View Full Version : Evo Engine / Turbo / Drivetrain
- Clutch for 10sec 1/4
- What is causing this Problem?
- Just installed Greddy FMIC
- Exhaust system setup ?
- cams question
- boost creep?
- Downpipe question/clutch
- Gears Crunching, another possibility other than Synchros
- So i was driving and loud explosion under hood and CEL
- best mods for 10sec street evo
- EGT Drill/Tap size and location
- Installed BOV, now car feels slower!!
- Mr Bov
- P0300 vs. Reflashes
- NGK Spark Plugs?
- Might be having a boosting issue
- mods and boost control?
- Best BOV for stock setup
- siquential bov
- Low Oil Pressure Readings
- Clutch and chatter
- How to achieve a 94 Octane tank via 91 Pump
- Axles
- Tial BOV experiances...
- timeslip
- A gritty, geary feel going into 3rd.....
- What i/c pipes work with the stock intake?
- car wants to go in neutral
- Acd
- Greddy Turbo Timer
- MBC not functioning?!?
- HKS turbo timer harness for MR?
- XS Power Pack Ignition
- Difference in the 2 HKS intakes????
- Exedy Twin Plate Problem
- Exedy twin disk thickness
- I have a thought on turbos
- ATTN: John Shepherd
- Pro1 Turbo Manifold
- Vacuum at idle, or in neutral (no gear, no load)
- All about intakes.....
- threw crank, and cam pos sensor codes: off timing? please read
- Which to buy.....
- little help please
- BR440 turbo spec?
- anyone have mechanics directions for evo?
- Loss of boost
- tickets for cat-less exhaust?
- Rain and rear diff noise
- devistation in engineville
- how high can you turn up the boost?
- Finally 3 1/5 exhaust pics!
- Why does HKS downpipe cost more than the Helix?
- Wanna trade BR500 for 440???
- Revolver Cams
- Spark Plug Questions?
- Best Turbo, Versatile
- EBC hose routing question
- Cold Idle Problem after HKS IDES Install
- What's up with the diff Evo stroker kits??
- Want to see what HKS 272 idle looks like?
- Source of Toluene?
- greddy sp2
- head torque question
- Who makes an O2 housing with a 3" outlet?
- Any Flash for RS yet?
- ecu safety controls and boost controller
- Standalone fuel system or Piggyback?
- Anyone measured the CFM at 21psi?
- need stock oil pressure info
- Where can I get Piper Cams?
- noises from tranny still :(
- Hks Rs?
- EVO 6.5 TME turbo upgrade review
- Intake and Catback tune
- Who has the BR440 Kit...?????
- Blitz Sonic Power Intake
- 3rd gear studder
- Dynoed the evo 3 and the gear box went bang
- need a new clutch
- Water Injection
- cam gear adjustment
- What's the quickest spooling turbo kit?
- Stock oil feed line for turbo
- Review: ACT Street Clutch + Fidanza
- loss of power, boost, issue with timing belt HELP.
- Is a HKS GT3040 a good buy?
- where to install BOV??
- Whinning noise after gears/belt replace
- Opinions! - What is the best air intake system for EVO VIII?
- anti-freeze wetter worth it?
- EVO MR Bypass valve issues?
- Which DP would make more torque?
- Anyone using the ssautochrome header for evo 8?
- buschur rods much different from others?
- two bad codes thrown... please read!!
- best parts used for tuning
- How many Highway miles??
- no intercooler water injection
- Head Gasket Replacment?
- NGK sparkplug question
- Home made boost leak tester
- RPS Releases new Double Carbon Clutch!
- Water Injection
- HKS 272 Cams - Vendors please help
- espelir downpipe
- What the hell is this??
- Greddy Evo2 horsepower numbers
- Good FREE information.
- Finally Dynoed!!! On a Mustang Dyno!!
- Dyno testing today WORKS P2 & Buschur 3"
- building bottom end with motor in car?
- Electronic Boost controller with no hose to cabin???
- stock valve springs/retainers
- Which spark plugs & wires?
- Battery Kill Switch???
- worx tuning bov
- flash questions?
- am i detonating?
- Will Kartboy hangers work for 3in exhaust?
- NX N-Tercooler, any users?
- Weird shifting
- The best mod I have done thus far! Noweeds.net
- Opinions of mild steel vs. 321 steel fo headers
- HKS hi power catback exhaust!
- Bleeding Slave Cylinder
- Best Turbo Kit
- Anybody tried Megan Racing O2 housing?
- HKS 272i/264e Cam timing
- Favorite Performance Mod?
- megan racing 3" exhaust..
- Sonic Power Air Filter
- APS Twin Vent B.O.V
- bshr stg 4 & br440.. 1g BOV cant handle it
- Installed Greddy Type S BOV, now can't stop boost spike.
- My Exedy Twin Plate Squeaks When I Take Off Slowly In 1st Gear
- Buschur Turbo-back ??
- HKS Cam Question
- 272/272 Cams. Have questions.
- Front Diff
- Sti Trouble
- How do I know which ECU upgrade kit to get?
- Turboback Exhaust passing inspections?
- apexi turbo kit
- Need help w/ TurboXS MBC install
- Help regarding boost setup
- forge recirculation flutter..
- rear main seal is bad......
- Spark plug is jscked up..........
- Flash ECU with SAFC II
- VES system / Exhaust dump system
- Helix Cat Delete
- Experimental: Electronic BPV/BOV
- 264/264's without injectors
- Biggest Suprise ever
- 6-speed conversion?
- Aftermarket Crank Bearing advice help??
- want 400whp or more on stock block cams and????
- 255 fuel Pump
- Ordering cams Monday. Soliciting advice/opinions
- Restrictor pill question
- please help....
- need help !!!!
- Sputtering @ 3/3500rpm after test pipe?
- Spark Plug Install Question..
- MR bov
- Spark Plug Cables?
- Turbo XS BOV
- Evo keeps stalling, help!
- Coils burnet.........twice
- Evo losing power
- getting a fuel pump which 1 hp o lph?
- Project EVO8.5 MR Over 500 HP with stock engine
- 3-5hr drive to a tuning shop with mods installed but not tuned for
- my evo lost all its balls
- "Evos dont have a transfer case"
- Got Walbro Pump...Do i need a Fuel Pressure Regulator?
- a good clutch that isnt too expensive
- Engine Problems?
- Transfer Case Fluid
- AFC decel setting = better drivability
- Could this be the best exhaust setup?
- quick q what to do with 300
- What are the benefits of cam gears?
- Lancershop bolt on fpr-reliable?
- Concept of an Auto Evo8
- Cams/Cam Gear install ?'s...
- Aftermarket Clutch Longevity
- Should I buy injectors?
- How much power can stock exaust hold?
- Helix hi-flow cat
- Idle fine, reset ECU and now CRAP!
- Turbo outlet/intercooler temperature calculator
- Output Shaft stuck in the Transfer Case - can't get out!
- Greddy V-SPL IC
- Which setup is best?
- Smoking, anybody else?
- troubleshooting help with tranny please
- Intercooler
- When do i need cam gears...or do i?
- Used oil analysis -- 22.5k
- Clutch or other problems? Need help.
- got some bolt ons installed, but...
- All about CAMS....
- 1G head
- Qusetion about power output for mods
- What Do You Know About The Gt 28 Series?
- "?" about boost
- AVO muffler question
- Newbie needs advice on Mods!!!
- New Dyno Numbers!!!! Turbo Trix Flash
- Help: IS my clucth going bad ??????
- Max hp w/ the least mods by Turbotrix
- How Would You Spend $8,000 on an RS?
- Clutch & T case question
- installed HKS EVC 5 on my car, now how do I use it?
- Clutchmasters Stage 4?? Help??
- Invidia G200 anyone?
- boost difference please take a look
- backfire exhaust
- Anyone with the RMR CF Gauge Pod...
- Those with HKS RS Intake and NO problems
- EGT and Wideband O2?
- Anyone tried Random Tech 3" high flow cat?
- cheap turbo kit
- Electronic dump tube...
- Installed xs mbc HITTING FUEL CUT OFF
- Dyno Poll (Race Gas)
- Dyno Poll (Pump Gas)
- Help!!!!! Car Wont Start With New Ecu
- Beam me up Scotty
- Flames from Exhuast??
- Buschur dyno results with stage II
- Engine Oil Hitting the Top Hood Undertray
- question concerning liquid-to-air intercoolers
- Opinions on next mods
- New Transfer Case -- will it go too?
- correct part selection
- Intake questions(please check it out)
- Fujitsubo Exhaust RM-01A
- Stock boost restrictor pill question?
- profect e-01 reading boost correct?
- Who has the RRE Clutch?
- Please dont laugh....stupid question
- Evo8 pads on Evo6 TME? Do they work?
- white smoke from engine bay
- Poll: HKS cams or Intercooler?
- Snapped a bolt off!
- Free Option Mags/vids For Help
