TB's
- dumb question about installing a LICP
- AGP bov
- Competition Clutch??
- kb50ans...what is this transmission?
- arp main stud torque specs
- New exhaust parts...Tomei o2 and DP combo
- Oil Path of our Engines
- turbo setup ?
- RS Clutch
- intercooler ques
- HKS Kansai airbox+apexi kit?
- Factory Mitsubishi Hyper Grounding Kit question.
- To re-use or not re-use?
- What can cause a lumpy idle???
- buschur fp3065 installed
- transmission problem..... i think?
- megan 02 gasket ix and vii
- E85 Ethanol vs Methanol/Water injection - The search for higher octane
- Catch can?
- 272 vs 280
- Borg Warner Turbo and DNP manifold
- My 2.3L Stroker wonders is stock cams will bring in more low-mid range?
- cam gear question
- boost question
- stock evo 9,boost controller question??
- Boost leak test Issues
- Drivetrain Questions
- What evo owners are running 600 whp with the atp gt35r kit?
- gsc s2 or cossworth 272
- questions about my transmittion
- Lightest clutch pedal feel?
- Playing with Racegas on the Dyno
- Need new clutch soon...suggestions??
- What's different between this 2 turbo kits?
- Help! will not idle
- gain for gsc s1 cams
- OBX short shifter
- Annoying idle problem with AEM EMS
- Kind of like a jump feeling when i slow down help
- Tial BOV opening under vacuum
- spark plug question
- Evo Green Results w/ meth
- IX owners and antiflouler CEL fix?
- Money to spend, need some guidence.
- How to Open BOV RS
- Aftermarket flywheel
- evo 8 cams or other parts
- BUSCHUR 37r INSTALLED!!!
- Buschur metal shifter bushing help!?
- spring pressure wastegate?
- What is the rpm diff between full boost with a atp gt35r kit v.s. other 35r kits?
- How would I go about attaching a nipple to my 35r compressor for an mbc connection?
- HALLMAN MBC question
- Transmission Problem - 5th and Reverse are VERY muddy... PLS Read
- Exhaust Gaskets
- FP Green Upgraded Actuator = Poo Poo...
- Ebay High Flow Cat
- took my evo to Harmanmotive for sum power pulls!!
- JUN MIVEC Cams are out
- looking for post of evo turbo in srt-4
- Valve Spring removal......help
- 02 housing for 4 bolt exhaust housing who makes one!!
- Getting rid of lifter tick
- What could be wrong with the car?
- Rear Radiator Fan Question
- Wanna see my new rebuilt engine?pics insde!
- Cant figure out the wastegate vacumn lines need help
- where to get upgraded front diff bolts?
- Somone told me Cold air intakes mess up turbos
- ETS 57 trim Dyno Graph
- CBRD 2.3 shop project car progress..
- Ets & English Racing Hit 1000whp And 645 Tq!!!
- EXEDY TWIN HD barks at me!!!
- what happend
- Buschur COP question
- short throw for a IX MR
- Cracked block?
- Question on XS Engineering products...
- Reverse Issue
- Things to consider when buying a new cluch - help me
- Arias Piston Question
- max boost?
- Help with supporting mods for an HKS gt2835r
- Exhaust Manifold
- Evolution 1 (yes. ONE!) drivetrain question.
- motor oil...
- DTC PO171 System to Lean...HELP.!
- Engine Swap 8 for a 9
- Intake questions
- Safe boost with a EBC w/o tune?
- BoV Question
- Have you seen my 4th gear?
- EVO Green, 93 octane, 30 psi of boost and a dyno chart
- What head bolts to run?
- 3076 Manifold Help
- The Final, What is a walbro install kit question, Answered
- 136.41 mph on 93 octane, new record.
- Forced performance stamp
- IX tranny problem and diff oil decision.HELP!
- Gt35r and Cali Smog!!!
- Exedy Clutch Questions....Need help Please
- Redline lightweight shockproof in Rear diff
- Precision GT3076R ball bearing turbo
- What turbo setup is this?
- Huge Problem Please Help !!!!
- do race high flow cats still smell?
- Anyone put a 3.8L 6G75 engine in your evo b4?
- Need some help Stock Evo 8 plastic Bov Surging -_-
- HELP)!!! Compression Numbers
- test pipe questions?
- evo 9 turbo
- trunk full of goodies
- Age old Question 3076R Vs 20G LT Green
- Where to buy Cusco LSD's
- Who to go to for porting?
- Mivec cam install questions!
- Buschur Racing Mustache Bar, Center Member & Rear Diff Bushings *Updated Pics & Info*
- What other turbo can i bolt on?
- Some Intercooler-Questions
- GReddy Racing Ti-C Exhaust
- where can i buy 4G64 block, OR a customised 2.6L engine?
- Anybody put a Turbonetics GTK on Evo?
- diagnose my drivetrain problem
- Hard to "Port", full rutter!!!
- what kind of spark plugs?
- Witch way should I go?
- o2 housing install questions
- Clutch Pedal Is Sticking
- need help .. evo ix 20g vs FP Freen ??
- Which Vendor has best deal on Forge RS and SBC ID3
- Wet 50 Shot Question
- .70 a/r vs. .82 What's the better 35r?
- GT35 or GT37
- Post HKS exhaust install - STRANGE NOISE
- anyone with a 4g64 + 4g63 evo head?
- How much is unused evo8 shortblock worth?
- Bench Race: Stock Turbo vs. GT35R (both 1.5 bar)
- CEL LIGHT- Help!
- a little help with mods
- Gaskets?
- My trans blew up
- knocking noise
- Fluid changes w/Clutch install
- Turbo making weird noise
- stock internals
- Needed: Stock BCS Pill (ASAP)
- Car won't start - Think it's the starter?
- About to adjust clutch pedal. Question
- MIVEC oil feed line leak?
- Best price on Tilton rebuild?
- Boost leak?
- n00b evo question... heatsoak?
- Check engine light codes that shut off engine
- tb spacer
- Hallman Pro vs. Stock BCS - My results
- normal boost?
- Exedy Heavy Duty Twin Disc Cluth Noise Question
- horrible partial throttle any ideas?
- Wtb: Evo Motor
- Help with strange problem.
- Violent misfires, freeze plug...
- Just finished my o2 housing install.......
- Help two questions 35r and v-band
- 57 Trim on an evo
- Getting a race gas tune, which fuel should I use?
- need help with codes
- Boost leak or crappy install?
- 4g63 evo IV to IX
- Anyone ever had a transfer case go out?
- Can't boost over 19psi
- got dynoed today! 4WS FTMFW!!
- need to know a torque spec for turbo.
- First gear whine?
- How you you tell if the Buschur DP was made for the old non ACD or ACD transfer case
- JDM MR BOV on a 57 trim?
- XS Engineering Ignition Amp V2 WHAT PEOPLE THOUGHTS?
- Solid Motor mounts - knock?
- Oil adapter ring
- bov recirc pipe for uicp? where to buy?
- Is ACD worth it?
