PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Another "what turbo should I get" discussion
  2. mixing c85 and c16 50/50
  3. Question about double pumper set up
  4. Oil catch can set up!
  5. o-ring head and block?
  6. Machine shops near sun valley California
  7. Tore my motor down completely, off to the machine shop :)
  8. Triple Disc Clutch Owners.. Got a question on engagement.
  9. CB 70mm Manifold/S90 Help
  10. Quiet exhaust system
  11. We went back to the drawing board and have a new more compact protoype design
  12. Evo 8 jumping/clunking at full steering low speed
  13. Boost leak, bent valves, bad injectors? Please help.
  14. fp black full boost?
  15. What is wrong - EVO 9, engine sounds like lawn mower, top plastic cover cracked
  16. Twin Scroll vs Single Scroll Turbo Test
  17. Help!
  18. How rebuild your blown FP Black yourself.
  19. ceramic ball bearing garrett gtx
  20. EVO IV Gearbox identification HELP
  21. Any reviews/experiences with the Haltech Platinum Plug-In ECU?
  22. Slight damage to turbine blades .. problem? PICS!
  23. 2 blown ecus, any test or advice?
  24. Nisei intercooler vs. newer options.
  25. Oil pump failure? =/ 9000 miles on 2.4LR build
  26. 02 hood dump
  27. Question on fp5r cams and clearance, and wiseco with 2mm valve clearance
  28. SCE copper head gasket on a 2.4 questions.
  29. 0.20" over headgasket question
  30. Evo IX low compression across all 4 cylinders
  31. Turbo(FP 71hta) or Cams(GSC S2)
  32. Evo VII Transfer Box/Case Question
  33. Evo 7 engine wire
  34. Best turbo?
  35. Evo 9 turbo to FP HTA73 Green BB
  36. WTB: Evo 8 Six Speed shifter
  37. throwout bearing
  38. Clutch to suit 1000hp
  39. DIY COP Setup Parts List
  40. Do I Need To Upgrade My Engine Valves???
  41. broke two LSD in two weeks. HELP!
  42. Building my bottom end. 2.3 liter options. Opinions needed
  43. How big injectors?
  44. 2.4lr Boost creep issue need advice
  45. Blouch 3.0 XTR
  46. Built Setup Details ADVISE NEEDED
  47. I finally found a replacement turbo!!
  48. Power limit on pte880 injectors
  49. Question about exedy twin installation.
  50. New FP Green! FP54 57lbs/min
  51. Evo Balance Shaft Thread
  52. Your vision of ultimate street setup
  53. O2 housing
  54. 6 speed and 5 speed transmission question
  55. RPM oscillations, slipping clutch or ???
  56. 400HP Evo 9. Stock turbo?
  57. ID 1000CC high-Z injectors
  58. possible transfer case whine
  59. advise on intake system
  60. boost
  61. EVO 9 RPM jumping
  62. Ac compressor keeps seizing and breaking under high rpms
  63. Valvetrain Question
  64. Turbo help, options, best for?
  65. Evo stoker motor identification?!?
  66. Converting ACD T-case to Non-ACD
  67. MR Transmission Acting Up Sometimes...
  68. Redline MT-90 Gearbox Oil HELP
  69. ID Pigtail wiring
  70. Considering speed density conversion
  71. Final Drive Questions - Performance Benefits/Detriments
  72. ANOTHER oil weight question. Pls help
  73. Stalling/misfire issue code and p0172
  74. FP turbos
  75. Help with my cam gear timing
  76. Honest opinions on FIC 1450's please!!!
  77. Magnaflow 5x8 oval on JDM rear bumper
  78. Evo 4 mustache bar eliminator kit?
  79. Mishimoto Radiator Kit
  80. Timing Belt install issue...EVO IX
  81. Block surface prep for machined head
  82. Stock replacement
  83. Chattering Noise
  84. evo 6 urgent help needed
  85. Thoughts on how to drive vacuum/dry sump pumps
  86. Auto Meter Wideband O2 bung install location verification
  87. Tc oil leak
  88. Evo 5 speed torque solutions motor mount
  89. Advice for air intake needed - CARB legal
  90. Wrap Exhaust to Protect Drivetrain?
  91. Exedy Twin to Triple Conversion Q's
  92. Evo IX ACD Pump Questions
  93. FP ss vs mhi black
  94. WORKS Stage 2 clutch kit.
  95. evo cylinder number 2 problem, need help plz!
  96. Muse Intercooler Piping question
  97. Need help with throttle body
  98. Help...Radiator fan turns on when car is started and cold
  99. Replace front case with motor in car?
  100. Evo 8/9 header interchangability
  101. 2.1 build about to begin!
  102. ETS or AMS T3 manifold???? Which is better?????
  103. Battery/intercooler plumbing/factory airbox fitment
  104. 2.2 Built Advise Needed
  105. Stock frame turbo options
  106. Evo 6 Kelford 272 Upgrade
  107. Cannot seat real axles
  108. HKS GTII7460R flapper failure - how to repair?
  109. STM throttle body shaft seal question
  110. Diaqueen (now MZ320345) SAE90 LSD Oil Discussion
  111. looking for a short shifter for my 6 speed
  112. Idle dip
  113. Evo 9 Motor Mounts
  114. fp red bb
  115. Max horsepower for my evo?
  116. Twin disk ceramic CC clutch. Should my car sound this way?
  117. Low voltage in crank position sensor circuit
  118. What manifold to run?
  119. Front lsd in 03 evo, best route?
  120. Tapered Roller bearings For Trans rebuild
  121. evo 8 throttle body coolant hose help!
  122. Oliver Rods
  123. evo 6 not building boost
  124. Evo iv clutch
  125. XONA Rotors Turbo Questions
  126. Fresh build, clutch won't disenguage
  127. Blitz SBC boost controller with 3 or 4-port solenoid
  128. Pcv wont stay in place?
  129. Rpm limit and the weak parts
  130. Trouble with starter; video + alternatives
  131. Evo 8 pill dimensions or extras?
  132. Spoolingup Cop
  133. rear diff issues after changing plates!!
  134. FP red BB or JB?
  135. Getting ready to install New FP green HTA 73
  136. TME turbo with 20g wheel (surge?)
  137. Anyone run an ETS 1.625 or 1.9 stock placement exhaust manifold?
  138. need turbo advise
  139. Turbo Advice Needed
  140. release bearing or master/slave cylinder
  141. iso turbo kit
  142. CC twin to triple conversion?
  143. 73htz green lowest boost
  144. Max amount that can be taken off exedy twin flywheel
  145. Clutch??? Brand? Sprung? Puck? HELP!
  146. Torque Solutions shifter cable bushings 5sp wrong size for Evo VII
  147. gt35r turbine housing option
  148. Choosing the correct piston for 2.4L 4g64 block
  149. t3 evo 9 manifold
  150. Odd ACD issue
  151. Competition Clutch twin disk
  152. Tomei Expreme Turbine Outlet V2
  153. slow spool, poor power delivery
  154. T3 Super 94 or T4 Twin Scroll PTE 6870
  155. EVO 7 Engine ticking
  156. EVO8 MR-All AWC lights on constantly
  157. AMS t3 manifold with 44mm vband for Evo 8 review!!!!
  158. Best 280 cams that aren't gsc
  159. Clutch won't dis-engage - Troubleshooting ideas needed
  160. Mivec Head
  161. Need help AYC not working.
  162. 2006 evo
  163. Cars not running right
  164. Weird spooling sound
  165. Top mount turbo vs. forward facing!
  166. Which FP green is this
  167. Any Super94 "HTZ" results?
  168. Evo 9 Mr -Center Diff Oil Change
  169. I am looking to buy an Evo 8 Engine
  170. GSC S2 Rev Range Past 10k rpm?
  171. Best place to get transfer box rebuilt
  172. cx racing crossmember
  173. new airtrek owner
  174. Twin rebuild help
  175. Best valve springs for 4g64/4g63 combo
  176. If I put an 06 trans in my 03....
  177. Strange grinding noise at light throttle
  178. Evo8 won't idle when cold
  179. 450whp - 550whp Setup
  180. What is this noise? (Vid)
  181. TRE1235 vs ETS 3.5
  182. Evo 9 mr blow off valve install?
  183. Low Compression Evo 8 Next Steps
  184. Evo idle problem and feels sluggish
  185. Zero fuel pressure at start
  186. Aftermarket oil drain plug washers?
  187. ACT or COMP CLUTCH?
  188. kelford cams 272 272 evo 9 which aprings and retainees to use?
  189. Lower intercooler hose
  190. Why is my set up dead on torque good power with a kinugawa turbo but no torque
  191. Any feedback or reviews of the carbon synchros from Synchrotec
  192. Exedy triple problem need insite
  193. Rear Diff oil???
  194. Which injectors?
  195. Week of Hell
  196. Turbo Rebuild Questions
  197. New to the Scene picked up a non running Evo 8
  198. evo 9 timing belt
  199. Engine lag
  200. rear diff question
  201. Exedy Twin vs. Comp Twin (for my application)
  202. Suggestions on a great quick response turbo
  203. new from Holland
  204. FP Cast o2 housing
  205. New clutch/transmission, stuck pedal! Help :(
  206. Fpblack ss housing results?
  207. Evo 6 boost help needed
  208. Tomei fuel rail
  209. Help me identify this downpipe.
  210. CALLING all Sharkfab manifold owners
  211. CARBONETIC TRIPLE PLATE CARBON CLUTCH problem
  212. what clutch is every one running for big power
  213. Evo 9 Coolant Temperature Gauge Reads Slightly Higher than Normal Continually (Pic)
  214. RPM dips at idle
  215. Kelford 272 scuffed HELP
  216. LSD Advise for Evo 6
  217. Exedy Stage 1 - real torque?
  218. Help!!! Installed intercooler and now car won't start
  219. Opinion on fp turbo comparison (apples to oranges)
  220. Evo 8 idle problem after fp red insatll and tial mvs wastegate
  221. GSC S2 cam with oem retainers?
  222. Stock turbo sounds like a drill, what to upgrade?
  223. 2.3 Stroker help need opinions!
  224. muse o2 dump...
  225. Buschur Rear Differential Mounts Review
  226. Acc belt snapped
  227. Need advice on camshaft cylinder
  228. Mhi housing
  229. What do you think of my ring gap results
  230. Muse LICP from VR Speee Factory
  231. gains from going kel to 280 to R2 on A 2.4LR
  232. Driveshafts
  233. Kiggly vs gsc valve springs
  234. rate my compression and leak down test
  235. Clutch fork and TOB questions
  236. Replace 6-speed with lift
  237. The journals on my crankshaft are .5mm undersized
  238. Greedy profec a
  239. FP XR BB turbos Oil Feed restrictor?
  240. Acd?
  241. fuel pump dying?
  242. 100MM crank that has been shaved off is this safe?
  243. Turbo Oil Feed Line Banjo Bold.
  244. 6266 build
  245. Pls Advise - 2.2L Setup
  246. C/R estimate
  247. 6 to 5 speed conversion question
  248. WTB: bellhousing for 5 spd Evo8/9
  249. How to identify HKS valve spring?
  250. External wastegate vs exhaust gas pressure , experienced input please!
