- Whats the deal with Sequential Shifters?
- How to tell if...
- will the old hks bov recirc flange work on the new hks sqv bov?
- Drive train loss
- Which turbo kit to get...??
- 35r open downpipe?
- Turbo kit setup questions?
- Clutch Master Cylinder question
- dp number for the Concept-G Blue TBE (Tanabe)
- Just got done with my turbo swap
- Rsr Gtii
- HKS RS vs. HKS super mega flow reloaded
- cosworth cam settings need help !!
- my next mod ?
- is flywheel decrease torque ?
- Concerns after install of Dual Port BOV??
- precision 780s
- maximum stock turbo boost?
- Transfer case?
- Which intake??
- catback and testpipe delete??
- How much did you pay?
- price for installing connecting rods?
- 429whp 410wtq stock turbo E85
- br 50 trim vs. ams 50 trim
- How long will a gt35r last on a 60K evo?
- Best Cam match for a Evo Green?
- weird boost leak
- 3rd gear not engaging under boost
- Help with Tranny Decision
- Max HP through the MAF what have people made?
- gt35r oil feed line volume
- Injectors??? Denso=HKS/Greddy/Helix?
- anyone using the titek o2 housing
- best shifter bushings for the 6sp
- 500hp and Single Clutch Kits
- How To: Make a High Priced Poorly Designed IC
- Here it comes Texas.... a 37R Buschur built Evo!
- What would you choose? 20G-5 or IX turbo W/ ebay intercooler?
- opinions on my plugs?
- evo 8 odd hp #?
- Head Gasket Install after ARP install..
- need a Transfer case NOW!!!!
- JDM IX Exhaust choice
- is it ok to put an intake on w/o a reflash?
- Maximum boost
- Flutter/Surging out of nowhere
- anyone with m1 cosworth cams on evo 8
- Twin plate experts please help!!! 4/2/07
- Data Acquisition Discussion (I want to log everything...)
- Should I coat my 02 housing?
- Transmission noise, or ?
- F$@# high prices build your own Intercooler:)
- HELP me really quick
- FPEvogreen Or FP3065
- Which more hp mods would be the next in a evo ix?
- terribly newb question.
- Can you guess what's wrong?
- Gear Box F*** Up.
- Shimming supertech dual valve springs???
- will 3.5" TBE be too much? planning for about 400 AWHP ish
- ACT or Exedy clutch?
- Pick out a FMIC for the Evo 8 HELP PLEASE
- What to do before Tune?
- Is there a torque limit 4 our driveline?
- AMS High Flow Cat. Pass Smog?
- Tial surge even with EMS?
- Muffler silencer question
- What intake pipe brand will fit the evo 9?
- Question on my PT67 Dyno Graph
- turbo question
- HKS Version 2 BOV Question
- Tomei 270 Procams and Supertech valve springs
- Stock EVO 9 dynoed. Then reflash and intake.
- GOOD evo shop in los angeles / west los angeles area
- High Oil Temp Causes Questions
- Agency Titanium Catback
- Ams Catback.
- radiator need !
- what 02 housing tbe exhaust are you running?
- Crank case evacuation pump
- Greddy evo 9 cams?
- DC Sports Tubular Manifold Dyno on IX?
- Cams
- [Test] Why Revolvers are hit or Miss....
- Custom Turbo by FAT
- Review: ACT HDSS + ACT Xact Streelite flywheel
- temp gauge question,
- Head studs - why or why not?
- ACT street disk clutch kit.
- 02 sensor size?
- no lift shift??
- Please help. What could it be???
- Swapping out final gear...
- Exedy triple carbon vs. tilton twin carbon
- 2.4 vs 2.3 vs what to do?
- Got dynoed this weekend!
- 5th gear "grinds"
- Anyone know where to get syncros????
- 2000 miles on 06 IX and noisey engine
- Stock clutch question...
- ATP turbos mate up to the stock mani?
- Need help!!
- Does anyone know where to get...
- What power would you expect from standard'ish car with AMS GT35R?
- Re-use stock spring bolt setup on aftermarket downpipes?
- Paid for Premium fuel and got Reg
- Greddy TI-C Exhaust
- 20g9-lt mods + tune
- short video of idle
- newb question, wow.... i feel dumb
- Can anyone post some links?
- highest Whp/Wtq on exedy HD twin disc clutch???
- 22.8 Mpg E85
- New Turbo
- Are the Evo 9s head studs are they stronger then the Evo 8s?
- compresor map
- Worn stock clutch @ Willow Springs. Replacement....
- Need Help With DB Levels & Exhaust
- New pictures of full race kit....
- do i need injectors
- intercooler question
- Engine Running Hot?!
- trany, tranfer and diff oils...
- 2.0L Motor Build Need Help!
- HKS Kansai Sevice Intake Manifold
- OVer Boost Brand New Evo IX (30+ Psi)
- 3" exhaust flange adapter
- What coils for coil on plug ?
- noise: howling just need feedback possible bad turbo
- No start after some minor installs
- 272s finished - minor problems.
- what injectors for buschur 35r
- Urgent - Cam Installation Question
- Q's on a used turbo I bought...
- boost question
- stupid question
- mini battery problems?
- Which is worse in an exhaust? (types of restrictions)
- 4g64.....help
- Bushur Rocks
- AEM Electronic Boost Controller
- Buschur 20g-9LT
- Things that just SHOULDN'T Happen
- Tial V-Band Housing Pics. (LARGE PICS)
- Mild Tune and Head Bolts ? ? ?
- My Mods
- Clutch slipping with 20g-9-5.
- Getting ACT clutch, need advices
- benefits of proper internal wastegate setup on EvoGreen?
- car sputter/hiccup..Any ideas?
- Intake install question
- Tuning Question!
- bearings for a 2.3?
- Picking car up....
- Is this a sign of piston ring?
- Help with clutch replacement please!
- Where to get intake pressure for Forge MBC - pros and cons?
- Best cams for mostly street?
- CBRD dyno'd works P2 flash..
- help!! cant find torque specs any where for clutch
- Evo 8 vs FP Evo Green comparison *pics*
- What type of HFC?
- Cel Code P0102
- PLX wideband ????
- tranny noise yay
- fp green vs meth?
- Strange clutch issue
- Drive train question
- stroker motor cost?
- Need some help.
- 520whp for a street car isnt too bad right?
- Won't start HELP!
- greddy evo 9 cams
- Heellpp!! Blew My Motor Today!
- cutting VIII flywheel
- Tanabe Exhaust System
- Ultimate turbo
- GT3076 to Green install kit question
- Low Vacuum Issue
- ??? where is the evo ix suppose to hit the rev limitter???
- oil pressure ?
- Exedy twin disc rebuilds
- Free 8hp Mod?
- What should I expect at the dyno?
- obx front mount intercooler?
- Road Race Engineering GT3076R turbo Kit??
- Borg Warner S256 Turbo Kit
- EBC help Greddy type S
- putting on a turbo timer and tbe? any advice
- FPEVOGreen/Buschur 20g-9LT turbo + 18lbs actuator on only pump = Boost hump
- 518whp@93oct & 625whp C16 EVO 9
- Best prices on CUSCO twin plate clutch??
- Discussion: What Air/Fuel Ratios are safe and why?
- Installing Turbo tips!
- hks springs need help!!!! please evo gurus
- cosworth dyno on ix sean ivey
- 560whp Evo 9 @ Buschur Racing (yes.... another one)
- Review of Redline LightWeight ShockProof for Tranny
- Cat removal question
- Resurface Flywheel or dont?
- 4g63 to rear wheel drive trans?
- E85/Methanol Vs Race Gas Results!
- Question to Owners Past 60K Timing Belt Change
- My sweet new intercooler, big pictures
- boost controllers......
- Black smoke after installing TBE + flash
- fp green dyno today.
- ikeya formula shifter
- Exedy single plate organic clutch
- GT30R dyno..etc
- Boost dropping on high rpm, how to solve it?
- looking for a 4" intake pipe with a recic bung for bov...
- Some FPgreen spool data.
- The Proof is in the meter, BR intercooler testing continued.....
- EGR Removal
- RUSTY Plugs !
- Fuel Pump Install
- Heat???
- Stewart Warner boost gauge?
- solid lifters
- Installed Forge MBC, and WOW!!!
- Hey ALL...Going to the SHOP Tommrow
- oil light problem
- New Tranny, New PowerFlex Mount..LOCKOUT IN 2nd NOW!!!
- Exhuast Anaylisis and Discussion - and o2 housings revisited - Video
- What is the history of the T3, T4 nomenclature?
- Shep built 4.11 tranny
- Anyone using the new Blitz cone filter?? Impressions??
- just wondering if this is normal after DP install
- Stainless Steel Exhaust Studs?
- e85 users
- Greddy Cams
- Tranny Fluid Cocktail-Any issues with this?
- how easy to convert ayc non usdm evo to acd usdm?
- Anyone Have Green PumpGas Numbers?
- Fpgreen vs bigger turbo's for street use?
- Will I benefit from a Quaife front lsd?
- Lifters or belt tensioner
- GT (GT35R) Coolant Inlet and Outlet Fittings?
- Installing TBE today a quick question
- 20g upgrade for evo ix 899$
- ANOTHER fully built Buschur Racing Evo being finished up. Watch out Cali!
- eXHAUST
- oil leak. need help!
- T3 divided exhaust manifold, anybody?
- Mahle piston pin offset amount?
- 476 Dyno Dynamics whp on stock block EVO9
- greddy cams??
- evo 9 owners
