View Full Version : Evo Engine / Turbo / Drivetrain
- HKS MIVEC Cams
- RSR downpipe help
- Hks Carbon Ti Help!!!!
- high exhaust temp
- Accufab Adjustable Fuel Pressure Regulator
- Can Eclipse 2g exhaust fit Evo 1?
- best cam timing for 272 and GT35R on 2.0L
- evo8 radiator cooling plate fit evo9?
- Can the transfer case be removed without taking out the trans?
- Possible to run high 10's? Mod list...
- fireall pics
- HELP! Forge UNOS not working
- Modded IX owners, What are you plugging the O2 bung with???
- Need help with a DSM igniter for my MSD setup
- My Parts Are Finally Here!
- Upgraded Intercooler pics and install
- cam combo?
- yay another p0300 problem
- boosts not steady?
- 05, 06 BOV Position
- Mazworx Evo8 Tubular Manifold for GT42R
- Boost Issue!
- Problems with exedy HD twin disk
- HELP!!! Leaking coolant
- Intercooler piping question
- help!
- Expert Question about Manual Boost Controllers
- ACT Clutchs?
- Lower ic pipe work it?
- Boost Pill Reinstall
- will evo pistons or rods fit in a dsm 6bolt?
- Any one got AMS Stage 1 with Dyno FLash?
- Helix Full Intercooler Pipe Kit
- Now the real fun begins (56k sorry)
- intake question
- HKS SSQV BOV for sale
- Anyone using the blitz dual-sbc spec S boost controller?
- Cutting Forge WGA..
- 20G-9 (Who has dyno charts 7k rpm+)
- Adding some parts to the car on Friday..
- Max HP on straight 91 oct.
- Turbotrix Mivec Intake Cam
- GT3071: too much shaft play ?
- direct ebay link for o2 housing?
- puck Clutch ? slipping ....
- 272 owners....
- power estimate
- EGR CEL Fix?
- Blitz Turbo Timer harness ?
- Question about accelerating a bit after releasing gas pedal.
- JDM MR bov
- Complete Powerflex Motor Mount Bushing Set!
- cam install finished, lifter tap question
- Breather filter or oil catch can?
- Installed Megan Racing manifold!!
- Does anyone have any info on this engine?
- injectors?
- Where to buy stainless 2 bolt exhaust flange?
- How many have switched out their Wastegate actuators to prevent boost bleed off?
- Hks Ssqv For Sale
- Hks Ssqv For Sale
- 71k still stock clutch
- Cams on stock turbo
- upper ic pipe question
- Quick question
- EVO8 head to EVO9 head
- Helix CEL fix=car stalling?
- Clutch
- Coil-On Plug Ignition Systems
- 900+ HP Evo
- cam for which powerband?
- ACT Clutch After 1 Year of Spirited Driving. Draw Your Own Conclusions.
- 65mm T.B. user input
- 631whp GT35R 2.3 and GSC 272/272 Cams
- Calling Help From David Buschur
- 4g63/4g64 info
- BEST BOV with LEAST PROBLEMS
- vishnu stage 1+
- 400AWHP Suggestions
- Quad turbo... Pics
- if you have experienced notchy gear shifting please read
- Evolution MR short throw...
- Small track awesome video!
- Is the BR 20G-9 wheel really a WR?
- hooking up MBC to turbo or BOV?
- Boost gauge Must???
- Installed Forge MBC on my IX
- Tila waste gate problem.
- DC Sport Downpipe Donut gasket
- **NExt MOD and TUne**
- Need help with Tial WG and MBC.
- o2 wires? Which color is which?
- HKS GT2535 Turbo
- 4G63 engine help
- Aftermarket ignition needed?
- Need help hope i'm not in trouble
- GSC 272's with cam gears
- did i hit fuel cut????????
- E-Cover to S-Cover difference?
- Anyone have experience with the gt3040?
- ECU flash help
- Fuel pump
- 10.5 Hotside!
- VTA BOV works in Evo9
- NGK BPR5EKU in my EVO
- question about RnR intake?
- Excessive GAS Consumption...
- Aftermarket Cam Noise (tick)
- stock and aps bov
- GT3071 from 0.63 to 0.82
- Ebay o2 on Evo IX
- GT3076R owners, post your #'s.
- JUN Stroker Kit: Who Has Personal Experience???
- AMS 37R kit
- 20G-9 from buschur.
- Turbo ID for HKS GT3240 please .
- Turbosmart Blow off Valve
- direction in next step of modding
- Any point in coating compressor housing?
- ISC problems
- factory wastgate solenoid lines
- ? about hks cam
- its like a late....or early christmas
- will my buschur exhaust from my 03 fit my 9?
- Buschur Racing dyno day results and observations.....
- nickel antiseize is worth it
- My stroker setup...comments?
- "Blueprint" for mods
- mounting the 2.5 gallon smc alky tank? any ideas
- Race motor?
- Is there a how-to on disasembly of the evo turbo??
- SS Braided Clutch Lines? Yes or No?
- High flow Cat or test pipe?
- stroker kit plus gt35r...
- forge unos mbc installed.
- alluminum vs. stainless steel
- evo 8 turbo timer harness work on the evo 9?
- Upgrade confusion???
- what is considered a good core
- Shift Knob...
- Kansai Carbon Air Box EVO VIII Trouble
- Wow, VTA does suck
- IX cruise speed + Octane level
- Quick ? about Redline & Aem Intake
- GT35r Project coming to an end..Big Thanks to Peakboost and Buschur Racing
- My Evo is being shipped to AMS for full build
- Short shifter levers that are the same (or taller) than stock?
- Dyno Evo on a 2wd Dyno?
- Evo IX dyno results
- Hks Cams?
- Buschur Delux or AMS with lower intercooler pipe
- Lifters causing a rough idle?
- Methanol Injection on EVO 8 Stock Turbocharger
- need some help guys..TME or 10.5
- RnR fmic question...
- 2005 MR turbo size
- Buschur SCCA
- Big fuel system from Topspeed
- long runner vs short runner manifold testing
- Need #1,4 ignition coil...aftermarket availability?
- Exhaust Manifolds that fit the IX?
- noob ? about BOV
- Easy steps to Reduce Weight
- To all those with concerns about the Forge UNOS MBC!
- Bolts for Cam Gear Cover
- Midrange grunt
- Denso Injectors
- Ralliart Engine Mounts vs. Stock, a couple pics...
- boost related ..
- Stalling issue / Fuel issue
- Intakes...
- Fuel pump?
- Intercooler?
- sound clip of blowoff valve
- Evo 9 Intake Cam ..
- questions concerning oil pump
- My First Dyno Runs !
- who has tme turbo in stock
- clutch problem
- Exedy Double or Triple Cerematallic?
- hks 272 cams
- ams turbo kit guys
- another fuel milage question? 200 miles to the tank?
- High Impedance Injectors
- 28 psi on stock motor?
- So who will be first with Cosworth head?
- SS Autochrome o2 housing/stock downpipe
- hesitation at 5k rpms???
- Exedy Triple or Double Cerematallic?
- BR question on Alky
- I need a $1,500 or < "bolt on turbo"... not used
- 2G Rods????
- SSQV Flutter Causing Compressor Surge
- who fried their coils???
- rev drop problem
- need help fast hesitation?????
- Have some ???s on new gt3076r turbo kit.
- types of turbos?
- BPR8HIX plugs?
- Installed Forge WG Actuator, hit 32 psi!
- Big turbo guys with o2 open dump??
- how much can it handle?
- Bleeding ACD
- BOV leak sound?
- Crower Cams?
- Fuel Cell Conversion w/ part numbers and price
- Help me Dx a boost problem please.
- 2.0 or 2.3 stroker
- Screamer pipe VS. in exhaust: less HP ?
- t67 greddy turbo kit
- Wierd Start Up Problem that Started Yesterday
- Boost leak test gone terribly wrong.
- RNR Turbo Back Review
- How much HP can the EVO IX tranny handle?
- Alright!
- Buschur Ported Maniford Gasket?
- Forge UNOS MBC solution
- Removing Transfer Case - NEED HELP
- which O2 housing
- Backfire??
- WHICH TURBO IS BETTER? TME or EVO9 TURBO?
- EVO IX boost creep?
- o2 housing
- Philly EVO's 20g-9 results.....
- Porting Manifold and Turbine - LESS TORQUE?
- Question about fuel pump install
- Problems with Forge RS BOV
- Help!!
- different between an '03 vs. an '04 EVO???
- How to adjust Agency Power BOV?
- XS Power Manifold?
- Evo 1 starter shot and clutch is toast. Replacements?
- Piston diagnosing HELP!
- RPM Drop, possible clutch slipping?
- Sneaky pete worth it?
- Any luck with o2 simulater!
- Forge RS BOV Size
- Short Shifter Question
- Full acceleration problems
- Helix HFC threw a cell...
- All You GT35r Guy's
- p300 after clutch install
- RACE FUEL vs WI(METHANOL)
- Lower Intercooler Pipe options? (LICP)
- 2.5" inner dia IC piping for GT35R too small?
- Boost reading at idle
- Buschur New exhaust questions
- Anyone using comp cams 280's?
- need turbo bolts
- HKS DL2 Question
