PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Valve Train Question?
  2. Full Exhaust
  3. Vacuum line off boost solenoid
  4. Larger diameter intake systems?
  5. cause for misfire after motor mount instal
  6. 100% Injector Duty!Rewire Walbro?
  7. Heat Wave Out of Hood Vent
  8. Emissions Question
  9. My sweet custom home made aluminum fan bracket for my turbo upgrade!
  10. Help- Underhood Shifter Bushings and 6pd Reverse
  11. miss fire
  12. Ppi exhaust manifold vs bushur
  13. What #s should i be expecting?
  14. 2.3l + t67
  15. 03 evo pressure plate to throw bearing wire ring busted
  16. clutch problem please help
  17. Magnus V5 Cast Intake manifold installed and tested by TTP! 600whp stock motor!
  18. need help on picking a new clutch
  19. car has no power and sounds horrible... misifre cylinder 3?
  20. acd lights came on..questions??
  21. FP wastegate actuator questions
  22. Defective Piston Evo9?
  23. Shifting to Reverse is like moving through tar
  24. Opinions on AP Racing Clutches
  25. Car won't start
  26. Act hdss
  27. had exhaust leak. took exhaust mani. off and found this ::*pics*
  28. FP Red HTA?
  29. intake vs. wideband
  30. What can I use to remove the stock lifters from the evo head?
  31. quick ? about aem and no lift shift
  32. Not sure whats wrong...
  33. 5th gear grind... 1200miles shep trans
  34. FP 80mm Compressor Cover
  35. 4g64 help
  36. Trust/Greddy T67 10cm Turbo
  37. What is going on with my oil return line
  38. Mitsubishi tools
  39. installed ex mani, now won't start
  40. S1 guys your input please.
  41. ATF SPIII fluid
  42. what clutch with mods
  43. Piston Coatings
  44. So where can I find a Mishimoto Radiator?
  45. Help me find a thread about Intecoolers comparsion
  46. (Im going to rebuild it)Anybody has a pic of bad Ring and Pinion off Evo 8 T-case?
  47. 95-97 Galant 4G64 Block Usable For Stroker?
  48. Post your setrab/mocal oil cooler pics with setup
  49. stock camshaft lift?
  50. should i do e85 or not !
  51. Dogbox
  52. need to mod oil pump with ams balancer shaft removal ????
  53. BMC drop in air filter
  54. need advice on my jdm IX MR.
  55. GT35 or 6265 turbo?
  56. Kelford 272's Timing Q's for EVO 8
  57. idle issue..
  58. how do you pull a front axle on a evo 8
  59. Phantom knock
  60. Thinking of going Catless
  61. CAT sensor
  62. Misfiring and Backfiring after Timing Belt and fluids were changed??
  63. Logical thing to do next
  64. greddy type s help
  65. Stock 9 Cam Centerlines at 0 deg adv?
  66. Bov
  67. Head Gasket reccomendation?
  68. Need help!!!! Fried ecu????
  69. Boost problem...
  70. Streetable clutch/flywheel upgrade?
  71. Streetable clutch/flywheel upgrede?
  72. kelford install
  73. Attention Quartermaster and Spec clutch users
  74. Balance Belt Tensioner
  75. Exhaust mani options
  76. started installing my fp red today...
  77. Adj Cams?
  78. Clutch issues 1,000 miles from home!
  79. Trans Issue ?
  80. FP3065, Boost leak Issues.....
  81. Should i do gsc s1 cams not sure !
  82. Evo 9 Cam Centerline
  83. Evo 9 Cam Centerl ine
  84. MR 6 speed made stronger?
  85. help
  86. help please
  87. Engine = boom. Questions
  88. Transfer case pressure?
  89. Weird sound, low boost NEED HELP!!
  90. 1st gear issue
  91. installed pwr radiator and still reading hot!!!
  92. Valve spring keepers??
  93. what is the flow rate for an evo 8 turbo @8 psi
  94. Magnus 75mm T/B on Stock Manifold
  95. Plz help indentifying this intake
  96. Boost control troubles after upgrades
  97. Best or really good street clutch kit, in your opinion/experience...
  98. Oklahoma/Arkansas COBB Accessport?
  99. I spun a rod bearing !! :(
  100. Cam gear install and tensioner pulley problems....
  101. My car shut off will not start
  102. Odd problem.
  103. Evo IX Idling Problem
  104. check this video out
  105. Non-AC Accessory belt size
  106. Removing the balance shaft,without removing the block
  107. Spec super twin disc install
  108. Dealership mess up my clutch? Twin disk problem?
  109. Misfiring or Clutch Problem?
  110. ACD removal
  111. hmm so dc sports downpipe rubbing?wtf
  112. Throttle lagg issue HELP
  113. Lesson learned on tuning for boost upgrades.
  114. Tomei BOV?
  115. Couple questions..
  116. AC Compressor Question
  117. Need Help, Were do i start????
  118. Whining noise after belts/cam install
  119. What intake mainifold is best?
  120. how to tq crank pulley?
  121. Car wont start please help
  122. 75 mm Boomba Throttle Body VS stock dyno results
  123. ALL IX owners: What SS Braided Clutch line do you use?
  124. Noob question about Super HKS blow off valve
  125. Evo 8 Camshaft Seal Part Number
  126. Rod Knock... Now what?
  127. what is this grommet?
  128. Opinions/Feedback on O2 Eliminator Downpipes
  129. Cars Still Smoking
  130. guys...HTA GT3582 or HTA GT3586
  131. vacuum lines
  132. EVO IX MR not boosting properly...help
  133. Eagle rods and stock e9 pistons?
  134. Broke bolt in turbo, what should I do?
  135. 2.2L or 2.3L or 2.4L?
  136. Carrillo Rods + CP Pistons in a stroker
  137. Compression Test
  138. Broken Plug wire?? What should I do?
  139. Locking out between gears..
  140. throwout bearing
  141. STMs Front Facing Turbo kit with Dyno sheets and videos!
  142. wastegate actuator problem
  143. GM 3port vs. MBC
  144. Needs Help.
  145. Size of long bolts to connect to engine stand?
  146. Cel p0401 egr...
  147. 2.3l, gt35r build
  148. Manley Pistons?
  149. MY build. Please critique
  150. Lower Injector Seals - Boost Leak
  151. Buschur C.O.P issue
  152. Is evo 9 gsr stock clutch 'pull' or push type?
  153. Car Died. Sputter Hard. Any help appreciated.
  154. Car Sputtering, not driveable Looking for help!
  155. ETS 4" Intercooler install help
  156. WOT shifting, what does it take?
  157. Is this a real fpred
  158. Hks evc-s
  159. Buschur filter replacement?
  160. TB Leak??
  161. Roaring sound coming from passenger side wheel, gets louder the faster/longer i drive
  162. Need Help Removing Water Pump Pulley
  163. ACD/Drivetrain warranty
  164. Missing bolt in Megan O2 housing?
  165. Wiseco and what compression is this..
  166. Better Fuel pump with no whine?
  167. Need clutch inputs
  168. new clutch = new flywheel?
  169. Likley hood of boost creep O2 housing
  170. TTP's FullBlown E85 upgrade and dynotesting on the stock block 571whp/481wtq!
  171. when i grind into 5th, what exactly am i grinding?
  172. 6 speed conversion to 5 speed
  173. Help needed
  174. Use Blue Locktight when doing Timing Belt?
  175. ATP EVO GOLD Turbo- Aussie Made
  176. ATP EVO GOLD Turbo- Aussie Made
  177. need some advice on my set up (fpgreen)
  178. Fully Machined Compressor wheel
  179. Aftermarket Exhausts
  180. acd/Ayc Bleeding Advice needed!!
  181. Shifter sticks to the left?!
  182. Some info on a few things:)
  183. Camtech 272s or Kelford 272s
  184. What part exactly in T-case makes it whine? Mines whines 50-75mph.I want to fix it
  185. Hiccup after 5.3k with AEM EMS
  186. After trip to chicago the clutch fails and wont start?
  187. Perrin downpipe question
  188. Intercooler Piping...
  189. how many times i can use the ARP headstuds
  190. KELFORD 272's
  191. map 02 external wastegate setup
  192. Newest Addition to AWD Motorsports " MostH8d " GSR!!!
  193. 2005 Evo 8 stock boost confusion
  194. V A / V F rods
  195. Does the JM Fab intake pipe work with ETS UICP?
  196. New Inline Boost Controller from Boomba
  197. running hot
  198. Stainless or ARP bolts and studs????
  199. Timing belt help
  200. Most 'Civilized' Performance Exhaust?
  201. Exhaust Porting Questions
  202. Head issues
  203. over heat after cam install
  204. 2.2L 4G63 Kits
  205. What is the highest psi you are running on pump gas with fp red on stock motor?
  206. bad luck
  207. Plx dm-200 obdii
  208. How to port a 9 turbo help!
  209. oil all over the Cat.
  210. Exedy Twin HD Slippage
  211. engine noise help!!
  212. Who here is running Ikeya Sequential Shifter on syncro gearbox?
  213. Comp 280's idling at 17 in-hg?
  214. question about my cams
  215. Another ACT problem?
  216. boost controller
  217. Weird "Bucking" problem?
  218. Looking for just one rod...
  219. NeW FP Red(80mm) vs FP Green(80mm)
  220. Clutch slipping??
  221. need some help from a pro. broke tensioner bolt!
  222. anyone still using syncromesh fluid or ?
  223. Look at what I found in my UICP......
  224. Boost leak test help
  225. CEL problems
  226. Clutch fork springs
  227. Is this an evo trans?
  228. Burning oil after boost leak test! HELP
  229. ACT HDG6 - Multiple TOB Springs?
  230. Car diagnosis?? Please help
  231. Strange 1-2 Shift Issue
  232. I F up my motor lastnight's 1/8 mile race
  233. engine mounts
  234. DP and Brace Combo
  235. HTA 3582 oil feed line
  236. FP white vs. IX w/TME mag CW
  237. Anyone using a after market speedometer?
  238. in gear, car won't go past 2000 rpms
  239. O2 dump vs BR ss o2 housing
  240. Mystery cams? Please help.
  241. Is it bad to buy used Cams?
  242. QTP Downpipe Flange hitting driveshaft.
  243. BC 280 cams & stock TB VS kelford272 & boomba tb
  244. 550 WHP Fuel system
  245. 6 Pad solid hub or performance disc??
  246. 1000cc+ injector user's stock ECU
  247. Notes from my garage - Tbelt
  248. Would Cams do alot to my set up?
  249. Check engine light help!
  250. knocking?
