- Fp green down! Need rebuild how?
- EVO 9 motor sounds out of nowhere
- How do my sparkplugs look
- 2009 Lancer GTS BOOST
- Ignition Boot Problem. Please Help.
- help identify UICP
- Half-Radiator = Car Runs Cooler:)
- Swapping to the stock IX dv, would I
- Quatermaster 8leg vs exedy triple
- Injector Dynamics Atomization and Spray Pattern Videos
- synthetic trans fluid?
- quaition on new 6466 vs 6766 .
- Oliver/R&R Connecting Rods
- Transfer Case Seal part #s
- 4 bolt 02 housing
- full blown double pumper question
- EVO 7 Strange hesitation when cold after radiator change...
- Timing belt loose
- Ford atf/power steering fluid
- ? about stock evo9 boost limit
- Who killed a block with a HTA Green????
- Evo 7 - 9 lightweight cross member
- Help, engine shut down
- Transmission advice needed
- help, radiator/headgasket issue
- gtx3076 or gt3582
- Test pipe?
- Any reason *not* to get this Oil Catch Can? (42 Draft Designs)
- Anyone tried the Shell URT Advanced Race Fuel?
- Rebuild check list
- Eastwood's ZDDP Oil Additive
- Turbo Dead.....
- Radiator Removal Question/Help
- HKS GTII issue
- exedy or carbonetics carbon triple?
- ARP EVO flywheel bolts
- Exedy Twin Disc Disengagement issues PLEASE HELP!!!!
- Stock DV and aftermarket BOV
- Misfire only at WOT
- ETS Evo 8 Forward Facing turbo kit
- Final Drive Gear 4.00 vs 4.11
- Can anybody please tell me what this is????
- oil smoke comming out exhaust on cold start up?
- cam, spring and retainer install!!??
- Spooling Up spark plug gap?
- Evo IX not running on all 4!!!
- Transmission Bracket Seal?
- Engine Brake In question
- Which cam is better for my setup?
- Boost creeps to 25-27 psi
- blow off valve
- Check Engine Code P0421 on a catless Evo
- Drivetrain guru's looking for a educated guess
- Rear diff upgrade...
- INSTALLED: Greddy TBE
- Once and For All: How to time an Evo with a 4g64 Swap
- car went dead
- Is a slight drivetrain whine normal?
- How to adjust TPS?
- can the act HDSS clutch kit really handle the power of a cammed 2.4 and FP RED???
- can anyone recommend a machine shop to resurface oem flywheel?
- Will these injectors work?
- Walbro 400 install and pump pressure/flow testing
- Journal bearing vs ball bearing
- Safe torque range when tuning?
- ACD Clutch Pack ONLY from Mitsu?
- HTA86 or 6466 on a built 2.3?
- does a eclipse gst exhaust manifold fit
- Shim part numbers for Evo 8 tranny
- HELP flywheel wont seat right....pics inside
- I need help! (transmission-transfer case)
- oem tob or aftermarket?
- Radiator Leak
- Brian cromer single stage valve springs and retainers with Gsc s2 cams help
- TESTED: Stock FPR capabilities
- Buschur evo 9 stage 3 head with gsc s3's
- 6k clutch dump- am i screwed?
- Help! I need a new 5 speed tranny or swap
- 450whp Goal...
- How can i connect AEM W/B onto a laptop?
- Testing engine bay temps - exposed pod filters.
- installing manley piston rings
- Will a 16G Evo-III fit a Evo VIII?
- OEM valve locks good for my setup?
- NEW PTE 6466 turbo pics.
- Fluidyne Radiator Evo 8, with Samco hoses?
- Want to reach 500whp(suggestions)
- Gas Gauge accuaracy?
- How to Set Base Ignition Timing - I searched
- Exedy Twin
- Dtock intake manifold limit
- HELP! Transfer case install
- Pros and cons of having mivec on a high HP 4g64 with evo 9 mivec head?
- A push style pressure plate conversion
- DIY CUSTOM Battery Relocation!
- Spring/Retainer and Valve Suggestions
- car running lean...help plz?
- Competition Stage 4-6 puck clutch
- INSTALLED: EBAY Civic Half Size Radiator!
- Weapon r intake manifold
- Problem installing CV axle
- 450-500whp Evo Viii: Need Opinion for best clutch for Daily Driven (need opinions)
- Valve spring tool??
- pt 5858 vs 6262
- Aiming For 9's
- evo 9 quaife
- 6262 Or Engine Rebuild?
- What happened to this IAC valve?
- What are good cams for evo 8
- BOV issue?
- installing arp main studs
- Manley pistons vs Wiseco Pistons
- Need help, lost power with mods...
- Clutch install... supporting parts question
- variable vane mitsubishi turbo? TD05 based
- Evo 9 Coolant Fluid Leak
- 1997 EVO 4 water pump help!! 4g63t
- hks ssqv compression surge
- Car idles fine for a couple of minutes, then it begins to run lean :(
- Will GT3076R + S2 Cams Laggy for Uphill & Track Attack?
- Evo IX: cold start issue after going 1 step colder plugs
- piston pin offset
- question about ets 3.5" catback
- new clutch for my 2003
- Stock exhaust with aftermarket turbo setup??
- Injector 1 not working...
- Fluidampr Install
- Evo + blow off
- Case study : WGA loses preload
- The Ultimate Under Drive Pulley/Lightened Pulley Thread
- Gates vs oem water pump
- Crank vent idea
- dripping - gunna suck to fix
- How to get ahold of TRE?
- Fullblown dual pumper problem Please help
- competition twin disc questions
- OILPAN! on my evo 4!!
- exedy stage 1 organic clutch- anyone have it?
- t-case upgrade for increased torque
- Boost leak at TB
- trying to wire in gm BCS
- Spiking 24, dropping to 10-11 ...
- Metal on Metal Sound
- Transfer case removal question
- What is Stock Evo ignition
- Fp or t3
- boost or fuel cut? what else?
- LOUD Intermittent Tapping Sound
- Boost leak results
- Revolver cams
- Evo Twin Intank Fuel Pumps
- cbrd turbo?
- Clutch swap help
- Motor Mounts
- MIVEC Line Questions
- 4g64 block with mivec head cam gear questions?
- purpose of the oil pump with timing
- 4G63 Billet Block Video**
- Mini battery
- Exhaust gaskets that don't suck?
- Breaking in a new motor
- buschur race core IC
- need advice on turbo upgrade
- Leaking from transmission bottom
- Opinions on the PT BB 6262,5862,5858
- budget evo 4 5 6 radiator!
- Stock 9 turbo SD intake
- Walbro fitting kits
- boost is falling way off, please help!!!
- some people do maintain their cars!
- Need advice on turbo
- twin to triple or just stick with the twin for now? measurements inside!
- Labor cost?
- Boost falling off at 6k
- WGA and EBCS 3 port on Evo IX
- What Gear Oil? Mitsubishi doesnt seem to be any help!
- Evo VII Idle issues reloaded
- T-belt and top end work...
- dry sump stage 3 or 4
- porting stock exh. manifold
- Custom turbo manifold/ stock turbo
- slave cylinder or clutch???
- Mivec Cams
- Sprung or unsprung act 6 puck?
- What's going on at Forced Performance
- Need Help with drivetrain noise
- New Comp Clutch Twin Disc 430miles making weird sound.
- Has anyone had Issues with Shep Trans
- Will I need a tune?
- Do I need a IX turbo?
- "Where does this Bolt go?!" Thread
- WTB: hks dli for evo 8
- New cels! YAY!
- Do these rods look used?
- Need suggesion on clutch
- Cheapest/Best place to get an Exedy MM022HD
- EVO 1 to 9 Rear LSD questions
- low vacuum at idle, low boost issues.
- what is next? help...
- Bigger Turbo with stock block
- EVO 8 artisan 20G upgade. information please!?
- Pls Help Me to Choose...
- Noob Queation About Pre-Ignite
- Replacing one piston?
- Waste gate or bov going bad
- New Clutch Recommendations?
- UICP/Synapse DV/tune question(s)
- turbo set up??
- which FP is best for 25psi on 91
- MAF or SD? BOV ReCir or VTA?
- OEM tubular exhaust manifold install
- FP GREEN 73HTA or FP Green BB
- Cat/check engine light
- Car wont boost more than 21PSI?!?!?
- Help w/ Clutch Install in NJ
- evo ix drivetrain suggestions
- AMS Oil Pan with MAP O2 Eliminator
- Pennsylvania exhaust legality????
- Fuel Trims and P0171 headache
- Custom project: Max Boost from Evo 7 TD05HR 16G
- quick question evo trans
- Subtle low pitch whine/roar
- Throw out bearing
- Precision 6266BB vs BW EFR 8374 !! Dyno graphs inside!!
- New CEA Precision 6466!! Dyno graphs vs 6266 and 6766 INSIDE!!!
- Maxing out my DD Pumper????
- Boost issue
- Injector question
- Rebuild necessary?
- 2nd gear slightly grind
- should boost taper this much
- Injector Scaling Calculation Formula.
- Waste gate actuator help
- Who daily drives an Exedy stage 2 SD?
- Fp green problems
- DTC P0037: Heated 02 (rear) heater circuit low (with 02 simulator is on)!
- t4 twin scroll internal wastegasted GT35 turbine housing
- Turbo Replacement Schedule
- Max Boost and RPM on my setup?
- Fuel pressure with car off
- First 2012 EVO X MR - Mod input
- Drop in Air Filters: WORKS vs K&N vs HKS Super Hybrid. Any thoughts?
- i need help with my Evo 4 gearbox parts!
- Clutch engagement to high?!! HELP PLZ
- fp black... bb fp red.... bb fp green
- Lets talk boost and compression on my Evo 8
- Questions on fuel... a lot of them
- Magnus launch control device
- Mahle Piston Wall Clearance 86mm
- General cost for 60k service
