- fitment
- About to pull my trans.
- Is this the transfer case? Help please!
- 05 evo mr turbo to evo ix turbo
- Light weight clutch 900whp
- Evo IX Stock Divert Valve
- Help!! Change oil brands now have loud tick/knock
- Finally decided to take my Evo 9 another step forward
- WTF am I missing?
- 50 over bore head gasket selection
- C16 vs Q16 vs M1 vs E85
- Evo 6.5 Rear Diff Madness
- Evo 6.5 rear diff
- Revs Hang Between Gears
- Turbo shopping, looking into gtw turbos.
- Head gasket thickness and OEM vs Aftermarket
- Cannot get my acd pump to run
- What does MIVEC reference for timing?
- Help
- Please help!
- Loud humming from under my evo
- Timing belt tensioner oil leak... with fix!
- Anyone running a Borg warner 366sxe or a 369sxe?
- Advice from the experts
- Evo 4 rs
- EVO 8 valve cover gasket leak- removal instruction
- Evo 8 power steering pump
- Gsc s2 cams
- AMS intake with Bombo 70mm vs Stock Ported with 70mm TB
- E85 or 93?
- Hard start/misfire at idle help
- A Stupid Question...
- Ticking after warmed up? Only after oil change
- Injectors needed with HKS 272?
- Coolant temp 90 degreesC oil 170 degreesC
- Gen 2 gtx3076r vs. gtx3576r help
- Valve seals or turbo seals? White smoke & oil burn smell
- Tucked AC Lines, tryna stay cool and look cool too
- Rear diff evo 8/9 part number??
- EFR check after engine failure
- Engine Oil Catch Pan
- EGR Delete Question
- suggestions- who can rebuild gem front cv shafts
- QM 8 leg twin DRAG ISSUE!
- Licp reducer and tbolt size
- Pressure plate hitting bell housing?
- ATP GTX3071/3576 or EF2/3
- ALS on sas or throttle kicker?
- 6 Speed EVO 8/9 Synchrotech Carbon Synchro - Interest Thread
- Evo boost leak?
- Clunking sound
- Evo X FMIC -> Evo IX
- New Front Case/Oil Pump oil leak. Need Help!
- 350whp budget build
- Anyone running 3G revised lifters that has positive feedback?
- 4g63 head on 4g64 block
- Manifold question
- Updating/Upgrading for DD Need Help
- Whistling sound when driving?
- Braided clutch line on JDM evo 7
- P0136 & P0037 Codes - Rear O2 Replace?
- Rear dif wine after 12 plate upgrade by rrt.
- EFR 8374 problems...broken
- Blown head gasket?
- What power am I looking at?
- evo4
- evo4
- Quartermaster 8 leg question
- Propeller shaft - run or replace?
- Is there a noticeable real world difference between these injectors?
- evo 6
- Po300
- Very rich idle and stalling
- Evo 9 whining noise in 4,5 gear
- evo 4 using evo 7-9 o2 dump pipe
- What is the best option for my build?
- GSC S1, GSC S2 or Kelford 272 Cams
- Question on PCV
- BR Lower intercooler pipe, and O2 Dump
- IX Evo Mr Transmission replacement?
- grimspeed 3 port ebcs
- Garrett GTX Gen1 vs Gen2 and turbocharger matching math
- Question on 4G63 Crankshaft
- Chasing a misfire help
- Bad idle and stalls. Need help!
- ACD Problem -- Help!
- Double Pumper question
- Why is my turbosmart dual port different?
- Best Cam for stock turbo Evo 9??
- Has anybody tried the new CBRD RB-X turbo kit?
- structure of intercooler
- Any new power developments for bolt-on Evos?
- 3 port boost solonoid?
- Odd rich idle and cruise.
- Short Shifter for 6 Speed
- Boost leak test
- GSC S1 Noise
- Triple plate and hydrolic bearing.
- 450 walbro pump install
- 1000cc injectors running like 650cc injectors
- does anyone have these headers on evo?
- 12 Plate Rear Diff Noise
- Clutch problem?!
- Clutch problem?
- Left inner axle won't push in all the way
- Torque Solutions vs brand new stock mounts
- Funny noise
- ABS Delete----what do do with abs harness afterwards
- Xona 7864 Turbo?
- Transmission oil cooler evo ix 6 speed
- Manley Forged 100mm crank (Non-Billet)
- Please help!! weird issue
- Evo 7 Drivetrain on Evo 9
- Help Identify these connectors
- Can't idle, but can hold higher RPM's
- Evo 9 rear locked up need help!
- Cooling options
- 2005 mr 6 speed/ whinning sound on deceleration
- Intercooler on Isuzu KB 2.5 D-teq 2010 model
- hks kevlar timing and balance belt
- DBB FP Green/S2 Cams on Evo ix
- EVO 8 and 9 timing belt same?
- Axle wont lock in
- Help! Cam ID! Evo ix MR
- Tough time deciding turbo setup
- Stock exhaust falling off
- Compressor Surge 5th Gear? (BOV TIAL)
- 4G64 crank torque limit? Reliable forged 100mm crank?
- 450hp goal
- Propshaft
- Help!!! Car resisting to drive?
- Spark Plug Carbon on Terminal nut
- Two Monolocs??
- oem boost controller noise
- O2 housing?
- I need everybody's help please with weird engine noise
- Install mods now, or after tune?
- Best E-85 Fuel pump Hta Green
- Buschur Exhaust question
- Rear Diff Won't Line Up
- Curiosity
- torque spec
- cant get car to start
- No boost before 6k
- wavetrac lsd info
- Weird Idle & Stall
- What's the go-to 156mm Alum Rod these days?
- Best cams for built 2.0 6466
- P0300 and P0011 after cam install. Is this safe to run
- What are the best stage 3 cams
- Checking for engine swap Evo 4
- Evo 8-9 turbocharger wheel dimensions *reference only*
- Evo iv hardpipe intake
- Evo 9 turbo
- Spark Plug/Coil Pack Help
- Precision turbo exhaust discharge vband flange
- Doing high mod on my 8 Help,
- Coolant temp guage issue
- Gauging intrest: Gates racing timing belt for 4g64
- arp 1x1 method
- ACD Pump Current (& Fuse Question)
- oil spark plug
- worth upgrading from GSR turbo to MR turbo ?
- Oil Return Line Question
- Looking for help identifying 6spd problem.
- Spark Tech CDI vs Non CDI
- Setup thoughts !
- half size A/C condenser
- Ported Exhaust Manifold Matching
- 600whp Goals
- Aftermarket Turbo capability
- Rebuild Time, Harvesting ideas want to make 350 ish on 91
- Transmission input tube broken off??
- Fuel pump / Fuel tank studs snapped off
- Thrown rod
- Removing Stock O2 Housing
- Help!! Car wont idle and hard to start
- Exedy Twin VS ACT
- How to safely make 400-450 whp.
- Exedy Twin Disc Adjustment
- Ayc/acd pump won't build pressure.
- acd transfer case compatibility
- Cv axle
- Evo 4 won't start nor will fuel pump prime
- 2.3 Manley Forged best turbo?
- evo 9 radiator leak?
- Evo 8 exedy clutch polishing
- trade bb black for bb green
- Evo 7 GTA injector size?
- Clutch issues!
- In process building a 700hp 4g63
- Crank pulley bolts
- Valves locks???
- When to upgrade your valves???
- So my belt tensioner broke kind of...
- Help!!! Multiple issues
- PT6466 oil feed line help!
- Ported intake/exhaust mani worth it
- Best Rotating Assembly For FP Black/PT6262
- T-case
- time to build up my evo 8
- Trans oil question..
- What's next?
- Output shaft
- E85 smell under valve cover
- Ignition issue
- Issues after upgrades
- Help...
- Interesting concept, less H/P = more power/speed
- Currently have an MHI BB FP Black; thinking about moving to a JB SS Black
- Coolant exploded evo 9
- Xona turbo downpipe options
- Boost spike? Boost leak? Faulty wastegate?
- Quietest fuel pump
- A shortblock is a shortblock?
- Possible rod knock or something else?
- Cannot lower idle RPMs with BISS in SAS mode
- Recirc on Speed Density Setup?
- New Clutch - South Bend Stage 2 Daily
- Engine reinstall question
- Current intake = Perrin / suggestion intake =?
- T4 Twin Scroll gtx35xx?
- is this 4g63t from evo 1-3?
- ACD T-case in a non-acd evo
- Pick me a manifold winner!!
- ACT Clutch pressure plate
- Rear cv axle, evo 8
- Oil leak around upper timing cover
- Evo 4 awd setup
- Gtx3076r, gtx3576r, gtx3582r
- Kelford 280's
- Side Skirt Exhaust Exit?
- Info on evo 5 transmission
- Oil for my tcase and diff
- FP cast o2 housing downpipe options
- Fp zero
- Where to get Evo 8/9 bareblock
- Burning Oil after GSC S2 install
- 2.1 liter Destroker with Stock Frame turbo?
- Questions on condition of pressure plates
- Evo 6 block swap on Evo 8
- Turbo
- Centerforce Dual Friction Clutch - 450ftlbs with stock pedal feel! Stellar review.
- Wtd: evo 8 power steering pump
- Timing Belt snapped
- Normal tranny gear wear?
- Clutch engagement issues - Exedy Triple Disk
- TIAL QRJ question
- garrett reverse rotation turbo
