- Strange noise when cruising partial throttle
- Switching to E85.. Searched
- PN#s for pulleys on serpentine belt change
- 6466 Replace GT35R
- Tial mvr guys. Question inside.
- Engine mount studs
- Injector Dynamics ID 1000
- Any ideas? P0300 + running on 3 cylinders (sometimes)
- Need help with piston rings
- how rich is the stock tune on a evo 8?
- Turbo setup question w/ 02 dump
- Evo won't shift
- Any big gains with a 3.5" exhaust in 750+ HP?
- Those with ACT clutches and their best 1/4 mile times/mph
- Engine Rebuild advice needed !
- Whinebro
- Blown turbo?
- How to crank engine
- Need help!! Car does not start
- Greddy Profec-b and car battery
- I need some help with timing belt install - Evo 9
- Rebuilding FP Jb turbos??
- american evo x gsr to fq400?
- White smoke between valve cover and head at high rpms?
- Lifters
- HTA73 Lag, On a stock 2ltr?
- Stuck
- Evo iv shudder
- Turbo options and cost
- Need help choosing the right size fuel injector? Ask in here
- Evo 7 Overboosting
- What electronic boost controller do you use?
- Late boast / Turbo Lag
- Thinking about changing Turbo
- Injectos or Fuel Pump or Both for 350whp
- GSR Rear Diff into MR
- pulling motor!
- best aftermarket exhaust mani that fits stock turbo?
- Arp 2000 hardware limit
- Stuck to only first and second gear.
- Removing A/C
- Car won't start after installing gauges
- evo 9 turbo
- evo 7 transfer case problems!!!
- Slave, clutch master, or other?
- stock fuel pump
- 600 whp clutches.
- What mods next?
- 14 psi stock VIII?
- Grindy 2nd and 3rd
- Lifter tap or Rod knock??? (Video inside)
- help with clutch looking for info
- 05 Evo 8 stalling
- need help passenger axle is stuck
- Need to replace Front passenger CV axle
- Mini Battery
- popping out of 5 gear
- Is my power normal??
- Clutch recommendation
- OEM fuel hanger ID return line?
- Help! ticking/clunking noise
- QUICK ? Standard ETS tank will fit 9 bumper?!
- Injector Size Question
- 2nd gear 2k rpm cold hesitation
- 08 mr rough idle
- Evo VIII wouldn't stay running but then has gradually improved over time. [RESOLVED]
- burning oil?
- synapse DV barb fitting
- high idle after warm up
- Rebuilding; sensor replacement questions
- I did a poor battery relocation install, help!
- Need help with a decision
- Evo 8 with MAP EF2.5
- Boost problem. Bad wastegate or MBC
- anyone seen these???
- Evo 6 engine in Evo 8?
- Fitment Question
- Cams?
- How to make 450hp
- keeping balance shaft for motor build?
- DV Ricer Remedy?
- DIY: Clutch pedal Stop
- vibratoin after coilover install
- External Waste Gate Missing Hose?
- Fuel pressure too low?
- HTA 3586R or PTE 6766SPR for my setup?
- Best clutch for a 500hp street car??
- PLease Help!!
- how to properly destroy your motor
- Help me spend money (or not)
- Which clutch is right for me?
- what misimoto intercooler works with evo 9
- Aftermarket balance shafts!!
- Need advise about turbo
- Rpms drop when hitting boost!?
- Will a car gain pumpgas whp with a WG external dump?
- To clutch or Not to clutch
- possible signs of a blown headgasket?
- valve seal question
- Can I drive my car with 272 cams and no tune?
- Neo ti Intercooler piping and intake
- Mis-matching motor mounts causes horrible vibration???
- Wastegate Solenoid A Issue! HELP
- HTA 3586 Stock Block
- First pass at the track and clutch pedal goes to the firewall?
- Ignition : wasted spark vs sequential
- BOV Flutter?
- What spark plug to use with Fp Green EVO 8
- driveshaft noise rear...???
- My build Thread Need Advises!
- Boost Problem
- Evo 8 Head on 4G64..Any porting needed?
- How To: Evo 9 cam install, MIVEC
- How To: Rear Differential & Mustache Bar bushings Whiteline
- Wideband AFR idle and cruising rich 13.9-14.1
- AMS Balance Shaft ISSUES!!
- Gone through 3 evo motors, need suggestions
- 2 disc clutch for evo 8 wich one?
- TOB won'r grab pressure plate
- Got 70mm Full Blown TB. Will I gain any power if I install 70mm/2.75in IC Pipes?
- Will a Lancer Aircon Condenser fit a CT9A?
- quartermaster 8 leg street....frustration
- Evo 6 transfer box ratio vs Evo 6 transfer box ratio 8
- king bearings?
- whiny clutch issue - WITH VIDEO!
- wastegate stuck open????
- Which Mobil 1
- evo 9 turbo untuned?
- what main and rods bearings should i use for my 2.3 build??
- Difference between off the shelf and "drop in" pistons
- Bad Clutch kit and Clutch Padel Stuck (Need Help !!! )
- Knocking sound, help identify...
- Just installed the treadstone 340lph
- Polishing turbo compressor cover
- Wiseco 1400 hd pistons vs the e85 1400hd pistons. What's the difference
- Manley 2.2
- Cylinder 4 is 40 psi less than other. How long will my engine last
- 4G64 LR 2.4L setup
- What throttle body are you running?
- Need some advice where to go for intercooler and piping kit?
- Transmission fluid in Tcase?
- Intake questions
- Kelford cams
- Help dropping SUB-FRAME
- Aluminum Rods= Is it ok to drive it 450 miles non-stop?
- P0300 code poped up!?
- Have your pistons seen better days?
- My Catch Can Setup
- Coolant tube
- Another Turbo Thread EF3 or BBK-B Ported
- evo 8 engine alternative
- I give up...what does "CHIBA" on my header...
- Getting an FP Green needing fuel suggestions
- how would i know if i have a catted down pipe????
- fuel pressure help!
- crankshaft sensor problems
- please help evo 8 wont start
- Engine seize?
- High Idle after TB Cleaning
- Drive Train Slack question
- Need help dropping transmission
- evo starting issue
- Clutch sensor or starter solenoid?
- Advice please, which turbo 500hp from 2.0L
- Serious oil burning problem, really need some insight
- Installing ARP conrod bolts
- Question for someone running a FP HTA 71 on EVO 8
- Delta Cam Repair?
- garrett gtx3576r or EFR 7670 What turbo should i buy
- Engine Oil Dipstick Position in 4G64
- Six speed help! Car won't go into sixth.
- Aftermakert airbox or not
- Engine cutoff - white smoke out of intake/conefilter
- anybody do any testing with the new 3786?
- P0300 & P0303 Misfire Mystery
- Sound Diagnosis
- What is the difference between the OEM Evo 8 and Evo 9 thermostat?
- Help me with turbo issues
- Battery and E-brake light On.
- what cams! need help
- ARP Headstuds Torque?
- 4G64 build?
- Evo 9 MR issues
- fast bad misfire only in boost between 5-6k rpm
- Really Fed-up with My Super Rich AFR whenever Immediate Full Throttle!
- Pulsing vibration through car at 50mph
- Manley valvetrain users/installers; please help
- 2.3L Built using Toyota 86mm 1jz Pistons?
- Gm 3 port boost solenoid problem..
- sputter/misfire at wot
- evo 9 stock clutch slipping?
- 2006 Lancer Turbo/Misfire/Bogging/Sputter
- JDM Evo 9 RS Transmission Parts
- DW200 fuel pump - free moving pin inside?
- WTF, kelford 9-tx272 problem
- double pumper bad for road race events?
- Radiator Question
- Having a problem, hoping other's have had this...
- Tomei 260 vs HKS 272 vs GSC S1 on stock
- Walbro 400lph
- Higher compression in 1 cylinder?
- I need ur opinion with FIC 2150
- Engine Rebuild
- evo 9 engine removal guide HELP?
- 2.3 build questions on parts...
- Turbo help
- 38mm Wastegate for 1.6bar of boost?
- precision turbo question
- evo 8 longblocks question
- comperssion test what you think
- evo Ix coils? built in transistor
- tial wastegate actuator tops
- Trying to figure out an oil pressure issue
- do evo 8 and evo 7 share the same flywheel
- Zeitronix 5Bar
- Evo 8 MR Transmission Fluid
- I need help + advice, 30 miles after dealership work = internal engine damage...
- How an aluminum head is pressure tested for cracks.
- motor/tranny mounts?
- evo 8 block with 9 head
- jdm 5th gears 0.825 ratio part number??
- Need help my car jerks back and forth.
- ported manny
- Please for help
- Pressing in new balance shaft bearings
- New Odyssey PC680 question
- How to CC a cylinder head
- manual vs electronic boost controller
- input needed
- evo 5 wheel bearing
- what is the best turbo upgrade for a EVO5
- Shep 5 speed swap problems
- Engine/trans locked up
- who has a exedy triple carbon ?
- Clutch Inspection - HELP
- I need Data I have a Blitz EVO 4-5-6 Oil cooler, better than stock EVO 8?
- Hx35 users?
- buschur double pumper hobbs switch???
- need help, hissing should or belt sound-video
- Boost solenoid
- 3071, what housing should I use
- Transfer case help
- Do I need bigger injectors or not?
- os giken clutch pump replace part
- Someone needs to do a turbo compairison!
- Holset hx35
- Evo 8 antlag and exhaust cut out
- aem cam gear slipped! help
- How valve guides are changed in a 4G63 Cylinder Head
- EXCELLENT Paper Discussing 4G63 Variations (2.1, 2.0, 2.3) Advantages/Disadvantages
