View Full Version : Evo Engine / Turbo / Drivetrain
- MATCHING gauges?
- Another BOV questions
- DV/BOV techinal discussion
- Answer from Forge Motorsports
- Hi flow mettalic cat
- EVO Apex N1 Question
- Which Boost controller is ideal?
- Free CAI for Evo
- Hot outside temp and bogging
- Need EVO-III ECU help (programming)
- Vishnu's Exhaust thoughts
- Hks Gd Clutch Max For The Lancer Evo
- A plethra of Vishnu questions...
- Upper I/C pipe and Mas pipe from Buschur
- Good BOV Sound w/o Going HKS/Greedy
- HKS SSBOV pics
- What about just doing the test pipe
- Ralliart Gauge On VIII
- Clutch Replacement
- Clutch Clamping Force???
- HELP: Anti Lock Light is on
- electronic VS. mechanical gauges
- 23 PSI without any boost contoller!?
- Will Evo VII bumpers fit Evo VIII ?
- aftermarket cams
- Anyone got pictures of these factory accesories?
- Reflash ECU's vs AFC etc...
- Pruven Performance Axel back Exhaust
- Changing the Evo 8 sterep
- Little problem at Altitude in Denver
- Do these cars use chips or what?
- Which is better VTA or recirc?
- How to turn up boost on stock turbo?
- evo air intake poll
- A pillar gauge pods?
- What is the difference between and auto and manual boost controller?
- Good aftermarket wastegates?
- Blow off valves, any recomendations?
- HKS EVC, any good?
- Car Alarm Malfunction
- Mitsubishi TD05H-16G turbo
- Lancer Evolution Exhaust Cutout????
- manifold spacer removal=300hp???
- HELP! IC pipe disconnected
- Hks F-con V Pro
- Downpipe Recommendations
- EGT probe placement
- Ultimate Racing - 12.1 @ 110mph
- HKS 264 cams - before and after dyno sheets and impression
- Grind in 3rd?
- noise when backing up!!!!!
- Vishnu Tuning Turbo back 3" EVO 8 Exhaust
- Favorite downpipe
- I was told not to use the S-AFC...
- RMR or WORKS reflash?? Anyone install yet?
- Autometer Boost Gauge
- A'PEXi Super SFC II
- Is it bad to change your oil real often?
- GTECH PRO Competition - Anyone Tried it???
- HKs Exhaust for EVO VIII Release Date???
- defi gauges?
- sick evo
- have u guys seen this?
- NEBODY got STOCK EVOVIII RIMS
- Problems after installation
- Greddy Emanage Q
- can someone help me out with downpipeQ
- HKS Hi-Power
- Weird.. Not getting full boost?
- Power gains with downpipe?
- turbo timer hks type -1 metric
- Ticking sound from intake manifold area
- Looking for exhaust installs...
- Anbody have the Vishnu Stage 0 w/ Downpipe?
- JDM Tomei 2.2L stroker?
- Where to get a MBC?
- Evo Body Color names from ESM are different!
- Trunk clanking sound
- Defi "Heads Up Display" gauges
- My set up - newest shots
- Air conditioning motor powered by?
- When adding a free flowing exhaust do you lose boost???
- Clutch burnt out
- Help,I can't set boost lower than 1.5kg/cm with AVC-R
- Fitted HKS SSQ on my TME!
- Check out the anti-lag setup
- Ultimate Racing HKS Super Sequential Blow-Off Valve Kit
- Downpipe question
- grounding wires
- Gauge Pod?
- Motul gear oil
- Need Help with MY evc 5
- Best place to get HKS TT
- pruven intercooler upgrade
- CEL and ECU
- oil in evo please give feeback
- 12V Power under the hood?
- electronic DOwnpipe
- Results of BG Synchroshift
- Installed HID look Fog lamp bulbs, keep blowing fuses?
- Anybody running the rmr reflashed ecu
- setting the HKS EVC V
- Yet ANOTHER Boost controller question, MBC in partuicular
- What is this mystery box?
- Does you clutch seem SOFT?
- Silent exaust?
- Loud shriek, loss of power under boost
- Attn Evo Owners!!!!! And Shops!!!!!!!!!!!!!!!
- Baseline of 202 WHP on Dyno Dynamics
- Turbo Spoolin.......
- Does your EVO eat oil?
- Camber and Toe Settings
- HKS exhaust
- EVO 8 Burning Oil?
- need used AYC parts. any connections?
- downpipes and warranty
- CAM idle issues
- K&N Cone Filter?
- questions on reading boost
- More dyno results: BR Exhaust, intake, S-AFC
- turbo questions *help*
- Aftermarket Cruise Control
- Propshaft problem??
- some advise please
- Exhaust regulations
- Air silenecer/airbox?
- Fuel System mods to support 400+ WHP on EVO
- EGT readings - What should they be?
- 4WD Dyno?
- how bout that clutch
- evo recaro seat problem
- Datalogged Stock EVO With&without Spray
- downpipe material. what to use
- Turbo Cool down Question
- EGT Temperatures?
- Boost Controller questions...
- HKS Suction Kit Problems? (Alum Inlet Pipe with Yellow filter)
- Blew a fuse, help!
- Help! blew a fuse
- Dyno Results
- Exhaust question for Evo owners
- Valvetrain upgrade necessary with HKS 264/264/272/272 cams?
- HKS Turbo upgrade for EVO-> 3037S model?
- Blurred EVO Dreams
- "staged" upgrades? or piece by piece?
- Mitsubishi Evo VIII Problems
- Engine mod Help
- Factory shop manual availability
- How to tune Blitz SBC I-D II ???
- Factory BOV Blew Apart
- Air Extraction Louvers
- Intercooler and Oil Cooler Fans
- Oil Filter
- Mods question for you pros
- Oil Catch Can
- Universale High flow cat.
- Dyno results: Stock vs. Buschur Racing intake/exhaust
- Stock wire mesh
- EVO.....stock turbo question
- Best choice of Air/Fuel control
- 12.00 in the AMS EVO8
- Engine Configuration
- Ultimate Racing Stage 1 Plus Kit Vs. Buscher Racing
- Break-in *confused*
- Boost
- HKS intake kit
- Carbon Fiber Strut Bar????
- IC fill bottle and Clutch question
- who is on the works ecu preorder list?
- sequential shifter
- Ralliart/Hayward & Scott exhaust
- No oil filter washer from the factory?
- Fuel trims and WOT
- Motech ECU upgrade
- S-AFC and Boost Controller
- BOV and intake pics
- Brand new S-AFC for $250...
- Vishnu Stage One
- under boost
- Blitz SBC-DC boost controller install??
- Install a Passport 8500 yet?
- EBC with the Xede or not....????
- HKS Cam Tests
- evo ECU or AFC?
- turbo cool down
- anyone used nitrous N-tercooler spray?
- XEDE results....... how about some news? or other stuff too.
- Adjustable wing?
- Clutch noise/vibration in Evo
- speed
- Does anyone know the indside Diameter of evo 8 wheels
- the chip and hp
- boost gauge install... ahhh!!!
- Engine break-in period
- Suspention pops.
- How do you take off the EVO front clip?
- Will an air intake viod the warrenty?
- Air Temps - where reading from????
- Turbo Lag Reduction
- does your evo sound like this
- Newbie
- So whats the deal with the EVO Tranny's
- Apexi SAFC
- royal purple oil in evo!!!
- ecu?????
- Turbo upgrade
- check engine light wont go off
- Anyone installed new cams on an EVO?
- Shifting from 2nd to 3rd
- Ralliart chip....?
- JDM Evo front differential
- NOS Kit for EVo
- Messed up Air filter
- Pillar Gauge Pod...
- weird noise/plunky feeling
- ECU Wiring Harness "Extension" Update
- twin exhaust?!?!?
- anyone installed rmr clutch yet?
- When will Used EVO's be available?
- Just bought cd player. Help
- S-AFC Help
- Installed First Mod - Filter Kit
- dumb Valentine One install questions
- Idling problems due to intake?
- POP goes the air hose
- tranny is making bad noises
- 4G63 Turbo evo Stroker 2.33 problems
- Under drive pulleys
- Question about the turbocharger on the EVO
- Anyone know the VSS frequency?
- EVO VIII Upgrade Questions for Veteran Mitsubishi Owners
- Air/Fuel Piggyback Unit OR ECU Reflash
- how's everyone maintaining their evos?
- 94 octane over 92 octane??
- EVO: Why so much power at part throttle?
- internal head and intake manifold sizes
- Borla Exhaust needs your help
- 1st gear grinding.....normal???
- Need infor on Monster Sport?
- Rusty header
- Oil/fuel press. gauge install
- Debadged
- Turbo Timer
- How to adjust clutch?
- Can the evo withstand 19psi to redline, what are you boosting?
- OEM Tranny and Transfer Case Fluid?? Help me out
- do you guys have the same problem
- Apex'i Turbo Timer/Computer Pin-out
- greddy e manage or 3 buschur turbo back exhaust
- Does anyone know of a good spot to mount a knock sensor??
